Chrysler 300: Problems & Solutions
My family elders laughed at me for having a chrysler product now I see why....
Mabye Chrysler screwed up and actually made a few good ones for thoses ppl that haven't had problems yet ? but for a lot of us the problems are very real. :mad:
Family saftey is important to me and I have totaly lost faith in this car .
1. Easy exit automatic seat retraction stopped working. Found out I can easily reset the memory.
2. Express down windows wouldn't express. Similar to (1)--very easy for me to reset memory.
3. One passenger window operated intermittently. Controller replaced.
4. Lost volume on radio one time. Worked fine next engine start and hasn't repeated in past year.
5. Yes, have wheel corrosion issue still being discussed.
Not too bad I would say. Always starts at the flick of the key. Has never stalled. Doesn't shake. Doesn't pull to the right. Transmission shifts like it was direct wired to my brain. Tire wear is perfectly even. Average gas mileage is 20 mpg. Great aircon in Tulsa's 100+ temps. Excellent handling at any speed. And WOW acceleration. Better than my last Buick that needed two engine changes within the first 24k miles. If someone gave me $50K to buy a new car. I'd say no thanks, I'll keep this one.... Go for it man !!!
Here are the following problems:
- tranny jerks when going from park to reverse.
- tranny shifts hard when going from 1st to 2nd.
- car nearly stalls when stopped at a stop light
**this only happens after the car is warm, a/c is running, vehicle is in drive, brake is applied**
I have been able to get this problem to happen with my sales rep but the service manager tried to tell me today that it is from the cooling fan kicking in.
- rear windows won't go down when needed - intermediate problem
- the car won't shift when accelerating to get on the highway. I take that back, it does shift only after I let off the gas or the car red-lines. Of course the dealarship is located in a downtown setting and it is several cumbersome miles to get to the highway.
- cd has been stuck in the nav system *that was replaced today with a refurbished only to have the scrolling stick not work.
- car pulls to the right *dealership has adjusted but still pulling.
- brakes seem to be spongy most of the time, however, sometimes when applied they seem to add an extra force for no reason.
Specs: miles 2967, purchased May 31, 2006, price 36,070.00 (sticker price), satisfaction with service and follow up: NONE, still waiting to receive my loan information (I have already made 2 payments), still waiting to receive title and plates (temporary plates expired June 30, 2006), Number of days in the shop: 5, total number of hours on the car 93:25:49.
Does anyone have any interest or suggestions?!
New discussion created and posts associated with this issue have been moved to Chrysler 300: Seat Memory.
forum had alot of problems with his car and asked for a buy back and got it.I did it in 2001 on a Chrysler Sebring.With a buy back you don't lose money like you would with the lemon law.I would go to your service manager and explain the problems you have had and see what he can do to start the process.Good Luck.
"Anyone that builds good cars, Can build bad!"
* Auto-Up feature on Driver's side works when it wants to (working right now), Dealer couldn't duplicate the problem
* Alignment jerks to the left & right
* Slight vibration through steering wheel (even on smooth roads, especially at highway speeds)
* Tranny jerks a bit when coming out of park to reverse or reverse to drive
* Sometimes tranny jerks (slightly) while driving
* If I were to accelerate then let go of the gas pedal I have a "severe" downshift and loose my transmission for like 30 seconds. When I hit the gas the car does nothing but "rev" up and slow down.
* Radio won't come in first 30 seconds, started doing this just the other day, but now it comes on right away.
* Molding striping on roof coming loose (getting these replaced, they have them in now)
I like the looks and features of this car, but at this point I’m sort of frustrated with some of these issues and I may not buy another Chrysler product. (This is my first Chrysler product, my co-workers warned me about Chrysler, I should’ve listened!)
--What you're probably feeling is an overly sensitive front end. See some of the previous posts. The car is very sensitive to road crown and unevenness. If you are a light touch driver you will likely overcorrect and only make the situation appear worse. Hold 'er steady and just enjoy the ride.
--Sometimes the shifting is less smooth than expected, especially when motor/transmission is cold. Hasn't caused a problem in 23K miles.
--I think what you're experiencing is called transmission windup. Happens to me only with a fast accel and only when I lift off abruptly in 1st or 2nd gear. That's a characteristic of the Mercedes transmission (and probably the problem of having to deal with all the torque). The only solution is to train your right foot...or maybe use the Auto-Stick when you think you're going to be putting yourself into that situation.
--Might be similar to the loss of volume problem experienced by some people. Supposedly there's a software fix. Happened to me twice, about a two weeks apart. Last time was over a year ago. Disappeared without dealer intervention.
--My problem is a rubber seal on the front edge of the passenger rear window. I just push it back. Nothing else has come loose on the car... No more rattles than there were the first day (and there were a couple).
I'd gladly deal with these glitches in this great car than drive anything else out there...
As for the other poster, I do hope that these issues are fixed without any hassel. This will be the first time putting in the shop for the tranny/alignment and second time being in the shop all together.
I do own one at this time the same one that I've been having problems with it's going in the shop again monday now for the 11th time , I'm working with my lawyers trying to get Crysler to buy it back , My car is shaking at redlights, stalling sitting and while moving, making very loud noises when the "fan"? comes on, if you stand by it when this noise comes on you have to move because you can't stand by it or let alone talk to someone can't hear over the noise !
Anyway sorry for the slow reply i'm just so discusted in all this mess, rite now , nothing would give me more pleasure then to ram a couple sticks of dynamite up the tail pipe and let it blow !
:mad:
My husband boutght me my 300 for our 1st anniversary I loved the car and was totaly thrilled , but then the problems began within the first few days.
_________________________________________________
It's more like 80% of us who have no problems feel sorry for the 20% of you who do. My Mag Pearl 300 Ltd has 13,000 on it without a peep, shudder, pop, pull to the right or any other problem. Just remember the 80-20 rule. 80% who are happy without trouble don't say much. The 20% who do say too much.
I have to disagree with that. If I have trouble with a car, I _will_ say as much as I wish to say.
Right now I'm driving some Suzuki Verona (no 300C..
We found that we were filling up more frequently so I began monitoring MPG. The car went from 21MPG to 16.5MPG.
I have been on top of the maintenance and even doing maintenance earlier than suggested.
1. Oil changed every 3 months (approx. 2600 miles).
2. Just had Recall work done to transmission so tranny fluid has been replaced.
3. Had radiator flushed at last oil change.
4. Replace engine air filter when dirty. (inspect once a month) Just purchased K&N High Performance Filter that is designed for the stock intake housing. "Has gained the engine more horsepower but has not changed the fuel efficiency."
5. Get tires rotated at every oil change.
PCV valve is being replaced next week.
Does anyone know what could be wrong? :confuse:
I have been using fuel from QT (Quick Trip) since I have had my car. I decided that I would change back to CHEVRON fuel on my last fill up since I have never had a bad experience using CHEVRON fuel on my past vehicles.
I would check your tires.If thats not it,check the CV joints on your front axle.I'm assuming your talking about a 300M.
