My past GM vehicles ran 180,000 miles before selling them in VG condition.
The RAV 4 and Honda CRV looks outdated when parked next to our Equinox.
Their spoilers looks like an after thought!
Sales are topping 17,000 Equinoxes a month!!!
"What makes it even better" Equinox problems are much less than the 2004-05 Lexus RX330. Brake Failures and Transmission problems are occurring. Equinox problems are also much less than the 2003-04 Nisson Murano's CVT transmission problems and leaks. Power steering problems. Oh, by the way, if the Murano's alternator fails, it will leave you stranded. It's been a common occurrence. Most vehicles will get you to a safe location with a failed alternator. Check it out, it's all posted at the NHTSA web site (complaints and recalls) and on Edmunds Postings
Now, I am glad that I did not buy a Lexus RX330 or Murano.
Luv my Nox
Speaking of improved mileage, a poster somewhere suggested turning off the traction control each time one started one's Equinox in hopes of gaining one or two MPG.
Any thoughts about that...other than it's a pain
I didn't notice any changes in the 3K RPM needle surge on up-shifts without traction control.
J K F
Got home, went to my dealer and they had to "order the part" brought it back to have work done and sat there for 3 hours waiting for rental to find out i could not rent a car at that time... Came back to have sticker removed and window fixed.. Never removed the sticker or the big scratch on the hood it came with!!! had to being it back for the 3rd time they never offered to pay for a rental again!!!... 2 months later i got a letter from the town that i had an outstanding parking ticket from the dealer $100 They wanted me to pay for it and send them the bill!!
I have a clunking (clunk clunk clunk etc.) noise when i am stopped at a light or slowing down with the brake on...Any one have that problem?
The dealer did not hear anything when they drove it
Have problems starting the car sometimes it turns right off!
On highway and it does not switch gears it over revs!!!!
Should have bought the Trailblazer!!!
I get so many compliments on it but i would never recomend it or the dealer in my town.!! :mad: :lemon:
Thanks, much appreciated.
hope this might help out.
Most vehicles are set to have the AC turn on automatically when you have the vent turned to defrost mode. Well what we found out is that the '05 Equinox is not manufactured that way. The Equinox is set to have the AC compressor turn on automatically if the vent is set the the floor (not the defrost mode), it does not matter if you have turned the AC on or not. If you change the mode to defrost, the compressor turns off and air from outside is now coming into the car, same as if you don't have the AC on and have the vent set to face or bi-level.
The only reason this became a concern for me is because I wear contacts and having the vent set to face or bi-level mode, tends to dry my contacts out, therefore I resort to have the vent set at my feet. But not anymore, considering it automatically engages the AC compressor.
If you are experiecing the compressor turning on in defrost mode, please inform me. Thanks!
I'm getting ready to take mine to the dealer to discuss with them. Just thought I'd do some research first to get some answers.
sam.
I have come to my own solution, of keeping the vent pointed in the defrost mode, instead of at my feet, especially on nice days when I want the windows open or air coming in from the outside. This position does not engage the AC compressor to turn on, thus helping to save on gas. Chevy decided to change this feature in the Equinox compared to their other vehicles. Most other Chevy's will engage the AC compressor (whether you have the AC on or not) while in defrost mode. This is one feature that I am annoyed with.
That is my only suggestion to you, good luck! If you come across any suggestions or any more information from your dealership, please let me know.
I check my Nox with the hood and driver door opened and the fan speed on low. When the right mode knob is on vent or bi-level, you can turn the compressor on/off with the snowflake button. The light is on when compressor is on and light is off when compressor is off. As soon as the right knob reaches floor mode, the compressor turns on and the snowflake button is useless. You can push the snowflake button to turn the A/C light on and off, giving you the impression you are controlling the A/C compressor, but the compressor runs regardless. Defrost and Defog mode work the same. Floor, Defrost and Defog mode also cancel recirculate, but the recirculate button continues to go on or off when you push the recirculate button. The least they could have done is to force the A/C light on and Recirculate light off in floor, defrost, defog mode to match what the system is actually doing.
It appear compressor always runs by design in any mode that directs any amount of air to the windshield. I doubt any dealer can do anything about this.
If you set the mode to floor, then turn mode knob one click to left (between floor and bi-level), you can control the compressor with the snowflake button. In this setting the compressor does not run with the A/C light off and most of the air comes out of the floor. A little air comes out the dash vents and you can adjust them to direct air away from you.
There must have been a consignment of off spec. hoses installed sometime after initial production commenced early in 2004. Pity GM has not come clean on this and identified/recalled the VINs affected.
The bulletin states that discoloration of the coolant is normal and is the result of sealant pellets added to the system during production, however they emphasize that sealant pellets are not to be added during the flushing repair so one could conclude that your flush has not been fully effective.
My Nox was manufactured in March of 04. It has about the same mileage as yours and the coolant is a slightly opaque pink.
Have not seen any prior references to rear brake pulsation although there are a number of references to front brakes rumble due to warped rotors (see post # 470). My front rotors were skimmed at 7000 miles.
Hope this is of some help.
New Vehicle (BASE MODEL)
Invoice Price: $22,997
MSRP Price : $24,675
Dealer Price: Get a Free Quote
• Price this vehicle with options
• Compare with other vehicles
• Select a different Chevrolet | Equinox | SUV
I drive an AWD and it's possible to get a 19+ mpg average by driving at the posted speed limit and controlling rev. surge below 3000 on the tachometer. The vehicle is very throttle sensitive, has good acceleration and will travel fast but seems to require a more conservative driving style to get close to 20 mpg.
My previous ride, a 3.8 V6 T'bird, had about the same fuel consumption but with much better streamlining and little or no electronics controlling the engine and transmission.
http://www.nhtsa.dot.gov/
I have a 05Chevy Eqiunox-The problem is the Amplifier is under passinger back seat ,bad-place. If someone spills pop or water on seat it runs down seat right in to the amp, which causes the amplifier to short out. GM should put the amplifier in the rear of the car where people will not be sitting and drinking. There are cup holders in the back seat area and it is normal to drink in an auto, but people need to be warned about the amp and where it is located.
I have had my fully loaded LT nox ( a lot less than $32K) for over a year now and other than the coolant issue- for which there is a permanent fix. I have had no other real problems.
I wonder how many of these postings are from ACTUAL owners of an Equinox?
In regards to the other problems, im not sure. But its surely under warranty. Tell the service people to be thorough in their repair job.
The last "Hit and Run" was reporting total vehicle break down with no facts or information to back it up.
I wouldn't waste my time with them other than to expose them as il-legit and disturbing the peace.
I guess that what happens when a new GM product comes out to rival the competition.
My wife and I totally love our Nox and would buy another one.
Nox On!
I know that it is 1 year after this note was posted,,, is there anyone else that has had problems with the battery.
My battery is draining often and the source cant be found. I have to use a battery pack 8 out of 10 times to start my car.
If anyone has any thoughts please post it for me.
What is a BCM?
It is one of several computer/control system in a modern vehicle.
Believe it or not there is also a BPCM. That is a Battery Pack Control Module.
A reputable dealer repair shop can isolate this abnormal parasitic battery drain.
The more information you can give a service tech. about its occurance the easier it is for him to solve the problem. Hope that helps.
MrShiftright
I would like to share my experience with this piece of junk......
First of all, please read my message #268 in this forum. I posted this message last Jan, 06 2005. The said message was a copy of my letter to GM, stating my disappointment and complaint about this not so impressive vehicle or shall we call it a piece of junk metal (sorry for those who love this vehicle so much, I once loved this vehicle also)...
This is how my story goes, I bought my NOX last Nov. 2004 after one month I heard a knocking noise on my steering wheel (that is why I had a letter to GM Last Jan. 2005), to address this problem my dealer replaced my steering column free of charge because of the warranty of course. Two days later my AIR BAG, HORN, and CRUISE CONTROL malfunctioned. Again, the dealer found out the problem by replacing the steering coil (this is still with my first letter with GM). I thought the problem would end up.
However after three months, I heard a knocking noise on my left wheel. My dealer said the problem was with the left strut and shaft. So, my dealer replaced it again free of charge. But after replacing it the problem still existed, a knocking noise on my left wheel continues. And for this reason I wrote another letter demanding for a buy back with GM. I made five letters to GM citing all the provisions of the LEMON LAW of OHIO and the MAGNUSON-MOSS WARRANTY ACT, but the customer representative in DETROIT who was in charge with my situation just said to me that he cannot discussed legal matters with me because all legalities were channeled to their legal department (of course). Instead I was advised to file a case with BBB Auto Line, but because I had some doubts representing myself to BBB Auto Line I consulted a very good lawyer a friend of mine asking to represent me instead.
Since we had a good case, we never went into trial. Instead GM offered a settlement by paying the loan that I had and returning all the money we paid like the down payment and the monthly payment we had.
And now, I am very happy with my TOYOTA 2005 4RUNNER. Goodbye JUNKYNOX!!!!!!!!!!!!!!!!!!!!!!!!!!!!
where is this coming from and how is it remedied?
