Visitor Agreement.
If such a code exists, it only makes sense to my feeble mind that the post O2 sensor would give such a reading. It needs to be a sensor that reads what the cat is putting out. Now, could a pre O2 be failed/failing, causing the fuel/air mixture to be wrong, which then causes the bad reading on the post sensor? Yes. BUT, I would think it would then throw more than one code. The pre sensor should be reading bad as well as the post.
I have no idea what a stuck thermostat would have to do with any of that. But if it were stuck, then the temp would read wrong, too, so you'd have more than one indication for that failure.
Again, this is all based on just my basic take on it all and has no relation to the vehicle or how the engineers programmed it.
If it were me, I'd send them a message asking how they determined the problem and/or all the codes being thrown by the computer.
The dealer in question is a BMW dealer.
There are several dozen posts on M5board.com that discuss how various faults can trigger a "catalyst efficiency" fault when the cats are still good. Sometimes other faults are present, sometimes not.
Again, it seems that a failing thermostat can cause the S62 engine to run cool enough that the "cat efficiency" code is triggered. Another prime source of problems are the four camshaft position sensors.
In any event, I'm going to call my Service Advisor and see what he can find out...
The '95 would probably be a really bad choice for my current situation!
But hey, I have to go right through Devon every day now, so maybe that was kismet!
Still overpriced, but I like this one much better. Wonder what a 108K '99 3 series is worth? New tires and brakes, but what about the rad, etc.?
3 series
should have just bid the $8,200 on the 95K 2002 wagon....
Does that mean you have to wait 100 years to get one? :confuse:
oh, wait, I see you fixed that typo.
seriously, though, why does an 85k mile 525 bother you more than a 100k 325 does?
They did some updates on the 5'er for 2001 also IIRC. Just don't ask me what they all are at this point!
even with the 3 series, i would look for something in the 2001-2003 range, which with equivilant miles, probably wouldn't cost much more.
A maintained car without immediate needs is OK by me with higher miles (assuming the price is adjusted accordingly!). I either drive 3K/month or 6k/year these days, and either one will work with a 100K car that is cheap to buy.
I was a bit surprised though, as we've had colder temps than yesterday, and I've never had the pipes freeze. I guess the wind was just sucking what little warmth there was, right out from under the house.
it doesn't take much to freeze them up.
But, this is the one that just went up for sale at a local lot, just a couple of miles from where I work..
'05 BMW 330Ci ZHP
The ad says it's Silver-Gray, but it's really Sparkling Graphite..
There was a black 3-series coupe (328?) at a dealer north of Denver for about the same price, but had less than 30K miles on it. Probably not as well equipped as the one linked above.
I'm thinking that the next time around - maybe 18 months from now - I'll get a reasonably cheap daily driver and a nicer car for special occasions. Spend $25K total.
I like the '04 they have, as well... Imola Red is attractive... just not sure how long I would be happy with a red car..
Also, not sure about the whole sedan/coupe thing... A sedan offers more flexibility, but the coupe is easier to get in and out of for the driver, on a daily basis.. (yes, I'm getting old...lol)
Yup. Priced about $5k-$5500 over trade-in value. As a CPO, however, that's not TOO bad. They could stand to come down ~$2k, though.
My boy loves that M3... especially the color and BBS wheels.. but, an automatic? :surprise:
I've had no dealings with that guy before, or ever discussed price, so I'm not sure how negotiable he is... In general, used cars priced in the $20K range (at a dealer) have about $2K of wiggle room.. I think either of those ZHPs would be decent buys at $2K under asking ($18K or $19K, respectively).. No idea if he is that flexible, though..
Doesn't matter... It isn't getting above freezing for the next week, at least.. So, no way to get a good test drive... Plus, I really can't see buying a car before the weather gets warm.. It's brutal, right now... and, starting my car up cold once per day (at work), is about all I can handle...
There is always another car available..down the road..
I think I found exactly what I want.
It is cheap, though, which makes me wonder what is wrong. Seems to be priced only about $1500 over wholesale.
it is cheap. If you're serious I could look it over for you... Probably Tuesday Morning if it's still there.
I'm off on Thursdays but this week Im off to Florida for 2 days.
I'm trying to cut back. Every time I even think about the car it raises my BP.
:mad:
I have seen PLENTY of cars that have had serious damage and have clean Carfax/Autocheck reports and PLENTY of cars with "Accident" reports that never had any damage worth mentioning.
I have a Certified Avalon on my showroom floor that has an accident on its' history report... when I bought it the back bumper cover was scuffed, I had the original bumper skin repainted for $120. No other paintwork on the car.
Meanwhile I have an 06 Avalon at the auction right now. Clean Carfax and Autocheck, right front fender, hood, bumper, bumper support, front part of the Apron were all replaced. Right front frame rail has clamp marks on it.
Now, which car would YOU want?
The Camry gives nothing up to the Accord in suspension tuning and is MUCH MUCH quieter than the Accord, gets the same gas mileage with an automatic, has more comfortable seats, and seems to have slightly higher build quality. I did like my Accord but overall the Camry seems like the better car between the two.
If we lose a sale to an Accord, aside from pricing, it's generally down to people considering the Accord to be "Sportier" and people find the Camry to be more comfortable and cushy than the Accord. I'll also agree on fit and finish, but let's face it, they are both well made cars. What surprised me when I started at Toyota was how few Accords I have been appraising.
I am finding that people really are beginning to cross-shop us against the Malibu an awful lot lately.
I was looking at a 3 Grand Touring a few weeks ago that seemed great, but when the Carfax showed an accident with an airbag deployment, I didn't bother any further with it. The body and paint could have been showroom, but there are too many cars out there to pick from to gamble with that. IMHO
It was an '04 Mazda3 5-spd hatch with 67k miles for $7995.
Thanks for the offer anyway, brentwood.
I guess I'll sell the MS3 to Carmax. I suppose $13k is a pretty good price for a 52,000 mile Mazdaspeed Grand Touring that needs tires now and front brakes soon...
Westchester County, NY has been selling their accident data to Carfax for less than 24 months, some states don't sell their data, some counties don't, etc.
And if a car's hit hard enough to blow an airbag, it's probably got structural damage, if the car was bought at an auction, the buyer almost certainly knew it.
Here's a funny story for ya.
Cadillac lease ends (My beloved STS) GMAC is no longer leasing Cadillacs, I can go through US Bank, get another one. From $500/mo to $850/mo with a pile out of pocket.
No.
Residual is $26,600 Galves is $14,500, MMR $15500-16k. I'm sure TMV trade in was $18500 but who's counting LOL
OK, so this isn't gonna happen.
I want another XJ8. So I find the right one, bought it online at a dealer auction website, paid about $5-700 more than I should have but it had no paintwork, was clean, and it was Black/Tan and had Navi. Not like these things grow on trees either so I bit the bullet and bought it.
ok, done deal. And I bought it at Manheim Nashville so I got a nice Southern car, right?
Well, after I buy it turns out it was a lease return out of Long Island!
Lawn Guyland! Gee, you could have saved a lot of trouble and bought it before it's Nashville trip! Does it come with nice steer horns on it like a good ol' country Lincoln?
Other than the fact that it makes me want a roomier car even more, there are 2 things that make this car related. The first is that my wife actually agreed to my choice for his middle name. The second is his resulting room decor.
Here is the paintscheme in the room of Ricardo Enzo:
My 15 year old son is a sports fan/basketball player first, but he also likes cars. He started at age 1 with a BMW Baby Racer and by age 3 he was in a Power Wheels Jeep. Now he wants to help install the radiator, Recaros, and the refurbished heater box in my 1975 2002. I think he wants it to be "his" car when he starts driving. With no P/S or A/C I wonder how long that enthusiasm will last.
And, you're right ... given the issues you've mentioned regarding the car seats in the MB, you'll want to get something just a tad bigger. I know you've got the Mazda 5 for family trips, but a second car to haul the kids around it would be a necessity, I should think.
Hey, any excuse to go car shopping!
Speaking of sons, I'll be in CA next week to visit my folks and my son. It will be the first chance for me to see his "new" Mustang - the '97 or '98 V6 with the automatic (yeah, I know, a secretary's car).
I believe he got some accessories for it as holiday gifts, so I'll get some pictures and post if I get a chance.
I think we were all indoctrinated with a love of cars from our parent(s), both in my case. I could identify most cars by age 3. The encouragement is always good.
Does the 190E have a rear-seat center seat belt (it must, right?)? If so, that's the way to go with the baby seat, IMO, though I guess it'd render the rest of the back seat sorta useless, and I can't recall if you're hauling two car seats now?
I was going to take a look at that low mileage P5 fezo and I talked about a couple of weeks back, but it is off the website, so it seems it is now gone, too.
