13533543563583593236
  • tjc78tjc78 Member Posts: 17,507
    He's good about making a tank of gas last 2 weeks and very good about not getting speeding tickets
    I wish I could say that my early driving years were ticket free :cry:
  • roadburnerroadburner Member Posts: 18,613
    Me too; still, I told my son that he has to stay ticket-free for one year before we discuss upgrading from the '02.
  • qbrozenqbrozen Member Posts: 33,848
    Q, it looks like you just got the OK for a Porsche.... print and keep that email for future reference!!
    haha. Yeah, I'm going to have to start reading my Porsche buyers guide again.
    That Hyundai warranty excludes a lot of things but it sure sounds good.
    The 7/100 part only applies to the powertrain. Honda could do the same thing by simply adding a couple hunderd dollars to the price of the cars and I think they should do this!
    I would definatly take it up with Honda stressing the fact that you have been complaining about it.
    Otherwise, hey, things can and do break on ANY car!
  • corvettecorvette Member Posts: 11,733
    Hyundai's powertrain warranty is actually 10/100, but the bumper-to-bumper is 5/60.
    That's true, but remember it's not transferable. 2nd owner only gets the 5/60 portion.
    The bad thing about that is it erodes resale values. Why buy used when you lose 40k on the warranty vs. new? Hyundai and Kia are on a roll, but residuals are the one thing that is lagging, and I think that's the main reason why.
    Suzuki's 100k warranty is fully transferable, so theirs is the best, IMHO.
  • nyccarguynyccarguy Member Posts: 17,825
    My Prelude ACTUALLY needs to have some work done. I guess some things do eventually wear out after 9 1/2 years & over 144K miles. LOL! I brought it to the dealer where I purchased our 2011 Pilot (and had 1 oil change already) for an alignment (car wanders slightly to the right on highway) & to fix the temperature control slider which broke off in the back in the blue (cold) section. This was great in the summer when I needed AC, but now during these mid-40 degree AMs I need some heat.
    The good news & the bad news. Good news 1st of course. The problem with the temperature slider is 2 $30 cables.
    The bad news: The dash has to be removed and 1 of the cables has to go through the fire wall and into the heater core. 5 hours of labor @ $110.00/hour ($580 + tax).
    They were unable to perform an alignment because the front lower ball joints (there are 4), front sway bar links, & bushings need to be replaced due to wear (1219 + tax). The rear sway bar links should be replaced (not necessary right now @ $335 + tax).
    They also found the front motor mount (the one that bears most of the load) needs to be replaced. If it is not, this will cause additional stress on the other motor mounts ($385 + tax).
    Clutch master/slave cylinder is leaking & should be replaced.
    Then my heart almost dropped when he told me my clutch was shot. I had the clutch replaced before (52,000 miles) and it was a $2000 job due to the fact that the ATTS (Active Torque Transfer System) has to be removed & re-installed (and extra 5 hours of labor). He then proceeded to tell me that he believes this because the clutch has a very high take up & feels extremely heavy. He asked if I had noticed the high take up. I said yes. It has been high (and heavier than normal) ever since I had the clutch replaced the 1st time using an aftermarket clutch, Honda Flywheel, & Honda Throwout bearing. Then he said, OK then it feels strong and doesn't slip one bit. - Feeling regained in left arm again.
    Right now I don't have the money to fix the car, escpecially since I only drive it 1x a week to work. I'll wait until I have some money together & maybe get a second opinion, then have it done properly next fall.
    Long live the Prelude!
    To make matters worse there are a few systems that are only warrantied for 3/36. I can't remember them all but one is the radio/nav system.
    edited October 2011
    They were unable to perform an alignment because the front lower ball joints (there are 4), front sway bar links, & bushings need to be replaced due to wear (1219 + tax). The rear sway bar links should be replaced (not necessary right now $335 + tax).
    Take it to an independent shop. I find it hard to believe that everything is "shot". I would guess ball joints for sure, but, they are most likely replacing it all because they are in the area, so to speak.
    If everything you mentioned was really bad you would notice excessive play in the steering and most likely "clunking" when you hit the brakes.
    thanks tjc78. I'm going to take it to a speed shop where I've had work done before (They installed my suspension techniques front & rear anti-roll bars) & I know they know Hondas (& how much I love my Prelude).
    I have noticed the car seems a little rougher since I started driving the TSX & The Pilot on a Daily basis. While both cars are 2010 & 2011 respectively, I do recall my Prelude driving that good for well up to & over the 100K mark. I still took it up to about 85 on the way home from the dealership & took some ridiculously fast corners. Amazingly, it's "still got it."
    Oh, hey, don't bother. Its a money pit. I'll take it off your hands and you never have to worry about it again.
    mwuhahahhaha
    Gas mileage has improved significantly since I started driving the Pilot back & forth to work. I'm getting almost 19 mpg as opposed to my wife (who I think rents it out as an ambulance) whoe gets between 13 & 15 mpg.
    I hope you can find cost effective fixes for it.
    My NA Miata started to age, though it was a '93, and I sold it. It would have needed shocks, new carpet, new paint, etc. I still wonder if I did the right thing in selling it, though.
    Not selling the Prelude! No way, no how!
    Yeah, don't.
    My top was also cracking. It had a year or two left, but that's $460 just for materials. 1-2 days of labor. Pain in the neck job.
    I almost sold it a few months back. I'm glad I didn't. It is truly a special car. Once I get my computer at home back up & running, maybe I'll submit to READER'S RIDES on IL.
  • michaellnomichaellno Member Posts: 4,120
    Excellent idea! It's unique enough now to warrant an entry on the blog.
    Sorry to hear about the cost of the maintenance, but the $2K invested will keep it running well for a good long time.
  • andres3andres3 Member Posts: 14,191
    Is at its half-life point. Do the maintenance and go drive around the world with it a few more times!
    Other than the clutch at 52,000 miles which was a doozie, I think I had to replace the passenger side door lock actuator out of warranty & that's it.
    Royal Purple Synthetic oil, Mann filters, tires, transmission fluid changes... That's pretty much been it.
  • ab348ab348 Member Posts: 20,713
    That dealer of yours sounds like the Honda dealer locally that my ex-gf used to go to. They would replace just about every replaceable part every time she brought it in for other things. It got quite ridiculous - every time it needed an oil change they would ding her for $400-$800 in "maintenance" items or things that they claimed were, in your words, "shot". I was convinced they were ripping her off, but she never listened. Needless to say, I now give that dealer a very wide berth. I would never buy a car from them.
    Get a 2nd opinion from another shop.
    Yeah, I agree with the others on getting a 2nd opinion.
    It is VERY rare for a Honda to need those front end parts but it's possible. The motor mount is fairly common after all of those miles and years.
    I don't like aftermarket clutches in Hondas. They never feel "right" and often have a heavy pedel.. If it's not slipping I wouldn't mess with it.
    Having ATTS makes replacing a clutch an absolute B***H on those and the techs just despised them.
    I would like to see just how badly that clutch and slave cylinder are leaking. A slight seeping can hold on for years.
    Thanks all! I'm definitely going to get a 2nd opinion. He said the clutch/slave cylinder was leaking slightly, so not that bad.
    Craig - I went aftermarket with the clutch when I replaced it because the stock clutch wore out so early (52,000 miles), without being abused, and was extremely expensive ($2000) to replace due to the ATTS. Clutch replacement on a base Prelude is a normal $1000 clutch replacement job. The aftermarket clutch has lasted almost twice as long as the stock oem clutch. Like I said, it is still strong and doesn't slip one bit. I'm leaving it alone!
    Thanks everyone for your input.
  • gouldngouldn Member Posts: 220
    Just to pile on with the others get a quote at a independent that you trust ... you may save a lot of money
    My 01 Forester at 110K started to growl badly. Up till then I'd been using the dealer and they wanted in ballpark of $2K to fix the wheel bearing and several other 'critical maintenance items.' Mind you I had been taking it there every 7500 miles. I decided that after 100K it was time for a change of scenery and researched local independents. I found a great one that is walking distance to my work, and they fixed the issue for $300, and have had all my business since. The car now has 175K and runs great.
  • akanglakangl Member Posts: 3,282
    Talk to the shop today, they have the head back for the Escort and other than some minor tweaking reported by the machine shop all looks fine with it. It was machined and is good to go.
    They hope to have the car running this evening and ready to be picked up tomorrow or Saturday. They plan on driving it a bit to make sure all is well before they give it back.
    I know the kid is very happy his car is coming home.......our checkbook on the other hand..... :sick:
    I filled up for the third time since we got our Pilot, we're averaging 18.25 mpg so far. I find myself paying more attention to how I drive as I watch the "actual" mpg. No complaints, couldn't be more happy with it :shades:
    You must do a decent amount of highway driving. My wife drives the Pilot around town like it is her former 2007 BMW X3. I've noticed a sharp increase in gas mileage when I take it easy.
    It's been about 50/50 so far. Ours is rated at 17 city/24 highway, 20 combined, so I'm hoping it levels off around that 20 mark.
    The CX-7 is rated for 17/23 and we've been averaging about 21 or so; I'm not unhappy with that.
    FWIW, see if you can possibly replace just the slave cylinder, and then bleed the system.
    My clutch pedal went soft on a 93 Miata, and a clutch slave cylinder rebuild kit cost me $10.84, tax included.
    I also had to bleed the system and used about a dollar's worth of brake fluid.
    That bumped the price to a blistering twelve bucks or so. ;)
    Not sure if the Prelude's setup is similar, but worth investigating. If you've ever bled a hydraulic system, it's not really any different than brakes, assuming it's similar to the setup in the Miata.
    It seems that shops don't want to "rebuild" anything these days. With labor rates over 100.00/hr that probably makes sense.
    Besides, they fear that the job will fail and they will be stuck doing the job over for free.
    Two different mechanics can look at something and have two different opinions of whether of not that item needs to be replaced.
    Of course, while getting a second opinion, if the second guy says the part looks O.K, he becomes tha "good guy" and the guy who felt it needed replacement becomes a "crook".
    I was thinking of a DIY type fix...it's not a difficult job to do.
    My clutch worked for years, sold the car and it was still fine.
    Oh, I agree and that is what I would if it were my car.
    I have overhauled many a wheel and master cylinder and I never had a problem.
    Heck, I didn't even have a hone. I wold use a piece of sandpaper to rough things up.
  • stickguystickguy Member Posts: 54,321
    I seem to recall having my slave cylinder on my 2005 Accord (yes craig, a stick accord) replaced under a TSB. Worked fine, but there was some funny noise I think. Did not take them long, and didn't include the clutch.
    oh, sometimes the best repair for a leak is a piece of cardboard on the garage floor. retorquing can sometimes work wonders too (depending on what is leaking!)
    edited October 2011
    I've been using 85 octane, but saw that the manual suggests 87 or higher. I'm not sure if that would help or not, might try a tank or alternate between the two. What are you putting in the CX-7, is that 21 mainly highway driving? What does your daughter get in the Mini?
    Also paying three times as much as I was with the Civic to fill up, but not bothered by that too much yet ;)
    I see you are in Colorado. I guess you are at some high altitude. At higher altitudes, I understand gasoline octanes are lower than at sea level. If your owners manual says 87 octane, your 85 octane gas at a higher altitude is probably fine. And moving up to a higher octane will probably just be a waste of money.
    But what do you guys think of the Chrysler 200? Had the opportunity to test drive one today and wow, nice car. No, I didn't drive it, but hubby did and its the first time I've heard him say he was seriously thinking about going home to get the Civic to trade it in.
    Heck he even forgave the fact it was an automatic and a sedan, something he never does.
    On another note, the Escort has been brought back to life and we pick it up in the morning. Total repair bill was less than the estimate, came in at a cool $1534 and they mounted/balanced the winter tires for free.
  • js06gvjs06gv Member Posts: 460
    edited October 2011
    I think there are far better choices in that class of car. The 200 is little more than a warmed-over Sebring, which at least in 4-door form was mediocre at best. To Chrysler's credit, I do hear that the interior quality has improved substantially, which was needed because the interior in the prior version was pretty lousy. I'd be looking at a Malibu, Fusion or anything foreign before going with a 200 or Avenger. Don't forget the Hyundai dealer either.
    I'm really not a Chrysler basher. I had a Magnum for a company car that I loved, and recently rented the newly revised versions of the Grand Caravan and T&C and both impressed me. The 200 is just behind the competition, and by a longshot.
    2024 Ram 1500 Longhorn, 2019 Jeep Wrangler Rubicon, 2019 Ford Mustang GT Premium, 2016 Kia Optima SX, 2000 Pontiac Trans Am WS6
  • kyfdxkyfdx Moderator Posts: 272,549
    I agree with bolivar... In Colorado, 85 = 87
    Chrysler 200?
    Seriously, I think there are FAR better choices.
    Ford finally got it right, GM is trying but Chrysler just seems to be living in the past. Not "bad" cars but much better choices.
    At least that's my opinion.
    On a 200 I would wait the couple of years for the new from the ground up 200.
    The current one looks really nice - particularly inside. Give them a chance. I think Fiat has the right idea here. Too bad this all makes Chrysler an Italian based company but the results are worth it.
    I only put Shell V-Power 91 into the CX-7. The 21 is mostly rural 2 lane from Castle Rock to Elizabeth, plus some interstate to the Springs.
    No idea .. she takes care of the gas so I'm not aware of what kind of mileage she is getting. She and the wife alternate driving days; they work together at the school district. But, if I were to guess, I'd say high 20's or low 30's. I think she puts 89 octane into it (regular Cooper; not Cooper S).
    dad23 and I are at about 6000' elevation, so slightly higher than Denver. The octanes available vary by station. The station I use for the ION - affiliated with the Kroger grocery store chain - offers 85, 87 and 89. The Shell stations in town have 85, 87 and 91.
    The only car that I've owned that recommended 87 octane was my '03 Ford Focus; in the manual, it specifically recommended 87 even if you were at high altitude and had the choice of 85.
    A lot of people seem to forget about the garbage and I do mean garbage cars Fiat sold in the U.S. before they left with their tails between their legs.
    People bought these cars only to find their dealership GONE! Warranty work?
    Forget it!
    Ah, but now they are back as the owners of Chrysler of all things.
    Give them a chance? Why?
    As I said, there are a who LOT of better, PROVEN choices out there!
  • andre1969andre1969 Member Posts: 26,139
    I think they did about the best they could with the 200, considering what they had to work with. The interior transformation is nothing sort of spectacular! It actually has an upscale, quality look about it! And the new engines are a nice surprise, especially that new 3.6 V-6.
    My biggest problem with the car is simply the roofline. It's awkward looking IMO, and while the transformation from Sebring to 200 is pretty good, they really couldn't change that roofline, most likely, without incurring some major expense.
    I have seen a few new 200's around, so evidently they're gaining in popularity. I hardly ever saw a 2007+ Sebring, although the Avenger, which is a rental car favorite, seems pretty common.
    I'd buy a 200 if I could get a really good deal on one, compared to the competition, but I think I'd rather wait and see what happens with the next generation...if there is one.
    FWIW, the 300 and Charger were a remarkable transformation as well. One thing that always made me leery of the 300 and especially the Charger was the downscale interiors. They just reeked of cost-cutting, compared to the older Concorde, 300M, and even Intrepid. But for 2011, they've more than made up for that!
    I really like where the new Chrysler products are coming. But, long term will tell if this is simply 1957 revisited.
    that was ages ago. ancient history. Fiat is nothing like it was back then (and of course, neither is Chrysler). From reading about their products, I'm excited to see them getting into the mix and Dodges, etc.
    Much better to be essentially a supplier to an established company with an infrastructure.
    and no, there are not that many people that still remember (or at least hold a grudge) about Fiat.
    that, and the vast majority of people have no clue about the actual ownership of the company, or what the cars underneat. Just styling and incentives!
  • Sandman6472Sandman6472 Member Posts: 7,330
    edited October 2011
    In my case, the independent shop got it wrong with my recent a/c problem. So I did learn a lesson here about going to the dealer. The labor/hour charge is definitely more at the dealer though. The Honda rep called & left a message...called him back within a minute but got his voice mail. Tried 3 other times now & all went to voice mail. Got a 50/50 shot here for some $ help. We'll wait & see...so far the a/c is working fine and have a 12 month guarantee.
    Did sit in the new Civic & the Insight and wasn't impressed with the Civic at all. If I had the choice right now like I had back in 2006, I would buy something different...the interior of the 2012 is pretty cheap looking with hard plastics and ugly radio controls. The Insight's interior & dash look a bit better but the Focus, Verano & Elantra look so much more modern. Saw the verano's nice dash in my Car & Driver I received yesterday. The exterior of the Verano is sharp looking as is the dash...am very excited to show the wife. the only thing wrong is the base price is a bit hefty when compared to the class as a whole. Not sure it's worth that much more than the competition but in the pic, they showed the car in silver and it did look stunning! For some reason it just fits better better on the Verano than on the Regal...if it drives as well as the competition, we'll have a lot to think about.
    Going with the wife for the Focus test drive with the $50 coupon on Monday...we'll also try out the Fiesta just to see how much she likes it. Also, the South Florida Auto Show is in Miami this week and if I feel up to it, we're planning to go next Saturday so we can look at all the choices on our short list. A great time to be able to sit in them without any hassle from the sales folk. Figure to get there when they open, so the crowds will be less as I think most folks will come in the later afternoon/evening. We'l be there for the 11 a m opening and hopefully have a smaller crowd. If we do go, it'll be my 1st return to the show since my accident back in 2005...I really miss the show so G-d, please help me to feel better so we can go! Legs & back, don't fail me now!
    The Sandman :) :sick: :shades:
  • oldfarmer50oldfarmer50 Member Posts: 24,628
    "...What do you think of the Chrysler 200..."
    Cosmetic improvement on the Sebring but not up to say a Ford Fusion.
    I have been a rabid Chrysler fan since my first car, a 1969 Plymouth. I owned a 1997 Cirrus which is 3 generations removed from the 200. For it's time it was a contender and I loved it. Trouble is, Chrysler hasn't really improved the car much since.
    I recently owned a Concorde and loved it. I currently own a PT Cruiser and although it's a nice grocery getter it is strictly 1990s technology.
    You finally got that $50 Focus coupon to work? Or is this a different deal?
    The 200 is supposed to be much improved over the Sebring. That said, if I really wanted one, I'd wait a year or two and pick up a cheap used one down in the lower 48, and drive it up to Alaska. The depreciation curve is pretty steep on those. Caveat: Be sure to get one with the six-speed automatic. The four-speed is standard on the base four-cylinder models.
    I'd strongly consider any of the Asian imports over a new 200. The Fusion looks dated but is still competitive.
    Test drove a Fusion, Taurus, Regal, and Lacrosse today. The Fusion, um, no thanks, it felt dated and cheap, was a very boring car with a ton of road noise, almost as bad as the Civic. The Taurus hubby liked but the seating position was a little odd when it came to the dead pedal. The Regal had way too much road noise, the Lacrosse was pretty nice. Funny thing is NONE of them touched the 200 for quietness and bang for the buck.
    Next on the list is the Sonata, Optima, Accord, Camry, Legacy, and possibly the Passat or Jetta. Trying to give at least all the mid-size sedans a look.
    On another note, we picked up the Escort today, the kid made it about 5 miles from the shop and knew something was wrong. It was trying to quit on him and had no power, so hubby drove it and took it back to the shop. Apparently it had a misfire on cyl #2, so they replaced all the spark plugs free of charge and that fixed it. Little car is back up and running good now.
