Visitor Agreement.
If you live in an area that doesn't have a dealer (I had to drive 25 miles), then that would be a good option.
I never found anyone selling them on-line, so you are one up on me..
I really like mine (Nokian WR), the longer I have them... Even the dry road capability is a big step up from the S-rated all-seasons that I had before... A real win-win for me..
I can definitely say YES!!!! I got my 2006 Jetta TDI with package 2 and it is worth every penny. I got it on Jan 8, 2006 and now have 72,000 miles on it. I am averaging 46 mpg. I estimate that I have saved over $3500 in fuel costs. It came with XM radio which I have found to be well worth the cost. The only problem with the car happened the 2d day I had it. There was a problem starting it. I drove to the dealership to complain. They came out to try it and it would not start. They gave me a loaner and 3 hours later I had my car back. There had been a bad connection in the starter which resulted in a loose wire. Since then, everything has been great. I have had no further starting problems and the cars really handles well and is fun to drive. At this rate, it looks like this one will last a good 300k miles. My original tires are still on the car and look to be good for at least another 40k miles.
This is the most frustrating of a long list of service issues with this car. At 50K miles, the transmission failed and was replaced (under warranty), other repairs included replaced glow plugs, braking mechanism, air flow regulator, etc. This car has been a money pit. Even the MPG has not been as desired...lucky if I see 38 when others are in the mid-40's. This will very likely be my last VW also :mad: :mad: :mad:
Guess VW are not immune from building the odd bad 'un but they do seem to be pretty rare. Not much comfort to you, though. Sad tale and easy to understand why you wouldn't trust another one.
I find it VERY difficult to beleive that all the teeth on it suddenly just fell off. This kind of thing ususally happens slowley and can be seen at inspection-time.
http://www.theglobeandmail.com/servlet/story/LAC.20070510.WHDIESELSSIDE10/TPStor- - y/Environment
I particularly hope the following message makes it to US consumers:
"In the battle with hybrids, the companies pushing the new diesels will certainly point out that hybrids save on fuel consumption only in city driving. Diesel cars consume 20- to 40-per-cent less than gasoline cars under all driving conditions."
This also means that your pumpe-duse engine requires VERY special engine oil. Use of any other oil has been shown to destroy the camshaft. (Many VW dealers have been using the wrong oil.... beware)
Now, to answer your question about intake system. There is no need to do anything. The stock system ALREADY uses a cold-air intake system. (air pulled from behind headlight)
Also, if you have not already been warned, do not use an oiled-guaze type of airfilter (such as K&N) The oil from the filter can be sucked onto the MAF sensor and destroy it.
I have no idea why someone would want to spend extra money on an alternative air filtration system that provides absolutely no performance benefit, Filters worse and has been reputed to cause damage to expensive engine components!
I'd appreciate any feedback before I make any changes.
rodekill
What did it damage? I am betting that we will have sustained the same damage and it will give us something else to check under our hood to see why we can't get the thing going. Thanks for any info you can give.
The car has 84000 miles on it
EGR does this because already-burned exhaust gasses CANNOT burn again... so they cool off the combustion process.
Now that you know this, it is unlikely that BlueTec (which injects urea in to the exhaust to aid the catalyst) can "get rid of" the need for EGR.
Perhaps you are aware of some chemical reaction which I did not learn about in high-school... Please tell us how injecting urea AFTER the combustion chamber can reduce oxides of nitrogen? Does it split the molecular bond between the nitrogen and the oxygen? What is the resultant "emmissions" from this process?
(Does the Nitrogen bind with somthing else?)
The chemical-soup coming out the exhaust is SOOO hard to control. I find it amazing that enginers have been able to bring interal-combustion as far as they have.
Mileage - combination city and highway - 37 mpg
Highway - 42 mpg
Driving habits - hard driver, heavy traffic - high speed work commute, much hard braking and accelerations.
Highway habits - (way to fast) 80 mph Houston to Dallas 41 mpg, Dallas to Houston 110 mph 37 mpg
(wife driving) over 40 mpg anytime. She is a slower driver and could have probaly averaged a higher highway average if she didn't stop at every antique store.
Best features I like - Braking is amazing! seats are designed for a 6' driver (unlike [non-permissible content removed] cars)Responsiveness on the road is best I have driven. I feel safe in this car and I let my 16 year old daughter drive it to soccer practice across Houston because it is the safest car I own.
Average report from an average user.
I just got an 06.5 Jetta TDI about 3 weeks ago, and I have really liked mine too.
My mileage has only been around 30 MPG on the first 2 fillups in Birmingham urban driving, but I expect that should get better as the engine breaks in. I don't expect it to be great in this area anyway since it is so hilly here.
The intake manifold is known to get cruddy over time (due to the EGR system which is NOT installed on European TDIs)
It is not unusuall to have to remove and CLEAN the intake manifold... but I have never heard of anyone replacing it just because it is cruddy. (It is easier to just replace it... but that is expensive and unesasarry.)
For more details, here is a link to EGR CLEANING 101
To answer your other questions:
Are any downstream impacts to not fixing it right away?
I am not aware of any perminant engine damage that can happen to the engine by postponing the cleaning process.
What would happen if this completely failed?
It will just get so cruddy that the engine will starve for air and lose power.
It is said that a TDI engine should be "accellerated hard" once in awhile. This is to help blow the accumulated soot out of the turbocharger to keep it clean. What your wife saw was this cleaning process in action.
If you were to repeat this hard accelleration a few more times, your wife would have noticed each time blows LESS soot. (because there is less to blow out.)
To relate with your woodstove analagy... you then know that a woodstove should be burned HOT at least once a day to clean out the chimney of buildup. If not done, then a chimney-fire may occour. (Always use a chimney-thermometer to monitor that it stays hot long enough to do the job.)
With the TDI, you should use full-throttle accelleration at least once per tankful. Up a hill is even better. Dont be afraid to take the RPMs up near redline. (never past it!)
This accelleration will also help to blow out the buildup of oil in the intercooler.
If a TDI engine is "babied", it will begin to plug up and eventually will need to be torn apart to be cleaned out by hand.
Here is a link to TDI 101 (Starting Post For Newbies) which should answer your other quesitons and more.
Good post.
I've followed similar discussions on this forum, and have read about the need to purge soot from the TDI engine in many posts in the TDI Club; however, I believe that you've concisely communicated here the significance of doing this on a regular basis.
I just got a 06.5 Jetta TDI about a month ago, and I'm trying to run it the right way to make it last a long time. Tips like these are an important part of the process.
Sean
The number of parts they've thrown at your car is quite impressive, and would be a rather unique situation if all those parts actually had failed. Most of those parts (the turbo and injection pump in particular) don't fail all that often in the real world, although they're quite commonly mis-diagnosed by il-trained repair "technicians". I would find an independent mechanic that specializes in VW diesels.
And will VW meet the new requirements by 2008 or 2009, and start selling here again?
My understanding is that VW will start selling 50 state compliant Jetta TDI’s in the first quarter of 2008.
Will the new restrictions add a few thousand to that price?
What isn't made in Mexico these days? I don't think where it's made has anything to do with the price.....I have a pickup made in Mexico that has a sticker reading $45,000...
Just because they get 40-50mpg doesn't mean you can lump them into the economy car class. I spent a day in a loaner Civic while our Odyssey was being serviced and I can see a justifiable price difference between that and a Jetta. Heck, my '00 Jetta has features lacking in the Civics.....heated seats, leather, heated mirrors, just a couple off the top of my head. Of course mine was $15,000 seven years ago.....
My point was that paying so much for a Mexican-built car is wrong, because the quality is nowhere near that of the German-built VWs, and because the Mexican factory workers are getting paid a fraction of what German or U.S. workers get. Where's the savings for the consumer?
Ford builds the Focus in Hermosillo, and sells it here for $15,000 brand new. That makes sense. $26,000 for a TDI doesn't.
