http://www.powerservice.com/
Thanks, Dale
In return, a turbocharger gives you significant power from a very small engine.
Just think how the early NON-turbocharged VW diesel engines were!
daleho1 if it really is taking 3 full seconds before anything happens at all i would have it looked at. Does it seem like it is out of gear? Good luck with VW service though, from my experiences it has been a Freaking Joke dealing with dealers. :mad:
Also if you want to hear bad things about smart boxes, chips, special air intakes, the list goes on Mr. bpeebles will lead you in the right direction. My advice, leave the car factory if you want long lasting, reliable, efficient use from your TDI.
Are you suggesting the Volkswagen engineers left somthing out of the design and your TDI is "stupid" until a "smart box" is added to it? LOL
I guess my point is... Just exactly what function are you expecting to add to your TDI with a "smart box"? (Better handling, shinier paint, smoother ride, increased MPG... etc)
This TDI is the first drive by wire diesel I have had so thats why I quistioned the acceleratoir lag thinking it might be in the electronics. if I understood correctly the 06 TDI has varibale pitch fins in the turbo to spin it up sooner and keep it from over spinning at the higher rpm thus no waste gate. correct me if I'm wrong
Unfortunatly, your 2006 uses a "pumpe duse" engine which has a seperate , cam-driven, injector pump for each of the 4 cylinders. Being all mechanical, there is very little that electronics can do to alter the mechanical settings.
The "Kerma" is a very well respected brand among VW TDI owners. I have never even heard of the "The van aaken smart box (Parleys Diesel)" for VW engines. There is also "RocketChip and "Upsolute" for TDI engines.
For the older (NON-pumpe-duse) TDI engines, the Kerma replacement injectors was arguable the best single power-improver available. At the same time, the MPG would not suffer (if you kept your foot out of it.)
In most cases, after applying any power-upgrade, the CLUTCH would suffer because the stock clutch could not handle the increased torque. It is possible to just "spin the clutch" by applying throttle.
You are correct that the VW TDI engines use a VNT (Variable Nozzle Turbocharger)
Please read this webpage to get a better understanding about VNT operation. (Pay close attention to the LAST photo which shows the VNT in action!)
I considered a Van Aaken Smart Box (VASB) when I started my modding. It's a plug-n-play tuning box. It can easily be popped off for service trips, if you know what I mean.
I have a neighbor that bought a TDI around the same time I did, but his is an automatic. He went the VASB route and still runs it to this day (his only performance mod). It's very effective actually. I don't know about 20hp-26hp.......that sounds like sales fluffery. If you know anything about tuning these motors, 26hp would be a HUGE performance jump for just a simple box. I'd say it's more like 10hp, but that's still quite a nice kick in the pants for a diesel.
With my mods I may be approaching 20hp and have unscientifically run 0-60 in mid 8's. That's with some serious clutch dropping. But the performance gain at passing/highway speeds is where it's most useful and doesn't destroy the clutch!
off this subject, I rolled over 20000 miles today and about the same time the Exhaust system warning light came on (steady not flashing) I can't say for sure if it came on exactly 20000 but I do know it was with in 15 mile of it at most. would you know if VW might have it programed to come on for the 20000 mile service? could you recommend a good vag com?
So you've got Dyno results to post right?
My biggest gripe with these oiled filters is they do a poor job of filtering. Perform an oil analysis using an OEM paper filter and then perform an oil analysis on an oiled filter. You'll find elevated foreign and wear material in your oil with the oiled fitler. I've performed the test using an Amsoil and K&N oiled filters. Yeah, the oiled filter results will still be within specs, but more wear is more wear. On an engine that has a long service life such as the TDI, I'll take the filter that filters the best.
There are lots of very high mileage/nil problem TDi's about that have only ever been fed straight ULSD so the benefits of the the "improved" versions may not be terribly worthwhile, but one of the UK main motor mags recently stated they thought the 1-in-4 idea was worthwhile. You pays your money and takes your chance.
I've tried the 1-in-4 diet on my 1.9 TDi/130bhp and would be hard pressed to post any hard-fact improvements, but a friend with a 3.0 TDi/225bhp in an Audi A6 swears by it.
Each to his own, as they say. Sorry it's not more positive.
This is actually very untrue, and in extreme cold climates like Canada, if you dont add a form of anti gel additive to your diesel you will not make it far out of the driveway!
Here are a couple of helpful links on Good fuel additives to use with your TDI's.
http://www.stanadyne.com/new/ppt/showfile.asp?id=3437
www.stanadyne.com
Here is the tech bulliton which VW even recommends this additive with every fill, and will NOT void warrantee.
http://www.stanadyne.com/new/ppt/showfile.asp?id=717
quote: Mr.bpeebles I always add about 6oz of Power Service additive at every fillup
We did a visual inspection of the dismantled intake and while it was blackened, based on what he saw, he pronounced it good to go to another 100,000 miles. There was literally no build up. This was interesting in light of the fact that ULSD has only been used only for app (the past) 15% of the mileage. Most fillings have been the CA LSD (claimed to be 140 ppm). However I have used a fair amount of 49 state LSD (up to 500 ppm).
Of course the group of us discussed the PP520's and alligator chip options:)
During a recient long trip , I measured 58MPG over 3 tankfulls. (which makes the measurement more accurate!) My TDI has traveled over 800 miles between fillups several times.
I do not know if the ULSD has attributed to this kind of MPG.... but not much else has changed on my TDI besides an oil change.
About a month ago, I added a few ounces of G12 coolant, which I bought from the dealer. I didn't realize that I should dilute this with distilled water. I looked down into the expansion tank, and it looks like the pink fluid has separated somewhat (i.e. there is a darker concentration near the center of the tank).
Should I attempt to siphon off some of the excess coolant?
I am thinking about taking my car to a service station for a coolant flush and fill (with the G12 that I have already purchased of course).
Is this something I can do myself, or is it better left to the professionals?
My do-it-yourself experience so far is limited to oil changes, fuel/air filter replacements, and tire rotations.
There are tools available to check the "concentration" of the fluid in your system. Only thru measruement should you try to change the mix-ratio. (draining and refilling is not the only recouse.)
I am not sure how anything can "seperate" in a tank that gets constantly recurculated thru the engine. I suspect you are seeing an optical illusion.
BTW, I'm glad they walked away from the Bluemotion name. Does VW use UREA?
-Cj
Not bad as a rough guide.
I can only tell its diesel during the beginning. But after its going, I can no longer tell! Its so hard to pick! Plus the 100hp vs 140hp is whats eating at me. I would hate to pick by price and settle for less than what I want...
As long as there is a sunroof and the car is Deep Sea Green I'll be fine! I should be able to get the body accessory from VW anyways. The Lip spoiler, the AVGNON(Sp?) rims(Build a jetta 2.0T with package 1&2 and the rims you get then), and even the leatherette seats are great! As long as its not the hub caps...
Yup, I'm stuck betwwen a rock and a hard place. I can actually use my company slogan here... Diesel, Something different (Dairy Queen) but I'm not sure how the transition from smooth high reving v6 (170hp 164lbs ft) 95accord to a jetta. Its complete the opposite... :sick:
-Cj
I went to the VW dealer yesterday and he was telling us some information about the diesel cars. A summary of what he said: The current... Old(?) TDI engine could use either ULSD or Regular Diesel whereas the new 2l TDI can ONLY run on ULSD. ULSD is.... SO on so forth. He was from England and was telling us how gas was $9, no one drove automatics, and how there is a $1300 tax for driving an SUV.
He was a very knowledgeable guy! He even informed us about the 2.5 jetta going from 150hp hp 170hp (making it more attractive to me!) and VW's color changes.
He did loose points when he had no clue that VW jettas were made in "Deep Sea Green" metallic... Honest mistake because its green thats mixed with grey.
Shadow Blue, Deep sea green, and that gold wheat color are all gone for 2008. Oh and the excellent news is that the jetta 2.5 is rated at 22/29 for 2008 instead of 22/30.
BTW, VW DID change the trim names. Its now S, SE, and SEL. So far, only the 2.5s are out and there is no word on the 2.0T engines for the jetta.
:surprise: OMG THE JETTAS TRUNK IS MUCH LARGER IN PERSON THAN PHOTOS!!!!!!!!!!!!! :surprise: My first time visiting a VW dealer in quite some time. I think the last was when the A5 jetta was JUST introduced and there was only one on display.
-Cj
Automatics are not uncommon over here and DSG 'boxes are increasingly popular.
The Annual Road Tax, (Vehicle Excise Duty), in UK for the highest band of vehicles, (those producing CO2 at >225g/km), is approx $600, not $1300. However, London is proposing that such cars be charged $50 per day to drive into the city. Other cities are watching with interest.
We don't get the 2.5TDi in Jetta or Passat here in Europe. Other VAG marques use it at in either 160 or 173bhp formats but it's getting to be very rare and is replaced by the 2.7TDi at Audi but that's not used by VW. VW use some 2.5TDI plus 3.0TDi and 5.0TDi V10 engines. :shades:
Boot, (trunk), on the Jetta is actually larger than on the Passat. Go figure. :confuse:
2.0 gas engine is still around but the one to watch for is the, (relatively), new 1.4TSI gas engine. Comes in 140 or 170bhp formats. Yes, it is only 1.4 litre but has both a turbo and a supercharger. Very clean engine.
If you Google on vw.co.uk, or audi.co.uk, or seat.co.uk or skoda.co.uk you can browse all the VAG products/specs we get.............and be shocked by UK car prices. Jetta prices range from $29.5k to $36.3k. Passat goes as high as $51.7 for the 3.2 4Motion model. I've used an ExRate of 2 USD to the Pound.
The VAG group has Audi at the top then VW followed by Skoda and SEAT. Common engineering but quite different approaches. Worth trawling through.
Hope this helps.
