Visitor Agreement.
The latest announcement is Ford's Fiesta, which is already sold in Europe. It's a slower animal than the Jetta TDI, given it's 90 horsepower versus 140 for the Jetta, but it gets rave reviews for being to even handle German highways, and gets a stunning 67.5mpg! :surprise:
Edmund's Inside Line First Drive - Ford Fiesta Turbo
Does anyone else have an experience like this or am I just crazy? I can't attribute it to my driving habits since I drive the same speed, route and distances to and from work every day. I've also noticed the mileage boost seems to "linger" on my next tank if I happen to fill up next time on ULSD. However, if I fill up twice on ULSD I drop back to the low 40's.
I first noticed my mileage drop about 6 months ago when most of my local stations switched from 500ppm to 15ppm diesel. Last year when I took a road trip to Tennessee I averaged 52mpg, but on the same trip this year averaged only 41mpg. However, I never started to put two-and-two together until recently.
Anyone?
That is why I always add ~6oz PowerService diesel fuel additive with each fillup. Not only does the PowerService increase the cetane to where the engine wants it... I also get added lubricant for the expensive injection pumps. (And some injector-cleaning detergents too)
I log every drop of fuel that goes into my TDI and keep a spreadsheet of MPG. There is no question that when my wife fills the car (and does not add PowerService) that I lose about 3-5 MPG.
Anyone who drives a TDI in NorthAmerica should consider fuel additive as part of owning a diesel engine. PowerService is available at any WallyMart. (Use GREY bottle in summer and WHITE bottle in winter)
I live in the Tampa area andam considering setting up a biodiesel conversion. Would anyone from the Tampa area like to participate? The basic set up would be 1200.00 but a better (more gallons less effort) can be had for 4000.00 split 5-8 ways would make the capital cost less with more efficient production of 200 gals per week.
Willie Nelson uses B100 in his Mercedes he keeps on Maui. There is no downside running B100 where it is available. Do not confuse biodiesel with waste vegetable oil. They are NOT the same. This company has had a lot of success over the last several years renting VW Beetles that only use biodiesel.
http://www.bio-beetle.com/index.html
Biodiesel is made by removing the Glycerine from the WVO,by various processes,including the use of Lye and Methanol.This causes the glycerine to separate from the oil.
WVO is filtered using a 10 micron or better filter.If there is a chance of water contamination,then it is also dewatered.
A WVO conversion involves the use of a Tank Heater,Heated Filter,Line Heater,Switchover Valve,etc. 2 tanks are used,diesel and vegoil.Car is started and warmed up on diesel,then switched to vegoil. It is switched over to diesel just before(3 minutes) arriving at your destination.
Concerning the Biodiesel everybody knows where the biodiesel comes from. You can just google it I will get tremendous amount of information.
http://www.biodiesel.org/pdf_files/fuelfactsheets/bdusage.PDF
You are misinformed. Biodiesel is a product that can be made from waste vegetable oil and many other things.
Restaurant oil can be converted to fuel, but that is a messy process. Only a retired person or someone with a lot of time in his hand want to start making his own fuel. Personally I prefer to buy it, and use my time to enjoy life, not brew fuel in my garage until I blow up the house then my losses will be tremendous. Didn’t you learn about that guy from UK that blow up his garage with second degree burn? What kind of saving he made, nothing, on the contrary he ended up we big medical bill, and 6 months of treatment. Personally I will not go that route.
Biodiesel generally has a cetane rating of between 50-60 whereas diesel fuel generally has a cetane rating of between 40-50. Biodiesel?s higher cetane rating is due to its higher oxygen content and superior combustion properties.
That in turn will give you better mileage. As some one has already posted BP ULSD has a cetane rating of about 53 and gives very good MPG.
FWIW, Lutz has always been down on diesels for the North American market.
BTW, I'd like to see the latest sales numbers on gasoline vs. diesel engines in Europe. Not just overall numbers, but also by car size category.
I will believe it when I see it with a 3300 lb gas station wagon getting 45 MPG. You can have the LRR tires. I would not own a vehicle with them. My safety is more important than saving a couple MPG with tires that are unsafe at any speed.
I agree that the sooner the other automakers get something to compete with the VW Jetta TDI it will be good for the consumers.
MSRP for the Loyal edition Sedan: MSRP for the TDI-Sedan
$22,440.00 manual $21,990.00 manual
$23,540.00 DSG $23,090.00 DSG
The Loyal edition includes sunroof and DSG as part of the package but for the TDI you have to pay $1,000.00 for sunroof and $1,100.00 for the DSG. The Loyal edition was to be the teaser car and for the loyal TDI fan club that would pay the dealer mark up and also to be the first set of cars allocated to the dealers. But it appears that VW released the TDIs earlier than expected so you ended paying more because of the DSG and sunroof. However, there were some early TDIs without sunroof and with manual. I don't believe the Loyal edition (demo) had bluetooth. I think that's an option you pay for. If you can get the Loyal edition at the MSRP above I would take it.
Although the term "biodiesel" is all the rage right now....there are serious issues with using it in a modern diesel engine. One of the biggest issues is the inconsistant mixture and the possibility of destroying your injectors.
If you wish to experiment with "biodiesel", get yourself a pre-2004 VW TDI (before the pumpe-duse engine).
Here are some of the facts I have discovered about BD (biodiesel);
*)It costs more in fuel to plow/harrow/seed/harvest/make/haul BD than what you get out of the process. (IT IS A NEGITAVE RETURN!!)
*) BD is a very good solvent and tends to clean gunk from your fuel system.
*)When BD burns, it leaves a sticky residue that plugs up fuel injectors.(due to its chemical makeup)
*)It is essentually a chemical-soup to make BD there are a lot of ways to make bad BD.
I'm pretty sure I read in a review of the demo TDIs that have been available for test drives that they are mostly done up in the Loyal edition and the article stated it includes a sunroof, upgraded radio, front air dam lip and rear trunk spoiler. The transmission is completely seperate item and not associated with the Loyal pkg.
I gave up on VW and bought a Ford Taurus. I know, apples to brussel sprouts, but I’m happy with it, it is comfortable and should get better mileage than most cars its size.
It gets better mileage than the 1993 Explorer it replaces by 6mpg and it only has <300 miles on it.
The Loyal edition costs about $450 more than the standard edition. For this huge sum of money you get a SUNROOF, FRONT AIR DAM LIP, REAR SPOILER AND AN UGRADED RADIO.
Now, I don't know about you but it seems to me that is a decent deal and to my knowledge anyone can buy the car---not just previous owners. Why they call it that I'm not real sure. I think they were going to use it in some kind of marketing campaign and then realized they wouldn't have to with the price of gas/diesel skyrocketing.
Maybe you missed this-------------------> :P
They can still use it in a marketing plan. All those that are loyal to the human race can buy at sticker price....maybe more if your dealer is a scurmudgeon. Save $500 on a sunroof and radio for prior TDI owners sounds good though. Those Loyal to white cars can get a white car? I'm full of ideas!
Mico
I was confused just as you are with that. I wouldn't worry about the Loyal Edition unless a dealer has one that you are interested in buying. There were only a small number of them and you can't order one. You will see an end of production date (EOP) on the form. However, this will help you see what the difference is from the standard TDI. A nice guy on another forum cleared this up for me. Good luck!
Instead, you can work with a participating dealership and submit your "preferences" for specific features/options. If one of these happens to come out of a build-cycle, it can be earmarked to be routed to your dealership. It may take months before your "preferences" are matched up.
Another way is to work with your participating dealership to review the VWs which already reside on other dealership lots. A participating dealership can do a "swap" with that dealership to get that vehicle into your hands.
The reason I specify "participating" dealership is because some of them are apparently unwilling or unable to use their computer to locate a vehicle for you. I know this 1st hand because I had to go thru 3 different VW dealerships before I found one that would work to get me EXACTLY what I was looking for. Once I found a participating VW dealership... my new car was on their lot within 3 days. (they did a 'swap' with another dealership in Rhode Island)
My first VW was a 1969 Squareback & I've had a few others - including a wonderful made-in-PA '87 Golf and a '90 diesel that took many minutes to reach 60mph. VW has missed their older traditional market who loved the sturdy simplicity of their older products by insisting on the latest gimcracks and gewkaws like their new keys among other things.
