In a gallows sense of humor mode, passing on a two lane blacktop can almost qualify as "DO NOT TRY THIS AT HOME OR IN THE REAL WORLD" warning. There are a host of reasons for this, but as you imply, the stakes are EXTREMELY high. Knowledge and experience can literally be a life and death proposition and/ or result in night of the living dead experiences.
I personally love the New Mexico desert, etc. As you probably know, most of the roads there ARE two lane black tops. The ante is ALWAYS (JACKED AND WAY...) upped when an approaching car is trying to pass, as ...YOU are trying to pass.
There has evolved a custom of putting (normally white) crosses where there have been fatalities. In NM, those crosses seem to be located in (some to MANY) VERY illogical places.
Currently I can get 12v from running lights and a separate 12v for low/hib beams. Need 12v that will work for when either one are on (running/low/high).
Oldsmobile Station Wgn ,then 99 a Buick Park Ultra now a 2010 VW Jetta Diesel. You cannot see the exhaust or smell it there is fine dust on the tailgate and have the dust on the door threshold. The TDI roars uphill using very little fuel. The Buick would roars uphill getting 9 mpg. I can pack it my
5 passenger with plenty of room
For some reason I can't find a front hood guard in any of the usual places..Google search, eBay
or even on this forum...anyone have any thoughts?
http://www.carbras.com/default.asp
1999.5 - 2005 Jetta"
Thanks for the link cosmos, but they don't stock the hood guard for the newer Jettas.
I found another link from an old VW Jetta Forum that might have one...will keep poking around until one shows up.
This is the first time I've ever stumped eBay looking for an item!
Just bought a hoodguard for our Honda Ridgeline off eBay, you would think the VW's would be there too. Lots of hoodguards for the older VW models tho.
It is sorta like xtra-thick scotch-tape. It is nearly invisible. pebbles and stones bounce off of it without damage.
Also - It does not alter the looks nor aerodynamics of your vehicle like a hood-guard does.
You should find retailers by going to 3m.com or expel.com.
(they wanted $700.00 to do the Ridgeline)
HOWEVER: I always ALWAYS add diesel-additive when I fill the fueltank. Not only does it increase Cetane... it also contains lubricant for the fuel-pump and injectors.
The additional Cetane boosts MPG by 2-5MPG... this is a fact!
I have an engine Stutter at 2000 to 2500 rpm when the car goes down hill on cruise and then calls for fuel as the grade starts to climb again. It's a rather violent engine miss and feels like the motor is goling to self destruct for about a second.
However, it only happens on certain brands of fuel. I changed the fuel and air filter less than 10,000 miles ago. As I re-fuel at least once a day on these long drives and use different brands, the effect is sudden and obvious.
Last fill up was at a "Loaf and Jug" in Great Falls Montana, and the car sailed home 8 hours of driving, without a miss and got the best mpg's of the trip. Go figure!
So in effect my anecdotal experiences has been app 425 fills, literally all over the country, but in 15 states and 1 foreign country.
... Have you inspected the camshaft - are any lobes disintegrating at all? PCV/intake clogged?
Also I know for a fact there are huge numbers and percentages of folks that can easily snatch defeat from the jaws of victory. They are also some of those folks that are DAMN fine at what they chose to do.
My 82 of course has maintenance required (valves, timing) and the mechanics with the tools needed have all long since left the scene, which is another reason I'm thinking of selling it if I can and trading my 2011 Mazda Pro for a higher mileage vehicle, but what are the chances I would get a TDI to run fault free over 100K?
Thanks for any comments
I think I would only be saying the obvious, but the difference between 30+ MY diesels and the MY 2012/2013 is in some ways SOS/DD, but literally night and day differences.
Lower compression, albeit less than >/ 25 to 1 compression ratios are to remove the "marbles in a can" sounds. Having said that, the 2003 TDI has (as I recall ) 19/1 compression ratio and does not have those "MIAC" sounds. For a decade or more, modern diesels have been designed to run ULSD. Who knows what ppm sulfur diesel fuel the 1982 was designed to run?
The 2003 Jetta TDI is going on 177,000 miles. It has had the normal TSB's. Unscheduled maintenance has been (non diesel related) change of batteries, windshield, two burnt out brake light bulbs, early drivers side low beam burn out and a just recent 176,000 miles passenger side low beam burn out. New tires @ 112,300 miles Schedule maintenance has been TB/WP change at oem recommended interval of 100,000 miles. It has been on a steady 20,000 to 30,000 miles OCI's, aka oil changed out 6 to 8 times. Air filter has been changed out 2 times. It still gets between 48-52 mpg. (aka 50 mpg). Brake pads and rotors and suspension are oem. The 1.9T and it slightly larger 2.0 TDI's are pretty well tested. The 2.0 TDI with AdBlue right now is probably the best of the breed. EPA H of 43 mpg.
I live in the city, so I prefer to commute via public transportation, but I think my '09 Jetta TDI would make a great commuter car for someone who had to drive to work. The driver's seat is both comfortable and supportive, the interior is well-appointed and nicely finished, the car handles well with minimal road noise, and it's got lots of low-end torque (and of course, a turbo) for passing when needed. All of these attributes should make it a relatively pleasant means of dealing with a typically dreary commute. (Though from what I've read, my enthusiasm might be considerably curbed if I were stuck behind the wheel of a new, "Americanized" Jetta, unless I had to carry extra passengers in the back seat....)
If your first priority is fuel-efficiency, however, and if a good portion of your commute is, as you suggest, truly "stop'n'go", a Prius would likely be a better choice, albeit only if you could adapt to its idiosyncrasies and its decidedly "un-carlike" driving experience. The TDI is an mpg champ on the open road, but it drops back into the pack in city driving. In my area of Queens, where there's a stop sign or traffic light at nearly every intersection, I average only 20 to 25 mpg. The real joy of TDI ownership for me comes during my escapes from NYC, when the car usually gets 40 to 45 mpg, whether on the interstate or on back roads, where it's also quite fun to drive. So even though it wasn't the ideally frugal choice for someone living (and driving) as I do at the moment, I'm glad (so far, at least) that I bought it.
You just have to weigh all the factors relevant to you, and if a TDI (Jetta, Golf, Sportwagen or, soon, Beetle) is still on your short list, then by all means take one out for a good, long test drive!
another possibility is heater-core. (maybe does the smell lessen a bit if you turn the HVAC system *off*? not sure if it would in that case)
but also: there is a spherical coolant resevoir (white plastic i think). inspect it carefully, and all tubes, wires leading into/under it - unplug nearby wiring harnesses - and look for signs of corrosion inside the wiring plugs/harness/conduit. the reason is that resevoir or attachments it can crack and leak coolant *inside electrical wire bundle*, causing major damage.
I wanted TDI, but it wasnt available in'08, I'm very happy with my Jetta though, turbo 4.
However when I took car in for a recall--they found nothing was wrong--I got to drive an '09 TDI (a demo), trip computer read 50 mpg at 70 mph, this car only had 1400 miles on it!
So I think the mileage of the TDI is worth getting vs the 2.5, and it did not seem slow at all with that torque!
Drive a TDI and 2.5 and make your decision.
This would be it about equal to the latest and greatest high MPG gassers, like the Mazda 3 or the Chevy Cruse Eco, but it would have an advantage in driving qualities that's for sure, and probably better resale value. On the minus side, it's going to cost more to buy.
Let's put it this way: the 03 TDI is rated @ 42/49 mpg. I routinely have gotten 50 mpg (range of 48-52) and it continues for app @ the 170,000 + miles. But the real important part: who the H--- cares? The 03 Jetta sold app 9,000 units. FF to 2012 for both torquier and less mpg diesels, and they are selling the best ever (many more units) and at record profits (for VW). Go figure.
Indeed VW took the hint and increased the available torque and it dwarfs even the Camry Hybrid. It even gets 8.2% better fuel mileage. (39.6 vs 36.6, www.fuelconomy.gov) Safely and (in hind sight) WISELY decreased the mpg (conversationally) to app 40-45 mpg.
I say like the VW products, give the Chevy ECO Cruze and Mazda 3, 5 to 10 years. Both models and name plates have only recently gotten serious about performance and mpg. Both were dogs (mpg wise) before this latest effort. Mazda 3 has been in serious need of refreshment and for a longer time.
So for example, the 03 TDI had a diesel premium of MSRP $236. (if I remember correctly) The resale value is 2,532 dollars more for the TDI.
but if you were plunking down $25K for something, you'd probably rely on more than what your neighbor says over the fence, right? You'd check it out.
it's better to be surprised on the + end than the - end I think.
So I believe the 42 mpg # would be "my" number if I bought a TDI and drove it in mixed city/hwy conditions.
I would say no because then in theory you really can't then rely on an real ratings for then you can say no one to only a few can get any rating at any time. This of course is preposterous. So your premise is really a conversational shot gun approach. In effect your underlying assumption is the EPA rating is some sort of guarantee. It never has been and never will be. But then defacto you and most folks know that.
With our '06 Jetta TDI, we've been getting 32-33 mpg, 38-40 mpg, and 44-46 mpg in the above described conditions. (It's fuel mileage has gradually improved every year so far.)
Both are equipped with DSG. Hills, winds, loads, traffic, and road conditions all have an effect on fuel mileage in the real world.
Given these two cars' performance, safety, ride, comfort, price, standard equipment, and reslae value, I can live with the fuel mileage of each. Claims of 50 mpg+ do not impress me, because that is not how, where, or why I drive.
My brother's Jetta TDI is right around 38-40, but he's up at altitude. He loves his car.
While it is still capable of 50+ mpg, you have to drop both the revs and speeds to consistently get it. But then again those are some of the prices for: 300# increased, the DSG vs 6 speed M/T (far less RANGE), changing emissions standards and compliance (differing penalites), and 52% more # ft of torque.
The additional thing is that gassers designers have long been put on noticed that the need to optimize their systems (aka drive train) for the 65 mph speed limit (range of course is anywhere from 45 mph to 85 mph). Obviously there is a double wink wink going on here. One example of the "range" is some pats of the Texas interstate @ 80 mph and soon to be legislated 85 mph. GBT !! The most obvious one most folks care about is mpg. In that sense the small percentage and volume of diesels have long been there. In effect I have taken that for granted from a practical point of view for easily 218,000 diesel miles. Indeed three VW examples are optimized for 81 mph @ 2,200 rpm 6 gear, albeit DSG/ 5/6 speed M/T. Below that (optimization) mph you can really post good numbers as fho2008 did with the 50 mpg @ 70 mph.
I have one gasser that uses a 6 speed M/T to optimize. It has been criticized and draws praise in the same analysis for using a so called "dual gear" over drive type gearing. I am sure there are other examples, but I am not real familiar with the others.
The NHSTA's own accident and fatalities figures confirm that even with higher speed limits, more cars, drivers, mileage, trips, the figures posted are the LOWEST and safest ever since they started recording these things.
With an automatic the 2006 Jettas numbers went from 35/42 to 30/38. Some of the older models are even more efficient, but most still can't beat the best new diesels - Passat 30/43. (Excepton is the 2003 Jetta with a stick that got 35/44 converted, or 42/49 by the old standards)
