Scion tC Problems and Solutions
volcomknurdvolcomknurd Member Posts: 13
edited March 2014 in Scion
i was curious if any current owners of the new tC have had any problems with theirs. i know its a brand new car, but nothing in life is perfect.
«13456711
  • gtwgtw Member Posts: 46
    My daughter got hers July 3 and now has over 1,000 miles on it. No problems what so ever as of today.
    closest thing to a problem might be a slight plastic creak somewhere in the dash when I hit a bump.
    One thing I did notice is that it seems to hold the revs slightly when you shift. That is, when you depress the clutch, it almost seems like I didn't let off the gas fully, even though I had. I used to have a Mystique that had a pronounced case of this (due to holding the revs for emissions reasons). I almost sense it more than hear it, and may just be overly anal about stuff like this, but I have never driven another one to compare.
    Anyone with a 5 speed notice anything like this, or just think I'm nuts?
    This thread will never move to the top of Edmunds most active list ;-). Overall, this is the best put together car I have ever bought (knock on wood). Almost at 500 miles, and getting ready for the second tank of gas.
  • deucedeuce Member Posts: 13
    Funny, I also got my tC july 3, and have just over 1100 miles on it, no problems.
  • tahlequahtahlequah Member Posts: 54
    my tc is doing exactly the same. In fact, it's so pronounced that I'm not yet convinced that the clutch isn't slipping - except for you perfect description of the event, stickguy. It really is felt more than heard and it seems most evident shifting into 3rd. That you experience this, too, makes me feel a little better and that it may be a product of the high rev value, not a fault per se.
    other than that, every other complaint (if you could even call it that) is just cosmetic - and those hardly warrant a mention.
    I just hit 450 miles on my tc (bought July 9). I'm averaging around 25 mpg, 50/50 highway/city. can't complain really.
    at least it's not me. At some point I may ask the service department about it (at the first oil change if not before). IIRC, especially with the drive by wire throttle, cars can be set up to hold the revs for emission reasons. I remember with the Contique it was a common issue, and there was even a remedy (called "moosing") that involved putting a plug in some hose.
    It is just noticable enough to be noticable, if that makes sense, but doesn't really detract from the driving experience. I just notice it.
    Of course, if any owner finds out more about this, post for the rest of us.
    Got a Toyota enthusiast to drive my tc this evening just to double check my concerns RE: clutch activity - seems I'm not the only one having a tough time with a clean shift. They too had trouble with smoothness but remarked that it's a long throw and I shouldn't worry. Still, we're talking about two people who are very adept at driving a stick, both saying essentially the same thing; it's a long throw that doesn't make for a clean shift, especially at higher revs.
    And while we're throwing out complaints, there is actually one other concern I have and that's the "missing" affect most especially on the highway. The enthusiast seemed to believe it's all due to the AC compressor draining the engine but, if that's the truth, it's one helluva drain. Certainly more than I've ever experienced in any other car. I also thought it was the compressor until I turned off the AC and it did it anyway. It does it less frequently and is less noticeable, but it's still there if you drive long enough. (of course, with the friend driving I ran into the "mechanic" scenario: you know something's wrong but the problem doesn't rear its ugly head in front of the mechanic and you end up looking a fool!)
    Any ideas what else it could be besides the compressor? Is it possible that the engine is so hyped to work that a constant 60mph is a bother for it? I suppose that's a stretch. Maybe I'm just not used to a car with so much torque? That seems entirely possible to me.
    I have no idea what the "missing" effect is. Can you describe the sensation? ALmost sounds like you are talking about a miss or a skip, and I haven't noticed anything like that. I will pay attention on Friday when I take another highway run, hopefully without tons of rain.
    By long throws, did you mean the clutch travel is long, or the shifter throws (which I don't consider long)? I notice the rev sensation when depressing the clutch (as if I hadn't lifted entirely off the gas), but have no problems with a clean engage. I also have been pretty gentle with it so far. Once it is fully broken in, I'll play some more with quicker shifts and shifting at higher RPM.
    I believe the tC does have drive by wire throttle, so it is software deciding what RPMs to be at, not the driver's right foot. if thats the issue, its possible that a reflash might be in order. Or we will just get used to it and eventually won't even notice.
    Biggest problem I have with being smooth is going back and forth to my Miata, which has a very stiff clutch with extremely short travel. Great for fast driving, not so great for getting stuck in traffic.
  • rodzillarodzilla Member Posts: 2
    When I am babying the vehicle, due to the long clutch travel, I have a tough time getting a smooth start. When I drive it more aggressively, it shifts a lot smoother. Keep the revs up and it goes without any jerking. Keep shifts under 3K RPM, and live with a choppier ride. Until I pass a 1000 miles, I really don't want to push it. So, I live with rougher starts.
    I think the engine rev when engaging the clutch is for when you downshift. It's blipping the throttle for you to make for a smoother transition. Although, it doesn't quite feel right when it's happening on the upshifts. Personally, I'd prefer to match revs on my own on the downshift and not have the engine rev extra every time I engage the clutch.
    I too ran into the "skipping" thing on the highway. It's a perceptible nudge I can feel when tooling along. Almost as if the engine skipped for a fraction of a second. It is a bit disconcerting. It shouldn't have anything to do with the amount of torque the engine puts out. It's just a wait and see thing for the long term. Hopefully, it's just a software reprogram for both issues.
    Stick shifts owned
    81 DeLorean (Mom's car. Learned how to drive a stick on this.)
    81 Trans Am (M21. Heavy duty racing clutch. Brutal workout.)
    80 Chevette (What do you expect for 50 bucks?)
    90 Maxima (Very nice and connected feel)
    00 Maxima (Ugh. Not very forgiving.)
    Smoothest and nicest clutch so far was a test drive in an 04 Mazda3S. It is just about the nicest stick I've driven. Supremely forgiving. Unfortunately, the price difference and a lack of adjustability in the seating tipped the balance in favor of the tC. Or maybe I should say fortunately :)
    I have no idea what the missing effect is. Can you describe the sensation?
    It's missing like I've put "bad" gas in it. But it's worse than that - I shouldn't say worse, just more pronounced than if it were simply bad gas or the compressor.
    The clutch travel is long.
    Yes, that's what it's like EXCEPT the engage is blunt, for lack of a better word. If I depress really slow (I mean really slow), it will catch cleanly (all the while revving as if I'm still on the gas), but to depress as one would normally, it's a jerk, especially in 3rd.
    I believe the tC does have drive by wire throttle, so it is software deciding what RPMs to be at, not the drivers right foot. if thats the issue, its possible that a reflash might be in order. Or we will just get used to it and eventually wont even notice.
    What does the drive by wire throttle do exactly?
    I've been driving a stick since '83. I've logged hundreds of thousands of miles, literally - 80,000 in one year! I've never burned out a clutch nor have I ever had trouble shifting the way I do in this tC. I suppose some adjustment time (on my part) is to be expected but this isn't coming to me quickly. But, in all fairness, I've never owned or driven a car with this hp and torque before so I'm assuming I am the problem at this point.
    Thanks, Rodzilla. It's true that the shift is easier at higher rpms, even still, I'm feeling inadequate because I have never had a car behave this way.
    I'm glad to know you've experienced the skipping/missing effect. Sorry that it's happening to you but glad that you know what I'm talking about. It is disconcerting indeed.
    I must have bought the only lemon Mazda ever made. I traded my 03' 6i for my tC. It was six months old with 3000 miles! It handled okay but what a nightmare that thing was otherwise. From the moment I drove it off the lot things went wrong. First time I waxed it, the paint on the trunk at the corners of the spoiler chipped off. That was the first paint job. Two months later, it happened again. That was the second paint job. By then, the dealer was so pissed at the body shop that they sent it to another body shop to have it painted a third time (KY's lemon law is four strikes...not three). In between all this there were brake issues (the pads were loose so they had to be replaced, that was at 1000 miles and the calipers were wasted), two recalls and a myriad of other things. I lost some $$$ dumping it but it was so worth it when I saw the tC.
    What's your rpm in 5th gear when you notice this missing?
    I'm wondering if you are prematurely in overdrive. If you are trying to use 5th gear below 2,000 rpm this could explain the problem.
    the way the tC is geared, that would be about 40 MPH.
  • mackabeemackabee Member Posts: 4,709
    Guys, one thing about the engine in this car is the VVTI or variable valve timing with intelligence. Here's a short explanation about the intelligence part, it is not science fiction, it is fact. The engine and computer in this car actually "adjust" to your way of driving over time. If you like to drive quick and fast the software "remembers" your inputs. Same goes for the "granny" drivers. It remembers those drive inputs. The throtlle has the ETCS-i or electronic throttle control system with intelligence. Same concept as the engine. Also remembers your inputs, the drive by wire portion does away with the throttle or accelerator cable and is replaced by an electronic sensor which is very fast acting to your input on the accelerator. Next time you drive the car notice how fast it responds when you press the accelerator.
                       Mackabee
  • wolfxwolfx Member Posts: 72
    Yes, stickguy, 2000 rpm would be about 40 mph and I'm feeling the miss regardless of either. The only factor I've found thus far is the AC but, like I said, even with it off the miss is still there just less so.
    Mack, everything you said makes sense. My question now would be: do I simply drive the tC like I drive my other cars and wait for the tC to adjust to me or is there a better approach? In this break-in stage, I am reluctant to do anything that might compromise the car. I'm only at 485 miles.
    And, yes, I had noticed the quick accelerator response very early on. So soon, in fact, that I thought perhaps the miss I was feeling was a result of some inability on my part to hold a steady accelerator pedal. But, when I got out on the highway and switched to cruise control in as flat a stretch as I could find, I thought differently. Is this also a product of VVTi?
    Well if you are in fact at 2,000 rpm in 5th gear and you romp on the gas, you would be putting quite a load on the engine ("lugging") and you will get a protest from the engine I'm sure.
    If this miss occurs in all gears and regardless of rpm that's another matter. That's a problem.
    You could probably start driving it the way you usually drive and not hurt anything. This vvt-i is very intelligent! Have fun and enjoy!
                          Mackabee
  • dat2dat2 Member Posts: 251
    I have tested the tC with manual twice now, both times I noticed a poor throttle response, mainly off idle. It seemed to take measurable split seconds for the engine to respond while idling. Does this also occur while driving, such as downshifting. I am comparing to my '96 nissan 240sx which responds brilliantly to blip throttle downshifts, how does the tC do in the situation??
    Can anyone confirm the drive-by-wire throttle? I have heard some say it is normal throttle cable and others say it has the drive by... Thanks!
  • mpls_xbmpls_xb Member Posts: 1
    I spoke with a Scion 'customer advocate' (1-866-70-SCION). They were not able to confirm electronic throttle on Scion, specifically xB.
  • ocelotevaoceloteva Member Posts: 5
    From Car and Driver
    "...Powering the tC is the Camry's 2AZ-FE 2.4-liter four-cylinder, a sophisticated engine with an aluminum block, a magnesium cam cover, electronic throttle control, and variable intake-valve timing."
    I think it has very quick throttle response. Maybe you aren't coming off the clutch as quickly as you think?
    Also, for the rev holding question, was driving last week when it was cool, and did not notice it at all. Wonder if it is something in the ECU mapping related to temperature?
    I noticed the poor throttle response in blip-throttle downshifts, it is slow to blip, i think this must be related to the electronic throttle. For example, when slowing down for a corner, or in corner, blipping the throttle to not affect the transfer of weight in the dynamics of the car...
    So, what does it mean when you let out the clutch and the steering pulls to the right?
    It's a Republican?
    Actually, that's normally the result of torque steer. I haven't noticed any, but I haven't really nailed it from a start. The other thing to consider is that the widish tires are more sensitive to nuances in the road. In any case, just steer left ;-)
    Anyone notice if their parking brake has to be yanked all the way up to hold? On mine, it goes way up, and pretty much has to be on the last notch to hold the car (which it then does just fine). Just wondering if this is normal, or I should look into an adjustment.
    I might just be used to cars that only have a few clicks and don't need to be pulled up real far.
    Yep, torque steer, especially if you nail it with the wheels slightly turned to begin with.
    AH, well.....that explains that, then. Now tell me, is this normal? The wheels usually are at an angle but I'm not nailing it by any means. I don't think I've ever had this experience before....then again....I've never had a car like this before. That's why I seem ultra paranoid: just trying to find out what's me and what's the car.
    Ya'll are a HUGE help. Thanks. Although I hope my car is not a Republican.....but I digress......
    And you're not kidding about the nuances of the tires! I'm not complaining, just confirming.
    Well some FWD cars torque steer worse than others, but all of them do to some extent. Depends on design and on power output. Also how you drive. I've felt torque steer on cars where the owners never mention it or insist it isn't there---but it is.
    Might be good for you to drive another identical car and see for yourself if anything strange is going on.
  • carguy79carguy79 Member Posts: 23
    I have had my 5 speed tC for a week now. I too have the revs between shifts, nut I am not concerned, my 98 Nissan 200sx did the same thing and the clutch is still working perfectly at 98000 miles. I have heard an interior noise especially when car has been sitting and I have to back out of my driveway into the street. Sounds like some flexing to me. It is a great handling car, second to none in its category
    did you drive a 200sx se-r? how does the handling of the tc compare if so? i know the 200sx se-r was not as hard core as the original se-r but it was still supposed to handle pretty well. also, does the tc seem any faster?
    stickguy - I'm not having the same experience with my hand brake that you described. It seems of normal operation to me.
    i have noticed you have to pull the brake almost all the way up on my tc also.
    hmmmmmm are ya'll parking on an incline? Maybe that's why I haven't noticed anything unusual - the parking lots where I land are flat. Haven't had an incline experience yet.
  • mougenotmougenot Member Posts: 4
    Is it true that the buying process of a Scion is the same as buying a Saturn? No room for bargain?
    It's true. But, you're only paying $500-700 above invoice (not much of a mark-up!). It seems that most dealers are giving great trade-in rates. That seems to be softening the blow of "no haggle" pricing for some. I know I got well above my book value when I traded.
    However, for those folks who apparently relish a good round of haggling, they seem quite disappointed that Scion offers a great bargain on a top quality car at a cheap, cheap, cheap price. But you can't please everyone, now can you? I am not one of those people so I thoroughly enjoyed and appreciated the "no-haggle" approach.
    Understand also that the accessories are overpriced, or so it seems to many (myself included). Options appear to be Scion's best bet for profit. Be aware, though, doc fees in some parts of the country seem suspect - unusually high.
    no my 200sx was not a se-r. The tC handles alot better, I expect that the vehicle is faster than my 200sx even though I have not gotten too hard on it since it doesn't have many miles on it
  • dulanicdulanic Member Posts: 4
    For the noise you hear, if it is a popping/snapping noise, it's a common problem. You may also notice it taking corners especially uphill and uneven surfaces when the car flexes. There will be a service bulletin put out sometime soon for it, there are a few bolts in the roof that are backing out. It's a simple fix, and Im taking mine in to be fixed. All they have to do is torque down 2 bolts and they have been using Lock-tite to prevent them from backing out.
    that's the noise. Someone else posted about tightening some screws, which sounds logical.
    If you get it done, please post details and TSB # if there is one.
    I'll check at my dealership tomorrow if the TSB is out. I asked this on the other thread, if you guys having the noise problem (and girls too) please list the last four numbers of your VIN. My son's is 1250.
                     Mackabee
    There is no TSB yet. It may still be a little while before there is.
    If it affects lots of cars then it will be out shortly. Toyota doesn't sit on their laurels when it comes to safety or technical bulletins.
                 Mackabee
    posted on the other thread that mine is 2717
  • charchar Member Posts: 18
    My VIN is 6478. Thanks Mackabee!
  • tcwhite47tcwhite47 Member Posts: 1
    My noise problem is allegedly the hatch stays (shocks). The car has been in three times now and they are waiting for a TSB. The noise is a sort of rattle, plastic sounding, and can be continuous. It is worse with more light and heat. The first time it was in they took the roof apart and said they fixed it. They couldn't have test driven it because it was the same. The next two times they just drove it to see what it was. They have another tC with a roof noise problem. I called Scion after the second visit because I was concerned my problem wasn't the same as most of the other noises described. It started two weeks after I bought it. I now have a "case" opened. Vin #2455.
  • luvmytcluvmytc Member Posts: 1
    Yes!...Isn't it great that the vehicles are already priced low. God I hate having to haggle. It was soo painless. Screw the honda civics! The one I priced(21.400) was way over what I paid for the Tc(17,600). Opted to get the extended warrenty since it is the first model year. Not a single complaint. Smoked my first honda SI last night. You cant find a better bang for the buck! I had to drive 2 hours to St. Louis and managed to get the last one! What a bad [non-permissible content removed] car!
    3539
    What do the last 4 digits signify?
    the last digits (probably last 6 actually) are the sequential number assigned to each car. Most of the vin is the same for all of us, signifying model year, model, where made, etc. The last set is unique to each car, so you have the 3,5XX one made.
  • pdm72pdm72 Member Posts: 11
    A while ago someone mentioned that there was a fix for the roof rattle--I have a couple of questions about that. I have not yet taken delivery, and expect to in about 3 weeks. I'm wondering whether a) whatever was causing it will likely have been addressed in production yet, and b) assuming it isn't, what can I request the dealer do before I pick it up so whatever the bolt problem was is already taken care of. I'd like to be able to request something specific--my dealer is not conveniently located, so I'd prefer not to have to take it back to fix something if they know how to prevent it already.
    Also, would people who've had the sub/spare tire issue recommend getting an aftermarket sub instead? I know it's not a huge deal, but still. . .
  • zero260zero260 Member Posts: 14
    I just recieved my tC 5 days ago. I noticed a rattle on the driver's side door whenever i pass over bumps or bumpy roads. Has anyone had any similar experience? My sun/moonroof seems to be working flawlessly...
