Scion tC Problems and Solutions
i was curious if any current owners of the new tC have had any problems with theirs. i know its a brand new car, but nothing in life is perfect.
One thing I did notice is that it seems to hold the revs slightly when you shift. That is, when you depress the clutch, it almost seems like I didn't let off the gas fully, even though I had. I used to have a Mystique that had a pronounced case of this (due to holding the revs for emissions reasons). I almost sense it more than hear it, and may just be overly anal about stuff like this, but I have never driven another one to compare.
Anyone with a 5 speed notice anything like this, or just think I'm nuts?
other than that, every other complaint (if you could even call it that) is just cosmetic - and those hardly warrant a mention.
I just hit 450 miles on my tc (bought July 9). I'm averaging around 25 mpg, 50/50 highway/city. can't complain really.
It is just noticable enough to be noticable, if that makes sense, but doesn't really detract from the driving experience. I just notice it.
Of course, if any owner finds out more about this, post for the rest of us.
And while we're throwing out complaints, there is actually one other concern I have and that's the "missing" affect most especially on the highway. The enthusiast seemed to believe it's all due to the AC compressor draining the engine but, if that's the truth, it's one helluva drain. Certainly more than I've ever experienced in any other car. I also thought it was the compressor until I turned off the AC and it did it anyway. It does it less frequently and is less noticeable, but it's still there if you drive long enough. (of course, with the friend driving I ran into the "mechanic" scenario: you know something's wrong but the problem doesn't rear its ugly head in front of the mechanic and you end up looking a fool!)
Any ideas what else it could be besides the compressor? Is it possible that the engine is so hyped to work that a constant 60mph is a bother for it? I suppose that's a stretch. Maybe I'm just not used to a car with so much torque? That seems entirely possible to me.
By long throws, did you mean the clutch travel is long, or the shifter throws (which I don't consider long)? I notice the rev sensation when depressing the clutch (as if I hadn't lifted entirely off the gas), but have no problems with a clean engage. I also have been pretty gentle with it so far. Once it is fully broken in, I'll play some more with quicker shifts and shifting at higher RPM.
I believe the tC does have drive by wire throttle, so it is software deciding what RPMs to be at, not the driver's right foot. if thats the issue, its possible that a reflash might be in order. Or we will just get used to it and eventually won't even notice.
Biggest problem I have with being smooth is going back and forth to my Miata, which has a very stiff clutch with extremely short travel. Great for fast driving, not so great for getting stuck in traffic.
I think the engine rev when engaging the clutch is for when you downshift. It's blipping the throttle for you to make for a smoother transition. Although, it doesn't quite feel right when it's happening on the upshifts. Personally, I'd prefer to match revs on my own on the downshift and not have the engine rev extra every time I engage the clutch.
I too ran into the "skipping" thing on the highway. It's a perceptible nudge I can feel when tooling along. Almost as if the engine skipped for a fraction of a second. It is a bit disconcerting. It shouldn't have anything to do with the amount of torque the engine puts out. It's just a wait and see thing for the long term. Hopefully, it's just a software reprogram for both issues.
Stick shifts owned
81 DeLorean (Mom's car. Learned how to drive a stick on this.)
81 Trans Am (M21. Heavy duty racing clutch. Brutal workout.)
80 Chevette (What do you expect for 50 bucks?)
90 Maxima (Very nice and connected feel)
00 Maxima (Ugh. Not very forgiving.)
Smoothest and nicest clutch so far was a test drive in an 04 Mazda3S. It is just about the nicest stick I've driven. Supremely forgiving. Unfortunately, the price difference and a lack of adjustability in the seating tipped the balance in favor of the tC. Or maybe I should say fortunately
It's missing like I've put "bad" gas in it. But it's worse than that - I shouldn't say worse, just more pronounced than if it were simply bad gas or the compressor.
The clutch travel is long.
Yes, that's what it's like EXCEPT the engage is blunt, for lack of a better word. If I depress really slow (I mean really slow), it will catch cleanly (all the while revving as if I'm still on the gas), but to depress as one would normally, it's a jerk, especially in 3rd.
I believe the tC does have drive by wire throttle, so it is software deciding what RPMs to be at, not the drivers right foot. if thats the issue, its possible that a reflash might be in order. Or we will just get used to it and eventually wont even notice.
What does the drive by wire throttle do exactly?
I've been driving a stick since '83. I've logged hundreds of thousands of miles, literally - 80,000 in one year! I've never burned out a clutch nor have I ever had trouble shifting the way I do in this tC. I suppose some adjustment time (on my part) is to be expected but this isn't coming to me quickly. But, in all fairness, I've never owned or driven a car with this hp and torque before so I'm assuming I am the problem at this point.
I'm glad to know you've experienced the skipping/missing effect. Sorry that it's happening to you but glad that you know what I'm talking about. It is disconcerting indeed.
I must have bought the only lemon Mazda ever made. I traded my 03' 6i for my tC. It was six months old with 3000 miles! It handled okay but what a nightmare that thing was otherwise. From the moment I drove it off the lot things went wrong. First time I waxed it, the paint on the trunk at the corners of the spoiler chipped off. That was the first paint job. Two months later, it happened again. That was the second paint job. By then, the dealer was so pissed at the body shop that they sent it to another body shop to have it painted a third time (KY's lemon law is four strikes...not three). In between all this there were brake issues (the pads were loose so they had to be replaced, that was at 1000 miles and the calipers were wasted), two recalls and a myriad of other things. I lost some $$$ dumping it but it was so worth it when I saw the tC.
I'm wondering if you are prematurely in overdrive. If you are trying to use 5th gear below 2,000 rpm this could explain the problem.
Mackabee
Mack, everything you said makes sense. My question now would be: do I simply drive the tC like I drive my other cars and wait for the tC to adjust to me or is there a better approach? In this break-in stage, I am reluctant to do anything that might compromise the car. I'm only at 485 miles.
And, yes, I had noticed the quick accelerator response very early on. So soon, in fact, that I thought perhaps the miss I was feeling was a result of some inability on my part to hold a steady accelerator pedal. But, when I got out on the highway and switched to cruise control in as flat a stretch as I could find, I thought differently. Is this also a product of VVTi?
If this miss occurs in all gears and regardless of rpm that's another matter. That's a problem.
Mackabee
Can anyone confirm the drive-by-wire throttle? I have heard some say it is normal throttle cable and others say it has the drive by... Thanks!
"...Powering the tC is the Camry's 2AZ-FE 2.4-liter four-cylinder, a sophisticated engine with an aluminum block, a magnesium cam cover, electronic throttle control, and variable intake-valve timing."
Also, for the rev holding question, was driving last week when it was cool, and did not notice it at all. Wonder if it is something in the ECU mapping related to temperature?
Actually, that's normally the result of torque steer. I haven't noticed any, but I haven't really nailed it from a start. The other thing to consider is that the widish tires are more sensitive to nuances in the road. In any case, just steer left ;-)
I might just be used to cars that only have a few clicks and don't need to be pulled up real far.
Ya'll are a HUGE help. Thanks. Although I hope my car is not a Republican.....but I digress......
And you're not kidding about the nuances of the tires! I'm not complaining, just confirming.
Might be good for you to drive another identical car and see for yourself if anything strange is going on.
However, for those folks who apparently relish a good round of haggling, they seem quite disappointed that Scion offers a great bargain on a top quality car at a cheap, cheap, cheap price. But you can't please everyone, now can you? I am not one of those people so I thoroughly enjoyed and appreciated the "no-haggle" approach.
Understand also that the accessories are overpriced, or so it seems to many (myself included). Options appear to be Scion's best bet for profit. Be aware, though, doc fees in some parts of the country seem suspect - unusually high.
If you get it done, please post details and TSB # if there is one.
Mackabee
Mackabee
What do the last 4 digits signify?
Also, would people who've had the sub/spare tire issue recommend getting an aftermarket sub instead? I know it's not a huge deal, but still. . .
