2007 Toyota Camry
18990929495102
  • vadpvadp Member Posts: 1,025
    The MAINT REQD message reffers to oil changes only and nothing else.
    Well, apparently Toyota has opted for a fixed oil change interval of 5,000 miles which is still very conservative.
    The system doesn't monitor your driving conditions.
    Very surprising, to say the least, since a good number of manufacturers are already installing the "Smart" monitoring systems in most of their models, and were doing that for years.
  • patpat Member Posts: 10,421
    I had a prior post bookmarked, but it was zapped because Edmunds reconfigured the topics.
    It probably was just moved, not exactly zapped, but yes, that would have zapped your bookmark. A search at the Camry group level should find it, but if not, email me with all the specifics you can remember and I'll see if I can find it for you.
  • pageniepagenie Member Posts: 2
    We are planning to purchase a 2007 Camry LE.
    Why? Because we are trading in a 1996 Camry (I still love this car! It finally developed an oil leak that we don't want to invest in since the fix could be temporary.) The one problem that I have with the '96 is with the defroster. We got the car second-hand so I don't know if there was always a problem or not but the defroster is terrible. I've been very near having a wreck because of it's lack of efficiency.
    How is the defroster in the 2007? Improved, I hope. Does it still work off of the air conditioner?
    What is meant by "panic features" included on the keyless entry system?
    Moving up from a '96 Camry and never had keyless entry before.
  • 210delray210delray Member Posts: 4,721
    Thanks Pat for the tip. I'll look it up first.
    I had only bookmarked it (someone else's post), because it was a detailed description of how to reset the light.
    I have had a 1997 Camry, and now own both a 2004 and a 2005. The defrosters in all 3 worked fine. All cars today use the air conditioner (except near or below freezing temps outside) to assist in defrosting.
    It's simply a button that you press to make the car's horn and lights flash.
    The idea is if you see a thug fiddling with your car, you can scare him off (while keeping a safe distance) by activating the button.
    You shouldn't use it to try to find your car in a crowded parking lot. ;)
  • dan4pwcdan4pwc Member Posts: 8
    i have a quastion but i dont know where i should posted anyway your feedback is apretiated.my camry is Japan maid and i have it for last 2 months recently (4 days ago exactly) i observed that under the trunk in both side its to bulky pices of metal with perforation on them i think they are for instaling the TOW HITCH but i'm not sure and in parking where i park my car its 3 more camry none of them has this 2 pices anybody knows any thing did you ever saw such a thing.
    These are the pictures coments are welcome
    http://www.carspace.com/dan4pwc/Albums/Camry%20Le%20HITCH/
  • lameanolameano Member Posts: 1
    Hi, my wife has a 2007 camry and I have try 4 times to hold the odometer button (not on A or B) and start the engine and the darn "maintenance light" is still there...what can I do?? Did toyota change it for the 2007?
    Browse around, or google, for wwest and defog for the answer to that one.
    In short the engineers at NipponDenso(***) have NOT a clue, ABSOLUTELY, as to how to prevent fogging of the windows/windshield nor how to most quickly defog/demist (nor even SLOWLY for that matter) a windshield during cold weather.
    IDIOTS ALL...!!
    ***The principle supplier of automatic climate control designs/products for the asian market with serious beach-heads in the US via Denso US. Luckily the europeans are a lot smarter than even we.
    And no, there has been no substantial improvement since the early ninties when I first encountered this problem in my brand new 1992 LS400.
  • jack47jack47 Member Posts: 312
    The defroster on my 1995 LE Camry works just fine.
    In fact the whole damn car runs so well that I keep postponing buying a new one.
    Here's how to do it, from "moeharri" in 2005 (I don't believe the procedure has changed for '07 models):
    Turn the car off, hold the trip/odometer stick and keep holding it while turning the key to accessory/on position (you don't need to start the car). Keep holding it until you see the odometer count down from like 5 to 0 or so--you'll know when it's reset.
    The odometer has to be in the normal mode (not trip A or trip B mode) to begin with. As you hold the "stick" in, the odometer will count down from 5 or 6 dashes to blank, and then the actual mileage will show again. At that point, release the stick and the light should go out.
  • eroc69eroc69 Member Posts: 56
    Dont know if this is the right thread but here goes.
    When I stomp on the gas, the tires Turanza EL-2s or something dont spin as much which is a good thing BUT the front end hops sooo that it sounds like the car is on hydraulics and Iam hopping the front end. That is probably not a good thing but I thought the tires would spin better and not jump so much. That also makes the dash sound like Iam jumping on it, that cant be good right??
  • junzou68junzou68 Member Posts: 2
    Hi, I'm wondering if anyone else is experiencing the same problem. My 2007 Camry LE (4 cylinder) is averaging 25mpg highway, and 23mpg with 50% local. I used to have a 1998 Camry, and it was getting 30+ highway AND local. Is it possibly a defect with 2007 Camry?
  • stlpike07stlpike07 Member Posts: 229
    Your mileage is better than mine, so consider yourself in good shape. I have only gotten 25mpg once......the rest of the time it ranges from 18-21 mpg which I think is EXTREMELY low.
    My '98 Camry consistenly got 25-28 mpg all the time.
    18-21 mpg is indeed low. Are there any recourses you can take? Shouldn't this be considered a defect?
    I don't know about any recourses. If you hear anything please let me know. I was hoping for at least 5+ more mpg. I'm kinda dissapointed about this issue.
  • virusvirus Member Posts: 21
    I'm curious about this. The ES350 and the Avalon both require premium fuel and both have the same hp/tq numbers. The Camry has the same exact engine, requires 87, but has 4 less hp and 6 less tq numbers. One would assume that simply using premium would also achieve the same numbers. My previous Maxima lost around 7hp and 9tq if you used 87 octane and mileage went down between 8-10%. Both the Maxima and Altima have lower compression ratios than the Camry. With all of this in mind here are my questions.
    1) Why is there no mention of "the use of premium fuel will increase performance"?
    2)Will the use of premium gas increase performance?
    3) Will it increase mileage slightly?
  • gbabalukgbabaluk Member Posts: 70
    1) Why is there no mention of "the use of premium fuel will increase performance"? Yes.
    2)Will the use of premium gas increase performance? Yes
    3) Will it increase mileage slightly? Yes.
    This is all a "marketing" gimmick from Toyota. Lexus ES350 and Avalon are supposedly "luxury" cars and the owners of these cars are more likely to purchase "premium" gas than the "Camry" owners.
    I have used premium in my SE V6 from day one.
    Have a great day!
    I would also like to know if Toyota reworked the ECU fuel/air ratios and mappings to allow the 87 octane? I just find it very hard to believe a car with a 10.8 compression ratio only needs 87 octane. I'm also wondering if the performance difference to include mpg is enough to offset the 20 cent price difference? It definately did in my previous Maxima. I just don't want to use premium if it's not necessary because once you start using it, you cannot go back without knocking and pinging once you have been using it for a while.
  • coloroncoloron Member Posts: 14
    We have the exact same dash rattle in our 07 XLE. Very annoying and of course the dealer doesn't hear it. We also have a scraping/thumping sound from the rear when going over bumps like speed bumps which extend the rear suspension. It took 3 trips to the dealer to get them to even "hear" that problem. Toyota must go out of their way to hire techs who are hard of hearing. They did lots of lubing but nothing has helped.
    I have an 06 4Runner and this 07 Camry. We bought both based on Toyota's reputation for quality. We've been very disappointed. The Camry is loaded with moans, groans and rattles. The 4Runner transmission makes an annoying howling/whining sound at various speeds along with other mysterious thumps, bumps and rattles.
    I know every manufacturer has an occasional problem but Toyota's refusal to fix their mistakes (such as the numerous 4Runner issues) by calling them "normal characteristics of the vehicle" is just criminal. I'll think twice before buying Toyota again. I've had better luck with our old cheap Chevys!
  • kdhspyderkdhspyder Member Posts: 7,160
    Searching for which crime was committed... searching...searching...
    A little over the top maybe in your comments.
    Well, you'll be happy to know (laugh) that the CEO of Toyota publicly apologized in both August 2006 and January 2007 for all their quality problems.
  • slim2slim2 Member Posts: 20
    I have a 2002 Camry Le with 15" wheels. I am looking at the '07, but notice it comes with 16" wheels with lower profile tires. My '02 rides great. How can increasing the steel diametewr while reducing the rubber in the 16" wheels tires improve the ride ? Why are all the car makers going this way ?
    Bigger wheels are in. Plus it makes it possible to increase the size of the brakes, which is a good thing.
    You may notice a ride difference going from the 205-65R15 tires in your current car compared to the 215-60R16 tires in the '07 Camry. But it won't be because of the tire size, but rather the tire brand and possible suspension changes.
    I did some research online and there were pros and cons most agreed on. Harsher ride is one of the cons. Most pros said styling, handling and braking. Since I bought my '02 Camry for ride (along with the usual quality traits), I must say I will now research car makes that at least have the option of standard profile tires. Sorry Toyota, if that leaves you out, but Camry had a dang good ride, and I don't give a hoot about style in my tires.
    You should ride in the 2007, it's not just the tire size that makes a nice ride.
    I will give it a try, but I will be more likely now to compare it to the same year in one of their competitors if they offer the higher profile tires. When I was younger, perfomance might have been the priority, now it's how the potholes feel.
    You really need to compare directly, because 60 series tires (with a slightly wider tread) aren't going to differ very much from 65 series tires.
    Now if you're talking about 18-inchers with the 40 series tires, that's another matter entirely!
    FWIW, I have both the 15-in. stock steel wheels and replacement all-season tires on my '04 Camry (winter use) and 16-in alloy wheels from an Avalon identical in size to those of the '07 Camry (rest of the year). I can honestly say there's no difference in the ride.
    Thanks for the info
  • ahsanman99ahsanman99 Member Posts: 28
    you need to go and buy a honda accord.hondas have way more relibility then crapy toyotas and better quality and sportiness.i own 89 accord with 370k miles on it and 94 accord with 252k on it and 91 acura integra with 170k on it and have no problems.
    ahsanman99,
    If you don't mind me asking, where do you drive every day that you would rack up that many miles?
    To those who claim that Honda is so much better than the "crappy" Toyota.
    Please be honest, and at least somewhat informed.
    Every first year production vehicle has problems.
    The current Accord when it just came out, had numerous problems in its first year.
    The same thing is applicable to the Civic.
    Most of the 2007 Camry problems will be (already in the 4 cyl model) taken care off by the time it completes its first year on the market.
    And to those who've bought their Camrys during the first 6 months after its introduction - I feel your pain.
    Next time wait at least a year.
    BTW, if you're so "fed up" with the "Crappy Toyotas" and willing to jump the ship this coming fall/winter just to get the freshly redesigned Accord, you'll be doing the exact same mistake all over again!!!
    Thank you vadp......Good post.
    And, to everyone saying, "The Japanese CEO appologized publicly........" ok, your point is? Japan is a very collective, high-context culture so it is very normal for someone to do that. The standards of quality are generally higher than in the US anyway...
    The problem IS toyota dealers not admitting that some people are having problems. I have friends with new bmw's and mercedes and even their dashes rattle sometimes. They aren't having the transmission problems (which other car companies are).
    If there is a TSB out for a vehicle problem the dealerships need to honor it and perform the TSB. I think people are so upset because of how they are being treated by the dealers. Any toyota dealer can perform a TSB, so I suggest that if one dealer is troublesome that you try another.
    ahhh, the thing is, the system is probably geared against the dealer doing any work unless they have to.
    i'm thinking, if toyota corporate wanted the people with problem cars to be taken care of, they would be.
  • joanfromzone6joanfromzone6 Member Posts: 1
    the current issue of consumer reports listed ford fusion as having a better reliability record than camry - tell me it ain't so -
    The Fusion is based on the proven Mazda6 platform which has been on the market for quite a while already.
    The Camry is a brand new design in its first year of production.
  • honda00honda00 Member Posts: 29
    It appears that alloy wheels do not come standard with a 4 cylinder LE.
    The Toyota website says that 7 spoke alloy wheels are an available option to replace the wheel covers that come with the LE model. However, when you try "build" a camry on their website, the only option that appears are 15 spoke aluminum alloy wheels for $795.
    I haven't really been to a dealer to see what is on hand, so can anyone tell me if it's common to see 4cyl LE's on the dealer lot that have alloy wheels?
    Option availability will depend on the region of the country you're in. Toyota has 12 regions, and the fine print says "not all options or option packages are available in all regions."
    That's why when you "build" a Camry, it asks for your zip code, which in turn, selects the proper region. So apparently, only the 15-spoke alloys are available for LE's in your region.
    My guess is that the bulk of LE's (4-cylinders at least) are ordered by dealers with standard steel wheels. But the only way to find out is to contact dealers in your area. Some are more willing than others to acquire cars from other regions.
  • lmacmillmacmil Member Posts: 1,758
    I know it's a different engine but the 3.3L V6 in my 2005 SE gets better mileage on premium (determined via a 2000+ mile trip.) Just about enough to offset the increase price. Can't tell any difference in performance, probably need to go the drag strip for that. Psychologically, it's worth it :)
  • imidazol97imidazol97 Member Posts: 27,790
    Why would they not allow option packages the same everywhere inside US?
  • jaxs1jaxs1 Member Posts: 2,697
    You are probably going to get better mileage on a 2000 mile road trip anyway.
    Unless you have identical controlled conditions to compare mileage, it is junk science to say you determined premium fuel increased fuel economy enough to pay for the extra cost of gas (or at all).
    Toyota has separated itself from retail sales by allowing the regional offices ( two are independent from Toyota ) to decdide what sells in a specific geographic area.
    It works very well. In the flat coastal areas where weather is moderate 2WD vehicles predominate. In NE and the Rockies it's 4WD vehicles. In this way no region is forced to take vehicles it can't sell. To keep the process simple the local region chooses only the options that make sense in that market. It serves the greatest number of buyers with the fewest variations.
  • djm2djm2 Member Posts: 712
    kdhspyder:
    You are correct in your posting. Prior to purchasing my 2007 V6 Camry, I wanted a 2007 V6 Rav-4 in a 2WD. I could not get this vehicle in my area of the country.
    QUESTIONS: What is the point of having the option and trim level in their catalog, when they do not make it available to the customer? If I cannot purchase the vehicle that I want, what is the point of the process? I don't care about the logistics of the company, I am paying for the vehicle, so I should get any vehicle that is in their catalog. I purchased the Camry because of the comfort of the seats, but I am not sure that I will purchase another Toyota product in 2010, (or sooner)! This marketing issue and their V6 transmission issue doesn't speak well for the company! While my vehicle does not have the trans problems,(that are posted on this site), and it presently has 2300 miles, I am very disappointed with the quality of product when I read about the problems being experienced by other owners. If I had to make this purchase again, I might have purchased a loaded Impala or Buick! Toyota had better wake-up and listen to their customer base. This trans issue along with the past sludge issue could be the demise of their total image. Any company can have a problem with a product, but what separates one company from another, is what they do about the problem, and how they deal with the customers. This marketing practice and trans issue is not adding to their professional corporate image! To be successful in business, give the customer what he / she wants at a price. Don't dictate to a customer and don't stone wall the customer when there is an issue with the product! --------- Best regards. ------- Dwayne ;) :confuse: :shades: :)
  • kyrptokyrpto Member Posts: 216
    Toyota is poised to become the leading auto/truck company on planet earth.
    They have a commanding lead in hybrid technology [I own one] and their new trucks will take a deeper bite out of the big three.
    Toyota/Lexus also leads the way in advances in safety, where Mercedes used to be the benchmark.
    "Toyota had better wake-up and listen to their customer base. This trans issue along with the past sludge issue could be the demise of their total image."
    Toyota is fully awake - a few glitches with a new model isn't going to de rail this juggernaut.
    Other auto makers keep setting the Camry as their target - maybe in another decade the big 3 will figure out the formula.
    Regarding the choices it's a question of productivity and inventory balance. When there are unlimited options to choose from the factory then becomes a boutique. In a huge industrial operation this is death on quality. Honda is the extreme. Choose your color and choose your trim..you get no other choices.
    One of the features that the detroiters are trying to copy from Toyota and Honda is the production method that keeps tightening tolerances as time goes by. If the production has to be stopped, diverted, restarted to produce onesies and twosies of a product then then quality suffers. It's no mistake that Toyota and Honda have been known for bland center-of-the-market type vehicles. It's intentional. This is where the most volume is and this is where they can run the lines with the same products day after day after day.
    This is a small country really. Buyers complaining about the NE region or SET or GST only have to hop a short flight and get a better deal or exact vehicle from somewhere else. Buyers do it all the time.
    Transmission concerns on the '07 Camry. I'm happy that you've not experienced any of the posted issues. What if you are in the vast majority of owners? In fact I know that you are. The new '07 Camry has over 450,000 new owners. In total the complaints to the NHTSA is....35 !!
    The owners that do have problems deserve to be happy. IMO it is a very very vocal minority on the internet with the HUGE HUGE majority of satisfied owners never even considering a post. I know at least 20 people with the new '07s and none have any of the experiences being posted here. Hesitation yes, my own '07 Solara does it...somewhat... but nothing to complain about.
  • mdchachimdchachi Member Posts: 275
    The solution here is to not make the entire catalog available to the general public. That way you'd never see the options that are available to the regions and not know what you're missing. I'm sure there are many frustrated customers thinking they can get 4cyl manual transmission with navigation & non-leather seats or some such combination.
    Actually Honda is now more flexible that Toyota.
    In the old days when the choices were just DX, LX and EX, you didn't have much choice other than those trims plus color and transmission.
    Now that there are so many trim levels available with the addition of the SE and VP, plus the fact that you usually have the choice to choose manual or automatic transmission, using Honda as an example to justify the lack of choices on a Camry doesn't make your point.
    With the LX and SE you can now get a V6 with cloth seats with or without sunroof and different kinds of rims depending on what trim level you choose.
    On an Accord, you can get navigation with both 4 cylinder or V6 and also with automatic or manual on both engines etc.
    You still can't cherry pick every option, but with so many preconfigured Accord trim lines to choose from, an Accord purchase is now much more flexible than the purchase of a Camry.
    If I wanted to buy a Camry with factory navigation in California, the only choice is an SE/XLE V6 with every option or a fully loaded Hybrid.
    I wouldn't need them to offer any bizarre combos like a 4 cylinder with cloth seats, manual transmission and navigation, but at least a loaded 4 cylinder XLE with navigation should be a choice similar to an Accord EX-L with nav.
