Toyota Canada is also changing the name to Yaris, kind of surprising considering how well the Echo (sedan and hatch) has sold up here. It is suppose to arrive here in October as a 2006 model, so if you would like a preview keep an eye on some Canadian based auto web sites. Also, (start of rant) I find it kind of funny when people claim they would not buy a compact car citing crash safety, when I believe it has more to do with vanity, people not wanting to be seen driving an inexpensive (cheap) compact car by family and friends. If your first thought when slipping behind the wheel of a Yaris, Fit, ect. is one of your imminent demise do us all a favor and buy a bicycle, for you lack the basic confidence required to operate any motor vehicle safely (end of rant, thanks).
(unless you're broadsided by a semi, now we might have problems)
The chance of being hit by another car of equal or lesser size is quite slim when you are in a car like the Echo/Yaris.
If you're so afraid of driving a little rig you probably shouldn't be in a larger rig, either. A small car like the Echo would be very maneuverable out on the road and if a person has enough sense about them they can avoid a lot of "crash" situations with a healthy dosage of common sense.
I throw it into the lack of signaling on America's freeways category. It's a bad habit to get into, this habit of not signaling your intention to change lanes on the freeway. Who got this bright idea that it doesn't matter, that's literally sweeping the country the last few years? It does matter and it's so easy to do, it's a good habit to get into and keep. Good driving manners are tied into good driving skills, which include the lead subject here, crash avoidance.
Slowing down a bit and watching what you're doing never hurts and leaving your stupid cell phone at home is a great idea, too. See what I mean, I could type on and on about driving safety, because it's a common sense issue. Avoiding driving a small car ain't gonna save you anyway if you drive like a moron off the block. Correcto-mundo, dudes?
The link posted earlier to the Toyota USA press release showed a more Scion xA sized Yaris.
I wonder if the Scion xA is going to shift over to the Yaris platform...but until we see the actual measurements (originally the Yaris was an inch or two longer in the wheelbase) we won't know if the change would be meaningful.
BTW, the Scion xA was nowhere to be seen - but there were a lot of Honda Fits/Jazz's.
Beginning stick drivers may require a tach.
The oxymoronic thing is putting tachs in cars with automatics...
The real advantage of a manual is that it will hold the gear as you slow into a curve and then come out of it again. Auto trannies sometimes throw shifts at awkward moments....
I read of concerns about safety. I cant imagine this car coming out without the government having done crash tests to prove that it won't be a death trap.
Steve Edge
I'd use it as a city car, an errand runner, a car to drop kids off at school, soccer practice, golf games, etc.
I wouldn't take it on the highway.
For those trips, I've got my Odyssey!
The thing we need to remember is that compared to 30 years ago, even the smallest cars on the road today (even the Smarts) are safer than pretty much any car on the road back then. Many of us are worried about safety, and we are right to do so... in many if not most cases, it is not only our own life we are putting at risk. That being said, no amount of safety equipment will ever make the difference that solid defensive driving skills applied by a confident driver will.
So is the Yaris small? Yep. Is the Yaris a death trap? Nope.
But back to the tach, what are you doing that you need to "get the most" out of your engine that the tach helps you with? The driver's seat will tell your butt cheeks where your shift points, max torque, cam float, etc is. How much time do you spend driving within 1K of red anyway?
Put a sticky-note over the tach and drive your usual routine for a few weeks. Let your car teach you how to drive it.
How does a tach help with fuel economy while cruising in an automatic? I understand the whole revs thing, but by "cruising" I assume you mean continuous 60 or better and you're in top gear (lowest rpm) anyway.
If you get in a situation where the auto needs to downgear on you, its because the car says it needs it to keep the engine in the power vs. economy range. What do you do to manipulate the engine or trans to improve mileage that a tach helps you with?
Over about 50 mph, as you noted, the car will stay in 4th gear anyway when cruising so the tach isn't needed at that point.
If you're going to be hit by an H2, A Yaris vs. an Accord won't make much of a difference I guess.
The only way I can think of that you can survive in a collision with an H2 in a side impact case would probably be in another H2...
Steve Edge
I like it.
I also like tachs in my cars, but some people don't. I suppose it takes all types.
Post anything new you hear about the Toyota Yaris/Vitz/Echo in here, OK? My mind is an Echo sponge!
Only my 1999 Honda Civic has no tach, but its an automatic so its fine.
It helps me determine how much throttle to apply, especially when driving on a level area. Instead of letting the engine spin up to 2500rpm, you can use the tach to let it go up to only 2000rpm. It also lets you see how much faster your engine is spinning when exceeding the local speed limit.
I also practice the Neutral coast, and sometimes even with the engine off :surprise: (of course no one try that unless you are a certified id10t like me!)
I am sure the Yaris would benefit from this as most cars do (as the engine size gets bigger this is less practical, obviously).
I heard that the Yaris would use the Old echo's 1.5L? I wonder if they will turbo it as they did with the RS Vitz in Japan, just make sure it gives good economy with the turbo unlike with the XRS 1.8 engine. I mean come on, there is a 7mpg difference and only a 38hp difference!
The Yaris definitely doesn't look bad, I thought they would make it look hideous, so I am happy about that. I hope they equip the cars well however, because being required to pay extra for power steering and a rear window defroster is just silly :P
Anyone else that can get hard info please do, because most of my knowledge is just speculation.
Having gone three months without a car is torture. I hate our transit system and biking in the city will eventually get me killed (bad bad bad drivers on cell phones.)
Any newer news?
So, the U.S is getting the sedan and not the hatch, and Canada is getting the hatchback, is that right? This speculation game poses more questions than it does answers!
http://www.toyota.com/vehicles/future/yaris.html
The new version will be called Yaris in both Canada and the US. It arrives in Canada in October 2006 as a 2006, and in Spring 2006 as a 2007 in the US. Word is the the US will get the 3 and 5-door hatches (definitely) and a sedan (probably). There has been no word about a sedan in Canada so far as I've heard.
You probably mean "It arrives in Canada in October 2005 as a 2006 model-year"
I like the green one too, like the person who wants it on their background. I wonder if they will have any orangey shades.
Save up $2,000 a month until then and away you go.
I'm assuming it will have the same 1.5L. Does anybody have different information?
me: that would be disappointing. I'd expect low 40'smpg would be the rating of a new small car model. For example a Pontiac G6 sedan is rated for 32mpg highway with a 3.5L and a 4-spd auto. If you're giving up significant size, power, and safety, and going to a manual I'd expect to get significantly better mpg. A 5mpg gain or so is very minimal.
Mileage "official" mileage figures from Toyota Canada converted to US gallons:
Manual: 34 city, 42.7 highway
Automatic: 33 city, 40.5 highway
Please note that according to Consumer Reports and real-world experience, the Echo got very close to EPA figures, something that could not be said for the majority of cars.
Canada's EnerGuide mileage tests also show the Echo getting better mileage than the Corolla. They rate it as 42 mpg city / 54 mpg highway. That's for the 2005 Echo.
And yes, I am well aware that in the "real world", the 2005 Echo hatchback and sedan got MUCH better mileage than the Corolla.
