Pontiac GTO Prices Paid and Buying Experience
It looks like Conkle only has two GTOs left: a black one and another one that they're asking $56K for. I'm not interested in black and I can only guess that the other is modified in some way...
my cyclone grey GTO 2005 17,000 miles will be ready next year for sale...keep me in mind....
any other local GTO guys on line here..? :confuse:
whats new with the TIRE SHEDDING PROBLEM ? :confuse:
any local speed shop COMPUTER TUNERS AROUND? :confuse:
Regarding the pricing on new GTO's, they are at most a year and a half old, not two (since the first 2006 models did not arrive on dealer lots until December of 2005/January of 2006). Pontiac built extra 2006's (~14k of them - Monaro production ended nearly six months before GTO production) because they knew they wouldn't have anything to replace them with until the G8 hits early next year/they knew the GTO wouldn't meet the 2007 airbag specifications.
Furthermore, with only ~600 GTO's remaining, and maybe 125-150 of those being manuals, it has come down to a seller's market. If you're in the market to get one, if you can find the color combo you want new and can afford it, now's the time.
For those wanting a good deal, GM did put many of its field reps into GTO's resulting in a large number of slightly-used (3k-6k mile) GTOs out there (sold to GM dealers only at special auctions).
The two most important things you can do if you're considering any used car are:
1) proper test drive/inspection (looking for issues)
2) having a GM dealer run a GMVIS report on the vehicle (requires the VIN number). This will tell you the delivering dealer, date of delivery, and any service-related work done to the car, warranty or no. The last thing you want to be doing is buying SEP: someone else's problem...
Regarding mileage, no six-speed GTO owner should complain about "poor" gas mileage (unless you keep your foot buried in the throttle, and/or are driving 100+ miles/day). EPA says 21 city/29 hwy... more like 18/26 in the real world - heck, even my A4 '04 averages 18 city/21 hwy, better than my wife's 2004 GMC Envoy w/I6...
--Robert
LS1GTO moderator
I am checking for strut replacement.
Can anyone do a GMVIS on VIN#: 6G2VX12U86L825371
Deal or no deal?
1) buy a GTO with the 18" wheels with the p235 tires,
2) Have GM do it's max positive camber adjustment only to prematurely wear the outer edges of the p245 tires,
3) Refit with aftermarket equipment.
In the end a typical GM experience that will cost money no matter how one approaches it. I want a GTO but the common sense side is telling me not to bother.
My guess is that the car is outside the range of VINs that require strut replacement. The last built car was completed on June 7 2006 and it had an 838xxx VIN. Your 825xxx VIN is probably a mid-May build; the defective strut issue afflicts cars built from mid-January of 2006 until May 4/5, so, assuming my assumptions are correct, it's unlikely you've got the bad struts...
Suspension mods to fix the weak points would cost between $120 (SuperPro Radius Rod Bushings - I bought them from http://www.autoformgroup.com) and $240 (http://www.peddersusa.com). Pedders also makes HD strut mounts and sells replacement strut bearings - $38.79 and $34.71, ea. (and bear in mind you need two of each). So, for about $375 in parts + maybe an hour's worth of labor (the radius rod bushings you can do in your driveway if you're at all mechanically inclined) + an alignment , you'd be pretty-well set.
If you've driven the car and haven't fallen in love with it, then maybe it isn't the car for you. But if you love the driving experience but are afraid of the possible things that may go wrong, well, my experiences have been overall positive/I love the car - and I know I'm not alone (there are a fair number of new GTO's which have rarely seen the dealer - as well as the occasional car that lives there - I had that experience with my first GTO, unfortunately, but GM (eventually) took care of me...
Thanks-
Evan
GM put a ton of field reps into GTO's in July-August-September of 2006... those cars got between 2k and 6k miles on them, and were subsequently sold in a GM dealer-only auction... your car might be one of those, based upon its mileage. GMVIS is also useful because it will show you if the car was administratively bought back for any reason (someone in Waco, TX ended up with my first :lemon: GTO, unfortunately for them...)
Help
VIN : 6G2VX12U86L820669
VEHICLE INFORMATION
Merchandising Model : 2VX37 -2006 GTO COUPE
GMWarranty Start Date : 08/31/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PATRICK PONTIAC-BUICK-GMC INC.
405 S WASHINGTON HWY
ASHLAND , VA 23005-2312
(804) 798-4200
Selling Source : 16 - PONTIAC
Site Code : 04090
Business Associate Code : 115655
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 08/31/2006 68 miles 08/31/2009 36068 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 08/31/2006 68 miles 08/31/2012 100068 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/31/2006 68 miles 08/31/2014 80068 miles
36/36000 FEDERAL EMISSION 08/31/2006 68 miles 08/31/2009 36068 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/07/2006 A20669 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
I'm betting you guys can interpret that better than I can, but I don't see anything out of the ordinary. Thanks all for the help.
Congratulations on the car. Have you picked it up yet? I am sure you will love it. I have a red 05.
Chris
What kind of MPG should I expect.
Any recomendations on the milage for the first oil change?
Sorry for the long post haha
Evan
it's normal for pinion gears to make *some* noise, but hey, your car is under warranty so do max out on having the dealer evaluate *anything* which concerns you including rear gear noise.
left rear sits lower than right? that's gotta be fixed, obviously, unless you are a massive individual and are siting in drivers seat or left-rear of the car at the time! could they have forgotten to remove the "chock" spacer-thing from one side of rear suspension? - those were used for the car's long boat-ride and train/truck ride too, afaik.
192 are automatics, and only 9 manuals (7 Torrid Red, 1 Brazen Orange Metallic, 1 Quicksilver Metallic) are left. Some of these might be demos as well...
If it has a Yxxxx code and says something about strut replacement, yet there's nothing in the "Claim History" section showing both struts replaced, you need to get that done (dealers were supposed to proactively replace struts on vehicles in inventory, that program ended 2/28/2007, but less than 50% of Pontiac dealerships ever read the bulletins/do the work.).
MPG? Depends on how heavy your right foot is. On an '04 A4 (LS1) I get 20-21 mpg in highway driving, more like 16-18 city driving (most tanks average between 18 and 20).
First oil change? I'd do one at 500 miles, if not immediately. Your car was probably filled with oil in May of 2006 - 15+ months ago. Get that stuff out (and any metal shavings/debris that might be in the engine, as well as any assembly fluids/lube) ASAP.
I don't know how you get your info, but please never leave the forum. Your info always seems reliable and on the money. How do you know all of this info (inventory sold, how a model was prepared for shipping, etc,....)?
Rear springs sagging... have them replace them, common problem. Measure the stock ride height (in mm) from the bottom lip of the rim to the bottom of the fenderwell... the stock ride height figures are posted on LS1GTO, but they should notice the difference between the left rear and the right rear.
Clunk coming from the rear or front? Where are you located? You might try to find a close Pedders dealer (http://ww.peddersusa.com) to do a free 28-point suspension inspection. Of course, they'll give you some suggestions on upgrades - in many instances their stuff > stock, in others it makes sense to use your warranty. They probably know more about GTO suspension than your local dealer...
http://media.gm.com/servlet/GatewayServlet?target=http://image.emerald.gm.com/gm- - news/viewmonthlyreleasedetail.do?domain=74&docid=39053
Someone on the site did a locate on M6-equipped GTO's and came up with 9. 201 remaining, -9 M6, = 193 A4's...
201 GTO's
9 M6's
= 192 A4's.
There, that's better...
Car is fast. Love the color.
Bob
~Evan
Do you know of any good pedders dealers in the Washington DC area?
I am taking in my GTO tomorrow to the dealer. It has developed a whining sound (like cicadas) that is worse when I accelerate. I also noticed some reddish/brown fluid leaking slightly from one of two pipes on the right front underside of the engine. I can also see some stutt rub on the front right but this may have happened before my alignment a couple of months ago. I want them to check the front rod radius bushings and have them show them to me at the service.
Chris
my 05 was indeed repaired (cyclone grey) and i elected to have the aussie rear-bumper-bottom-cover installed instead. it is black and does not say G T O . also it has a square thing in the middle, a little doorway thing that maybe is there to accomodate a trailer-hitch. ?
btw, i think the blazing orange color is awesome. but i'm color-blind, lacking most of the green-receiver cones so i'm probably not seeing the same color as you no matter what i'm looking at.
I had located in Massachusetts a silver six-speed 2006 GTO with 10,600 miles. The dealer was willing to let it go for 24,750. I had never driven a GTO prior to visiting the dealer and boy what a surprise. The car is a power house! I felt like I went on an amusement ride after I test drove it. Right there my mind said: 'this car is so impractical - what!? with all that power- at a time when gas is so expensive' and I told the dealer no. Then next day called back said I'd take it, called another day again and said no and then called and said yes and lastly called and said no. In the end I went to look at another car (Acura TL) that I thought I'd like but I kept thinking about the GTO. Unfortunately the dealer had sold the car when I called. I'm now here in mourning. I'm gonna get a GTO because I'm smitten and it's a rare ride. Somebody pass me a tissue please. ;-(
