Visitor Agreement.
I think the owner could have bought a couple of new ones, for the price of continuation.
2. Engine reseal and bottom end bearings replaced at 520,561mi
3. Front crank seal leaks. I have an entire engine seal kit that I'll give to the new owner
Not trying to be too too nitpicky, but who rebuilt the engine at 496k miles? Seller states that the engine was "Converted to 3.8L by Andial and auxiliary oil cooler installed at 400,000mi." No mention of who did the engine work after that.
And a $10k repaint is pretty extravagant too. Spend that much to paint a miled up car worth $16k and insured for ??? Just curious, what is the most anyone here would spend to repaint your pride-and-joy, high-miles, daily driver?
Had an older guy approach me, and say he had some spare parts for my car that he'd give me. Turns out they were from a 200D - he thought all fintails were the same.
I talked to a friend today who said he saw a "car just like yours" in a movie. He meant the 280SE Cabrio in "The Hangover". Funny.
He was pretty good with a soccer ball, as I remember.
http://austin.craigslist.org/cto/2194461710.html
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270698414552+&view- item=
That Benz wagon looks promising.
Car does seem to have some orange peel paint surfaces on the A-pillars and just below the front door beltline, could be an illusion but it caught by eye. Otherwise...wow.
Several years ago an MB specialist I patronized when I lived elsewhere had an 85 like that, black on palomino, spotless. He put it up for sale for $7500 and it sold in an instant.
Benz TD Wagon --- looks so much nicer than the usual beat=up, worn-out. high mileage rats you see for sale. Can't say if the price is justified, since it is so unusual.
ya know, all the snow these days has me thinking.
Roughest 47k miles a vehicle has ever seen.
This guy has a habit of leaving the mileage off his cars.
Hey, kids, look! Its the most efficient powertrain ever made! No power lost from crank to wheels!
i like the troop carrier... you could paint it pink and make it into a 'troupe' carrier, right?
i'd like mine armored, though...
the jag looks nice. i'm guessing the mileage is really low.
cheers -m
I wonder how much hp the average car "loses" between the flywheel and the pavement? I remember reading that my 2000 Intrepid was one of the worst offenders. 200 hp from a tiny 2.7 that sounded good on paper, but only 150 made it to the wheels. Part of the problem was the transmission. Early versions of that tranny were weak, so I think they redesigned it to, for lack of a better word, "dump" some of that hp along the way in order to save itself.
Hmmm.. that brings up an obvious point I never thought much about... where does the energy go? Unlike torque and force, energy is strictly conserved... as is power in a steady-state situation. So the answer has to be "heat" which is really not a good way to make a transmission last... 50 hp is a LOT, that's roughly 30 kW... that's enough power to heat TWO goodsized houses, maybe three or four, in cold weather... how do you cool that away? I'd say you can't, and you don't have to because it's not a steady-state situation; at sustained high speed, the torque converter would be locked and the losses would have to be much less.
Do you remember how that number was measured?
Cheers -Mathias
Nah, and in fact, it could just be hearsay. I remember someone in one of my Mopar clubs mentioning that stock, the 2.7 only put out about 150 hp at the wheels, but there was aftermarket support for it, and it could be boosted to 250 hp or so, at the wheels.
What about just making the transmission slip, or not fully engage somehow?
One little trick I found with my Intrepid, to get it to go faster, is if you held the revs to around 4900 rpm, which is about where peak torque was, it would take off faster and hold the gears longer than if you simply floored it, where it would go to around 6,000 rpm and then upshift.
That's what I'm trying to say: Now you're dumping the better part of 30 kW of heat into your transmission and it'll die. That can't be helpful...
OTOH, that may be what's going on during hard acceleration when the torque converter is not bridged by the mechanical clutch... that's gonna be hard on the transmission, but it won't last more than 20 seconds, max... after that you're at 100+ mph and in full lockup no matter what... and can take your time cooling the fluid back down.
Aren't their some automotive engineers on this site who would know this stuff?
Inquiring minds want to know!
Cheers -m
So that 260hp Altima would be about 220 at the wheels.
Can't say with 100% certainty, but I think its attributed to many things. Frictional losses, heat losses, ummm... whatever you call it when things flex under pressure. So in an auto, the torque converter is like 5% by itself.
I'm surprised it's that high in a manual... those aren't cooled except by fins in the bottom. And they're typically maintenance free to 200k or so...
Frictional losses = heat losses. One nice thing about physics, it's reliable... friction always makes heat... it's gotta make something, so other than heat, what is there? Noise doesn't take a lot of energy... it all becomes heat in short order. That's why most if not all automatics have a transmission cooler, and if they don't it's a good idea to add one.
CHeers -Mathias
Yeah, not the best idea.
To be fair, Nissan seller doesn't say the power is at the wheels, does he?
The car shows 98,000 miles one year ago, so figure it's about 110K right now.
Private party retail is about $4500, mileage is a 'neutral' with no deduct, minus $800 for alternator, minus 10% negotiation on retail, that leaves us with a fair offer on the car of about $3200.
You might as well just go buy a clean, good-running Lincoln LS, which is essentially the same car underneath.
The latest "Top Gear" magazine I have has an update on the new XJ in their test fleet. Several electrical glitches.
Energy Losses in a Car
Cheers -Mathias
eh. Ya know, you're right. He says "pushing 250hp to the wheels" not AT the wheels.
Same platform, but that's about where it ends. I had an LS-V8 for a little while. Nice enough car, but horrible mileage and ultimately boring.
Not that this would be any better. I did test drive the S-type before buying the Lincoln. I liked the Jag a big better but what did it for me at that time was the little fact that replacing 1 of those electronically controlled shocks on the Jag was something like $1,000 vs about $100 on the LS.
never did go look at it though, even though I think it was at a pretty low price for the time.
I did drive a v8 AT (obviously) when they first came out, but it wasn't very long and I honestly don't remember it much.
I forget what exactly went wrong with it, but I believe it ate a transmission almost immediately, then something else went bad, and then transmission #2 was about to go. It was bad enough that the dealer took it back and gave him a really good deal on an '01 LS with a V-8. He never had any trouble with that one, but traded it at around 50,000 miles for an Acura TL. And ever since then, he would always trade roughly every 50,000 miles. He has a current-gen TL right now, a 2009 I believe, that he's leasing. I hate to imagine what his monthly payment is, with the kind of miles he puts on! 50,000 miles usually comes up within two years.
Looks interesting and even tempting BUT, I know the pitfalls.
Anyone know anything about these?
http://seattle.craigslist.org/est/cto/2210612431.html
Someone please talk me down!
if you like it, a cheap diversion, and you can always bail after you get tired of tinkering with it in the garage. Cheaper than getting a girl friend, or going to the casinos!
Just don't give it to a shop for a full restore.
what would you want to do with it? Put around on the weekends as is? A DIY restore keeping it original? Or go nuts, and turn it into a street rod? Now that could be a fun project to keep you busy until you are 75!
With those Girling mechanical brakes I don't know that I would want to put a modern engine in it.
Hardly a freeway flyer when it was new.
I sure as hell wouldn't take it on the freeway but it would be fun to take it to the local car shows int he summer maybe drive it around the lake once in awhile.
But I know I'm dreaming. A basket case engine that "probably" needs a rebuild? Gee, do ya think so?
Or I could spend 100,000 or more making it into a cool resto rod with a 350 engine, maybe a blower etc?
But if I did that, I wouldn't be able to crank start it anymore!
Maybe we could go look at it together since it's right here in Issaquah?
