Just as an estimate, he said it would probably cost around $1500, if I wanted to have the front bumper/grille assembly on my '57 DeSoto redone. I don't think it looks that bad though, so I'm not going to bother with it.
He is going to call around though, and get an estimate on getting the rear bumper re-done. Hopefully that won't be *too* bad, as it's a fairly simple piece...although it does have the dent in it, and has the dual, built in chrome exhaust tips. And then, if I got the bumper re-done, might as well get the taillight bezels redone.
I wonder if there are any relatively decent, rust-free '57-58 bumpers still out there somewhere, and maybe it would be cheaper to find one, rather than get mine hammered out?
I looked on eBay and did find this, but I don't think it'll quite fit... :P
And, check out this . Holy Chrysler, $895 just for a freakin exhaust tip?! :surprise:
And compared to some claims that get made when folks sell their cars, yours did have a 'frame off restoration', and you have the pictures to prove it!
Could save you some money.
I agree on the '58 Edsel...my only real beef with them is a few details up front. I actually don't mind the vaginal/horsecollar/toilet seat grille; I think a bigger problem is how the front is just too flat-faced and vertical around the headlights. The front fenderline thrusts forward, rising above the under-cut flanking grilles, but then when it just goes vertical around the headlights, I think it just looks awkward.
But otherwise, I don't think it's too bad looking. I always thought Edsels looked pretty nice from the back, with that gullwing thing going on.
And, the '58 Edsel my mechanic has is really plush and ritzy inside. Thick, ribbed fabric on the door panels (the mechanic said it was a real pain to get those "poofs" just right), integrated door panels, etc. Overall, definitely a plusher, more luxurious car than my DeSoto. One dumb thing I noticed though, is that they put that peel-off Mylar crap on the lower door panels, the area where you'd usually expect carpet. Not too smart, putting a flimsy material like that in an area that's probably going to get kicked. DeSoto did that too, but oddly, only on the more expensive Fireflite. On my cheaper Firedome, it's just vinyl down there, although they put the Mylar crap around door handle and arm rest, where it will still get worn (and did on my car, at least on the driver's side)
For '58, I think it's a slight improvement with the headlights, although the bumper/grille combo still seems heavy-handed. And both '57 and '58 seem kind of boxy to me, and a bit overly sculpted.
I think the '59 was a big improvement, as I like the more aggressive forward thrusting front-end. The grille seems cleaner and less fussy as well, and the overall styling, while still a bit heavily sculpted, seems less boxy, and a bit sleeker overall.
The '59 was longer than the '58, as well. I think Mercury sort of got caught with their pants down with the '57 model, which was on a 122" wheelbase, and a bit smaller overall than much of the competition. In this price class of car, it was normal for the entry level models to be on a wheelbase of around 122"...cars like the Buick Special, Olds 88, and DeSoto Fireweep. But the more senior models were on larger wheelbases of around 126" (Olds 98, the bigger DeSotos, Chrysler) and even 127.5 (Buick Super/Roadmaster). But with Mercury, even the Turnpike Cruiser was on the short 122" wb, same as a Dodge, or the smaller Pontiacs.
Overall, the '57 Mercury wasn't such a hot seller. Most likely, management reacted to this by ordering an increase in length to get it in line with the competition. But by the time that happened, 1959, there was a backlash coming against bigger cars, and the '59 Mercury debuted with something like a 126" wb for the cheap models, 128" for the pricier models. As a result, even though the economy was improving over 1958, Mercury sales barely improved. Something like 150K in '59 versus 133K for '58. And that was down from 286K in 1957. And, '57 was off from '56, when about 327K Mercurys were sold.
Kinda sad that the one time Mercury was truly unique and had its own dedicated body style ('57-58 and '59-60) they just didn't sell very well. For 1961, Mercury returned to essentially being a guzzied up Ford, and that formula worked well for them until probably the 2000's, when sales really started to fall off and the brand was eventually dropped for what? 2011?
Was actually in pretty decent shape - and judging by those tires, it was stored somewhere for a very long time. I saw the car again a year or two ago, but haven't seen it since. These have to be pretty rare.
And how quickly it changed - by 60-61, those fins were becoming passe already.
That may not be saying much, as CR would usually test run-of-the-mill, fairly inexpensive, mass market cars. They had tested Corvettes and T-birds prior to that, but in those days, those cars could be had with mild engines. And they'd test sports cars every once in awhile, but in those days, most sports cars, semi-affordable ones, at least, weren't fast in a straight line. The "sports" was in the handling.
I think they got 0-60 in around 8.5 seconds with that Edsel. While that doesn't sound all that impressive, CR was usually a bit conservative in their testing. C&D or MT would've gotten a quicker time.
GM just had it all over Ford in those days styling-wise.
Well, in 1973 SIA did a test on a '57 Turnpike Cruiser 4-door hardtop with the 290 hp 368 and measured 0-60 in 9.8 and the 1/4 mile in 17.2 sec at 80 mph even.
That car is in the position you mention - too new to be old, too old to be new.
Signals are working, but dim. The fun quirk today was the howling speedometer (cable, I assume - I bought a NOS one 10+ years ago, and it's still in the trunk). When I first started out this morning, the thing made so much noise, especially above 35mph, that the radio was useless. Once the cabin warmed up, the noise went away. Car started on the second turn, first try was sputter and stall. But ran fine after that. Not bad.
I still have the three remaining Uniroyal Royal Seal tire. The last picture compares the original-style Royal Seal tire to the ones I had put on the car.
What a beautiful car, glad they fixed it up nice.
South Jersey Craig's.
southjersey.craigslist.org/cto/4231215970.html
southjersey.craigslist.org/cto/4253559630.html
southjersey.craigslist.org/cto/4253342538.html
southjersey.craigslist.org/cto/4230084552.html
southjersey.craigslist.org/cto/4210204225.html
62 Impala -- well, no power steering, no AC, cheesy air horns, lotsa non-stock parts---I guess $15K is a good starting point for negotiation but this car may not be as good as the photos suggest.
84 Deville Sedan--- normally this is a $1500 car all day long but if he can back up the mileage claim, it might be worth something close to $3K
27 Chevy -- asking too much $$ with no chance of pay-back. Try $2500. Might make a good shell for a street rod, that's about it. Too bad it is so far gone---20s Chevys are not that common anymore. The slathered bondo patches aren't a good sign though.
79 Pontiac Grand Prix--it'd have to be pretty near perfect to warrant a $7K price.
91 GMC Syclone -- might be worth it if it were a solid #3 "clean driver" with no great needs.
I think that '79 Grand Prix is going to be a bit of a hard sell. Even though it's in nice shape, it's a base model instead of an LJ or SJ...231 V-6, crank windows, manual seat adjust, no rally wheels, etc.
Does engine choice make much of a difference in value by this point in time? I had an '82 Cutlass Supreme coupe with the 231 V-6, and I'm sure this Grand Prix would be every bit of the dog that my car was. I don't think I would ever want to re-live that experience. But, maybe I'm looking at it from the wrong point of view, as a regular-use car that I'd have to depend on. By this point, I imagine that whoever bought it would want it to preserve, take to shows, etc, and isn't that concerned about performance.
The V-8 option on these cars was the Pontiac 301, which had 140 hp with a 2-bbl, 150 with the 4-bbl. Hardly a powerhouse by today's standards, but I imagine not too bad for the era. I think that CA/high altitude models used a Chevy 305.
For the most part, I like GM's downsized RWD intermediates from that era, but if I was going to seek one out, I think I'd definitely want a V-8 model. And NOT one of those shrunken 260, 265, or 267 V-8's!
yeah the V-8 would make a difference in value but only proportional to the value of the car, which isn't that much to begin with. Let's say 10%. Might make it sell faster, though, since maybe you could get more power out of it with some mods.
Yowza
Luxury ride for the price of a Hyundai ! Not sure if this is money well spent or not, since you can buy a pretty nice used Benz for $18K. Seems like an emotional, rather than a rational, buy. Cross your fingers that the seals haven't all dried up. Looks like a REAL Benz, though.
That's definitely what a real MB is all about.
It's at a hard spot though - drive it much, and you kill the condition and value. Or, pay a lot for sunny Sunday local show car. I think it's pretty amazing looking, but maybe not a value for anyone but a rabid W126 fan who wants to potentially win awards.
That's a lot of money to spend to win a $5 plastic trophy. I'll rather drive the snot out of it and enjoy every last drop of it.
But that car won't be too fun to drive, really, a smooth cruiser, and not a fast one (it's a 300, not a 560) nor particularly economical. If I had it, I would preserve it and maybe drive it as much as I drive my fintail.
Auction just hit 20K, not bad for a 126.
I didn't mean drive it fast. I meant, use it up. No one is even going to notice an 80s era 4-door sedan.
Even using it up, the average punter would get more enjoyment out of a base 20K loss leader Camcord. This thing would only be enjoyed by an old school diehard - who wouldn't want to use it up. I think it appeals most to a monied eccentric who wants attention at a show - at my local MBCA show, people would be all over this.
I don't get the bidding, which is approaching Euro money for the car - no meat left on the bone for export.
Really? Are MBCA shows that starved for excitement? I'm kind of surprised. This is really a very ordinary car that happens to be in extraordinary condition. Well, I guess to a select audience it means something, okay.
126s are highly thought of, and preservation is big right now. I have no doubt that car finish in the top 3 (for "older" - pre-1990 cars) in my regional show.
And a local or regional MB show might not be the most exciting place, it won't be full of 300SLs and 540Ks, it's mostly rich geezers in no miles 10-20 year old SLs, with some old car weirdos thrown in. Cars like 190SL or 280SE cabrios etc are the unusual highlights, not the norm. Heck, my car made the MB magazine for a representative shot of "the field" at my local show, an unrestored fintail - as it is odd enough to get attention
I always thought the W126 very non-descript. You can buy real beauties around here in the Bay Area for around $7K, and easy to find, and low miles, too. Buyer's market.
When you see any, post links of those real low mileage beauties. The W126 is considered to be the pinnacle of the traditional MB sedan, hugely over-engineered and advanced over everything else on the road when new. New ones, while amazing and posh, just aren't the same.
Speaking of links...
I want want want
This isn't shabby either
you can just look them up on craigslist. I see them all the time, some with well under 75K miles. They range $6,000 to $8,000 and you can bargain hard down here---these are not easy cars to sell because they are high maintenance and gas hungry and SF has some of the highest gas prices in the country. In a way they are too new to be classic, but too old to compete in any way with a new car.
I've looked, but found very little that looked tempting. I suspect the really nice cars are stalked by dealers and shipped out.
