Visitor Agreement.
However, 175 hp?? That may make me think twice or 3 times.
Yeah, 175 hp doesn't seem like much hp to move a big boat like that around. Off the top of my head, the only comparable performance times I can think of for similar cars was when CR tested a 1972 Impala 350-2bbl with 165 hp and a 1972 Catalina with a 400-2bbl with 170-175 hp. 0-60 in 12 seconds for the Impala, 12.5 for the Catalina. So I guess the Fury would be similar, depending on gearing.
That Fury is kinda clean and even a bit sporty compared to something like a 1973 Impala/Caprice or 1973 LTD, both of which were trying to go for a more upscale, formal, pretentious look, which Plymouth itself would adopt for 1974.
You could improve performance merely by popping off the heads, milling them to boost compression, and adding an aftermarket 4 barrel carb. This should give you another 25 HP or so and snappier performance.
But you have to be realistic. The thing is as big as a house and really needs a Max Wedge to go anywhere.
Would just adding a 4-bbl carb do anything for performance by itself, or would you also have to change the camshaft as well?
I'd be kinda curious to know what axle ratio the car has, too. At some point in the 70's, Chrysler went from using mainly 2.76:1 rear ends to 2.45:1 rears. There were always other optional rears, but once the 2.45:1 became the mainstay, it seemed like it was all over.
Just to show how bad things got, I found the results of an old test that C&D or MT did in 1976, when they compared some Big Three dreadnaughts...
1976 Ford LTD 460ci 0-60: 11.3, 1/4 mile: 18.2
1976 Plymouth Gran Fury 400ci 12.2 18.2
1976 Chevrolet Caprice Classic 400ci 12.8 17.6
Kind of interesting that the LTD, with the biggest engine, was the quickest in 0-60 but started to choke in the quarter mile. To the point that the Gran Fury matched it and the Caprice, which was slowest from 0-60, hit the quarter mile faster.
Is this an indication that the Gran Fury and especially the Caprice were better revvers than the LTD? Or maybe the LTD was just geared too tall?
http://seattle.craigslist.org/see/car/244945413.html
This needs a work, but has charisma
http://seattle.craigslist.org/oly/car/244950662.html
This is pretty sweet if you can live with an automatic
http://seattle.craigslist.org/est/car/244946033.html
An unmolested, 5-spd Prelude of the Flash Gordon series
http://seattle.craigslist.org/tac/car/244931339.html
james
well, if his reserve is anywhere near his asking price ... good luck! that will be nothing but a waste of ebay fees.
I like the fact that, for 1981, it looks like Chrysler finally put a pull-handle on the armrest that looks like it might actually stay on! My '79 just has a strap that'll either snap or pull loose if you yank on it hard enough. Also kinda interesting that for the last year, they'd change the trunk design from gas struts to the more traditional torsion bar/gooseneck hinges. Seems to me that's an awful lot of trouble to go through, changing something like that for a car that was about to get discontinued.
I can only imagine what a 130-hp 318-2bbl mated to a tall 2.26:1 rear end must be like to drive. My '79 has a 150 hp 360-2bbl with a 2.45:1 rear and, I'm sure, a lot more torque, so it's actually tolerable.
I'd be tempted to try snapping this one up, if nothing else to keep it from ending up in a demolition derby (these suckers were solid cars) or junkyard. But I guess I need to realize that I can't save every old worthless car out there!
Hey, here's something I just thought of. Since this thing looks so much like my 1979, what kind of potential trouble could I get into if I bought it but never tagged/registered it? And then, if I ever felt like driving it, just swapped the tags off my '79 and took its registration card? If I ever got pulled over by the cops, I doubt they'd ever check the VIN # in the windshield. Guess I could get in trouble if I ever got into a wreck, though!
I know I've mentioned this story before, but I knew a guy when I lived in CA who did just that.
In his case, it was a pair of '75 or '76 Mustang II's. One was white with red stripes on the hood, while the other was white with blue stripes. On the registration card, it just showed the color as white. Both had V8's in them, but one was, shall we say, 'breathed' on a bit more than the other.
When he had to do the annual smog / registration dance, he took the 'docile' car and got all the tests done. Once the paperwork had been issued, he simply put the tags and information onto the "other" car and drove that for the year, while the other car sat in the garage (or back yard, I can't remember which).
The Miller Cycle Mazda is neat, if you can live with an auto.
That Celica GT could be the next big drifter. Get a Corolla S/Pontiac Vibe GT motor and drop it in there, or an S2000 motor or a SR20 perhaps...
The problem with the Celica GT is if I am going to by a 70s Japanese sport coupe, I would get a 240Z, and so would anyone else I know.
http://en.wikipedia.org/wiki/Miller_cycle
by the way, I hear that one should avoid the Millenia S. Besides, that one is WAY overpriced. There's one on my local craigslist that's half the price and appears cleaner.
I think that the base models offer 175 horse or so with a more typical OHC V6. I see plenty of the base model cars running around with 150k on them so if you found one with 100k, it would probably be a good bet as a used car.
"Acid has ate the tray up"
But in a twisted sort of way, I really like this beast.
Then I saw what that idiot did to that Delta 88.
I looked at all the pictures. It was painful, but I looked.
Yeah, I think the only semblance of mercy I can make out from those pictures is that it looks like they left the interior unmolested. I imagine that Delta 88 was a pretty looking car when it was new. I'm picturing a light metallic green with maybe a hint of silver, or perhaps a dark forest green metallic. My grandparents' '72 Impala was a forest green with a white vinyl top and green interior. I thought it was attractive.
I like that 2-door hardtop roofline, too. Something you don't see too much of anymore. I remember the Impala offered it, but most Impalas were the Custom model, which had a much thicker C-pillar, larger roll-down quarter windows, and concave rear window.
At a quick glance, this picture makes me do a double-take. It looks a bit like my Grandmother's back yard! Similar styled house in back, evergreen trees, woods to the left side, etc. I don't think my grandma ever had anything that tasteless in her back yard though. Well, I did have my '69 Bonneville hidden back there at one time!
Or maybe this, if lemko doesn't take it
That '77 98 is nice, too. Not my favorite color in the world, but I think that car wears it pretty well.
It's amazing how localized Craigslist can be. Here's a 1978 Mark V for sale in my small town! No pictures, but it's practically around the corner from me. I think if I ever got a Mark V, I'd want one in either light blue or jade, but hey, this one might not be bad if it's in nice shape. The Mark V is one of those cars that has kind of fallen out of favor with me, though. I used to love them, but maybe after riding in and driving my buddy's '78, the reality of it just disillusioned me?
I'm always fascinated by these low-mileage old cars, and would love to know the story behind them. I don't think someone would actually put something like this away in the hopes of it becoming a high-dollar collectible, but then you never know. While downsizing was the trend of the day, there was still a fairly large contingent of people back then who went against the grain, wanted their big cars to still be mastodon size, and held onto them as a symbol of a bygone era, I guess.
Or more likely, I wonder if it was just bought by some retirees who just didn't drive much, pampered it, and then when they passed on the next of kin decided to sell it off?
Oh, and I don't believe the claim that it can get 20 mpg on the highway. Unless you tie it behind a Prius or something!
Not having the heater work is a scary off-handed statement.
I always liked these although I liked the older body style better.
Super cheap jeep but I don't know if I buy the just needs a starter business
Neat Caddy for the money.
I'd be suspicious of the Talon, seems too good to be true. I sold the Sebring that had a whole lot more dents and a couple issues for more than that.
I wouldn't be too afraid of the Jeep, they are cheap to fix and fun to drive.
On the Caddy *shudder* looks too much like Christine, lol.
Mmmkay.
I wonder what makes the guy think that there were only six 1976 Pontiac Venturas made? They weren't very popular, but still, I'd imagine that Pontiac rolled off about 60-70,000 of them that year.
And let's not even talk about the opening bid! :surprise:
1932 Chevrolet Confederate Series
1941 Chevrolet Special Deluxe
1948 Chevrolet Fleetline
1955-57 Chevrolet Bel-Air
1958 Chevrolet Impala
1961-64 Chevrolet Impala SS
1962-72 Chevrolet Chevy II/Nova
1965-70 Chevrolet Caprice
1967-70 Chevrolet Camaro
1968-72 Chevrolet Malibu
1977-90 Chevrolet Caprice Classic
1994-96 Chevrolet Impala SS
Most Corvettes.
If I were to list the worst Chevrolets:
Chevrolet Vega
Chevrolet Chevette
Chevrolet Corsica
Chevrolet Spectrum
Chevrolet Celebrity
1975-80 Chevrolet Monza
Where would you rank the Chevy LUV?
in with the Isuzus - james
Granny car driver
