Visitor Agreement.
Thanks for your help.
i almost went w/ a 2006 civic si (best interior for the 22k price) but am ruling that out bcuz it is too small of a car;
going to test drive a gt right now, not the one i want but i need to experience it again to see if it is something i would want to repurchase lol
Daniel
anyone have a black 06 with some miles on it? how is the paint on yours? anyone do the 3m clear guard on theirs? can they get the grooves between the doors and the handle?
If you are talking about what I think you are, then the sound you are hearing is normal. When you shift, you can hear the clutch engaging. Also, if you are hearing some sort of hard clunk for a lack of a better way to describe it, coming from the rear, (axle) that is normal too. The gears are just engaging and they make that sound when you hit the gas.
As far as the popping noise, I'm not sure. Haven't figured that one out yet. I've seen and heard lots of people complain about it, but haven't seen it to be a problem yet. Sorry.
Aside from little nicks from rocks shooting up from other cars because of driving 80+ down the turnpike, the paint looks as beautiful as new every time I wash her. Hasn't faded, dulled, or anything for that matter.
Did I mention black is definitly the best color. (With black limo tint too!)
It may be absolutely normal. Love the car, just want to know.
From what I have been seeing and reading, the first production models that came out did, but the later ones haven't. I personally haven't had any problems, not one, with mine.
Granted there always will be that chance, but one thing I can tell you, if you get the GT, you will LOVE it. If you don't, you will probably regret not getting it.
They are awesome cars, and man do they get lots of compliments.
Dumb question, but you say you've driven stick before, are you starting rough, you know, bucking the car at all, or no, just smooth starts?
It's funny, I use to drive a manual neon too. Ha. Anyway, the clutch is definitly stiffer then the neon, and you should be able to feel exactly where its actually engaging. If you pay attention, as you push down the clutch, you will actually feel where it slips in, and its not all the way down.
Listen, if I was you, since you just got the car, take it right back, and just have them check it out now. Sooner the better. If it is something, the longer you wait, you could do damage to something else in the car.
Black DEFINETELY is the best color for the GT =D
Daniel
When you do 3000 miles or more in a month, the oil change is definitly a priority.
"Synthetic has a better shear capability, better cling, and thermal breakdown is an issue in a daily driver. More so if it's a turbo car. Other advantages include much lower pour point, much less viscosity change over time, and flat-out better lubricity. All of these are quite advantageous indeed--even in daily drivers. That lower pour point is particularly good--it means that oil gets where it needs to be much more rapidly after a cold start, especially in very cold weather. ... Thermal breakdown manifests itself as sludge and that tar like stuff that comes out of your crankcase every 3k miles. It happens on daily drivers! If you're not driving in conditions that let you take advantage of the lower pour point of synthetic oil, then you're most likely driving in conditions that let you take advantage of the resistance to thermal breakdown. Synthetic by design is less prone to breakdown, and does not need the quantity of additives necessary to make dino juice an "effective" oil. Synthetic is much less prone to cooking and less prone to varnish than conventional oil." ---allpar.com
So these are some great points on why synthetic oil is superior. Just remember once you switch to a synthetic they all say you should not go back to a conventional oil.
Personally, I think the most important thing is to change the oil frequently (every 3000-7500 miles), not what kind of oil you use.
I'm personally going for the strict BP only, when possible, 93 octane fuel because of the aftermarket products on the engine. Cold air intake, tune, long tube headers, X-pipe, performance cats, Borla exhaust, and a couple other things. These additions add almost 70 HP on the dyno and increase gas mileage 2 - 3 mpg when cruising; now of course they lower gas mileage when stomping on it but this is only natural. So anyway, I think it would be interesting to see in the long run which cost more, saving $2.50 at the pump or maybe saving as much as $5.00 or more dollars in overall MPG and keeping you engine cleaner while you do it.
I also try to strickly run on 93 octane and not even the 92 that you get with most gas stations on premium.
I think I do, or did see a savings. I say do, because of the blower. Even with my 4:10 gears, before I did the blower, driving down the NJ Turnpike, doing 80-90mph, I was getting about 18mpg. I think that is excellent for those kinds of speeds, and with the gears that I have.
For the few pennies saved upfront when going with a lower octane, I would say get a tune, and go with 93. It makes the car run so much better.
For example, putting on say, an Axle-back exhaust, well that doesn't do anything to your engine, so if all of a sudden, later on, your engine starts having problems, it will still be covered. Say something went wrong with your exhaust though, well, that would NOT be covered, because you altered it.
Same with a cool air intake, if you do not use a Ford filter, and something goes wrong with your engine, say they tell you they found pieces of dirt inside, well that wouldn't be covered, because they will say that you didn't use a Ford filter, and now its the fault of say K&N or whoever you used. Get it?
The computer retune is iffy, because it effects more on the car, but again, it depends on the problem.
If you are considering a custome tune, make sure you get a cold air intake first, thats the main reason the GT's are tuned, because the engine is so sensitive to any changes in the air flow. If you do, you will def. see a difference in the horsepower, it usally adds 20-25HP, with the CAI and tune.
And trust me, run it on 92 or if you can 93 octane, and it will definitly run better. Full synthetic oil is always a plus too.
Hope that helps.
i actually used V-Power on a couple occassions and seemed like the car was running better? probably a mental thing because I can't pinpoint what I mean by "better!"
Really?
I was under the impression that the octane rating of the fuel has ZIPPO to do with how 'clean' it burns. That is determined by the various additives the refiners add to their fuel. In the past, the refiners typically added more of these additives to their 'premium' blends but for the most part that is no longer the case. All grades typically receive the same additives.
The higher octane rating simply means the fuel is less susceptible to detonation (pre-ignition). I believe (though don't know for certain) that this is due to a lower vapor-point for the higher octane rating.
This lower vapor-point also means the higher octane fuel actually burns COOLER rather than hotter. The only reason that an engine will make more power running a higher octane fuel is if the compression ratio is high and/or the timing is advanced to the point where the use of a lower octane would lead to detonation.
In other words, the additional power is made by the compression/timing, not the fuel. Running the higher octane is insurance against detonation and to keep the ECU from retarding the ignition (and thereby lowering power).
http://www.caranddriver.com/article.asp?section_id=27&article_id=9752&page_numbe- - r=1
http://www.toptiergas.com/deposit_control.html
In part, these standards read "The deposit control performance of unleaded gasoline conforming to section 1 of this document shall be met at the retail level in all grades of gasoline sold by a fuel company in all marketing areas of a selected nation."
The secret to 'cleaner burning' fuel is NOT the octane rating, but whether or not the fuel meets the Top Tier Standards.
I have an excellent service department at my dealer and they have helped alot and are continuing to clear up these issues.
Upper front strut mount bump noise. will be repaired under wearranty or i will replace the struts and mounts with aftermarket tokico dsp-12 adjustable.
Out of balance drive shaft. replaced under warranty now is
75% better but still vibrates slightly.
The dash squeaks in two places and something bumps around inside behind the speedo when it's very cold.
The cooling fan hits the shroud when very cold for a short while until you turn it off and check under thehood then crank it up again and it's gone.
The ring and pionion whine on decel and will be replaced by factory warranty. It was barely noticeable until it was driven for a while with a bad drive shaft.
Other issues that i just don't like are the 18" goodrich g force kdws tires generate more road noise than any set of tires i have ever had. I will replace with goodyear F1 ds g3.
The front end has no idea where center is. It tracks anywhere the road takes it.
However there are alot of things that are right with it. It's solid vista blue and looks graet and excellemt power.
I had the worse case of buyers remorse that i have ever had on a purchase. But as i get things fixed on it, I like it better. Just my $.03
I was talking about the differences between premium and regular fuel. I made ZERO complaints (that would be zip, zilch, nada) about the Mustang.
My only complaint (if I were in a position to offer one) would be that Ford doesn't offer the car in Dark Highland Green. THEN it would be perfect.....
Loren
Powering out of a turn, or when entering a highway isn't what I would consider a stunt. Hell, I do it everyday so that it makes it easier to merge.
True, you have to be careful in the rain, because TCS doesn't stop you from loosing it.
A stunt? Ha, now that would be when a few guys wanted me to pull some 360s in the parking lot of 6 Flags.
May not be 17, but it sure is fun to play sometimes.
The difference may be that you and I, or someone else is just a little more experienced then our poor fellow who spun out. That's all.
