Engine Hesitation (All makes/models)
1363739414248
  • mert2mert2 Member Posts: 74
    but in the meantime does everyone agree?
    I have no idea what you guys are talking about, but I do appreciate your efforts and the efforts of everybody else participating in this discussion.
    It's about time for my 5000 mile service. I'm kinda hesitant (no pun intended) to have the TSB performed...Wish more people were reporting positive experiences about it.
    Hmmm...that survey is like asking people what they like about marriage while they are on their honeymoon...I want to see the one year follow up list.
  • bkinblkbkinblk Member Posts: 198
    Understood. The problem is the car is consistently inconsistent, thereby making your analysis troublesome, I'm sure. From what I can tell, the car initially seems to shift a little better in the mornings just after the re-connect, but as the day goes on (hotter trans fluid?), the car resorts to more frequent slippin and slidin and slight hesitation in stop n go. NOW, I have a MAINTENENCE REQUIRED light on the dash.
  • 05camry33se05camry33se Member Posts: 67
    bkinblk-
    Has it been 5000 miles since your last oil change? The light will illuminate at 5k as a reminder. I believe it is reset it with the odometer, I did this a few k back. More info is in your owner's manual on this. Hope it helps.
    22 MPG. 50 miles. Nothing out of the ordinary. Still think the car revs too high in first, then slides into second, but it always has done that.
    Thanks- I'll check it out
    yeah - what is interesting was the report "there's no going back" after the TSB mod... my hunch is they most certainly have the original programming file / download / what have you to restore the configuration to the current state, but procedurally, maybe they are not allowed to apply prior configurations (i.e. a downgrade) or maybe they permanently mark the car in some way to indicate to other dealerships that the TSB is applied, and could throw another shop off if they reverted to the older configuration pre-TSB.
    either that or they know there is some attribute about the reflash that isn't good or truly effective for the vehicle...i mean why advise against applying it?
    very very wierd.
    If the technicians are aware that the TSB is written to address some ancillary issue, not the hesitation symptom directly, they are probably correct in giving this advice.
    "Buyers Remorse" can be bad enough when things go well, or as the buyer should expect, when the result is unexpected or not directly a cure.....
    Nothing new. 22 mpg. 30 miles. Car is still a T.U.R.D. (Terminally Unresponsive & Ridiculous Daily-Driver). Funny thing is, if they put a CVT in the 2007, or completely work out the bugs in the 07, I would consider it based on overall quality. However, now, I'm married to a 10 with the personality of a 2.
    ...crickets....
    Unless you think otherwise we might as well discontinue the "disconnect" testing.
    What would be your personal conclusion...??
  • ecotrklvrecotrklvr Member Posts: 519
    If, and I say if, Toyota's 2006 Highlander is better, there's still hope.
    Toyota can't enjoy all the negative attention. That, and they have already shown some measure of willingness to put time and money into finding things to try. But I cannot believe this is an insoluble problem. A new model year changeover often provides hosts of small improvements to many models, by all manufacturers.
    Now, I'm not forgetting that this whole mess came about during a new model year upgrade. Before Drive-By-Wire came along, with VSC and TRAC standard, this issue was virtually unheard of at Toyota. Actually, it proves the concept that the product frequently changes at this time of year - it's just that sometimes the new technology doesn't work right the first try. Manufacturers try like hell to prevent it, but imperfect technology sometimes does get sold.
    Now back to the "if" - since so many people seem not to have this problem, and there doesn't seem to be any way to prove in court, or to an arbitrator, that this is a real safety issue - there won't be a recall. There's already been some TSB's. But when Toyota get's tired of making their vehicles like this, with this much grief, and all this hyperbole and vitriol, they will make them a different way. Their Executives and Engineers can't be happy to drive cars that have this problem - they have friends and relatives that ask about why their Highlanders and Camrys (and their Lexus up-market cousins) jerk like that, while driving thru parking lots. Someday, the products will change. And not just the firmware - there will be new hardware - faster CPU's, better communications interfaces, AND better firmware. They'll work better, and more consistently better. And when they do, we'll have something specific to ask for. All we can ask for today is something that inspires few to run out and get it.
    If they have a solution, it'll be an improvement to the 2006's. I hope so, 'cause for the Highlander, it'll be a complete redesign in '07, with a new design transmission - the 2006 will be a lame duck, last-year model. Plus it'll be a larger vehicle - the RAV-4 is getting a lot bigger this year, and Americans wanted bigger cars - at least during the last 18 months or so while the new model has been being designed. Meanwhile, I'm still reading the Forum, and keeping my fingers crossed for all affected. And awaiting the RAV.
    Soooo - anyone driven any '06's yet?
    And not just the firmware - ther'll be new hardware - faster CPU's, AND better firmware.
    that part i agree with you.
    from my perspective - the situation is in part that once solid, simple, well vetted designs are now being replaced by feature-laiden, out-sourced parts-based, multi-vendor integrated, higher complexity systems rushed to market that have their own "smarts"...
    and that tend to fail in the most bizzare, novel ways...
    making it almost impossible to service (unless it properly self-diagnoses and throws a decipherable code to a computer technology-centric mechanic (? sorry technician), at which point because of same complexity and the rest of the previously mentioned, demands almost full-replacement because the individual parts are not serviceable.
    did i mention lowered reliability?
    did i mention cost?
    i'm not speaking toyota here, i'm speaking about all the manufacturers.
    when these systems "work", they seem marvelous, but when they fail...
    Well said. What ever happened to the design goals that used to try to make systems that were fault tolerant and robust?
    Now, they've used the ECM's to "protect" the drivetrain - because it isn't inherently robust. They have to rig the throttle response to not allow much torque to be developed or transmitted, in any kind of responsive way.
    I applaud their making the safety systems standard - that's what demanded that the VSC computer have a way to close the throttle instantly - called Drive by Wire. But grafting the new system onto the existing system works "just OK" at best - when everything works as it should, it's great. But, as you said, lots of bits are being slung around - thru multiple micro's, via last-generation interfaces, all of which were designed for slower-responding systems. Since Drive By Wire is here to stay, they've got to do better.
    Anyone here remember the US built cars of 1974-1982? Two oil crises killed big car sales, and then tighter EPA regs - yikes. Lots of those cars were sold with lots worse driveability problems. They were built that way, and most were eventually "retired" that way. I went right from a 1968 Malibu V-8 to a 1983 Toyota Tercel, and missed a lot of that party.
    Toyota/Lexus cars had the ability to instantly close the throttle long before DBW was used. My 92 LS400 has two throttle butterfly valves, the one controlled by a cable from the gas pedal and another one just downstream using a servomotor.
    And...
    I'm pretty certain I have seen some note, hype, about the upcoming 2006 models saying that the ECU has been reprogrammed to hold lower gears longer so some level of engine compression braking will be available to help cruise control retrain the speed rise on downhill runs.
    Two TSB's performed. A new solenoid valve. Dozens of phone calls. Complaints to the dealer, NHSTA and Toyota Customer Experience. Dozens of Edumunds Posts, Two failed arbitrations. Battery disconnect test. CONCLUSION? The car performs the same as when I first purchased (leased) it. Counting down the months where it's cost effective to trade it in.
    Anyone else intrigued about the possibility of the MAF being a part of the problem?
    These things are essential to your vehicle's smooth running. If it's giving bogus information to the ECM, you'll get hesitations & stalling because the engine will be running too rich or too lean. THere are other sensors that, if malfiunctioning, will give problems like these as well. But none of them have thousands of cubic feet of air flowing through them like the MAF does. Beacause of this, it will get dirty over time, even with clean air filters. If cleaning them wasn't so dang easy, I wouldn't bring it up. But it is.
    I've cleaned the MAF sensor in all of my last 5 vehicles, and always got an improvement - smoother running, better idle, and even better mileage (once). Worth a try, in my book.
    on the MAF... i agree. any informatin for people on how to locate it?
    too bad the EGR valve isn't also conveniently located. i believe it may also be a major contributor to vagueness in shifting, bucking, hesitation.
    Sorry, but mine is an '02 4-banger. Most here have an '04 or '05 V-6. Wish I could help.
    but maybe a prevention method.
    The primary feedback sensor for the proper/correct mixture ratio is the oxygen sensor downstream of the combustion process and before the catalyst. I don't doubt that the system uses this downstream feedback to compensate, adjust, for long term changes in the MAF sensor's output. And don't forget, right there nearby to the MAF sensor is the incoming airflow temperature sensor, maybe just as important as the MAF.
  • jagalonjagalon Member Posts: 1
    I purchased a 2005 Camry XLE and love everything about it except for one, major problem. I noticed an annoying hesitation at 20 mph when accelerating around corners, or slowing down for traffic in front of me and then re-accelerating. When investigating this annoyance in the Toyota forum, what do I find? There are quite a few of us having this same problem!
    What, were our cars assembled on the same day, same place? Problem with quality control of a particular part? There's something we have in common that other Camry/Lexus owners didn't get stuck with. I've had the drive-by-wire computer re-set by the dealership twice and the problem is still there. :surprise:
    While others have complained the major complaints of engine hesitation seem to be coming from owners with the V6/5-speed transaxle, FWD/AWD, Toyota or Lexus.
    The only firm admittance by the factory personell is that the delay is there to protect the drive train. That could mean anything from preventing engine knock/ping while in an inappropreately higher gear, or to protect the transaxle clutches by delaying the onset of engine torque as the downshift occurs.
    I think it has become pretty conclusive that the inception of the problem is when the transaxle upshifts too readily when the gas pedal is fully released, even momentarily.
    If the engine were allowed to try to develop a significant level of torque while in the higher gear it would certainly lug and knock/ping, and since a downshift (or two!) is an absolute MUST the throttle must be kept closed for that.
  • cam2003cam2003 Member Posts: 131
    Started from day one when the car only had 10Km, I already sensed something wrong with transmission (jerky and hesitation).
    Can anyone explain to me why this was due to MAF sensor (get dirty with 10Km ?) or Oxygen sensor failure ?
    Hey, listen, I've got plenty of theories - no explanation. I doubt whether anyone has.
    There have been posts that indicated a replacement of a MAF cured one vehicle. Based on this one piece of information, I wouldn't spend much time or money on any experimentation. But, cleaning a MAF qualifies - quick and low cost. It takes less time to do, than writing down a well-presented post on theory or explanation.
    No offense intended here! Just for your info, I looked my MAF under microscope, looked shinny, no single dust on thermistor or heater element.
    Nah, none taken. I can tell that you're scientific, mechanically inclined, and interested.
    The thing that make the contamination so insidious is that it's the heated element that melts and vaporizes the contaminants, and thus "plates" them onto itself. The rushing air smoothes it over, and...a shiny surface results.
    I use a spray solvent, like brake cleaner, to shoot it clean. I find the less eco-friendly it is, the better it works - the eco-stuff leaves a little residue. It's such a little spray that I don't worry about the ozone layer from this anyway.
  • jbuchananjbuchanan Member Posts: 27
    Thank you ecotrklvr,
    I did not suggest this would cure this hesitation problems on all toyota's with this problem, I only shared my own experience with what seemed to sound like the same hesitation that I had in the RX300,Apparently it got misunderstood that the MAF sensors that I swapped from the Toyota to the Lexus were not the same part,If you look back at my response I said I they had the same part number, So that tells me that Toyota which designs both car lines,Tends to share some of the same parts as does Honda and Acura.I'm all for saving a penny! I would rather loose money and retain a customer then for them to tell all their friends.If I don't know the answer I'll do my best to find the right one!
    jbuchanan
    New Experiment....???
    I've been browsing around the internet, and the 04 RX330 shop manuals, trying to determine how changing out the MAF would result in alleviating the engine hesitation problem.
    The 04 Lexus shop manuals indicate that there are two temperature sensing thermistors (resistors that change resistance with temperature) within the MAF sensor module. The first of these is in a bridge circuit along with the nichrome wire airflow sensor itself. The second appears to be a standalone IAT (Intake Air Temperature) sensor.
    I have been tinkering with the idea of somehow fooling the engine ECU into thinking there is less (or more??) intake airflow than actual to see if an incorrect MAF signal might resolve the problem.
    But then I came across something on Ebay called a "Progressive Tuner".
    For $35 you can buy this device that modifies the IAT signal in such a way as to fool the engine ECU into running a richer fuel to air mixture ratio than is ideal from the perspective of minimumizing emissions, no unburned hydrocarbons nor oxygen in the exhaust.
    If Bkinblk is willing to try the device I am certainly willing to go on Ebay and purchase one and send it to him.
    What say you?
    Good description on Ebay just search for "progressive tuner"...
  • donxdonx Member Posts: 44
    Just sold my Toyota Sienna 2004 and bought a Honda Pilot 2005 (EX-L) a month ago. Like the Toyota Sienna 2004, the 2005 Honda Pilot is also a drive by wire system, but after one month ownership, I have never experienced the problem I had with Sienna and it never hesitated when accelerating after applying brake. If Honda can make the drive by wire system this smooth, I think there is no excuse from Toyota to claim that the hesitation is normal for the drive by wire system (for better fuel economy?), and have I mentioned this? my Pilot drives faster than my Sienna and the fuel ecomony is better than Sienna even thought Pilot is heavier and 4WD (the Sienna I had was FWD)!
    what about premature CAT degredation from running rich? that doesn't seem like a good thing to do.
    Of course I will try it. How do you hook it up? Is it something I can do myself?
    Will there by any CAT degredation? Is the "experiment" detectible at a Toyota service dept. (warranty issues)?
    That's great. I'm envious. Do you have a spare $5000 that I can use to get out of my lease? The Pilot seems like a great vehicle.
    if you run excessively rich, unburnt fuel gets to the CAT. have wwest warranty your CAT. ;)
  • dla2dla2 Member Posts: 87
    Our new Pilot also has none of the hesitation issues that my Camry had. My biggest complaint so far is that the back glass does not open separately from the rear door. But I knew that before the sale.
    First, when you go WOT, as some do, the mixture is quite seriously RICH. Not disputing that running that way wouldn't damage the catalyst, just that it is clearly a long term process.
    And I'm not proposing an "excessively rich" mixture. Given that running with premium fuel has alleviated the symptom for some folks (seemingly), running between optimum, 14.7:1, and "rich", ~12:1, might do the deed.
    And I am by no means recommending a long term experiment, like the "disconnect", a week or ten days should show results one way or the other.
    google for:
    seti "pioneer 10" osprey
    Link to my company is there.
    so then tracy kidder's book soul of a new machine: thumbs up or down? ;)
    Loved it, still a few copies laying around here at the office, maybe even a few at home.
    Once told Herb Richman that our Falcon Co-processor was:
    "The Very HEART of an OLDER machine."
  • billranbillran Member Posts: 113
    Well as long as we are commenting on vehicles we have driven that have no hesitation problems.. My 2005 Highlander has driven great from the day I got it and I have no problems with hesitation at all. The Pilot is an excellent vehicle and I almost got one of those, but my wife's preference won out and I have no regrets. I only mention this because sometimes this discussion deteriorates into something that would imply that all Toyota V6 - 5 speed transmissions are flawed, which I think we have proven is not true. Further, there are more than just a few of the owners of the hundreds of thousands of Toyota V6 5 speeds out there who are perfectly happy with their cars. I know this fact upsets some people. I do however think that it only right to restate this fact when we are headed toward a Toyota Bad, Honda Good sort of conclusion.
    I also know there are some out there who question my motivation in even posting. It is only because I see what I believe to be distortions and unsupported assumptions, and there should be the opportunity to express another viewpoint. On that note, I would question the motivations of someone who directly promotes a specific competing vehicle. A Honda dealer perhaps? I am only kidding there, but I have read similar accusations about my motivations and any sort of assumption of that type should work both ways.
    does your highlander have a drive by wire throttle system?
    I think you own a Lexus? I test drove GX470, and almost bought one (but ended up with Pilot for a better value), very nice, and I have not noticed any hesitation from several test drive. Just curious, is GX470 also drive by wire? I also liked Toyota Sequoa, and had several test drive as well. Don't know why the hesitation problem only reported mostly in Sienna(after 2004)/RX330/Highlander (after 2004) and new Camry, but not in GX470 and Sequoa.
    I think the 2005 Highlander is sharing the same power train with Sienna and RX330, so yes, it is drive by wire. I knew some 2005 Sienna owner, they told me they never experienced the hesitation problem I had with my 2004 Sienna.
    The hesitation saga continues...
    Or does it...??
    Let's suppose that when jbuchanan substituted a Toyota MAF sensor instead of the appropreate 04 or later Lexus sensor the Toyota sensor he removed from a nearby vehicle was a model prior to 04.
    The MAF sensor module in my 2001 AWD RX300 looks exactly like the one pictured in the RX2004 Lexus shop manual. Obviously there are physically interchangeable and the two electrical diagrams indicate plug and pin compatibility also.
    But....
    They have different Lexus part numbers, the 2001 is 22204-07010, and the 2004 is 22204-0D030. The 2001 Lexus shop manual indicates that at 68F intake airflow the IAT resistance will be 2.21 to 2.69 K ohms. The 2004 manual doesn't give actual resistance values only that measurements of 98.5 ohms (-40C/-40F) or 156K ohms (140C/284F) continuing for over 0.5 seconds or more indicate a sensor failure.
    An acceptable resistance range of 2.21 K ohms to 2.69 K ohms. A ~20% tolerance to measure a 68F airflow.
    The 2004 RX330 does not detect an IAT failure, out of range, unless it measures minus 40F airflow or 284F airflow for 0.5 seconds or more.
    Suppose the MAF/IAT module jbuchanan removed was on the low end of the tolerance and the one he installed was at the high end? Or even worse (better??) suppose the one he installed was for a pre-04 model year.
    What say you, jbuchanan??
    V6/5-speed DBW transaxle equipped vehicles with IAT sensors that by pure happenstance are on the high end of the tolerance, ~2.5 K ohms or greater, at 68 degrees F would be less likely to exhibit the hesitation symptom than vehicles with IAT that are on the low end of the tolerance.
    It's pretty clear that having a higher IAT resistance for a given "actual" intake airflow temperature would result in a richer mixture ratio overall than one with a lower resistance.
    But if it is this simple then why has Toyota and/or Lexus not addressed the issue?
    Where do I send the new Lexus MAF sensor that I am about to go and buy?
    I'm hoping that Lexus will allow me to sort through the available stock and find the one with the highest IAT resistance at room temperature but if not I can buy a "lot" of thermisters in this range and sort through them to find one that is 2.69 K ohms at 68F or close thereby.
    wwest, are you addressing me? Am I to understand that you are purchasing a new MAF with a higher IAT resistance to be substituted and tested in an 05 model with a lower resistance? If you buy, I'll fly.
    Ay this very moment the new MAF/IAT sensor has its cover removed so I can attach three wires. The plan is to have a switch mounted on the module itself so that it will have a neutral effect position, (normal signal) a "lean" (falsely hot, ~100F, sensor signal) position, and a "rich" (false cold, ~45F, sensor signal)
    Having "soaked" here in the shop at 74.5F all morning this particular sensor's IAT sensor measures 2049 ohms. The plan is to continue to use the module's actual IAT sensor but be able to switch in a resistor in series with it to simulate a colder intake airflow than actual, or a resistor in parallel to simulate a warmer intake airflow than actual.
    I will install it in my 2001 RX300 for a few days and try it at both signal modifying settings to be sure nothing untoward occurs.
    At the moment I am guessing that the "lean" position will be the one to do the trick. Constantly running a lean mixture would make the engine more subject to knock/ping. Hopefully that will result in the ECU being more reluctant to upshift the transaxle into an area where it's likely to lug down and cause engine pinging.
    Hopefully.
    if you two are going to do an experiment, please get the $125 OBD-II interface with software that can data capture the toyota specific variables... do the experiment correctly not half way. wwest, come on, it's no PDP- instruction set emulator but the data will liberate us all... ;)
