Chevy Silverado - Continued XIII
oby -
$50 to install the right angle??? doggone, man! a $2 zerk and $5 worth of labor.
kyle
kyle
-jarvus
Fill the new filter with oil, install filter, wipe down the drain plug area and reinstall the plug.
Go up and fill with oil. Start engine and check for leaks (only once in 35 years did I find a leak, but it was a huge one!).
Clean up work area, properly dispose of oil and filter. Have another liquid refreshment and check what is next on the never ending list of things to do.
I guess my final answer is that I never watch the oil gush out of the filter, I just accept that some comes out.
Mike L
PS: my 0.02 - M1 5w-30 (or 0w-30) and PF-59 filters every time the oil minder light comes on.
Oil reminder light - Im at like 3150 mls now and still no light has come on
Ryan
In the video on post #47 is a new Chevy 3500 dually 6.6 Duramax diesel with Allison trans in tug of war with Dodge Cummins and Ford PS
I've never done that before, any specific advantages to that?
-Jarvus
Fill the new filter 3/4 full before installing it to prevent a dry start-up. Not really much difference though as the filter is filled within a couple of seconds.
Note: No more than 6 qts should be added with oil change and filter regardless of the mark on the dip stick. This six quarts includes the oil added to the filter if you choose to go this way.
Dustyone
around here Silverado Ext.cabs are the family hauler...unless you a yuppy...then the Tahoe comes in....
The oil light was reset most likely when you had it changed?....so you may not see it until about 4200-4700 miles from then..that seems to be my average.
Jarvus,
Filling the oil filter allows the oil to get to the engine faster. If it's empty..instead of sending oil to the engine right away...it has to fill the filter..while the engine starves. Start up is the most important time for oil flow...period.
Dustyone,
The dealer puts in 6.5 quarts in my 6.0.
- Tim
for what it's worth, my mechanic showed me a
trick. he takes a center punch and pokes a hole
in the bottom of the filter. that allows oil to
drain while you are also draining the pan. works
for me and minimized the mess. oil light came on
at 5500 mi. for my ride. then again my miles are
80% highway miles.
Obyone, what is your truck, a 2wd or 4wd?
...red
filter - interesting (new!) reading here. i've never filled the new filter before installing. mechanic buddy taught me to drain pan, remove old filter. replace drain plug, lube new filter gasket with clean oil, install new filter and clean up area. go up top, insert 5 quarts, start engine, wait for message lights on the dash to go out, go back, insert 6th quart. let sit for a bit, come back and check dipstick to verify in operating range. if not, check for puddle underneath vehicle indicating forgetting to replace drain plug . he told me he forgot to do that once...doh!!! anyways, filling the filter makes good sense. where do you pour the oil? right down the middle? or down in all the holes too? thanks...
kyle
I finally noticed what the locking rear feels like. last night i was driving in some high wet grass and i put it in reverse hit the gas and i barely went anywhere so i floored it i could feel the drivers side wheel slip maybe for a second or 2 then a noise and i could feel the rear axle lock and i went backwards fine. I am glad i got this its better than using 4wd when you only need it for a second.
Ryan
Ryan
Family trips would be a Burb for me..
No answers are wrong....just have different opinions..
How can you think about family at 19?.....again..to each his own...
I wouldn't trade from 18-30 no kids...for anything in the world..
- Tim
Any of yawl got today off?....I decided to stay home one more day....then a big whopping 2 day week!
hehehhehhehe
Tim i figure 5-8 yrs a new vehicle. By then ill hopefully be out of school have a house. Thats why i am thinking about "family". Gotta start thinking thats what i did for the truck. I got it and im very happy with it too.
A day off you &#*$^(#^&*$ well i had sunday monday and tuesday off. I should have taken off today but then i thoguht hmm i owe $175 for my tail light guards thats this wks pay just about after taxes.
Ryan
Tim
agree on the burb or Yukon XL, Denali is like a reg cab short bed truck...easy to drive though.
Ryan
Thought you said the first oil change was free for whatever reason, since you went back to the dealer for filters or something...
At a friends service station, I seen the quickest way to drain oil.
1- Remove oil filter
2- Start vehicle--oil drains in like 2 secs flat
The guy working on the car forgot to put on the new filter...what a mess...
Ryan
charged for)
One doesn't get charged anything when one gets somethin for free
I did say that but it was on the print out (receipt)they gave me but the charge was 0.00 at the bottom. It was a verification of all the service done for my records. Hours oil and materials used (oil filter).
Ryan
upset my whole day. heh, cryin' ryan try to be
more specific.
Obyone, i'm a little confused, maybe even blind
or something like that. my truck is 2wd. and i
only find 6 zerks, 4 for the ball jts. and 2 for
the tie rod ends. are there differences on these
2wds. or am i not looking in the right places?
...red
Ryan
off the hook with me at least. LOL
Ryan
I makes a difference in how fast the oil gets to the parts and how fast the oil pressure comes up.
My oil minder light came on the first time at 6889 miles. But, I had changed oil/filter at 600 (dino oil) and 2500 (M1) miles without resetting the light. I wanted to see when it would come on if left alone. All but the first 600 miles were highway miles (I was on vacation) and that is why it went almost 7000 miles.
Mike L
LOL
and for the arm rest squeak...pour some 10-30 on it...it should go away..
...did you change to summer air in your tires yet Ryan?
- Tim
sqeaky arm rest-
all purpose grease may work better due to its clinging properties
Ryan
ryan...wd40. if you don't want to spray it in there, put some on the end of a long cotton swab. may want to "pry it open" a bit to see where the hinge is first before you go jabbin' some oil stick in there...
all...appreciate the responses on "filling the filter" question.
kyle
...see..we are looking out for you
- Tim
Ryan
Ryan
..Penzoil?....I'd rather use Mazzola Corn Oil!
Ryan
LOL
- Tim
Ryan
Had to...
- Tim
Would 5W-30 be a better all-year-around oil to put on a squeaky arm rest?
- David
Good thinking!
- Tim
My door handles ARE the same color as the rest of my truck: Black.
Richard
I had a good look at that Royal Purple synthetic oil...it is a deep kinda royal looking purple color...thought it to be unusual to be pouring something purple into the engine...
I think that purple would look nice if it was the color of some new type of beer...Royal Purple Beer has a nice ring to it....might go over well with the Tundra crowd...seeing that it seems to fit that yuppie mold....
you know, i wasn't going to mention that my door handles are the same color as my truck for fear of being referred to as a smartass - something i dread awfully. but yeah, ok, my door handle and body color match as well. by the way, i'm not under 20, but i haven't worked on cars much either. something i never got into. heck, that's why i come here, cuz at least there's one person here who's over 50 and has worked on cars a lot...you! oops, there i go being a smartass again! wait, no, you can't be over 50, cuz your truck is black...hmmm. that kinda invalidates the carmine theory...ryan???
kyle
Im not under 20. Almost 21 woohoo!!! 2 and a half months.
Well guys its gonna rain tomorrow im gonna go wash my truck now. Im gonna take the use only the hose without the nozzle theory and try it hope it works thanks guys for all the info
Ryan
Ryan,
I think you need some K9P for that armrest. Just go to any hardware store and ask for it. I'm sure they'll have some or know where to get it...
2001 Silverado LS, Z-71, 5.3L, ext-cab, Lock Dif, P265's w/ AL rims, Fog Lamps, Tint Glass, Comp/Temp Mirror, towing pkg, autotrac, graphite cloth 40/20/40 seats, and the outside two-tone colors are..........White & Pewter.
Sorry Ryan, I'm only 34, not old enough to get Carmine yet.
I can order all of this for only $26,725 + tax.
I'm going to miss my 1989 Silverado when I sell it.
- David
Everett, Washington
