I really wanted to make up my mind this month but I think I have to test drive a 6c before I decide. I also should probably try a Sport model to see if I notice a difference in handling.
Take care of either one and it will last you up 200K+ miles or 10-15 yrs. I and my family have had 7 Toyotas. There never has been a significant problem with any of them.
rs in boston
A) It has a 2WD, rear drive only, mode.
It has an AWD mode wherein an electrically controlled center "diff'L" is used to dynamically apportion torque between the front and the rear. For instance as lateral forces build at the front due to stearing inputs, etc, the engine torque is primarily apportioned to the rear.
C) It also as a 4X4 mode wherein the center diff'l is locked.
In contrast the new RAV4 system, a virtual duplicate of the Ford Escape and Mercury Mariner system, is based on a front wheel drive system and therefore can quickly become unsafe in the very conditions in which "marketing" says it should "shine".
Unless the engine/transaxle DBW, e-throttle, firmware is designed to rev the engine up to the "sweet-spot", the level cognizant with the current transaxle gear selection and the rate of rotation of the REAR wheels, to alleviate the potential for loss of directional control from engine compression braking in adverse roadbed conditions.
Frank
I feel that fwd/awd is the very best there is out there for the average person in an everyday driver....
Take this from an engineer with about 35 years automotive experience.
Frank
Current "slip detect" awd systems like on the CRV, 2006 Rav4 and others should really be called "too-late awd", because by the time is reacts for traction, slippage is already occurring. Its really only useful for getting unstuck from a stationary position.
Subaru's system and Audi's quattro are much better than the above, for the same reason that the old Rav4's system was better.
Thats one of the colors I'm interested in too.
I'm also an "engineer" but started out driving tractors in the cotton fields of AR in the early fifties. If you lose traction on the drive wheels of a RWD it's almost always correctable by simply lifting your foot from the gas pedal slightly and the front tires' contact patch is reserved, fully, for directional control.
That's why the early "beetles" were so fabulous, rear engine rear drive.
AND on every start from a stop, all 4 wheels have power applied to them. 55%/45%.. The only time that the Rav switches to fwd is when the truck is moving and no slippage occures... To raise gas mileage. The Honda system which has been in use for many years works fine. Its a proven system.. And with the traction control, Ill put a 06 rav against any previous gen Rav in a slippery situation.
You should do your homework...:)
Frank
http://tinyurl.com/7zoma
I know you want to justify your purchase, and it may very well be that you'll never be in a situation where that extra traction will come into play. But you clearly don't have the knowledge here that you pretend to have. Sorry. :sick:
Toyota has a bi-monthly ordering process with it's dealers.
If you make it too specific then your special vehicle may take upwards of 4-6 months. Many dealers, us included, discourage these ultra specific orders because they just create ill will when they don't come on time. We don't want unhappy clients.
Is it only leather that you want in your special order?
Frank
I live in a NYC suburb. My town's plows have made at least 2 passes before I leave my house (& I'm out well before dawn). Slip-detect is more than adequate under these conditions, & friends who own both Outbacks & CR-Vs back me on this. I also think (but can't prove) that part-time systems might yield slightly better fuel mileage during the warmer months.
That said, I'd probably have a Subie if I lived in northern New England.
From a strictly functional POV, full time AWD, however, is the superior system. It all depends on how one drives, and what one will encounter. You won't see any rally car drivers using a part-time AWD system.
PS, for the differnce in price you can go on a great vaction 3-5 times.
Jim D
However, one shouldn't argue that their Tercel has equal performance to a Ferrari, just because that person wouldn't break the speed limit in either car.
And remember, a good set of snow tires on a FWD car is better than the most advanced AWD system on the market.
You're absolutely right about that. For that matter, RWD + 4 good dedicated snows would do the trick in my area.
Frank
Frank
No need to try and convince me that the full time AWD is better, in certain circumstances. However, for the type of driving that I and others are looking for in this car-based vehicle, it will do the job just fine. And yes, I will enjoy the improved gas mileage that the new system provides. Incidentally, I'm not pretending to have the technical knowledge. In this case I don't need it
Well, that certainly wasn't my intention. By now that you mention it, if someone offered me a 2005 4cyl or a 2006 4cyl, I'd take the 2005, without question - if just for the availability of the 5spd, and the better AWD.
It is the 6cyl option that the reviewers are going nuts over (for good reason).
I don't believe CR's assessment was based on any biases. They aren't recommending anything, they are reporting their findings. It also stated the obvious, AWD does nothing to aid braking, adds a couple thousand dollars to the vehicle's price, consumes slightly more fuel and exacts a toll in acceleration. Finally, AWD is a valuable asset in wintry conditions, but if you drive on pavement and don't contend with snow it isn't worth the extra money. Sounds pretty logical to me (no technical advice required).
The reason that you see so many 4WD trucks and cars in the ditch during your average winter storm is because the drivers of those vehicles have the ability to accellerate in any condition, and believe that they equates to superior braking and handling. It does not.
I maintain that 4 winter tires on a FWD car is a better and safer package than any AWD vehicle on all-seasons FOR WINTER DRIVING AS A WHOLE. This is not a novel opinion.
Want the best of both worlds? Get snow tires for your Rav4!
Rest assured, I think you bought the best small SUV on the market today.
But my personal opinion (that I'm not pushing on anyone else), is that there are not enough significant improvements between the 05 and 06 4cyl. to keep it on top of the heap for long. But we'll see.
Frank
I will agree that there are drivers out there who feel they are invincible when driving their large SUV's in snow and ice conditions. They don't drive according to the weather conditions. There are many out there that also believe that ABS is superior in similar conditions. Wrong, stopping distances actually increase in ice and snow. These are the reasons why I see many of these vehicles in the ditch (some flipped) during snow storms. Just curious, do you live in an area where it snows?
FWD (with snow tires) is not better than AWD (with all seasons). I'll take the increased traction any day. Unfortunately, we are unable to control how others drive. Smart (even defensive) driving habits are the key. I think you stated that yourself. We will have to agree to disagree.
I agree that braking is no better and that folks with AWD or a variation sometimes overrate the capabilitiesof the vehicles. But the human factor does not alter my conclusion above.
If people were trained how to brake properly with an ABS vehicle as well as its limitations, it might have lived up to its billing. Stopping distances with ABS are not that much greater--again, though, the human interface places too much trust in the technology. On the flip side, those folks who have been driving with ABS malign it unnecessarily and just have forgotten that feeling in your stomach as you are sliding sideways on glare ice because you tagged the brakes too hard.
Tom
However, if you'd like to challenge a 2wd Pilot with snow tires to a braking distance test, or a slalom, I have a feeling that you'd find snow tires much more "relevant" than an AWD vehicle with average all-seasons in bad conditions. And these are the types of manouvers more common to most drivers than climbing extreme grades.
cheers!
Tom
