Chevy Silverado - Continued IX
matthew
I would expect a minimum of 200,000 miles for the engine iteslf.
owner. another thing some guys do including
myself, ( as if that matters ) is to first punch
a hole in the bottom of the filter. works pretty
good cause by time most of the oil drains from
the pan the filter is pretty much through too.
unscrew the filter and "wahlah" little to no oil
gets on the exposed surfaces around the filter.
little black thingy? now you've got me looking.
...red
excess clearance for the main rod bearings and what the long term effect would be on the 2000's that did not have the change. An opinion would be appreciated...
Dean
It's easy to replace. A little glue may actually keep it in place ...
Richard
- Tim
Ryan
Dean
Ryan
Some day I'll have to put some pictures of the Silverado.
(Insert shameless promotion here: http://members.home.net/rwagoner)
Richard
I had the local 4x4 shop where I got all my goodies paint and install the boards. I'm a "Ryan" type; don't install the heavy stuff myself! (Just yankin' yer chain, 'Babs!)
Scott-swolfe3
Of course, 20 years ago 20W-50 or straight 30 weight was normal.
If you start to have the knocking noises after the engine is warmed up - seek professional help!
Mike L
Ryan
swolfe3
Don't mention it. Actually I had my extra remote sitting around for a couple of months and was actually too lazy to look up how to do it...LOL.
Thanks to you I finally got off my butt and did it!!
Dean
Dean
Net effect, odometer/speedometer will turn slower. You will have less acceleration. You might increase corrected fuel economy....
Dean
http://users.icubed.com/~sknight/
Select JavaScript Programs, then Tire stuff. It lets you put in two different tires, your choice of speeds, and gives you tire speed and rpms for both.
Mike L
When odometer says 60 MPH you will be going 63.
Denny
L8TR Dudes
Pat
Ryanb0928@aol.com
I am having trouble posting them on aol or picturetrail. I think it has something to do with the type of file (bmp) i dont know but i will email anyone who wants to see em
Ryan
Pat no idea what you are talking about sorry if i have a chance ill check tomorrow
You are getting a fatter taller tire. 10 mm wider and 20.25mm taller. The effect, besides the change in odometer and speedo, is greater rolling resistance (read potentially lower milage) and better cornering performance (due to increased contact patch. Also, you will loose some take off power(so small you might never notice) as the increased moment arm will resist your final drive gearing more.
Mike L.,
O.K. Took my own advice and "did the math". at 2600 rpm the crank moves at 15600 degrees a second or 43.3 revolutions (360 degree rotations)per second. Further, that is 1 degree every .000064 second. Assume (I can't find a reference that specifically states this at hand and this is what I remember) gas travels at 3600 feet per second f/s. Or gas travels at 1 inch every .000023 second. Assume a 3 inch piston head. Peak pressure would occur .000069 seconds after ignition. Take this into consideration along with the sample calculations above, the piston head is relatively motionless 10-15 degrees before and after TDC. At this point the crank is essentially in transition under the piston and pumping losses are at their least at this point. That is a lot of time to play with timing (no pun intended). Retard timing 1 degree at 2600 rpm and all you get is autoignition and one or more uncontrolled wave(s) that could start anywhere on the piston head. If you get knock, advance the timing. If that creates too much a pumping loss, up the octane. The few degree advance would be so close to TDC the losses will be much less than uncontrolled ignition. Niether being the ideal situation. Your thoughts?
Phil
<How did you ever make out with the exhaust system?
< matthew
Matt: I have ordered the Flowmaster Seventy Series for my '00 Silverado 4Dr, ShortBed from Summit Racing. Flowmaster is several weeks behind in their production of the Flo-17265 Kit. This is the dual side exhaust, kit the same as you installed. Flowmaster said that this is an extremely popular and highly sought after aftermarket kit and that they can't seem to make them fast enough. I checked all local muffler shops, truck accessories places and no one had them, therefore I opted to order from a mail order house. I received a notice last Friday that the kit is to be shipped 8-22 for a total price of $368.00 (including shipping to Marietta, GA from Akron, OH). I hope that this full bolt-on kit will only require about one hour to install as yours did. I too will store my stock muffler and tail pipe in my basement for a later day if needed. Thanks again for your help in providing the sound files (.wav) as they helped me in my decision to chose the Flowmaster.
Dustyone
Phil
quart low (below the hatch marked cold area) with
the transmission hot, in park, and engine at idle.
My truck has 4300 miles on it. I think that it came from the factory low on fluid. Dustyone
Clay
pjcav
do we have too much time on our hands? LOL. Will check and get back to you...being that it's important and such...
Dean
Leavy
I was also waiting for Obyone to receive his Zummo system to see how that works for him.
Mark
Seems you promised to do something for someone...and you said you'd get back to him asap....hmmm, did you forget?....see topic #2060...post #136... Are you trying to give us rado owners a bad name?....
Dean
I havent been home much the past few days. Sorry fill me in
The asap was it iwht pics??? I have some but not on picturtrail cant do it im just emailing them out
RYan
pat
pat
i noticed in ur photos u have a Z71 hitchware plug in. very nice. i just put in the same one today, very nice cosmetic touch, if i must say so myself. ur truck out of the shop all fixed?
pat
pjcav
My money is with you. I believe its the ambient temperature sensor. First thought it was the impact sensor for the airbags but doesn't fit the description. My $.02.
So you were an Orion driver...boy times have changed. Your old base has been turned over to the State of Hawaii and 90% of the facilities are gone including Paradise West and The Prop Stop. The housing is still being used by military personnel, but no base security of any kind. I believe it was 1 July 99 where NAS Barbers Point was disestablished and 4 squadrons of P3 were moved to Kaneohe MCAS. My company does support work for all branches of the military in Hawaii. Mostly in maintenance of HVAC systems. Recently returned from TDY to Kwajalien...ugh. Well at least part of this post was Silverado related...
Dean
