Visitor Agreement.
I have NO idea how much a car uses at idle. However, 0.2 gph seems low to me (again, without any real knowledge on the subject), as that means a car with a 15 gal tank could sit there and idle for more than 3 days straight on a tank? :confuse:
"UPS drivers adhere to a no-idling policy to help reduce fuel consumption and harmful emissions. UPS has cut the amount of time delivery vehicles idle by 24 minutes per driver per day – a fuel savings of $188 per driver in one year."
Saving Fuel: The Benefits of No Idling
I wonder how much the industrial engineers make that figure this stuff out.... and what the timeline is for that payoff?
Because if turning off that truck adds more than 2 minutes to the driver's day, then they are losing money....
24 minutes times 200 days worked, divided by 60 minutes is 80 hours a year.
$188 divided by 80 is $2.35 per hour. This is a too coincidentally exact number, so if you do some quick math, you get a $3.35 a gallon price figure and a 0.7gph estimated use. (most large trucks and semis range from 0.7-0.8 idling) This seems right for what is probably 1-2 year old raw data.
BUT - that's for a large diesel engine. Most of these are P500-800 series vans that are customized for UPS. Almost all of them have a Cummins 6.7 diesel engine in them. A smaller gasoline engine should get much better than 0.7 gph idling, even if they are less efficient at doing so.
A typical gas engine is 25% efficient while idling, and a typical diesel is about 40%. Taking that into account, a 6.7L gas engine should use 1.6X the fuel of the same diesel engine while idling. That's 1.12gph Or about that's listed in most magazines. But if you plug in displacement of, say, a 1.4L engine like in the Cruze, you get a 0.23 gph figure, give or take. Most engines with a 3.0L or so engine will, of course, use almost 0.5 per hour, with a slight difference in use do to idle rpms. (almost all gas engines idle at 650-800 rpm for smog purposes, no matter what the displacement)
I will look at my scanguage today to see what it actually reads during idle. Yes .2 gph does seem low, but the numbers I saw ranged from about .15 to .5 depending on engine size and efficiency. I suspect my Accord is just over .2, but I will get the actual reading off of the OBDII computer.
note - a very small direct injection engine might actually get by with cycling every other piston stroke's fuel. I suspect that 2 cylinders running (for smoothness/balance) would be more than enough to keep it turning over.
EDIT - also, displacement seems to be the largest determiner of highway MPG, as most cars today run about the same RPM ranges in overdrive. (roughly 1600-2000 at 65mph). A small 2.0L I6 (as an example) would probably give you 35-40 mpg highway and still get you around pretty quickly.
Not in my experience.
At 2000rpm my Miata is doing about 42mph.
That's in 6th gear, BTW. At 65 it's over 3000rpm.
All v8s are in that range and some v6s are as well, especially higher output v6s.
This topic is interesting, albeit misnamed.
Idle Fuel Consumption Rate per hour(L)= 0.350 x (engine size in L) + 0.330
So for an average 3.0L engine, that would be about 1.38L or .37G per hour.
Muddying the waters is that this data is from 2005 iirc, and changes to compression, cylinder cut and DI will alter those numbers. I'd be willing to guess that a 2011 3.5L sedan sees the same idle number as its 2000 3.0L counterpart did.
Part of my son's science fair experiment last year. :-)
Well, contradictory to that, I have a 2.0L engine... and it does not get anywhere near 35 mpg highway.
Mercedes made some 2.2 and 2.3L I6 engines back in the 60s, IIRC, and they got very good fuel economy for their time.
Hmmm, all else being equal (which it rarely is), it would seem to me that a long-stroke I4 of two liters in displacement would have more torque than a relatively short-stoke I6 of two liters in displacement. Yes, no?
:confuse:
Since hardly anyone makes small displacement six cylinders in cars or trucks, this is more easily seen comparing small displacement motorcycles and ATVs. There it is obvious and compelling... fewer cylinders for a given displacement is more torque, more cylinders is less torque but very often more horsepower.
There's also the matter of cost and packaging efficiency to explain why we don't see any 2.0L inline sixes.
There is much more to efficiency than displacement.
Its top gear is a real overdrive, which helps as well. (the rest of the car is, well, a big Buick...)
Plus, qbrozen drives a GTI.. I wouldn't say that engine isn't designed well... It's just not designed for maximum highway fuel mileage.... :P
I drive stick as well, and keep the revs at around 3000 at all times. Yeah, MPG isn't the best, but I might as well enjoy it while it lasts.
Easiest way to test the theory today would be a G25 versus a 4-cylinder Altima: both 2.5L Nissan engines, though the RWD versus FWD might moot the comparison.
Speaking of tiny I6, my fintail is just 2195cc, but at most speeds is extremely smooth. Gotta love the I6.
To counter your point that no car uses a gallon per hour:
With the A/C on and with adulterated/oxygenated gasoline, my 2005 Pontiac ~20mpg car uses nearly a gallon per hour of gas.
Without A/C, it's about 0.6 or 0.75 gallons.
There are cars that get much worse mpg than my pontiac's ~20 mpg all-arond, ~24 mpg highway.
I'll bet some use about a gallon per hour at idle!
IIRC, another comparative datapoint is: my VW TDI uses about 0.25 gallons of diesel per hour at idle.
cheers,
/e
Think about it this way:
-- Given #1: each power stroke applies meaningful acceleration to the crank for only 140 degrees
-- Given #2: Only 2 power strokes occur every 360 degrees in a 4-cylinder/4-stroke engine
-- Given #3: There are two 40 degree periods per rotation of the crank in a 4-cylinder/4-stroke engine where the engine is doing everything in its power to stop rotating; only rotational mass of the flywheel is keeping things moving along on their scheduled rounds.
It is for this very reason that many 6-Cylinder engines of any given displacement easily outperform (in both rated power and fuel economy) 4-Cylinder engines of similar displacement. For your illustration you chose the poorly designed Mazda 1.8 liter V6; one end of the spectrum. The other end of course is the 2.5 liter I6 BMW was using in the E46 models; this was an engine which was every bit a match in all performance aspects to contemporary 2.5 liter I4 engines. In fact, I'd lay odds that if you were to run a 2004 325i against a 2011 Mazda3 GT, the 325i (in spite of its 200+ pound weight disadvantage) would literally run circles around the Mazda3 and get better fuel economy while it was doing it.
You get maximum economy, torque, and HP out of a 4-stroke engine from an I-6 engine. But it has to be very small to do so. As in 2.0L, optimally. Unfortunately, nobody makes engines like that. Mercedes did in the 50s and 60s - little 2.2L and 2.3L I-6 engines that were amazing at the time. Decently powerful, quick, and less weight that the other manufacturers.
It only made 130hp, but remember, the I-4 1.8l only made 125hp. Ford used that inline motor tuned to 127hp (I owned a '91 Escort GT).
So the V6 actually had a tiny HP advantage. Perhaps not worth the complications and cost, though.
About the 2012 Camry that's still in Pre-Production:
Wound up with the Accord.
Anyway, I gave him his very first lesson in driving yesterday in an empty high school parking lot. It was in our 2010 Mazda5 Sport MT. We just started on 1st gear. He was able to get it going on the second try. Did stall out twice, but got it going three times and drove slowly around the parking lot at 10-15 mph.
Today we might try second. Or is that too soon?
I would like any and all suggestions of those who have successfully taught one of their kids to drive a manual.
At some point I think I need to find a close to empty rural side rode. Shouldn't be that hard, since I live in Louisville KY. May have to drive out of town at some point....
Thanks in advance, Ben
PS Our other car is a 2008 Accord EXL Navi 5MT. That car was c. 26k, whereas the Mazda was c. 16k. So, I have to admit I'm teaching him on the lower cost car.
Our daughter turns fifteen later this year, and I'm thinking as soon as the snow melts next spring, she'll be getting her first lessons in the Mazda.
FWIW, trying second gear today is not at all too soon. :shades:
