A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Firestone Wilderness Tires
John B
with tires being excluded.>>
Except GM, they now warrant tires.
Dustyone
tires that were stricken with this problem and recommended contacting the distributor through him. The distributor offered a discount towards replacement, but we were not comfortable with this brand any longer. I had Bridgestone tires on other vehicles including several motorcycles but now I no longer deemed them to be safe. Instead, I bit the bullet and had my dealer install Cooper tires, the oldest tire company in America. We had them on her vehicle for 26,000 miles until we recently traded it in for a new 4 Runner, and the drove and looked like new. A great product and one that gave us a confident feeling regarding safety.
Bookitty
personally, had a few bad experiences with Firestone, but have seen impeccable performance out of Bridgestones. Never had any dry rot. I've seen dozens of GYs dry rot, though.
I've never heard anything bad about Cooper, you should be alright.
miles at 28psi on Goodyears and not have the
problems Firestone is."
From years of experience with goodyears, they would never last that long. The tread would wear out at about 36,000 miles, and you'd be riding on rims by 40k.
The reason they went to Firestone is because the rubber is harder and last longer, but unfortunately I guess the glue or whatever bonds the tire together does not.
I'm going to disagree with you on that one. I just seen LOTS of tires blow when not operated at the full psi. granted, i'm talking about very heavy apps, but i see the passenger tires as being even weaker.
Anyway, I'll probably wind up accepting the truck and taking it immediatley to a tire shop and have them swapped out. They are P265 tires. Any ideas what costs I'm looking at with going with Goodyear?
Truckchic
My death-stones were the Steeltex Radial, LRE as you mentioned. Mine were early '98 vintage. Like I said, I could feel an occasional looseness (Oversteer tendency.) in the right rear in slow corners. If yours are relatively recent vintage, you should be OK. Just hang in there, eventually Firestone may have to recall ALL of their tires just to preserve their brand name.
This is the second time that Firestone has pulled this stonewall crap. They did the same thing in the late '70s. This time they're being burned by the speed of communications (Internet).
Look at it this way. A company builds an product that is intended to wear out. After a few years the company figures it out that there are some serious defects in the product. So the company applies a remedy and continues production. It is to the company's advantage to do nothing about the problem. Why? Because the product wears out and eventually goes away. When the product wears out and is disposed of or replaced the problem also goes away. Only this time, an increasingly aggressive government, bored lawyers looking for fat contingency fees on class actions claims and the speed of the internet has punched huge holes in the stone wall. At this point I have my doubts that Firestone will survive in the form that we know today.
Rich
Dean
I was exaggerating. My point is that the "low" psi debate wouldn't be an issue with other brands of tires.
I've worked many years and witnessed many over-loads and have yet to see a blowout due to psi rating.
dusty,
Since when has GM warranted their tires under the product warranty? I find that hard to believe-especially for trucks.
Check this out for an interest article. This is where I got the idea that GM now warrants tires. My Firestone Wilderness AT had markings (TPC xxxx) that I have not found on other tires. This may be the GM spec.
Ryan
Interesting article but it shows that GM looks brilliant now but this practice is quite common. After the Firestone debacle--I'd bet most companies will alter their warranty deals.
With that said, tire companies won't be thrilled. This would mean that dealers-not their franchises--that would deal with complaints and replacement policies. They definately won't care for that.
Some have been lucky to have their dealers replace the Firestones with something else, but my guess is that this will stop when the dealers have to suck up the cost since GM will not reimburse the dealer. If congress will only force the recall on all size Wilderness tires (ie, P265x75R16), then I will be able to transfer the tires from my basement to the recycle bin through Firestone and recoop my $400.
I would assume that the rubber is not as soft these days.
So, I'm going to stick them in the back of my garage,and wait till Fstone folds up, and recalls them. So , after Monday, no more "I don't want to go in your truck, I'm afraid of the tires!". Well, to be honest, after seeing the ones I saw, I'm not real comfortable with them either.
Truckchic
I think I'll take the money I save and buy some Michelin or goodyear stock. They must be laughing right now with the unplanned increased profit margins.
I certainly would not trust GM on this issue. The fact is Firestone has produced an unsafe product. Now, nobody wants to bear the financial burden of correcting this - Firestone, GM, Ford etc. If I were you, I'd replace your tires. Why should you become a statistic? You might try to sell your old tires on e-bay to recoup some of your dollars - but, I bet you won't get any takers.
I think that Ford, by shutting 3 plants to make more tires available for the recall is putting some money into the process. Unfortunately I think that the Ford employees are bearing some of the brunt of the cost too.
Rich
thanks for the info. i found it hard to believe that the tires were all made at different plants as well. as for the 16", yes, there are some on recall, but unfortunately, they're not wilderness at's.
for those of you in the same boat i'm in (you have non-recalled deathstones that you want to get rid of) check out this link:
http://www.bridgestone-firestone.com/news/consumer/news/00803a.html
if you're tires aren't on recall, firestone WILL pro-rate you new ones, albeit bridgestones. but...you will get non-firestone tires, which at this point, for me, is good enough. i may even go to an independant tire dealer with brand new bridgestones and see if they'll pro-rate them on a set of new michelins...hmmmm???
bco
GM isn't cooperating with replacement either. Great quality company that GM is! LOL!!
SO i am going 75 ---> 70
Ryan
bco
Ryan
he'll give you the lt's...they're not that much more expensive than the wilderness at's ($16/tire)
bco...heading to tim's now
I never run less than 30 psi, no matter what the manual says.
Sorry I didn't reply promptly. I understand your concern about the stones on the GMs.
SUPER-SERIOUS RECALL OF FORD/FIRESTONE/BRIDGESTONE EXECUTIVE BRAINS
From Big Dave-40's Executive Suite - an exclusive, startling tale from the First Amendment Grapevine.
It seems that Ford Motor Company has put its big guns on the big tube to tell us that, "The Ford Family", stands behind all of its vehicles and won't stop until this Public Relations Debacle with Firestone and Bridgestone goes away ... kind of like the old Firestone 500 bedtime story. Most of you probably remember it: "Get Rid of Your Mother-In-Law, Buy Her a Ford Pinto with Firestone 500's on It".
Well, Ford is doing its level best to lie to you the way you want to hear it. How many Explorer owners were informed that their vehicle's tires were tested with (of all things) a Ford pick-up!!! The Ford Guys knew they were killing off the "Family" for at least five years!! It's been said that Firestone Workers and Management (along with Bridgestone) probably knew they were killing peeps (us'ns) for about ten Years before someone blew the whistle on them. Even our fine Government had some data that showed serious flaws as the carnage went on unabated!!
You might well ask, "What's next?" Well, wonder no more. Through his Worldwide contacts at every level
involved - from the bars outside the Firestone and Bridgestone Factories right down to the Gross Pointe
(correct spelling for these vermin) Country Clubs where laughter at wicked, killing crashes was not unusual - Our Leader, Big Dave-40, has come upon the latest scuttlebutt that ya'll need to know. THERE'S A GROUNDSWELL OF PUBLIC OPINION THAT IS NEARING TIDAL WAVE PROPORTIONS ...
IT'S A PEOPLE'S MOVEMENT TO RECALL ALL THE BRAINS BEHIND FORD, FIRESTONE AND BRIDGESTONE. Let's face facts: they need to be refitted or, at least, regrooved immediately. Either they seek serious professional psychiatric help or they are out of the business for good. Their sociopathic actions have killed too many. Big Dave says, "Enough!"
They've got to go and get re-shrunk. Get their Wives out of therapy and put them in post haste.
We all know how lousy Ford pick-up trucks really are. To use them as a test bed for killer tires to be mounted on that Toy called an "Explorer", is beyond insane. These guys lied, cheated and killed all the way to the bank. NO MORE!! There must be some fine print in the Explorer Owner's Manual that says, "not
for 'exploration' beyond your own driveway!!
Hey Folks, these Ford Folks are nuts to think we believe their PR [non-permissible content removed]. Straight from the hearts of the leading PR Agencies in the World. Just watch, they'll do everything in their power to do the least possible they have to do. They'll never live up to Mr. Studebaker's Motto, "Give Them More Than They Expect",
except in the most macabre sense when they give you a $30,000. piece of crap with dollar store sneakers
and tell you that you can go crusin' the Interstate like you're drive a Pit Bull. Well, the Pit Bull has gout and it's killing people still TODAY. Let's join the Groundswell. Write to Ford and tell them the Executives must go back to square one or go to jail -- no passing GO and no collecting anything but what they deserve, a high-speed ride in a Firestone equipped Explorer or Ford Pick-up "designed to act like one". That won't be
hard, they already act like an aborted Yugo!!
Write your Congressman, your Senator, the D.O.T., the Pres. and Hillary too.
You are called to action, don't let this chance to right a wrong go by. Remember, "There is nothing to insure the triumph of evil but that good men sit idly by and do nothing." IT'S YOUR TURN, PUT YOUR SHOULDER TO THE BIG WHEELS AND PUSH 'EM OUT NOW!!!
Yours For Safer Truckin',
U.S.T.F. COMMANDER BIG DAVE-40
I have 42 in the front of my Michelin LTX A/T's now, 38 in back, it handles a lot better then the Wilderness A/Ts did. Wet traction is a little better, dry seems a little worse(just a bit, need to put a few thou on them to really see). The main difference is that the truck seems a lot less "rubbery" than it did before,and going on the interstate is not generating comments from the right seat! I went 85 today on the interstate,and it was nice and smooth. Now, if they fix my rear window air leaks thursday morning, I'll be set for a trip or two...
I'm seriously considering purchasing a set of Michelin LTX A/Ts (LT265 75R16) to replace the Deathstones on my '99 Z71 too. (Like you, I need to quiet the front seat.) My other option is the Michelin LTX M/Ss in the same size. I'm really curious about the noise factor. Did you notice any increase in noise when you made the change? I've been told that the LTX M/Ss are quieter but I don't notice any noise now with the Deathstones so if the A/Ts are no louder I would like to go with them for the traction in the snow here in Colorado. Thanks in advance.
John
My question is - I don't want the Firestone, and that's what GM is using, so I'm going to swap them out as soon as I pick up the truck. What brands of tires do you all recommend. I'm not planning on going off roading - but I want something that will handle well in Wet, Snow, dry conditions. I do some highway/tollway driving (actually - everyday going to work I'm on the tollway) Advise? Recommendations?
Thanks everyone - I only have 3-4 more weeks to wait! I'm really Impatient! I want my truck!
Truckchic
i too had the firestone p265/75r16's on my '00 silverado z71. for those interested in good tires, but can't afford brand new michelins at $650...here's another option. with bridgestone/firestone offering to pro-rate wilderness tires against a new set of bridgestones, i got four bridgestone dueler at's (LT265/75R16) for 23% of the new cost. by measuring remaining tread depth, they determined that i had used 23% of the original tread on my wilderness at's (about right...i had 12k miles on them). so, for about $220, i got brand new tires. and good ones at that. truckchic, for you, they'd prob'ly be free...make sure you specify that you want the "LT" and not the "P" rated tires though. i couldn't afford the michelins, much as i would like them. the dueler's do not make any more noise or ride any differently than the wilderness tires i had. haven't had a chance to off-road them though. also, it gave me the opportunity to change to the LT rated tire which i feel much more comfortable with than the P it came with. much more aggressive tread also. to see pics of what it looks like, visit my updated pic trail album at:
www.picturetrail.com/kwerking
lots of other good info on there for silverado owners too. questions? sign my picture trail guestbook or post them here, i check back every day or two...
bco
I assume it would be new - and they would give you 100% towards the Bridgestone swap.
Did they charge you for balancing?
The truck is much more stable over bumpy roads and on the interstate, but doesn't ride quite as soft as it did with the Deathstones, but it's ok to me. I did hear questions from the right seat: Mom:"Is there more air in these tires?" GF:" How come it jerks my head now when we go over big bumps?" (Think Jean Luc Picard from STTNG when the ship is hit, she and mom both let their heads bob around when riding, then cry about their necks!) I tried it, and it hurt like hell the next day.
BTW, checked the air tonight, they put 35 in them,not 40. Either Sam's tire guage is off, or they just ignored me when I told them 40. I'll leave the back at 35, and will try 40 in front to see how it rides. The tread footprint looked pretty close in the back, a little under inflated in front.
I was actualy looking for the LTX M/S tires, but they didn't have four in stock at any one place, and I wasn't sure about the "clone" models/names, so I just got the A/T's. Same price, and they seem to be the same tire except for tread.
bco
Thanks. I'll look at the LT 's too. What's the difference? P - Passenger and LT = Light Truck?
truckchic
