Visitor Agreement.
you are not going to have a dog that can't pull anything....but going from 245's to 285's...you are going to notice it big time....and a 4:10 just would have helped take up the slack...
as I've said before....the 1st gear of the 2500 is lower for towing and seems dog like sometimes when driving dry....but just step into it a little bit and she picks right up...
Good Luck
- Tim
chris
- Tim
- Tim
I trying to decide between the 2001 Sierra, 2500, ExC., with the 6.0L engine with a 4.10 axle ratio and the 8.1L engine with a 3.73 ratio.
I will be pulling around a 8000 lb 5th wheel.
I've read everything I can about the towing limits and I'm still confused.
I understand the the truck will weigh 9200 lbs and the GCWR for the 6.0 with a 4.10 ratio is 16,000 lbs. so does that mean that I will only be able to pull the difference (6800 lbs.) minus the passenger and anything else I might add to the trucks weight.
I'd appreciate any advice on this, thanks.
I'll be pulling 5th wheel about same as you.
I THINK good probability 8.1/3.73/Allison will get as good 'a milage as 6.0/4.1/GM transmission.
(Absolutly no reason to get 8.1 with 4.10 unless your pulling goose neck and lowboy with construction equipment on it)
The 8.1/Allison is still the best choice even if the pulling gas milage is a couple mpg less. That allison transmission with grade braking alone is reason enough.
Drive one if you can find it to be convinced.
Only problem is that the 8.1 is going to take a lot longer to get delivery on, but if you don't mind being a little patient I think its worth it.
The 8.1 has been on constraint but insider informaton told me last week that the 'Constraint' has been removed and 8.1 production will ramp from 1% build to 30% build of total HD units.
Good luck with your decission.
75v
I don't think any of the curb weight on any of these trucks are anywhere close to 9,200lbs. The 6.0 would probably do fine, but if I were going to buy either the 6.0 or the 8.1 I'd go with the 8.1. I think you would get about the same fuel mileage in everyday driveing and maybe a little better towing, because the 8.1 won't be working as hard.
By the way I didn't go with either I went with the Duramax/Allison.
Hope this helps Richard Mc
The curb weight on a 2500 HD..ext. cab SB 4WD is 3021 Lbs...
- Tim
My 2001 Chevrolet Crew Cab Duramax/Allison, 4x4, Long Bed weights 6800lbs..
I have the shipping weight from the Transporter, the weight at the trash dump and I took it and weighted it on CAT Scales a few miles from me.. Full of Fuel Without me in it, Weights 6800lbs all three places said the same thing..
A 4x4, ExtCab, Long box, Duramax/Allison weights around 6,200lbs full of fuel and no driver.....
While this was true in the old days of primary and secondary carbs, I suspect in the closed loop multiport fuel injection days that we live in, it cost x fuel economy to make a specific amount of HP. So within a reasonable range, as long as the engine will make the necessary HP at whatever RPM you plan at towing, probably doesn't make as much difference.
I do believe a larger engine might last longer running at smaller throttle openings, but I'm not even sure about that.
Comments/criticisms?????
4670
Rear Gross Axle Weight Rating (lb)
6084
Curb Weight (lb)
3352
Rear Curb Weight (lb)
2278
Gross Vehicle Wt Rating (lb)
9200
Gross Combined Wt Rating (lb)
16,000
- Tim
Still confused about those figures in post #433.
Is there a web site that explains just what they mean. Does the GVWR of 9200 lbs. mean that the truck is only rated to carry that much, a total of it's own weight plus the cargo.
When the GCWR is 17000 lbs. at 3.73 ratio does that mean that you deduct what the truck actually weighs and what is left is what you can tow.
Thanks again for all of your help and advice.
- Tim
GVW - Gross Vehicle Weight
GVWR: Gross Vehicle Weight Rating- The maximum weight for vehicle, passengers, cargo, accessories, fuel etc.
GRAWR: Gross Rear Axle Weight Rating- Maximum weight on the rear axle.
GFAWR: Gross Front Axle Weight Rating- Maximum weight on front axle.
GCWR: Gross Combined Weight Rating- The maximum weight for TRAILER, vehicle, passengers, cargo, accessories, fuel etc.
Curb Weight: The actual weight of the vehicle, passengers, cargo, accessories, fuel etc. This can also be the weight of an empty truck instead, but since the weight is used to determine payload, I choose the loaded route.
To answer your original question, I would go with the 8100 with the 3.73. Is there any particular reason your are not interested in the 4.10 with the 8.1? If you pull quite a few times a year and climb a lot of hills, you might consider it.
Hope I could help you out. Go to your local dealer, gmc.com, or chevrolet.com and get the 52 page brochure, it includes some nice charts showing all of the info and explaining the limits.
Get the 8.1 /Allison
see below
Thats one mean looking truck. The most aggresive truck Chevy has put out. The truck stand very tall with the Allison. Easily 2 inches higher than my '98 3500C. And, it was only 2 wheel drive. I like the rims and hood sheetmetal a lot.
The 8.1 is just massive under the hood. The whole truck is just a LOT of steel.
I was REALLY impressed with how clean the engine bay is. There are no hoses, wires, and such running all over the place. I mean it is CLEAN. In fact, back right of the compartment is entirely empty--nothing but a wheel well.
THE DRIVE
First impression--SMOOTH. Very slick ride. It felt very solid and heavy when going over rough roads. It absorbs bumps with a little stiffness, but overall much smoother than I had anticipated.
The engine is just plain power. its hard NOT to chirp the tires. At highway speeds you barely have to touch the throttle to hold 55...its hard NOT to drive 70.
I LOVED the Allsion. Under moderate accleration, it shifted very crisply and kept the engine in between 2500 and 3500 rpms. The engine seems to really pull good. It doesn't want to 'rev all the way' like the 5.3 does. It was strange feeling 5 shifts from a stop.
The engine braking from the transmission is a GREAT feature. I can see this combo becoming very popular Very fast. At low speeds, it feels like you are driving a standard. When you let off the gas, the tranny holds the gear, so you the engine whines down, just like if you were driving a manual. The tow haul features 5th gear lockout and computer selected downshifting when the brakes are applied.
Overall impression: I WANT ONE! GM really stepped up to the plate nicely. Everything about the truck seems very well thought out.
And just plain powerful. The Allison should do for GM what the Cummins did for Dodge. The heavy duty performance of that tranny is awesome.
LOL
- Tim
get it right man!
LOL
- Tim
Ford offering a $1000 credit on the V10's.
Uh oh, more decisions for Buck. Back to a stripper SD CC V10 5speed????
Ryan
I like the one about 'have you seen that you've got mail movie? This guy hasn't..." (Show guy in Ford with tough music in background)
Everything is speed dependant!
Hunter
Especially those of us with one on order or about to.
Still the 8.1 with 3.73 vrs 6.0 with mandatory 4.10 should keep them close enough that if you "have to ask" maybe you'd beter be looking at Motor Scooter!!!
I've pulled a 5th wheel for 3yrs with an F150/5.0/220hp and can say 'Been There, Done That' -- Pedel to the Metal down hill to make 40 up the next--- DON'T WANT TO DO THAT ANYMORE.
75v
75V
If i go to 265's like Roger350, can dealer change computer to have speedometer correct??
75v
And yeah the deer lease as it is referred to down here in Texas is our hunting "spot"...
N75v111..you talk about the 6.0 like it is a 4cyl..i don't know what you have been told but if you are getting the 8.1l because you think the 6.0 is not strong enough you are wrong...i have been very happy with the 6.0 and the power..to be honest, the truck hauls [non-permissible content removed]...and i have got a crew cab and 4x4 with the 33inch tires..getting 12MPG in city and you saw my earlier posting of highway mileage..if you will have to gas the truck to keep it at the same speed on hills you are wrong...maybe it is the 4.10's that help the 6.0, i don't know cuz i never drove a 6.0 with the 3.73...but i would take my 6.0 over the triton v-10 any day, much more power in the 6.0 than any triton engine..
I wouldn't get the 8.1l unless
a)My company paid for the gas via gas card
B)I pulled the hell out of something a lot
C)I just had to have the allison to say i had it..
I pull a 22 Bay boat and maybe an occasional trailer bigger than that so i don't need a 496 to do it, nor do i need a $5500 diesel to do it..again, if i was money bags i would buy the diesel..but i am not, in fact i just graduated college...my father in law pulls his big [non-permissible content removed] tralver trailer with his crew cab6.0 and he says he can't even feel it back there at 75MPH..he also said he got 10MPG doing it...
yeah the dealer can recalibrate the speedo or you can buy a hypertech reprogrammer to do it yourself when you want
Highway empty:
55mph-17mpg
65mph-13mpg
Highway towing:
55mph-8.3mpg
65mph-7.3mpg
The vehicle was a 2001-2500HD-4WD-8.1L-XC with a 4.10 gear ratio. Towing tests were performed with a 9700lb boat.
Hunter
I would also pick the 6.0 over either of the V10's and think is is a great power plant. I of course would have went with 6.0 had the 8.1 not been available and probably would have been totaly satisfied over my F150.
I'll just have wait and to see how the 8.1/3.73 gas millage compares to the 6.0/4.10 -- but as I said they may be about the same -- the 8.1/Allison fits my needs better regardless of fuel consumption.
The Allison is a major factor in my selecting the 8.1 if your pulling good loads such as large 5th wheel RV's etc.
These things are so expensive that I don't want to wish later on that I had more power or the durability of the Allison.
I have friend who pulls Big Big [non-permissible content removed] size 5th wh horse trailer w/RV quarters all over the country and has lost transmissions in two big rams, two silverados and one F350 over the last five years (yeah 5 new $35/$40K PU's) thus the importance of the Allison to me.
Sorry - Did not mean to imply the 6.0 was bad.
Thks for the speedo reprograme info.
75v
So, driving 60 mph indicated will be 65mph....
And the odo will read 92% as fast. And you will get 8.1% more miles until you warranty expires....
Best of luck
Hunter
I took delivery of my truck on Nov 1st I have 550 miles on it so far. Acceleration is GREAT mash the pedal and it pushes you back in the seat. At idle you can barely hear the engine, under hard acceleration you hear a mild rummble, when you get to cruising speed the engine gets very quiet again. The first tank of fuel it got about 17 mpg.
I will fill it up again before the weekend and let you know.
n75v..no offense taken..i just don't want someone to choose the 8.1 cuz they think the 6.0 can't handle the truck...
Hunter98, thanks for the congradulations...i am really pleased with the truck..of course i would rather have a DMAX, but just graduating college i think i have a dam* nice truck...maybe after this Accounting degree gets to work i get can get a dmax in a few years...
Got another question about the GCWR in the trailering section of the 2001 Sierra brochure.
On the line for the 8100 V8 (L18) it shows the following GCWR :
3.73 = 17,000lbs.
4.10 = 19,000 lbs.
3.73 = 20,000 lbs
4.10 = 22,000 lbs.
I don't understand how it can have the the same ratio twice and come up with a different GCWR, could it be a misprint.
Also would the suspension on the 2500 8.1 be stiffer than the 2500 6.0.
3.73 = 17,000lbs.
4.10 = 19,000 lbs
These are for a 2wd
and
3.73 = 20,000 lbs
4.10 = 22,000 lbs
are for a 4wd???
Just a thought
Ryan
Travel safely,
Suburbansrule
ps. 4x4 would you be interested in selling the
stock wheels you took off the crew cab?
Good Luck
Hunter
