New Sierra/Silverado 2500 & 3500
Ryan - I was referring to Trade-in value, so $25k for a 2000 is about right for now.
I've got 11 months left on my 99 lease, but I want a HD Crew now! Not likely with its current trade in value. I think its less than my lease-end buyout already. Oh well, I guess at least I'll get to see the Avalanche debut before my next transaction. I'm not as hot on it anymore as I was about 6 months ago. I'm leaning toward the HD now.
Ryan
LEAVE ME ALONE I LIKE THE STICKER DAMMIT
you would have to take a 4x4 off cuz it wasn't a Z71.....am I right or am I right?
- Tim
Ryan you may think you will change down the road about not wanting a good looking truck, let me tell you from experience, no matter how old you get, you will always want a good lookin ride no matter what type of rig you choose in the future.
Look at Tim, he's out spit shinning his truck now
for Turkey day. As for your Z71 sticker, does that mean since you got extra skid plates your a Big Bad Off-Road machine now? Have a safe Turkey Day. You chevy boys provide good entertainment, even though it's at ryan's expense.......
Ryan
bowhunt they arent picking on me if i wasnt here this place would be ZZZZZZZZZZZZZZZ
I plan on towing approx. an 8,000 lb 5th wheel and I want to have enough power to pull in the California high sierra mountains and in the Canadian Rockies without putting too much strain on the engine and tranny.
I know I can upgrade to the 8.1 and have power to spare but I think it would be overkill in my situation plus I would be getting poor gas mileage for my solo driving.
Any advice you could throw my way would be appreciated.
#534
Gimme a break ace...
- Tim
Thanks for your participation. ;-)
Pocahontas,
Edmunds.com/Roving Host
(currently have '90F150 4x4 bought new - Not going to sell it till the new one's on the Car Carrier :-)
I'd like to know the manual #'s- assume their GM??
Need to tell dealer to get them on order and see if they beat the truck.
We're not expecting our unit until January also-- If By Then?? Production for the 8.1 is ramping from 1% build of total units out of the Pontiac plant to 30% so maybe both will build befor March at the worst.
Think I'll replace the Fstones w/Michelin 265 AT/LTX's like Roger350 recently did. He's working with Fstone to get $100 per tire on customer satisfaction policy (or lack of) stated on their web site.
By the way- you can call that 800# I posted yourself to watch for the TPW soon as they assign.
Most seem to call once or twice a week.
What's your color In/Out?? Indigo Blu/Graphite here--Gona get rid of the Blk wheel flairs however. (Sorry Ryan :-)!!
Z71 is some sort of OFF ROAD pakage i think - Someone -Probalbly Ryan - will straighten this explanation out before this ink is dry.....
Learned something from one of the other post-Don't remember who but thanks- on the LOCKING DIFF. - I assumed it was just positraction of old but guess it actually locks both wheels when one starts to slip. Think this is right.
In central Iowa - Watch for you after Monday--
75v
I was concerned about tow capacity for the HD as well. The 8.1 is appealing but it may be a bit on the thirsty side. The December 2000 issue of Trailer Life lists the tow rating for a 6.0 2wd, XC, sb, w/4.10 at 10,400 lbs. Probably enough for your needs. Similar vehicle with an 8.1 but w/3.73 is listed at 12,000 lbs.
I did see those tow ratings, I also read an article in the Aug. issue of trailer life where they did a review on the 6.0 and also the Oct. issue where they test drove the new 8.1 pulling a 10,060lbs. trailer. I compared the Fuel consumption and it was as follows:
8.1 Towing = 7.9mpg Solo = 12.2mpg
6.0 Towing = 8.4mpg Solo = 14.6mpg
Only 0.5mpg difference with the towing.
I figured if I got the 8.1 I might pick up an extra mile per gal. seeing that I woudn't be working the engine as much with the lighter towing weight.
As you can see I'm trying to talk myself into getting the 8.1. It's a big truck though, i measured from the ground to the bottom of the tailgate and it was 36 inches. I compared it to my 1500 Sierra 2000 and the difference was 4.5 inches. This might create a problem leveling my 5th wheel so will have to see how much adjustment i have with the hitch and the king pin on the 5th wheel. That might be the deciding factor on which truck to buy.
Decisions - decisions !!!
forgot to mention the 8.1 was using a 4.10 axle ratio so my mileage would probably be better with a 3.73.
If anyone knows or wants to cut and paste a pic over here do it...I don't know how...Thanks
that the 305's will not work. What brand of tires are you using? If you take a Goodyear 305 and a BFG 285 the tread width looks about the same but the widest point (sidewall bulge) is about 3/4 of an inch wider on the 305.
You bring out a good point. If the mileage penalty from a 6.0 to an 8.1 is 1.5 to 2 mpg, why not benefit from the power and towing capacity of the larger motor plus the Allison. Now I'm reconsidering my order. (Assuming it's ever built). Hmmm.... Sure could use some advise from the current 6.0 and 8.1 owners. P.S. I'm afraid to ask you what color you plan to order.
FourWheeler magazine gave a report on the 8.1 in mixed driving and for the damx in the same..8.1 got 9.1 MPG and the DMAX got 15.8MPG..
mth1 I was also dissapointed that the 305's would fit.. I really wanted the 305 and 16x10 combo but it just won't happen...305's will fit on stock wheels though..i saw one, i guess since the stock wheel is onlt 6.5 wide it doesn't pull out the tire too much if at all...I am using BFG AT KO's..I almost went with MT's but i think the extra grip on the MT's would have been too wide and would have eventually grabbed a hold of something and pulled it off the truck(like the air dam or the fender lining)
A buddy of mine is a manager of a discount tire so he let me try almost every combo we could think of...again i have seen 305's on stock wheels but the 8's just make the tire too wide in both the front and back..
Sorry im sure i missed this but you have LT285's BFG's on your truck? The all terrain? How much did they run you?
Im curious i seen some on an older (97) CK and liked em.
After this winter im gonna switch em out to that size thanks
Ryan
Thanks in advance,
Suburbansrule
Suburbansrule
David
Ryan, the BFG's AT KO's are about 154-156 no matter where you look...seems BFG set a price on them and no dealer is authorized to change the price..what happened to the bridgestones ?
The four turns did level out the truck and no i didn't get it reallingned...i tested it going down the highway and it still drives straight..
but if the allignment is free to 7500 miles then i might as well get it done..
anyone else have a creaking noise when turning left..all of the sudden this started last night..
Arent they 75's???
The tires i have now are P265/75/R16. I found some BFG's on their site. The all terrain TA's LT285/75/R16.
The bridgestones. Well i gave up on em. They are on national backorder i havent called back in 3 wks. I want to go with a little bit bigger tire. I figure early spring ill get em. Probably around march spring break time
Thanks for the info they look nice on the truck
Ryan
Thanks for the compliments...they are good tires and discount sells them with a 50K mileage warranty..
1-Persist until you succeed
2-The squeaky wheel gets the grease
If the Firestone dealer promised you the tires, by all means, you should get your tires. The more you complain, the more likely he will give you yours before someone who doesn't constantly complain. Also, you could call firestone's corporate and file a verbal complaint followed by a written one along with another to the local BBB. Just my opinion...
planning on ordering Summit White it's cooler for my part of the country and it looks cleaner even when it's dirty.
Tried to order 2 tone but it isn't offered with the split bench seats don't ask me why the dealer couldn't figure it out either.
Haven't actually put in the order yet I was hoping to get more information from new owners of the 8.1 and get their input.
Heard that the SES light has been coming on in some of the 8.1s and would like to find out more about this.
Thinking of starting a new thread just on the new 8.1s so I don't have to be searching all over the place for answers.
Ryan
this topic is being "frozen." please continue these discussions in Topic 2466 New Sierra/Silverado 2500 & 3500 - II. Thanks!
Front Porch Philosopher
