What I understand is 2wd has better fuel economy (can anyone vouch for this?) and 4wd works 80% - 90% of the time on front weel drive.
But at the same time 4wd sell much more .... so what am I missing .... I live in the north east so may face snowy driving conditions from time to time...
Help will be appreciated.
Jai
It will also be much better in the snow- so in my book it's worth the extra gas.
Good luck
tom
Yes, I owned a 2001 MDX for 3 years and the 2004 Pilot for two. As you can see we just got into a 2006 EXL. The engineering improvements are quite apparent. One I did not mention is the quick acceleration. One can be sensitive when pushing on the petal. Surprising for such a large vehicle.
Cheers
Over 100k miles, thats about $1600 in gas. Most wouldn't view $1600 as inconsequential. And there is the eco argument - 98 tons of prehistoric, buried plant material is required to produce each gallon of gasoline, much of which ends up as additional carbon loading to the atmosphere.
But, after pitching the eco argument, I would still get AWD if you felt like you had much opportunity to use it. You'll get most/all of the extra cost back on resale and when you need it, it will seem like a bargain. OTOH, for a person driving in a warm climate that never sees snow or off-road driving, it is pretty silly waste of money and gas.
- Mark
Plus, at current rates in my area, it would only be about $1200 in gas over 100k.
I've reseached and driven every SUV type vehicle in my price range and I keep coming back to the Pilot as a good combination of function, style and cost. But then I read these and other forums and get cold feet. I'm hearing about folks experiencing lousy gas milage, unsolvable vibration problems, complaints of high road noise, and a whole litany of rattles and noises in their Pilots.
I'm also considering Highlander and 4Runner. Those forums contain some issues as well but they seem to be less pervasive.
Am I being too paranoid? Is the Pilot really a quality "Honda" type vehicle that will be durable in the long term? Do the postings in this forum represent a true cross section of Pilot owners?
This will likely be the last new vehicle I'll ever be able buy and I want to get it right. I'd really appreciate feedback from Pilot owners on their perspective on the Pilot, warts and all!
Thanks for the response...I do have another question if you don't mind.....did you sell your 04 Pilot privately or trade it in on your new 06? I really don't need the price you got (none of my business anyway), but was wondering what type of mileage you had on it when you got rid of it and if paying more for the upgrade 06 Pilot vs 04 Pilot was worth it? Thanks in advance!
For additional frames of reference from actual owners, check out the reviews under Consumer Ratings (there should be a link to Ratings at the top of each of the various discussions you visit here).
If you're not going to be towing or driving your car really aggressively, you're probably worrying about something that has a 1.1% chance of happening vs. 0.7% with another make/model. You hit the nail on the head in your post when you said "reasonably reliable" which I think the Honda automatic is. Is it the most reliable? Probably not, but for most of us, it is good enough. As our host just said, no car is perfect.
I'd instead focus on the big picture which is that the Pilot appears to be nearly the best of the bunch in overall SUV reliability. I'd worry about the tranny problem only if I was towing significant loads for long distances and even then with the 60K warranty (and available extended warrranties), I might decide to just take the slight risk.
- Mark
Transmissions Prompt Large Honda Recall
04/15/04
Christopher Jensen
Plain Dealer Auto Editor
Honda is recalling about 600,000 of its popular sport utilities and minivans in the U.S. and Canada because the automatic transmissions may fail, the automaker announced Wednesday.
The five-speed transmissions made in Russells Point, Ohio, near Marysville are used in some 2002, 2003 and early 2004 Honda Odyssey minivans as well as 2003 and early 2004 Honda Pilot sport utilities. Also covered are 2001 and 2002 Acura MDX sport utilities.
This is the second major problem Honda has experienced with its transmissions. In September 2002 the automaker announced it was extending the warranty on the five-speed automatic transmission on certain 1.2 million Honda and Acura cars to seven years or 100,000 miles.
Honda decided to recall the transmissions - at an estimated cost of $153 million - after finding 10 transmission failures, Honda spokesman Chuck Schifsky said.
"The reasoning is that we want to look at every problem and take it seriously," he said.
He said all the failures occurred in vehicles with more than 60,000 miles.
But the problem may be larger. The National Highway Traffic Safety Administration consumer complaint section has at least three dozen complaints about various transmission problems on the Odyssey and MDX.
"Early transmission failure seems to be a problem with this car. Dealer knew immediately what was wrong," wrote one consumer.
Schifsky said those miscellaneous complaints did not play a role in Honda's decision.
"Other automakers should follow Honda's lead and recall rather than stonewall," said Clarence Ditlow, director of the Center for Auto Safety in Washington, D.C. "It is refreshing to see an automaker take responsibility for a defect."
Owners will be notified by mail if their vehicles are affected, and there will be no charge. Dealers will inspect the transmissions - which should not require disassembly - and make a "modification to increase the flow of transmission fluid," Honda said. If there is evidence of damage, the transmission will be replaced.
If the transmission is damaged, owners would probably notice extra noise. In rare instances the transmission could fail and lock up, "creating a potential safety hazard," Honda said. Of the 10 transmission failures Honda examined, "several" locked up, Schifsky said.
Schifsky said there is no plan for an extended warranty because Honda is confident it can fix the problem.
If Honda's dealerships can handle the work without inconveniencing customers and the problem doesn't result in any injuries, Honda's solid reputation should not be damaged, said John Tews, a spokesman for J.D. Power and Associates, the market research firm.
Toyota makes some fine cars and might have a slight relability nod over the Pilot. If I were going off-road and/or doing much heavy towing, I'd probably go with a V8 4Runner over the Pilot. But the Pilot is the much better people-hauler (especially if you have more than 4 in the car), bigger, quieter, smoother, and an easy $4K cheaper with comparable equipment. So you pays your money and makes your compromises.
- Mark
I think Honda AND toyota products have less chance of major mechanical issues than many of the other cars available for purchasing.
My wife owned a 95 Oddessy and I had a 95 Accord. My wife traded in her 85k Oddessy (sorry re: spelling) and I sold my 141k Accord.
Prior to these purchases, she drove a 78 Honda Accord, with no problems until our daughte totaled it out one night. Then she purchased a Toyota, and I purchased a Toyota. Never had problems with these vehicles and we have not experience ANY mechanical issues during our ownership of the 95 vintage cars. This is not to say others did not, however, Honda and Toyota products have served us needs very well.
My wife now drives a 06 Pilot EXL with nav. and loves her car. Last year I sold my Accord and purchased a Lexus rx330. Wonderful car for what I wanted.
My wife also drove the Toyota Highlander however, she preferred the Pilot. One difference I find between the Pilot and the Lexus is the quality of the "bells and whistles" of the two. But then the Lexus cost was much greater.
We feel fortunate in selecting Honda and Toyota products, however, we had to learn the hard way via ownership of Chevys, Fords, and Chrysler products.
Good luck in your quest for a new car and best wishes for a peaceful holiday season.
Good luck to all and stay safe.
jensad
P.S. I DO NOT work for or do I have any connection with Toyota and/or Honda.
The '06 Pilot is a fantastic and versatile vehicle unmatched in many areas. It has a top safety rating, as well as the excellent (for the most part, of course) reliability rating. It has an available navigation voice-command system that is unmatched by almost any car in the world at any price! It seats eight with fold-flat split rear seats, has the absolute best interior organization for "stuff", drives very comfortably with great determination and power, has avaialble 4WD, and the list goes on. It does all this at an amazingly low price when you compare it to all others, and gets reasonable gas mileage on regular gas. If you KNOW you intend to keep it for the long haul, and are concerned about repairs, buy the factory extended warranty and you will be covered without concerns for a long time. Buy the '06 Pilot, and don't look back. You won't regret it.
- Mark
Actually I got a call from my dealer and with my lease it was better to get into an 06 for less a month. I had only 22000+ miles on it and I was paying for 15000 miles a year and not using what I was paying for. For what ever reason it was less a month to go into the 06. The one catch is the 06 in now leased for 42 months not 36. My main concern is the monthly payment and with the 06 it is less. Like I said before the 06 is much improved over the 04. The XM radio trial period is nice. I enjoy getting the BBC World Service etc.
One more thing. The dealer actually bought the vehicle. It seems the demand for fairly new used Pilots are in demand.
Cheers
Best solution . . . DRIVE the '06 for a long test drive!
I had an 03 Pilot...and now have an 05 Pilot....
The improvement between the two years was quite good....
I hear the next total redesign won't take place until 2009?
Wow....still have a few years to go....
Thanks again...
MSRP was 33,595.00
agreed on 29,531.00
something called price adjustment of 273.25
adjusted selling price 29,804.25
500 down includes all fees
total cap cost 30,399.25
36 months, w/ 15k a year
385.00 month payment, that includes taxes
Residual 19,149.15 at (57%)
Or if I put 1000 down instead of 500 total monthly payment is 365.00.
Is this a good deal?
That's the story. Go get one!!!!!!! You won't be sorry.
TagMan
- p
Enjoy
The XM radio in my Pilot was in service. The dealer must have connected it. A copy of the stations was also with the other materials. This was handy in getting aquainted with the XM functions. One can preset chosen stations similar to am and fm choices. Just wondering, you have pressed the XM button next to the am/fm button? It takes some getting use to. I love that BBC.
Cheers.
When the unit locks up, none of the buttons will work. I haven't tried multiple buttons at once.
If I'm on the road, I have to pull over and shut off the vehicle and restart to reboot the system. Is there any other way to reboot with the vehicle running?
Has anyone experienced this?
CTG
Has anyone had the same problem?
On page 77 of the 2006 NAVI manual, it shows a delete key. I don't show the delete key or the done key when I select previous destinations. Only the list of destinations.
Any help appreciated.
CTG
That got only fixed by restart of the car
thanks,
CTG
Any thoughts on this? The `05`s were approved,the `06`s
are not.
Thanks for any information/opinions
Al Colby
I still have to pick up the car like SUV, and I want to have a remote start installed in this one. I'd like to hear from perople who have experience with remote start on any of the Honda Pilot models. Also, any thoughts, comments would be appreciated about installing remote start and it's consequences - good or bad.
Thank you and happy holidays.
