Visitor Agreement.
If this is right very happy. Ole MIke
EPA: 21 city, 26 highway
Actual: 18-19 city, 27-28 highway (calculated by hand -- trip computer reads high)
My experience has been that the hwy mileage is good. I probably get around 28 to 30 and I've got a fairly heavy foot on the open road. Locally, I find that the car an be a real gas guzzler when I do alot of crawling. I lived in Queens until just a couple of weeks ago so I had many weeks when I would avg around 15 mph and found that the gas mileage would drop well below 20 mpg. If I average 30, the economy would far more acceptable. I probably got 23 - 25 mpg under those circumstances.
Since I bought the car in December 2001, I have:
Driven 35942 miles
Purchased $3252.70 and 1731.7 gallons of gas
My long-term average MPG is 20.8.
My best MPG for a tank is 29.9 when we took a long road trip.
My worst MPG for a tank is 13.9.
My average fuel cost per mile is 9.0 cents/mile.
Gas prices have ranged from $1.25/gal in December 2001 to $3.50/gallon in September 2005. Average price has been $1.88/gal.
MPG city about 22-23 mpg.
MPG highway about 30.
Best highway MPG was 33 on a long trip using a lot of cruise control.
I normally get between 30 and 34mpg on highway during warm weather when the air conditioning isn't on and going 70mph
In winter I get as low as 27 and 28 mpg
Last week due to the insane gas price jump I dropped my speed from 70mph and wouldn't go over 66mph. I stayed in the 64-65mph range and I got an amazing 37.5 MPG
I have gotten 34-35mpg on a tankful before but never literally 38MPG.
Now that was an awesome feeling.
I recently took a long trip that forced me to use country roads (no direct highway), with a max speed of 55mph. My mpg jumped to 39mpg!!
I do use some low cost enhancements on it which I believe helped; Bosch Platinum +4 spark plugs (100,000mile life), K&N drop-in filter, touring tires (threadware rating 620).
I've just started using synthetic oil, so hopefully the mpg figure could see a minor improvement.
w/ AEM cold-air intake
City: 19 MPG
HWY: 28 MPG
calculated by hand (trip computer gives higher reading)
When this car becomes older, I now use even more aggressive conservation maneuvers to get 23 mpg city most (65%/35%) and 28 mpg highway. I'd love to learn some of your tricks. (Gotta admit that I wasn't very at tentative to tire pressure, but I would expect better mpg when the car was brand new.)
Nothing could be farther from the truth. A new engine is as tight as it'll ever be (until rebuilt again - if ever). The sliding/rotating parts have yet to achieve their ideal seating with their mating parts. To some degree this is also happening with the transmission. This period is traditionally referred to as "run-in" or "break-in", and though it's not nearly as involved a procedure as in previous times, it's still something that has to take place and will initially impact fuel economy. Engines don't hit their fuel economy stride until around 5,000 miles of accumulated mileage. Tire pressure will definitely affect fuel economy, too. Dealerships love to adjust tire pressure down below the factory recommended level prior to delivery to achieve a "boulevard" ride. A new tire will also lose some pressure initially until its bead fully seals against the wheel rim. Whatever its cause, lower pressure increases rolling resistance (bad for fuel economy), negatively impacts traction, and increases heat buildup within the tire (bad for tire life). Some owners actually prefer running their tire pressure several pounds more than the factory-recommended setting for further decreased rolling resistance and internal heat buildup. (But never increase the cold pressure beyond the maximum limit molded on the tire sidewall.)
Warranties...
Wife is buying a Honda Accord -
I am buying a Pathfinder...
What is the best deal on warranties for each?
I am seeing lots of different options and my dealer is
offering a few choices also, in different price ranges...
Options???
cryptoguy...
This is an Altima Real World Mileage discussion, so the folks who can answer you probably aren't going to see your post here.
What you want to do is check out the groups on the Accord and the Pathfinder. We also have a general discussion on Extended Warranties that may be helpful.
Enjoy!
Took a trip and went 847 miles.
Pretty much all highway at 60-75 MPH.
The car got 29 MPG., not bad.
I drove like granny though.
Also, fuel varies between states due to emissions standards and required additives. This as well as elevation can affect mileage.
The EPA is changing their ratings for 2008 to better reflect mileage for present-day driving habits. So basically, cars will be rated as having "worse" fuel efficiency than previous models.
http://www.fueleconomy.gov/mpg/MPG.do?action=browseList2&make=Nissan&model=Altima
2. 70% streets will kill any cars gas milage. My 1997 Saturn gets 38 driving 230 miles between Cinci and Cleveland. This drops to the mid 20s when I drive 5 miles between work and home through side streets.
Is it fairly recent that you started doing this 70% street / 30% hiway commute? How many miles total? How many minutes does it take to drive these miles?
If I drive 5 miles and it takes me 5 minutes on the freeway, but you drive 5 miles and it takes you 20 minutes (streets, stop lights, etc), your motor ran for 3 times longer than my motor. Wouldn't you think that would use 3 times more gas to keep it running (not really, but you can see where I'm going with this arguement).
AND WHEN I FIRST GOT THE CAR I WAS ABLE TO USE REGULAR GAS WITHOUT ANY PINGING. THATS WHAT I CAN'T UNDERSTAND.
Welcome to CarSpace!
Maybe an engine recall coming? Please let me know.
link title
sellcar, did you have a dealer to check your engine? I wonder the result.
