Chevy Silverado - Continued XVI
LOL
- Tim
Ryan
Can you tell im bored at work NO BOSSES!!!
Could a decrease in gas milage be attributed to a bad EGR Valve???
Ryan
nick
Ryan
Talked to a Firestone dealer...he said he would swap the tires but that I would have to send in for my refund. It wasn't just paying the difference...he said 6-8 weeks wait for the refund.
Is this how it's worked for you others?
Ryan
here's the deal. if you have firestone wilderness tires (or the other two that are on the recall list) but YOUR tires aren't on recall because they're a different size or not made at the decatur plant, firestone will pro-rate the value of your old tires against the purchase of new tires (the catch is that they have to be another firestone or bridgestone product). i got the bridgestone dueler at's (LT265/75R16). so...since i had worn 23% of the tread off of my old tires, he applied 77% of the value of a new set of wilderness tires against the purchase of a new set of duelers. overall, it came out to about $220. add on installation, balance, lifetime balance/rotation, tax, and road hazard warranty, and mine came out to $290 all told.
to see the duelers, check out my pictrail albums at www.picturetrail.com/bco
if you have more questions, post them here or sign my guest book on picture trail.
bco
steelworker
Do you know what rearend you have? 3.42 or 3.73
My problem is I'm 130 miles from the nearest dealer in Albuquerque.
I may just call a few other dealers and see if I get a different story.
BTW, he wasn't going to go off of tread % but mileage...so since I only had 1500 miles on them and they're rated for 50000 it was like $6.75 he was going to subtract from the new price.
Think I should get the 285's?????
Roger thanks for the info. Also did ur gas milage go down and was there a noise in the engine when that valve went bad???
Ryan
http://www.mit.edu/afs/athena.mit.edu/user/z/i/zimerman/www/Documents/tr6/egrvalve.html
I doubt it is the prob unless it is really clogged, especially since your truck is almost new. They are easy to replace and are pretty cheap.
Nick
I've been wondering, if I would have paid for road hazard warranty for just 1 tire instead of all 4, would the dealer know which tire it was for? LOL
Phil
http://www.picturetrail.com/ryanbab
http://www.sitel.com/html/press/c_glo_990216b.html
Ever wondered why you had rude people answering...well now you know.
check out the thread entitled: 1-800 we don't give a s**t
http://www.teleweb.net/mgdvhman/00LT6.jpg
http://www.teleweb.net/mgdvhman/00LT3.jpg
http://www.teleweb.net/mgdvhman/00LT4.jpg
http://www.teleweb.net/mgdvhman/00LT5.jpg
- Tim
All Stainless.....not cheap..$1000 local....but they will always look as good as day one.....and they will go with me to the next truck!....
- Tim
FORTOP
I dont have any piston troubles just a noise i have no idea why it is happening for all i know it is probably normal. The truck is running great. Just a noise when its idleing or in park.
Ryan
I have a LT model & haven't had any problems with my bucket seats.
Is it the power lumbar & or the power back booster that's causing the problem?
rcoos
- Tim
Yea the winter is gonna get em i know. Probably wash em every few days.
Hey Tim you have any extra black touch up paint ill trade you a black for a blue.
Ryan
i picked chrome because i thought it looked better and it's got a lifetime warranty as opposed to the 5 year ryan got with his. warranty covers fit and finish.
note to all on nerfs: last time i changed the oil and took all the pics on my truck, i tried to put it on a lift. lift was a nogo because the arms hit my nerf bars...not a recommended method for lifting/supporting your truck. anyways...this is important to you for a couple reasons. one, if you're going to do your maintenance yourself, use a lift that you drive onto and supports the vehicle by its tires. two, if you take it to a garage and you see your truck in the air supported by a frame lift...it may not be supported by the frame, it may be supported by your nerfs so you prob'ly ought to check...
bco
BCO - Are you talking about the lift that had 4 arms??? They used that on my truck for the first oil change and it was fine. The nerfs didnt interfer at all.
Ryan
- Tim
Hardly noticable now though. I know what the winters can do salt is a nasty thing
Ryan
- Tim
yeah, the lifts with the arms. the one i was trying to use was shaped like this (looking at the top of it):
X X
X X
assuming the X's are the pads that are supposed to contact the frame, the problem was the straight part of the arms. if you can imagine putting your truck on top of that...the | things that connect to the X's hit the nerfs before the X's hit the frame. just something to be aware of.
now, if the lift looks like this, you should be ok:
X- -X
X- -X
bco
BCO - sorry
also do your bridgestones collect tiny rocks like the Fstones did? I know mine are throwing tiny rocks like crazy i hate that
Ryan
Dean
ryan...they don't throw rocks real bad. but i didn't think that was a problem with my f-stone's either. don't do a whole lot of gravel road driving.
i HAVE found a "do-it-yourself" bedliner system that they sell at walmart for about $25-$40 depending on what all you get (roller, pan, etc). think i'm going to do the section underneath the bottom of the door sills before too long. pointless to have to clean road tar and grease, etc off that part every time you wash/wax. plus, that's the part that's going to take the greatest abuse from gravel anyhow. so i think i'll just coat it with the rubberized bedliner stuff. can't hurt...
bco
I think maybe I'll just go with the 265s.
I was reading on the westin website where a truck actually fell off of a lift while getting an oil change. Guess what the nerf bar save the truck. It was held up by 1 nerf bar. Easier to replace a nerf bar than a truck
Do it yourself liner - are you going to do the very back rear??? Under the Z71 portion or just the cab?
Ryan
Nick
We had installed a set of your Step Bars on one of our customer's 1997 F-150 pickup several months ago. We had told him that the Westin steps were the strongest bars that we had ever installed and that is what he wanted. But, we never thought that we would get the chance to prove it!
He had come in for a routine transmission service job. One of our technicians was lifting his truck with the 4-post lift that we use for service. When the truck got to the top of the lift, one of the lift arms shifted and after hearing a loud bang, the truck began to fall to the floor. But, we heard two more loud crashes. This was where the Westin Bars actually "caught" this truck.
The entire weight of the truck fell onto the Westin Bars and remained suspended in the air only by the bars. As the truck swayed back and forth, (running everyone out of the shop, me included) the Westin Bars moaned and groaned and bent, but they saved the truck and it did not receive one scratch! Had this truck not've had the Westin Bars on it, I am sure that this truck would have had several thousand dollars of damage to it, and most of all, one or more of us would probably have been severely injured.
I am sure that your Westin Bars were not designed for this purpose, but I just thought you might want to know how strong they really are!
Don Sprawls
Sprawls Service & Sound
Aiken, South Carolina
Found it at
http://westinautomotive.com/pages/westin%20cool%20crashes.html
Ryan
