2007 and newer Chevrolet Tahoe and GMC Yukon
Thanks for the feedback on E-85, I have also tried it but must admit I have not received the same results. I also live in up-state NY (Guilderland) and my 07 Tahoe only has 18K on the clock. My BEST tank on Reg Gas was 17.9 with an average of 15.4 I just returned from a trip to NC,1900 miles, best tank, 16.4, worst tank 14.2 again on Reg gas, we won’t talk about the numbers when running E-85, as they are to depressing. I have an open case with GM, actually the Tahoe goes in for service next week, they are going to change several sensors and the body control module. The service manager drove it for a week with similar results, so we both are convinced it is not driver related. Are you running 3:73’s or 4:10’s ? FYI, still no word on the wipers, but at least it stopped snowing for a while. George
What dealer do you recommend I am in the process of purchasing a 2007 Suburban for my business. I had a problem with Denooyer so wont go there any other thoughts
On highway trips I've gotten up to 19 MPG, which is pretty damn good.
I've had two problems so far: a dead battery (for no reason -- it was so dead that jump starting wouldn't help, and I had to call OnStar) and an *extremely* annoying rattle in the headliner. I'm taking it in next week to have the dealer fix the rattle.
Here's my question: has anyone tried driving offroad, and specifically on the beach, with the factory 20" wheels? I've read that the bigger sized wheels do not perform as well in off-road conditions. One of the reasons I bought the Tahoe was for its 4WD performance (versus, say, the Yulon Denali with AWD), and I'm disappointed that the 20" wheels, which I didn't really want, can hinder performance. Any thoughts here?
As for your wheels comment; I've got a Z71 which has the 18" wheels, which I presume is better for off-road driving and why that size is what comes with the Z. So maybe you could get OEM Chevy 18" wheels for your off-road adventures and keep the 20"ers for other times. Just a thought. The 18'ers that come with the Z71 ride surprisingly smooth compared to my former 2004 Z71. I guess it's all in the new suspension system on the 2007 models.
Tom S.
I am in Guilderland, and have purchased my last 3 Tahoes from Hand Motors in Manchester VT, give Chris a call, he will bend over backwards for your out of town business. I also purchased a set of factory 17 inch wheels and sensors last year that I did not use, as the 20's are working fine for my needs. If you are going to purchase smaller wheels, maybe we can work a deal. 19 MPG sounds good, what gears are you running 3:73's or 4:10's ? George
Do you know what gears you are running? 3:73's or 4:10's ? Thanks George
___________________________________________________________
Those big tires on big wheels do not work well in four wheel drive situations such as sand, mud, or snow. They are so wide that they just push too much of the muck and don't plow thru like a narrower tire/wheel combination would. The wide set-up also reduces gas mileage somewhat and can be noisier at freeway speeds. Narrower combinations don't look as good but they do work better under real driving and 4WD conditions.
It is tempting to try to remove the dome light and stuff some padding in there, but I don't see an obvious way to pop the thing off.
As for the wheels, it looks like I'll have to stay off the beach...
I'm in NYC/eastern LI and have yet to see any E85 in the wild.
You will first want to confirm that your vehicle does in fact use part
number H13 in its headlight application. The last time we spoke you
stated that the dealership told you that part number 9005XS was the high
beam and H11 was the low beam so it's possible that the information in
our lamp replacement guide is inaccurate.
If your vehicle does in fact use part H13 in its headlight application,
part H13ST would be the correct part number to upgrade to SilverStar.
This part is being sold by the following retailers:
Advance Auto Parts
AutoZone
GI Joe's
O'Reilly Auto Parts
I believe it is in the owners manual, but it might have been from my dealer or from the brosures.. But apparently you shouldn't go off road at all with 20 inch wheels.... Becausethe actual rubber is shallow you lose a lot of the shock absorbing that 17inch wheels have...
Nothing for not locking them doors at all in my case, I think your's is in the same situation.
http://www.huskyliners.com/mudguards.html
Don
I have found a wide variety of prices online ranging from $130 - $170 each >>> however none of the sites I have contacted will allow returns (they all consider them special orders) and NONE of them have pictures in the correct color --- Light / Dark Cashmere. Obviously so long as they fit and the color is correct - I do not plan to return, but spending $300+ on items you can see and can't return is difficult.
Any help is appreciated!
20-Inch Tires
If your vehicle has the optional 20-inch P275/55R20 size tires, they are classified as touring tires and are designed for on road use. The low-profile, wide tread design is not recommended for off-road driving. See Off-Road Driving on page 367, for additional information.
____________________________________________________________
Then you are not doing any serious off roading. The 20" tire going thru mud or snow is like dragging a surfboard sideways thru the water. It just doesn't work well. The tire tread is way too wide and the sidewall is way too short to work well in limited traction situations. But if it seems OK to you....well, then, go have some fun.
1. Two (2) forward wheelhousing liner screws to remove
2. Two (2) washer container push pins to remove
then you need to open the hood to work the rest:
3. I counted Six (6) upper fascia bolts need to be removed
4. One (1) lower fascia bolt to remove
5. Two (2) fascia to fender bolts (seems only need to loosen rather than totally removed)
6. Two (2) Lower rear fascia bolts to remove from support bracket
7. Two (2) upper headlamps bolts to remove
From this point on, I can not see if there are other bolts/screws that are hidden yet still need to be loosened or removed; but, it looks this is where you need to grab and pull the headlight housing straight out until it disengages from the fender attachment bracket and the locating tab, and the 2 locating pins disengage from the radiator support, and finally the electrical connections... Becareful as the plastic can crack and break easily, especially if is any more screw yet to be removed! Hope this helps a little.
Good Luck and have Fun!
May I ask why do you want to remove the headlight assembly?
I hope I did not misunderstand your question..
Someone mentioned something about an arguement and if I sounded like I wanted to argue please accept my apology-my comments were not meant that way.
I am just confused I guess.
Thanks Steve in Saratoga Springs, NY
I should have stated that my off-roading is pretty mild stuff. Inspecting farm land and deer hunting sites is about it. No rock climbing or anything like that.
Thanks martin22.
The installer agreed to look at it to see if they loosened the AM antenna, but I am nervous that this is going to be some kind of unknown interference from the Lockpick.
Anybody else seen this?
Kim
Warranty Denied? (SEMA)
2007 LT - owned 2 weeks - love it, love it, love it
I have a 07 Yukon SLT purchased in July 2006. In my version of the Yukon manual (part# 15854793), the paragraph regarding 20" tires is listed on page 483. In essence, it states that the 20" tires are designed for on road use and not recommended for off-road driving.
Hope this helps.
Thanks for the tip. I'm at tne office now but will check my manual this PM.
Don
Looks like the LT3 package has what we want - I may add the Z-71 option
My questions -
All the pictures show a black dash - I would rather not have black - are there any other color choices (LT3 with or W/O Z-71 package)
I have a car now with a black interior - its hot as hell - compared to our other vehicles.
How stiff is the ride of the Z-71 package -
