Visitor Agreement.
I'd be very suspicious of the 79 engine myself... salvage yards may be your better bet.
kcram
Host - Wagons
Anyway, assuming both engines are carbureted you need to check out all the ports on the heads, bolt holes for the engine mounts, carb mount on the intake, bolt hole patterns on the transmission bell housing, etc. My guess is it won't work, as Ford usually modifies each engine pretty heavily when it's designed for a truck. May end up being better to load up the credit card and get yours rebuilt. You usually just buy a short period of time with a swap.
thanks kathy
If I remember correctly, late 70s Ford truck V8s installed in 3/4 and 1-ton trucks could run leaded gasoline, as the emissions rules for that weight class were not caught up to those of cars at the time. Granted, leaded gas hasn't been sold in ages, but I'd also avoid a "leaded" engine for an "unleaded" (1986) vehicle.
It likely would bolt up, though... Ford used the same transmissions in cars and trucks with the same engine. The 460 was likely hooked to a C6 regardless of the application.
kcram
Host - Wagons
Please provide a link to support that all states require equal or newer engine swaps.
Where did I say all states require it? I said states that require emissions inspection can require it. Can someone install an older engine and tune it to the point where it meets the newer model year's emissions standards? Sure. Is it technically legal where that person lives? That's up to the local jurisdiction.
While it may not necessarily apply to the 1979 vs 1986 460 V8 originally inquired about, there are enough minor changes in an engine every so often to meet the next round of exhaust regs. The manufacturers guarantee to the government that their vehicles will meet that standard, and the EPA can force recalls if testing shows these vehicles do not. Joe Average makes a swap to an older engine and was unaware of a design change in his original. He gets the recall notice for an emissions repair, goes to the dealer for the fix. Dealer sees the part isn't there, realizes engine is older than model year. EPA violation and fines for the owner.
You just can't make the blanket statement, "sure you can swap" any longer.
kcram
Host - Wagons
it stalls on me when i stop at a light or stop sign.
can anyone help me
could it be the fuel filter? how do i find it?
If you’re encountering poor performance, poor economy & foul smelling emissions know that you’re not alone. The manufacturer has admitted to a major engineering blunder that we the consumer must be willing to allow our vehicles to undergo extensive alterations to rectify such problems. They claim that the engine was designed to run on no less than a 47 Cetane level which is found in all diesel fuels. The highest Cetane level however is a 45 found in Sunoco Gold. As if the ever rising cost of fuel wasn’t enough the manufacturer goes and designs an engine that requires expensive fuel additives to run. Aftermarket computer chips tend to help but be aware that this voids the factory warranty. Cummins & Duramax engines seem to run just fine on all types of diesel fuels so why should we the consumers be inconvenienced by the manufacturers inability to engineer a motor that runs on fuels that haven’t changed in years. If your thinking about purchasing a Powerstroke remember that you probably won’t smell the offensive emissions or encounter any performance problems until the vehicle has been driven for a few weeks so don’t base your decision on the test drive alone.
What I learned was that there were tons of 4x4's for sale, with few 4x2's. It's pretty obvious to me that people are trying to unload a bad tranny. I'm not sure if something like this can be detected in a simple test drive, after all most people who bought them new test drove them....right?
What a mess Ford has created with an otherwise nice design.
I doubt it. There's way more than a difference in transmissions between the 4x2 and the 4x4.
Far more likely that people are trying to unload a vibration problem, which appears to be far more prevalent among the 4x4 variants.
isn't the vibration coming from the tranny?
and is this a problem detected with a simple test drive? if so, how did it go undetected by all the buyers? i don't get it?
kcram - Pickups Host
my point is that there are many more '04 4x4's for sale than 4x2. I suspect the vibration problem is causing alot of unhappy folks to unload and it's a shame that Ford can't fix the problem.
My question is, how are you going to explain to a prospective buyer what the deal is with the vibration? And how did Ford manage to sell so many vehicles with this problem?
Temporarily I stopped using the rear tank and now when I fill up the front tank and drive for a bit I notice the gas from the front tank is being transferred to the rear tank.
Can anyone help?
