Cindy
Had a problem with power steering sensor truck would not run but replace it and it ran fine. My concern is the oil pressure and oil pump. what is wrong dealers do not know. :sick: :confuse: :mad:
I would greatly appreciate your response.
Thank you,
Scott
I have a 2002 durango. When I put my vents on a/c or heat it comes through the defrost no matter what panel I have it on. (it comes out slowly out of the panels when on panels) Is this something that I can fix myself? Any suggestions on why it is doing this or how to fix it? Thanks ~
I have a 2002 Dodge Durango that has stalled several times in the last two weeks and also would not accelerate luckily it has been around town, or when I back up will barely move but it does very slowly. I had it completely checked out at a reputable auto repair shop - 49,700 miles out of warranty. They did a complete diagnostic test, checked the battery which was 3 years old, pulled up some codes P0456, P0442,P0443, P0340 and after thorough investigation for leaks etc.- They told me that I had to bring to dealer to reflash the PCM because they did not have the updated software. The fun begins I bring to the dealer we drove it there no problems etc., they claim the battery is dead and had to replace there were no problems with the battery even though it is 3 years old, the post was broke well if it was broke I would not have been able to drive it there. They claim that the new battery will cure the stalling problem even though the check engine light is still on with code P0443 still showing up unfortunately the other shop cleared previous codes so they did show up at the dealer. Any suggestions or similar problems with fixes. I would love some help - this is my family car with young children as passengers and we are going on a long road trip soon!
With my two small children with me an hour away from home. I paid the $150 tow bill and my vehicle is sitting in the dealership lot as I type. They say it may not be until tomorrow before they can even look at it! I was traveling 65 mph, lost power, guages dropped to 0, pulled over waited an hour in 93 degree heat with my kids. I had no warning and was lucky to be in the right lane to get the the emergency lane. I can only imagine what I am going to hear! I appreciate any suggestions or input. I saw the PCM comment, even the tow guy said sounds electrical lets just take you to a dealer! Please help!!!!
Cindy :shades:
Cindy :shades:
I have the same problem and still looking for the answer to fix problem. The power steering pressure switch connector has failed and is pumping power steering fluid through your ground (black wire) wire - which is also coupled to your o2 sensors. Front sensor is shorted out - causing the computer to receive mixed signals. Tells the computer to go rich, dumping gas through extended opening of the injector. If you have been driving it for a while like this, step down on the gas in neutral or let it rev up. Take a look behind you and see the black cloud that you just created. Dealership stated to replace the wires involved within the wiring harness and reconnect them to the proper location. I am still in the process of doing this - unless anyone has a better idea!
Did you resolve your problem?
I have the same issues and still looking for the solution.
Thanks in advance.
Check your power steering switch and see if it is leaking. If so, I am told that the power steering fluid is getting pumped into the wiring. The black wire from the pressure switch goes / shares the ground wire to the o2 sensor, and shorts it out. I have been battling this for some time.
Dealership stated to create another wiring harness to the 4 wires that the 02 sensor. Still in the process of getting the right wires.
Let me know what you found out.
I went to Alldata and purchased the 'book' for $25. The ground wire for the power steering switch and o2 sensor are shared.
Did you get yours fixed?
Looking for help or advice!
Julies Mom
If the switch goes bad, leaks power steering fluid into the connecting wires. This is inside the wire itself - through the strands of wire. The black wire is the ground wire, which just happens to connect to a splice joint with the ground wire for the oxygen sensor. Fluid leaks down to the (front 1/1)oxygen sensor and grounds it out.
This causes your computer to receive faulty information, running excessively rich, causing black soot to discharge from exhaust. Gas mileage - very poor. Poor Performance.
I ended up taking the wiring harness off the non-engine side and traced the front oxygen sensor wires to the closest harness connection.
I ran new oxygen sensor wires. Problem solved.
If anyone has this problem, I will help you with which wires to cut and / or join to.
From you note about the leaking steering fluid, do you think it could be the cause f the computer issues? The truck has 132K miles on it and runs fine other tha the issues mentioned.
Power steering switch failure - causing power steering fluid to be pumped into the connection. Fluid inside the black ground wire is on the same splice joint as the O2 sensors. Fluid reaches the O2 connector and starts to fill up the other 3 wires.
One needs to replace the wires to the O2 harness. You can still use the same connector - take it apart and solder new wires in - or purchase 4 new wire splicers from factory.
All 4 wires re-coupled to area under the air cleaner.
If this problem goes too long - then fluid will be pumped up to your PCM and require replacement.
Your O2 sensors may be good - so save the old ones that you removed.
If you need additional information - please let me know.
Need additional information - let me know.
Good Luck
Cindy
Good Luck
Cindy
Thanks aray2
Thanks for any help.............
Ok. I'm/we are desperate! Would be grateful if you could describe how you fixed your contaminated o2/PS switch harness. I've cleaned it as-much-as I could. Reconnected it and reset the CPU. All was well for a few miles. P0171 code returned. Smells, lousy mileage and all the other symptoms. I trust that the o2 sensor is good based upon a number of web postings. Gonna try the new wires before dumping un-necessay $$$ on a new o2 sensor.
Any help would be appreciated...........
