on my 1999 tracker the front left bearing went out. then about 6-9 months later the right rear bearing went. when the right rear went, axle grease was leaking out BAD. i was afraid to drive it home. i took it to a little garage it cost me about $300,. because in order to change the rear beaing they had to pull the inner axle Out! i have been nervous ever since. i have replaced 2 bearings. when are the other two going to go. i will say this. since then i stopped off roading and have not needed a bearing since then....
I made a mistake. The Amsoil synthetic oil I bought for my transfer case is compatible GL-2 to GL-5 (75W-90) it isn't just GL-5. The trackers transfer case takes GL-4. Sorry
It looks like Rock Auto has the fan/motor assembly listed as an A/C Condenser Fan for a Suzuki Vitara for about $84 plus S/H. Not inexpensive, but not $300, thank goodness. It looks like changing out this assembly is not too complicated as noted by another respondent. Our '99 2-door/2.0/5-speed has been totally reliable with only routine preventive maintenance. Best of luck with yours.
My problem is the front crank window. Tilts forward a little and binds when putting it up. I have tried lubricating the tracks and that helps for a day or two. Then it does it again. All I have to do to make it go up is to push back on the glass it moves about 1/4 in and rolls right up. What should I do.
Also wikk useing a K & N filter improve my gass milage... :confuse:
Thanks for this info! I will look into it. I just found out tonight that my brother, who also owns a 2000 Tracker, had his fuse blow for his A/C. He hasn't tried to replace the fuse yet to see if it blows again though. Wish he would so I could see if he's having the same issue as me. I'll pass this info on to him if he does.
I have 99 Tracker. A few months ago the passenger side rear window would not go down..a few days later the same thing happened to the drivers side rear window. The fuse is not blown. Is it possible that both motors died within a few days of each other?
my 1999 tracker 2-door with the 2.0lt engine with 215/75/15 BFGoodrich all-terrain tires on it gets 24.6mpg on backroads. i have No highway mileage to give you as i dont travel on them...
We are starting to see quite a few crankshaft position sensors acting up in the repair business. I have one in the shop right now with a very similar problem. I was lucky today it hit 106 degrees here in Dallas and this helped me recreate the problem severe enough to set a code. Most shops are turning these away because most times there are no codes set and this makes it very difficult to diagnose (took me 8 hours of hard diagnosing) It looks like a trend on the 2000 models. Unfortunately you have to buy it from GM at $260 plus tax, it is the entire assembly located at the back of the cylinder head, kinda looks like a distributor but no cap or wires.. Hope this helps.
You need a OBD2 code reader w/erase support to do this. $100-$150 at your local parts store. Not all readers support erase function, cheaper ones do not. Also clearing the light will return soon after the erase if you do not repair the problem that is causing the light to come on.
I just replaced my front axle, transfer case and rear axle oil. Everything went well, what came out went in as per specs, except for the rear axle. The specs say 2.2 litres of gear oil but it only took about 1.5 litres before it came gushing out. I lowered the truck until it was on the ground just to make sure the pumkin was full, it was. How much oil is usually retained by the rear axle and is there a way of draining all of it out? Is my rear axle full?
if you have the tracker level you can Not over fill it. have the drain plug screwed in and fill the oil through the top hole and when it starts to leak out the top hole you have enough,.. i have done this to my rear axle 3 times. reason for 3 times was i did it twice . but when my rear axle bearing failed., the shop have to take the axle out to get to the bearing. so after i got the tracker back i took their oil out and put my amsoil back in ,... when i changed my front/rear/.tranfercase/trany/engine oil all at the sametime with amsoil wow what a difference. i would think you would get this difference from a mobil1 oil also. i noticed my tracker drifts downhill will less resistance. I use amsoil in my bike. which believe me is $$$$$ almost 6qts in a bike!!!
Bought a used 2000 Tracker 4wd convertible about 18 months ago. My 4wd shifter would not budge either. I tried all manner of engine/drive train loadings while trying to shift it into 4wd. Engine off/on, clutch in/out, rolling slowly forward/reverse, 30mph (forward...lol). Nothing worked. Finally decided to do what any man worth his salt would do.....I forced it. I moved the drivers seat up to where I could put my elbow against the seatback and barely squeeze the heel of my hand in behind the shifter. Then by rotating my wrist, I could exert tremendous forward pressure on the shifter. It moved forward into 4wd and after 10 minutes of shifting in and out of 4wd at about 10 mph, it freed up completely and now appears to be fine. Good Luck
We people in cold climates can also experience shifting into 4WD problems. When I experienced this condition during an extreme cold snap I was told by a Suzuki rep that humidity generated by melting snow in the cab of the truck was freezing onto the 4WD shift linkage causing binding. Keeping my linkage well lubricated has alleviated this condition somewhat. The shifting can be still be alittle stiff in extreme cold. The other problem alluded to by Pafoxhunter brings to mind the old saying. If you don't use it, you will probaly lose it. I have always owned part time 4WD systems, from four different manufactures. At least once a month I find a long straight section of road, engage 4WD high and drive straight for at least a mile. This I have been told keeps things lubricated and keeps you informed as to the systems condition. I found out that my 4WD was not functioning on my Tracker by this method, better to find out now than when I needed it. What are your comments on this practice?
Even though I am British by birth I have lived in this great country of Canada for most of my life. Is there any way of having a Canadian flag beside my pseudonym. Thanks alot.
i just bought a 00 tracker and i would like to put bigger tires, what is the biggest size i could go with with out a lift on it or having the tires rub on the wheelwells when i turn, and if i was to put a 3 inch suspension lift how much am i looking at $ wise and how big of tires could i go with ? thanks
Hi again, last post got deleted cause I put my email in it, sorry!
My wife's 00 4 door, 4x4 tracker got backed into the other week. I am in charge of replacing the front bumper. (The damage: left front piece of the plastic is pushed up under)
How in the world do you get the bumper off? Anything I need to watch out for (like airbag sensor, or whatever else)?
If your body is the same as my 03. Remove front grille by removing 4 plastic retainers from top of grille, gently pull the radiator grille from the vehicle by releasing the plastic retainers. Remove headlamps. Disconnect lamp first then remove 3 bolts, one bolt on top, two bolts on bottom front of headlamp. Remove side marker lights, unscrew and disconnect. Remove 7 plastic retainers along the top of the bumper fascia. Remove 1 bolt and plastic retainer at end of bumper fascia in the wheel well. Remove the 3 bolts which secure the front fascia along the bottom, then slide front fascia forward and remove. 3 bolts along bottom tighten to 11lb - ft, 1 bolt in wheel well 11 lb - ft, 3 bolts for headlamp 89 lb - INCH, Remember to reinstall all plastic retainers. Keeping all hardware in separate labeled plastic bags will help. As you reinstall make sure side marker light wiring is properly routed. You may have to reaim your headlights. Hopefully if you retorque those headlamp bolts evenly you won't have too. Air bag sensor is not attached to the fascia. Good luck
EXACTLTY what I was looking for. I knew there had to be more to it than just a couple bolts and ripping it off (been around too many old chevy trucks) Thank you so much!
well my tracker is back in the shop for a rear axle seal AGAIN. actually the same seal. passenger rear. last time (2 years ago) i had to have the rear bearing and seal replaced. well this time its just the seal. not sure why it decided to give out. i havent been off-roading or anything. the part cost $5, but the labor involved is pretty intense. you have to remove the drive shaft, rear axle and install the seal then put everything back together with new rear end oil. lasttime with the bearing it was $317 from a little local garage. b4 this i had a drivers side front wheel bearing go out on me. WOW was that expensive! i went to a dealer on that one. NEVER AGAIN. dealer wanted $500 with a new front rotor. way less labor than the rear end bearing.i wont know this price until it is done..
I have a question on "proper" RPM/shifting points, and the relationship between RPM and engine lugging.
I am sensitive to engine lugging and from the sound and "feel" of my buggy, it seems 2000 rpm moves it along ok without a sense of lugging. If it drops to around 1500, it begins to protest, and I keep it at least at 2,000-2,500 RPM. But perhaps I'm mis-reading the feel of my Tracker.
If your Tracker has the 2.0 engine, your feel for shift points is accurate. The 2.0 engine will cruise on level ground at 1,500 rpm, but you should downshift to accelerate. The 2,000-3,000 rpm range is best for common driving conditions.
Just trying to do a little research for a friend of mine. She owns a 96 geo tracker and thinks she blew the gasket on her exhaust. If this is the case and it needs to be replaced does anyone have any idea how complex this job is to do in order to replace this part??? I don't have the manual on her car so DIY info would be much appreciated.
Ouch! I wonder if the aftermarket make a better rear seal for your rig? Have you tried an off-roading aftermarket shop? You kinda got to wonder what is damaging the seal so often, a burr on the drive axle? Even one further down the axle could damage the seal on reinstallation. I hear you on dealer mark-up on wheel bearings and parts. Wheel bearings for my Toyota Landcruiser cost an arm and a leg from Toyo but I found the exact same bearing from Timken bearings for a whole lot less. Good luck
Just by chance check the breather hose on the rear axle for kinks or clogging. As you know if kinked or obstructed in any way the heat and pressure in the axle during operation will eventually blow a seal. Just a thought.
well i got my tracker back today ($104) cheap!! chevy parts, local shop did the install. The local shop told me that the chevy dealer said they have a whole bunch of these seals ready to go when the trackers start coming in. he said they replace a ton of these seals. they said its a common problem. ALSO..... if any of you need a seal. dont get it from your local parts store. chevy revised these seals to stop this common issue. my new seal is the revises one. the chevy price on the seal is$28 advanced auto's is $5 but believe me you dont want to pay labor more than once for the same part. i believe i got a deal on labor this time. because i know the guy and he felt bad about it being the same seal as last time. he said the new seal even looked different than the replacement oem seal from last time..
Hubby installed aftermarket stereo using an appropriate harness, however the illum. lights no longer work. Now, the h-lights come on automatically instead of the delay. ALL fuses are good under dash and engine compartment. Checked with meter. Also replaced Tail Relay..no luck Reinstalled factory radio and now the clock light comes on, but all other radio function lights gone also. Ahhhh, can anyone offer some advice. I would be forever greatful!! Thanks all!
Here's praying that Chevy put the new revised seals in by the 03 model year. If not what, what specifically do we watch out for when the seal blows? Every vehicle is different. Will oil appear on the inside of my rims? Etc, Etc. Thanks in advance for the info.
on the axle seals, what saved me from needed a whole new axle was, when i would check air pressurein the tires i would look at the inside of the rim. thats how i would the leak each time. this last time i found it early. but the 1st time i was a little late in finding it but no damage was caused. if you wait too long and loose most of your rear end oil, you could be looking to purchase new rear end gears and whatever else damage it may or maynot cause. i noticed thatmy Passenger side rear inside wheel was black, whereas the others wheels were clean. so i stuck my fingers between the opening on the wheel and smelled what i saw. and i recognized that smell! Differental oil..... 8(
On the bright side, if you lost your rear end due to lack of oil at least it would be a good excuse to put in a locker. If there is one available for our rigs. Glad to see that you pay attention to your air pressure, saves gas and tire wear.
Out of curiousity I looked into ARB, which was the place to go if you wanted to lift your Toyota Landcruiser also are famous for their air lockers diffs. Air lockers are way cool and incredible off road. Also the Old Man Emu suspensions are high quality. Go to http://www.arb.com.au/ Their stuff is easily purchased in Canada and U.S
I bought it a year ago and I love it the only problem is the check engine light came on at 30,000 miles did the research and it is a sensor in the exhaust.No big deal now if I don't drive it everyday it stalls when you stop at a stop light, it starts right back up and if you pull over and turn the ignigtion off and restart it runs fine. Any insight would be helpful Thanks
Obviously I'm new here, and I drive an '04 Suzuki Grand Vitara XL-7. I know this is a Tracker forum, but we all know the Tracker, and Vitaras are sisters. Anyways, I'm having a problem with my keyless entry system not working on occasion. 95% of the time it works, but on occasion it is just totally dead so I have to manually lock and open my doors. Any idea what is causing this? I also noticed when it does act up, there is no beeping noise with the key in the ignition and door open. (You know, the noise that warns you that you left your keys in the ignition.) Could this be related? I hope someone out there can help me figure this out...
Thanks for the Katrina Relief website. We've just personally gone through Hurricane Rita on our side of the state. It's like the Randy Newman song, Louisiana 1927....'they're trying to wash us away'.
At least my tracker came through during the storm, acting like a champ as I'm out photographing for the newspaper.
It's unreal isn't it? I have relatives in South Mississippi, including an elderly uncle that we didn't hear from for five days. My relations who lived through Betsy and Camille down around Venice LA moved a few hours northeast 20 years ago and they still lost a roof this time around.
Too bad Congress is so intent on earmarking pork projects instead of ... ah geeze, don't get me started on bridges to nowhere. :-)
Stay safe out there (and if you're in NH or NJ, don't go fording any flood waters in your Trackers).
As for any other problems, I haven't had any yet.
As a resident of Louisiana, your message is very much appreciated. Thankyou Canadian friend.
Okrafeet
Hurricane Katrina and Flood Relief (donation links)
Good Luck
Tom
http://www.tops4less.com
You may have to log off and log back on again to get it to "take."
Thanx!
Thank you so much!
feel of my Tracker.
Any thoughts, feedback?
http://www.puresuzuki.com/limited_slip2.htm
