Chevy Tracker
I think these SUV's used to be by Geo are they
essentially the same car and if so I am looking for
any Tracker owners out there...How reliable are
they? How do they drive? Seems like everyone has
a CRV or Rav. ARe you happy with your tracker? Mdp
I bought my 99 4 door in April, love it, no problems at all!
Before the Tracker, I had a 95 Sideckick JLX 4 dr. with the same engine. Here again it would perform flawlessly in these mountains.
I wouldn't hesitate to buy the small engine. these engines are nearly indestructible. I know of a number that have over 200,000 on them and still going strong. These are abused vehicles that are used for severe off-roading. Both of mine have performed better after getting 10,000 miles on them; much more peppy than when it was new.
I would recommend a Tracker to you. I have owned 2 of them, a 1990 Tracker 4x4 convertible, automatic as well as a identically equiped 1993 model. They are very relaible, and between the 2 of them I put on over 100,000 miles. I did nothing but change the oil every 3,000 miles, as you would with any car. The 93 version was leased, and after the lease a friend of mine bought it and has put roughly another 30,000 miles on it, and they too have been trouble free. No car is perfect, and you need to have some sort of idea about previous maintenance if you are purchasing a used vehicle, but I would recommend the vehicle without any fear.
The 4x4 worked great, and got me through the Blizzard of 93 without a single problem. Good luck single mom....and maybe if you find a convertible, the kids will love it all summer too.
Have a great day....and don't forget to look up the value of used Tracker at Edmunds and kbb.com before purchasing. If you know how to drive a 5 speed, you should try and find a model with that transmission, as they will be even more inexpensive and easier to maintain.
So can someone who has towed something with their tracker tell me how much it cost to get the towing hardware, and where they got it from? Also how well did it tow? I'm looking at the 4dr 4WD tracker because I can get a good discount through my credit union...
susan
What I don't like about the car is I think it is a lemon. I first had problems with the break lights. Then the car started making vibrations. The dealer is trying to tell me this is normal! The most pathetic problem is with the outside body moldings. The moldings are starting to fall off at each end. The dealer said they can pull the moldings off and re-glue them! I know this is little stuff but it should not happen to a new car. Had anybody else had problems like I do? When I bring it back to the dealer it seems to me like they dont really care.. they just have my money and that is it!
I just picked up my 1999 4WD, 4-door Tracker. Funny that you mention the brake light problem. The only problem I've had so far is a bad brake light switch. Fortunately, my wife was following me home the day we picked up the new Tracker, and she was the one who noticed that the brake lights did not come on when I would stop. I, of course, was a bit peeved with this. Kind of dangerous, and definitely something that should not have escaped the showroom. All they had to do was replace the brakelight switch, and it was fine. I'm sort of discouraged, though, that they let the car get out with this problem. All in all, aside from a lack of power, I'm quite satisfied with the '99 Tracker. I'm getting about 24-25 mpg, and that's with a lot of hills up here in the Poconos. At speeds of 55 mph or greater, or when the rpm goes to about 3500, I switch to overdrive (and back again when I fall below 55 mph). I'm curious to see how it fares in the snow, in 4WD. I've heard good things about previous Trackers in the snow, so I'm expecting the same or better from this one. If anyone out there has info about the '99s in 4WD in snow, please enlighten us.
Rich
my wife and I own a 2-door '96 4WD tracker
(5 speed)and have about 60,000 miles on it.
most of the time it is run in 2WD, and because
we must have broken it in right, gets about
30 MPG! I have nothing but praise for this car.
In 4 wheel drive, it is very sure-footed and will go just about anywhere. We love this car!
for a while now (okay mostly me). I test drove a
Tracker around town and was impressed at how
comfortable it was and how solid it felt. I also
had the chance to tour the plant where they make
them at Ingersoll,Ont., which also left me with a
favourable impression of the vehicle. I`ve read a
number of postings concerning the lack of power,
but I`ll reserve judgment on that until I take a
full test drive. What concerns me more at this
point is whether or not the Tracker will be large
enough to live with on a daily basis. We have a
three-year-old daughter and we like to go camping
in the summer (tenting). If we take along a fourth
passenger, will we have enough room for a cooler
and the other outdoor essentials? If anyone has
thoughts on this , I`d appreciate reading them.
Thanks, Steve
The quality seems good so far. No major problems, but I do have vibrations throughout the vehicle at 47 mph and again at 59 mph. Above and below those speeds everything is OK. One other thing, when the automatic transmission downshifts, it seems to get "stuck" in that lower gear. It doesn't shift back. The dealer says it's a common complaint for the tracker and Chevy is working on it.
My 1999 Tracker vibrates when I slow down from 45 mph to 40 mph. However it does not vibrate when I accelerate to 40 mph. Is this what you mean by downshift? It seems to me you have a similar problem as mine? Also did you speak to customer service about this problem, they did not tell me anything about this vibration.
My wife drives the Tracker and loves it, but these little things drive me nuts.
mitzi7D@juno.com
There were also many problems with interior materials breaking (too many to list, basically almost everything), and as others reported the water pump died at ~150,000 miles. I traded it off at 155,000 and in dire need of a valve job (on a head with just 95,000 miles on it).
I've had similar material quality and valvetrain problems with the only other Suzuki car I've owned: a Metro. Resale value for my Tracker was pitiful, to say the least.
If you ask me, get a Jeep. Parts are readily available and much more affordable, material quality is vastly superior, and the resale value can't be beat. Resale alone makes the Jeep worth the extra $2-3000.
did you also have problems with any other gears?
Thanx in advance...jfccac
