Honda Accord (1976-1989) Maintenance & Repair
Mr_Shiftright
Member Posts: 64,481
in Honda
In order to make the original and highly popular “Honda Accord Owners: Problems and Solutions” forum more manageable, we are dividing that forum into “Accord generations”.
Please make sure you are in the right generation for your Accord, and then post your questions concerning any maintenance or repair item.
Thank you again for helping to make the Accord forums so great here at Edmunds!
MrShiftright
MrShiftright
I would try to find an experienced Honda mechanic--you may have to go to a dealer--to have it checked out. Honda carbs by this time are a maze of vacuum hoses due to EPA regulations.
Good luck!
Just bought the car ( 1985 Accord Hatchback 1.8 ) the day before yesterday.
Like topic :
Where can I find
1) Technical specifications for the car (preferably w. torque diagram) ?
and
2) Repair instructions (manual), preferably w photos and/or good illustrations. Is there any info on the Internet any place ? Workshop Manual would be great, but even a manufacturers spare-part catalogue would be very helpful.
Thanks in advance !
Cheers
Gunnar
P.S. Engine runs "fine" , but lacks a bit muscle I'd say.
It pulls just fine from lower revs, but seem to get a bit pale from , say, 3,000 rpm and up.
Any ideas ?
My 1.8 litre engine has a carb.
Are they (the engines)sensitive on air filters ?
Mine is really dirty, though other cars I've owned
have not been that affected by old air-filter... ?
Another idea is that the ignition might be set at a too late timing ?
I'd appreciate any input !
D.S.
The most economical option would be a Chilton's manual. I know there is one that covers the 1984-1995 Accord and Prelude. It is not as detailed as a factory shop manual, but will cover general maintenance/repair. It has technical specs, though I am not sure it has a hp vs. rpm and/or torque vs. rpm curves.
i find this site excellent for pricing OEM parts and seeing exploded systems diagrams:
http://www.hondaautomotiveparts.com/auto/jsp/mws/PartsSearch.jsp
Re. "underpowered :
Did you have the 1.6 litre engine? And
did you have automatic gearbox?
>> I can imagine the combination of 1.6 litre + automatic + AC =
resulting in a very underpowered car...
Re. air filter :
OF COURSE I'll change the air filter !
I merely wondered if this specific engine is more sensitive than usual , on air filter.
This is varying on different engines.
Obviously a highly tuned, high revving (sports motorcycle) engine IS demanding on airfiltering - no doubt there.
But THIS 1.8 litre/100 hp car engine appear to be modestly tuned and might (or might not) be more tolerant in this aspect.
Re. reading info :
I'll get a Chilton's (or Haynes), for sure.
I just wondered if there's some place on the Internet w. info ?
? Question :
Do you know if there's any HP gain (worth mentioning) to be achieved from altering the cam timing (adjustable cam-belt gear) ?
I'd be prepared to sacrifice some low-end pulling-power to gain
a bit more "fury" on higher revs.
Cheers !
Gunnar
Believe me , I know about air-flow, volumetric efficiency, A/F ratios, break mean effective pressure, et.c.
I'm doing my best to come across the "language barrier"...
All engines "respond" to changes in flow resistance - both inlet and outlet.
Different engines "respond" differently though, and
the issue I was asking about ( and perhaps a bit carelessly put ) was if THIS particular engine (Honda 1.8 litre 12valve , 100 HP) is more fastidious than other (car) engines regarding the air-filter issue.
OK ?
Cheers !
Gunnar
P.S. The fuel delivery issue will obviously be thoroughly investigated - do you know if that carb is fastidious on adjustments (f. ex. float level) ?
Great to finally get a web-site w info ! *thumbsup*
Guess there's no way to enlarge the illustrations ?
My guess is they're originally Honda's ?
Any more tips on Internet sites ?
Thanks again !
Cheers !
Gunnar
You could try a fluid and filter change, you might get lucky. Hope so.
I had an interesting thing happen with my 88 Accord just the other day, it was shifting at all the wrong points, and actually dropped into neutral while driving uphill at around 50 mph. Turns out that I had shifted it part way between D4 and D3. As soon as I shifted it into D4 the problems went away. I wonder it there could be a linkage issue with yours, and your not solidly in D4.
Maybe just a fluid change is all you need, easy enough to do since all you can do is drain and refill.
Mrbill
If you have a manual gearbox, the
"my speed went down.... but my rpms stayed up"
certainly sounds like a slipping clutch.
Also the fact that it runs OK in town = low gears , and shows problem at highway = high gear , points to a slipping clutch.
Clutch could be in the stage where it just barely manages gentle driving, but at highway speed ( 5th gear ) actually exercises a certain amount of "micro-slip" , something you don't usually notice;
this micro-slip eventually overheats the clutch, and thus makes it start to slip severely ( speed dropping ).
Change of friction plate would be mandatory ->
hope that the pressure plate hasn't warped from the heat.
Clutch could just simply be worn-out, but
a careful inspection for oil leak(s) recommended ! Oil would smear the clutch surfaces ( and cause an early death ).
At standstill shortly after a "speed-dropping trip" ,
you should be able to smell a hot (burnt) friction-plate, and/or hot ("burnt") oil.
Or both.
If it's an automatic - I suppose it have to be a defect converter ( I'm no good at automatics ).
Good luck !
Best wishes
Gunnar
P.S. Make SHURE there's no brake dragging ( car should easily be pushed by hand on level, even ground ) - a brake drag could heat up and eventually worsen ( increase friction ).
My 88 Accord has a sticking neutral switch. Sometimes the backup lights don't come on, and sometimes the car won't start in park. When that happens, I shift into neutral and the car starts fine. I'm assuming the swith could use a shot of WD-40, I just haven't taken the time to do it.
Mrbill
Check engine light comes at start.
Does not go out.
Car stalls after about 30 seconds.
Where to start?
Not o2 sensor, is it?
good luck
Q: For the second winter now my ‘91 Mercury Grand Marquis has had an idle problem. At temperatures below 5 degrees (F) the engine will race when I try to slow down. The engine will start and run normal until sometime after it's been driven at least 10 minutes. It will then start racing at a very high RPM and will not go down. The engine must be shut down for a few minutes for it to return to normal, only to repeat the problem. All the usual culprits have been replaced including the throttle position sensor, air sensor, and temp sensor. Any ideas?.....Andy
A: What has to be determined is if the idle problem is a command or mechanical problem. A command problem is the computer deciding the desired idle speed. If it is a command problem then it can be isolated rather quickly. Have your technician show you where the Idle Air Control (IAC) motor is located and how to electrically unplug it. When the condition occurs, unplug the IAC motor’s electrical connector. If the idle drops then you have a command problem. If it doesn’t you may have a sticking IAC motor. The fix for a sticking IAC motor is a cleaning or replacement. Most of the time I’ve found that a problem like yours lays with the IAC motor.
My symptoms are similar, however my vacuum leaks are constant and on a much larger scale.
It starts up ok, then the idle speed rpm climbs just as you described. This continues until the engine warms up then the motor dies, will not idle at all.
I forgot the techncal discription of the following; I went to the dealership and talked the service manager into letting me read their engine manuals on this car he gave me 30 minutes.
There is a idle speed boost meachanism that over rides the set idle speed if needed to keep the engine running, during startup, when cold and during periods of intermittent loss of vacuum.
check all vacuum line hose ends and connections. makes a clean cut just behind the damaged hose ends and re-connect the hoses. If the condition continues, check for vacuum leaks at the manifold. You may need to replace or overhaul the carb.
I need a vacumn diagram (exploded view) for a carburated 1985 accord. I have never seen a car with this many vacuum lines. right now I am trying to determine which line feeds the brake power booster (blown Diaphram) to cap it off without removing the booster.
I want to make sure i can get the car to run normal before buying any parts.
i purchased a 1987 honda accord 5-speed, knew it had problems but bought it anyways. when it low idle its missing and jumping, and then sometimes it revs up to 4000 rpm by itself. some black smoke from exhaust tells me i am running very rich, the owner before put a new carb on it, and have read on this website that it could be the idle air control motor but cant locate the part, when accelerating up to 65 mph, the cars seems to run fine, but when not accelerating it jerks and jumps like it is missing, would appreciate any open suggestions,
In the early 80's all car mfgs did not know how to make horse power and still get fuel economy with computer controlled cars. one of the first methods dropped was using vacuum relayed sensors, devices and conduits as the primary input support system.
Mrbill
It might be low.
mcurrie
mcurrie
Problem: still leaking oil. Assuming it's not the pan gasket, or the filter mount O-ring, what other likely suspects are there? Rear main seal? And/or?
Any and all advice/suggestions are greatly appreciated.
If your clutch is slipping at all, it's ready to go. You can test a clutch by putting stress on it, like deliberately going slightly uphill while in too high a gear (say fourth at 20 mph) and stepping on the gas forcefully...it should slip like crazy if it's weak.
Any independent shop can do a Honda clutch....$700 seems more reasonable, or around there. But don't cut corners and don't go to some grease pit of a shop. If the flywheel is grooved or burned or cracked, REPLACE it or you'll have clutch shudder.
Don't do this very much though, as it is stressful to an old clutch.
And make sure you're watching the road ahead while you're test-piloting. The slippage won't be subtle...the engine will race like you are in neutral.
If it slips badly, you have very little time left.
