First, check the engine torque rod (fwd side of the engine compartment). Its purpose is to prevent the engine from rocking with torque changes. The spoked rubber inserts in the rod tend to deteriorate and break.
It's easy to remove and replace if you need one. Just use your jack and a block of wood under the oil pan to support the engine and remove the two bolts. A new one should only cost $15 - $30 aftermarket.
Start the engine and remove the top cover plate on the valve (two phillips screws). Place your finger over the valve seat. When the engine is cold, you should feel air flow across your finger. When the engine is hot, you should not feel any air flow. If either of these is not as described, the FIT valve is faulty.
In the event you find that the FIT valve is the culprit, and you decide to replace it, try this before buying a new one:
With the cover off, inside the valve you'll see a white plastic retaining ring with two slots cut on opposite sides. Using a small screwdriver or other suitable tool in one of the slots, carefully try to spin the ring clockwise. If it is loose enough to turn easily, continue tightening in small increments until the idle quits surging. I had the same problem with my car a couple of years ago and this worked for me.
Recently I've noticed a new sound when I start up my Accord. Right when the motor fires up, there is a high pitched sqeak that lasts about a second and then goes away.
Is this serpentine belt or timing belt slippage, indicating that they need replacing?
thanks.
If the timing belt were to slip, you would know about it :sick: (engine would not run well, if at all). The timing belt has cogs on it, so it will usually break, before it slips.
I don't know why I even considered the timing belt...duh..it has cogs. That children is what we call a brain fart! xD
I might have made the mistake of telling the Honda service department that it was a clutch problem. They replaced the clutch master and slave cylinders and the clutch, but the problem came back after driving 5 miles after picking the car up. Now the problem is in every gear from second to fifth. When I drive at about 2K RPM and try to accelerate (even without flooring), the car starts to shake.
Could this problem be that the new clutch needs to be adjusted, or is it another problem? Could it be that it needs a simple tune up? I noticed when I got the invoice that "tune up kit" was listed in the long list of recommendations by the tech. I was never told this by the service rep. I just plunked $2300 on the table for the clutch, front engine seal leak (timing belt and water pump replacement while they're at it), and new battery cables. In addition, I am replacing the radiator myself today. Needless to say, I was less than happy :mad: when the car started shaking on the way home!!
http://www.hondaautomotiveparts.com/
Their parts pricing is great, but their shipping and handling costs are slightly out of pace with the modern online retailers.
One mechanic tells me I have to replace the oil pan gasket, valve cover gasket and Distributor O-ring because of a leak. I don't see any leaks when I check under my car in the mornings. Can this be internal? Also while I'm getting this done should I get my timing corrected and a full tuneup?
Will this be costly?
Thanks for your tips
Jim
What I'm hearing is the "shotgun" approach to auto repair. I know the mechanic is not here to defend himself, but if you are leaking from all THREE areas, one would have to suspect you have very severe internal crankcase pressure resulting from a plugged up PCV system. Thus, replacing all those gaskets would fix the symptom, not the disease.
I suggest getting a second opinion with the car up on a lift, and also checking the PCV system for proper operation
thanks in advance ~~
I notice a squeak (engine crind) after parking and shutting off ignition. What can this be?
cybercool
http://www.ae92gts.com/ae92gts_antitheft.html
The ABS light goes on when I start driving as soon about 2 min. Will getting my brakes done get rid of the ABS light from going on?
Cybercool
But while they are doing the brakes, have them fix whatever is wrong with the ABS since they'll have the wheels off and will be right there.
I found the engine light code with the paper clip trick and it came up 43. The Fuel supply system. My engine light came on even before I had my fuel pump replaced. I don't know if this could be the cause. Will this be costly to repair?
Please help
Cybercool
My ABS light goes on after driving about 2 mins. Do you think having the brakes done will fix the abs light situation or will it be costly?
Cybercool
regards,
Dan
My engine light code 43 indicates a problem within the fuel pressure system. It mentions check fuel pressure gauge and oxygen sensor. Should I replace both fuel pressure gauge and sensor or just the sensor? Wondering to just replenish the whole fuel line and if it'll be costly?
Thanks for your input
Cybercool
I have a 1990 Accord and I'm having trouble getting it started. I think it might be the fuel pump because the car acts as though everything leading up to turning over is fine, but it acts like its out of gas. The needle shows a full tank. Any ideas on fixes?
Also, anyone know why the headlights and brights might go out after flickering for about 10 minutes, while all the blinkers, running lights, etc. still work?
Thanks for any help guys!
I had the same problem. It turned out to be the steering pump hose leaking near the oil dip stick. I paid a mechanic $168 to replace it. I have now no leaks and it's all good except for a whinning sound when I turn but that maybe the pump itself.
Jim
Since it's been warming up around here, I started to use the A/C the past few days. Last night, I noticed something odd. While driving, I heard a small chirp from the engine, and then it repeated itself. It does it every few minutes--i'd say about every 3-4 minutes. Also, the car jerks a bit when it happens, kind of like I am going over a **small** bump or running over a small rock. It happens ONLY when the A/C is running.
Could this be a loose Serp. belt slipping? If so, why does it only happen when the A/C is running?
Thanks for your help!
Also, does anyone know a good online retailer that sells the Fan Timer Unit? Thanks again.
-Matt
I'm just thinking out loud here, but I was reading through some stuff online and noticed that some people don't recommend flushing/replacing the trans fluid on older cars, because that messes up the tranny and forces you to repair or replace it.
Here's the thing, my '93 EX with 193K had the transmission replaced @ 85K in fall 2001...for whatever reason. It was done before I owned the car, but I have the AAMCO documents to prove it. With a little over 100K on this transmission, should I do a flush or should I just leave it be until it gives out (who knows how long that'll be...it's only 7 years old.) I'm split right down the middle, since my transmission isnt old, but yet it's still got some mileage on it.
Thanks for any insight!
Cleaner fluid should flow better, and it should help the transmission work smoother. But as far as solving serious transmission problems, it will not fix something that's worn out. Have you checked the level and condition of the fluid? The dipstick is down low towards the front of the car, and should have a yellow loop. Drive the car for a little while, then check the fluid. If the fluid is dark, dirty, or smells burnt, it should be changed. How many times you do the drain and fill depends on how bad the fluid, and the drain plug magnet look.
Can someone refresh my memory and and tell me when the ABS light goes on what does it mean and is it expensive to fix. Will a brake job be totally unrelated to an ABS job? My thought was if I had a brake job done it'll fix the ABS lighting problem.
Cybercool
