I cannot say if you have a definate problem or not with the tranny, however I do know that some Honda automatic tranmissions tend to act weird sometimes as you are experiencing. My family has a '96 civic and it has a hard time with second and third gear, it will shift into third, and then downshift into second for no apparant reason, kick up to about 4000 RPM, and then shift again at like 4500 or 5000. It will also hesitate a lot in 4th on the highway when the AC is on. I have talked with some third-party mechanics and they have told me a lot of people report the same type of problems with the honda auto transmissions on the sedans. It isnt anything that will cause the tranmission to lose life, its more just an issue of inconvenience.
I am not sure what the gauge problem would be related to. Maybe a circuit that has shorted somewhere?? I have not experienced this problem before.
Personally I can not stand this little querk about the civic that I have been driving. So when I was looking for my used 97 used accord, I decided to get the 5sp man trans.--you get the benefits of being able to shift when you want, and you get an extra gear, which means better fuel economy.
B. When was the transmission last flushed?
Honda transmissions are known for being "peculiar"... And they MUST be flushed (not changed, but flushed) every 35,000 (or maybe 50,000, not sure) and you must fill it up with only original Honda transmission fluid.
If the car has less than 150,000 miles, it MAY be covered under this Honda special extended warranty discussed here before, which also covers some issues with the transmission's behavior.
http://p-car.com/diy/odometer/
-Cj
Check your door panel, but every Accord I've had has been 32 PSI Reccomended, with a maximum of 35 PSI. 25 is much too low, I believe. Your mileage should greatly improve, as should your tire wear, when you increase them into the 30s. (Again, check the door-jamb for definitive answers on reccommended pressure, but the 185/65 15 tires on my Accord LX and the 205/65 16s on my 2006 EX Accord both reccommend 32 PSI.
- Is your brake system loosing fluid? Is the fluid level changing?
- Sounds silly but check if the fluid container is correctly closed.
- With the car engine off. Press the pedal..does it slowly goes all the way down or does it stops before?. If you keep pressing the brake after you pump it several times..does the stopping position of the pedal changes compare when pressing it without pumping.
- While stepping onto your pedal, turn on the engine. Usually the pedal should move about half distance to reaching the floor.
- When was the last time you bleed your system. Or when was the last time you change the complete brake fluid?
Driving in this conditions is too risky, specially if you are pumping the brakes when this problem shows up while driving (seems that you are doing that when u said "..retry to stop..")....you could get killed (or what is worst , somebody else killed), if you don't repair your brake system. Based on the few things you mentioned seems that your problem is in the master cylinder.
Let us know if you were able to solve your problem and what exactly was the problem so others can learn.
I'm having the same problem. My Car won't crank at all once in a while...
Anybody; do you know if there is any component between the ignition switch and the starter. I'm wondering because when this problem shows up; I'm able to make my starter to work if I bridge it directly. Hope somebody could help. Thanks
-Cj
Anyway, you need to make sure (check and rule out) the following (is better to use that order):
- Leaks
- radiator cap
- fan (if it doesn't turn on, check fuse, the relay or the fan control module)
- Check all coolant temp. switch:
- Fan switch (should closed between 196 - 203 oF)
- Coolant temp. gauge (the one that signals the meter in your console)
- Coolant temp. sensor (which sends signals to your ECM)
- water pump (maybe is not pumping with enough force...could be problems with its internal fins or maybe something else)
- Radiator clogged.
- Thermostat (Pellet type) (could be stuck semi-closed; which doesn't allow the coolant to flow freely into the engine).
Hope this list helps you.
Good Luck!
J
When it doesn't turn on; what exactly are the sounds? Are all the lights in the console coming on? do you hear the relays closing? what about the gas pump? does it crank at all? does this happens no matter if it is cold or warm?....we need more details in order to know if we can help you.
any easy way to check this?
Now, as far as I know even if there is no oxygen at all; that shouldn't stop the starter to crank your engine... so I doubt that was the reason of the problem you are (or were ) having.
If your car doesn't crank at all then you have a electrical problem; now in your case seems to be random so it maybe some false contact somewhere (could be battery, ignition switch, main relay, or even a problem in the fuse box). Random problems are the most difficult to diagnose but not impossible. Usually mechanics, specially if they are not able to reproduce the problem will do whatever may help to improve the conditions but based only on whatever you told them. That is why it is very important to capture all the details about when the problem happened. A car that doesn't start is a too general description... but saying that the car doesn't crank at all then you can just focus in the ignition electrical circuit only.
You could start checking the cables around your battery, check the charge and load of your battery (if you take it to autozone they will do it for free, call them to check)....if the problem is still happening I'll suggest to check your main relay (actually you don't need to buy a new one...I remember I have a link on how to do a maintenance of that relay but I need to look in what computer I have it).......Well...I hope all these info. helps you.
Greetings
Hope this helps. Let us know what you found.
Mine is a 1996 LX Auto. Thanks!
My Accord has been excellent, bought new 12/29/94 and now has 116K. Have had new CV joints, master brake cylinder and brake pads changed during that time.
I also own a 2007 Honda FIT Sport which I love..I should say my wife loves, she won't let me drive it..
I will suggest the following:
- Its known that Honda accord ignition switch had a flaw for models of those years; and also that you could increase the switch to fail if you have too much weight in your key ring. Try cutting the "fat" of your key ring.
- Try using a electrical contact cleaner. There is a post in this forum with the details on how to do it.
- Check your alternator and battery. I have the suspicion that your alternator (and the voltage regulator) has failed and maybe the reason for that strange behavior of your electrical door lock is because of that (maybe some over voltage from the alternator which at the end has damage the ignition switch). If you found that this is what it happen then correct this first before changing anything (most probably there could be some other problems....maybe sensor that has been damaged).
My Accord is the same model but a 95 and with 145k. I have never experience your problem but I have learned a lot of my electrical system due to a problem that so far no mechanic has been able to fix....it is a random problem.
Let us know what you find. Good Luck!!
Thanks..
HELP!! Does anyone have any answers?
I get terrible gas mileage on my 1994 accord auto ex. Complete tune-up have been done along with a new catalytic converter and exhaust manifold. Are there any problems that can cause bad gas mileage getting 15 miles per gallon. Thanks
if you don't have a key fob, my thinking is there is wire crimping to one of the doors, probably the drivers or front passengers for the lock/unlock, or possibly, there is a defective switch in one of those doors for same.
Also take out your spark plug and check its condition ....I know that you have done a complete tune up but you never told us how was the state of the s.plugs. By checking its state (physical state of the electrodes...it is very important to take note of the color that you see) you could tell exactly what is the problem during combustion. Also, include all the details that has been done in your "complete tune up".
Checking the state of the sensor is not difficult; but before concluding that the problem is your O.sensor; you need to check the following (these are the main reason why you could have a high fuel consumption):
- Dirty or clogged air filter
- wrong Ignition timing
- Errors returned by the computer (also known as ECM).
- Prob. in the fuel injection system (most of the times the ECM will detect problems with it also).
- Low tire pressure
- Fuel leak.
- Emission system problems (the O.sensor check is part of this item)
About changing the O.Sensor after certain number of miles it depends if you are rich or not....lol...just kidding. Usually the only components that you need to replace after certain number of miles without checking its state are the ones that if it fails could produce a bigger problem (i.e. timing belt) but the other components usually are changed just by inspection or if it is detected that there is a failure with it. Periodical inspection of your car after a certain number of miles its good (a must for older cars...specially axles, brake lines and engine).
Good luck!
Our family has a Honda Accord 1994 with the same problem.
I have just today, removed the door panel from the door that was making all the noise. I found that it is the door lock actuator that is the culprit. I don't know how to fix this actuator. I just know that when I disconnect the plug to it the noise and problem go away. I imagine I will have to purchase another door lock actuator and install it myself.
The problem door we have is the right rear door. When you lock the door it makes a loud whining/buzzing sound. Then when you walk away, it continues, sometimes through the night.
It is very annoying, so for now I'm just unplugging the power to that right rear door lock actuator.
Sincerely,
tricci
Also, provide more details (things that you have change before the test, tune ups, any changes to the EGR system, last time you change your catalityc converter).
Anyway, NOX is produced when combustion temperatures exceed 2500 degrees Fahrenheit. EGR systems and cat.converter are systems created just to reduce the amount of NOX (and other gases) produced....so before changing anything in your EGR or cat.conv. you need to focus if your engine cooling system is working fine. I'll recommend to have somebody else repair it because in most of the states, the money u spent repairing this problem with a state certified mechanic counts against the min. limit they req.. For example in my state, the min. is 350, so if for some reason the mechanic is not able to repair the problem; the state will pass the emission test if you show them the receipt (needs to be from a certified mechanic from the state) of what you have spent. Hope this helps.
How do you know this about the key fob?
I have the same problem with my 94 Accord.
I took apart the door and removed the actuator. This took care of the problem. If you want to know if the actuator is any good, the answer is no. To save money, just unplug the power to the actuator inside the door. This will illiminate the problem of the on/off without touching anything and the awfull noise it makes. The only thing is you will have to manually lock/unlock that door.
tricci
Is this normal?
My thermostat stays about 2/3 of the way to half way.
does anyone know how to fix this?
thanks guys.
I dont think you should have anything to worry about.
I took my Accord in to get the freon recharged because it was not cooling fast enough, easy fix right? Wrong.
Shop tells me I need a new radiator fan motor as it's not keeping the pressure where it needs to be ($289) I decided to get one aftermarket and have a buddy put it on to save a couple hundred bucks. They ask me if I want to leave the freon they just put in the car , I said sure.
When I drove home I start hearing this clunking sound coming from the right side of my dash. And hear a purging relief value spewing all that I can think of is freon from under my hood. I take it back and they said once I get a new radiator fan I should be ok...
Finally my question is, could they have messed up something by filling it up with freon when the radiator fan was not working at full capacity or is it no big deal?
My 96 accord has recently been vibrating at stops...it the same kinda vibration that happens when the ac cycles, but I don't have the ac on. Any ideas?
Also on a smaller note, I turned off my radio for an extended period of time, thinking it needed charge time since I always play music while driving :shades: only to hear a weird groan while turning hard . Sounds like when you pull into the driveway in a tight angle...maybe the body isn't as still as it used to be but I don't recall hearing it as often as I do now. Any idead? thanks alot you guys
Now here comes my guess; because they introduce more freon and expecting the pressure to go up; they introduce more gas than expected which is not a problem because you are planning to change your compressor anyway(I guess that is what you meant with "radiator fan motor ")....but in normal systems; overcharging your system will most probably mess up your compressor.
So answering your question; I believe they are right when they said that the sound will dissapear when you change your compressor; but before doing that I'll suggest to check for leaks in your system...check all the lines, hoses and also evaluate changing the Accumulator (with a new one and not a used one) which its main objective is to protect the compressor (avoids that liquid freon gets into the compressor).
Hope this helps.
The vibration could also be related (maybe your driveaxle are to a near end...who knows) or also could be a worn lower ball joints, or tie-rod ends or any hard rubber used in your steering system. The only way somebody could diagnostic your car is by having a visual inspection of all the components I mentioned. Greetings
The groans take place in the rear passenger side ....like a slow creak, groan....I even though it might be my exhaust (aftermarket)
the vibrations make me think it is either an engine mount issue, a tranny issue, or an exhaust issue....you can literally see the steering wheel vibrate at a stoplight....and feel it underneath you.
mine is stuck about 1/4 of the way towards the red.
Also, whenever I turn my vents on--hot or cold, I get a squeak. Does anyone know what might cause this?
thanks.
ND
Just to clarify, that is not an oil temperature gauge, but instead is the coolant temperature. You have no oil temperature gauge in the car. The only thing on the dash that refers to the oil is the low-oil pressure warning light; you should see it come on briefly when cranking your car each time.
I don't know why the needle would be stuck there, maybe a thermostat problem? It's apparent you have either a cooling problem or thermostat problem if the needle went that high in the first place.
I don't know where your squeak would be coming from I'm afraid, and I realize I'm not much help, but I wish you the best of luck!
thegrad
96 LX Sedan, 165,000 miles.
I'll suggest to check again the components that you have change recently (why did you change them original? because you were having the same problem??). Also, I know is possible to check if a sensor is working fine or not; you will need an multimeter to do that but don't have the electrical specifications maybe you could google them. Based on my experience, the component that most commonly fails are (in that order) is the thermostat, water pump, radiator clogged or leaks present, then comes the sensors and switches.
I'll try to get the info on how to check those components; but I'm pretty sure you can find them in the internet.
Good luck
Have no idea if it's still easilly available at auto-part stores... But before trashing it (or rather tossing it in the recycle bin) -- is there someone who'd be interested in it?
