so i opened the fuse/relay box in the engine compartment and pulled and swapped an equivalent numbered relay for the passenger power window (check, yours may be the same as well) and when I swapped with the relay for the fans, voila that fixed the problem. then I went to Autozone for a replacement relay for the broken one. about $23 if I recall correctly.
hope it helps.
Some times, a circuit pulling a good deal of current will cause relay contacts to partially weld together because of electrical arcing and localized heating / melting, and/or build up of carbon from arcing cycles.
All fuses fine. Coolant in radiator is full. Individually removing the thermostat or Electronic Coolant Temp sensor (ECT?), allow the fans to run. As mentioned earlier, all A/C and vent operations are off. Also, the fans do not run when the car is off.
Thanks for the electric explanation. It allowed me to check a few other things, but to no avail.
Open to further suggestions.
Thanks very much for your good ideas.
Good luck
I think alldatadiy.com covers Hondas that old, if you want to sign up for a subscription.
Did you know the EGR valve has an extended warranty? I have a 2001 V-6 accord and needed the EGR valve replaced. I paid over $200 and then went home and looked over paperwork I had received from Honda in the past and found out the EGR warranty was extended. I called the dealer and after a bit of hassle I got the full price of labor and parts refunded for the EGR valve.
It doesn't seem to rattle at lower speeds, but when out on the highway, it's very sensitive and rattles noticeably at little imperfections in the pavement.
I reached over there, and I'm pretty sure I can feel a jittery something just below the dash surface, and when I put a little pressure on it, the rattle pretty much goes away.
Am I describing something any of you have encountered, and fixed?
I would be most grateful for any advice. Thanks.
PS: EGR and TCS systems are totally unrelated, so that means two separate issues.
I have a 2000 honda accord 4 cyl automatic, with 99k.
This week, my local gas station mechanic replaced the timing belt, balancer belt, and water pump, (routine maintenance- not due to a problem). When I start the car, I hear a high pitched whine. By the way, I asked for honda parts, and he said he was giving me a honda water
pump and a "gates" belt. I showed him the noise, and he said "bring it back if it doesn't go away in a few weeks".
What do you think?
A timing belt, if not changed will eventually snap, and cause enough damage that, well, let's just say you'll wish you had changed it. You can pay less now ($500-$700 for Pump and Belt) or a LOT more later.
I have 2000 Honda Accord V6 3.0 - 4Dr, I had been to some auto-garage very recently and he suggested for Transmission Service (around60$) and Timing Belt Replacement (don;t remember $).
I did 90000 miles check up when car was actually at 93000 miles reading and today tacho reads 109000 miles.
Today I went to honda brad barker for oil change and he did not suggest transmission service and timing belt change...
I am really confused because last some other garage recommended me above 2 services while brad barker today did not..
Is it really required for this honda model to get done above services after driving so much or not required at all ?
This is Auto Transmission 4 Dr 3.0 V6 2000 Honda Accord, 109000 miles.
by robertsmx
You don't need transmission (unless you meant transmission service, which I believe is done around 90K miles). But you do need new timing belt/water pump.
by thegraduate
He said it would be a $60 Transmission Service, so yeah I'd do both of them.
Upengan78,
ESPECIALLY do the Timing Belt and Water Pump. It isn't cheap, but you're operating on borrowed time right now. That service should have been done at 90,000 if I recall correctly
is there something online, I can see the factory recommended services for accord 2000 v6
I am not able to find the manual and confused as Honda brad barker itself did not recommend timing belt, transmission service on today's oil change and while I was reading posted messages on internet regarding transmission service, some have been writing if transmission service would actually really be required or it would rather damage the original nice transmission setting...
What is the use of transmission service and timing belt..?
What are their benefits and I know I read somewhere if I don't replace then it would be lot of damage to car
Also, transmission service : does it mean just changing the transmission fluid ?
I appreciate your early reply..
Thanks and happy Thanks giving..
in general, at your mileage, I think it's recommended, but your manual should be your guide.
go on the honda website and register your VIN. then you should have access to the manual via download.
when it comes to transmission fluid changeouts, I think it's good to do them every 30K. some say 60K, and others say go until you have problems. in my '02 accord 4cyl AT, and my '03 ody 6cyl AT, I personally can tell there's a good change in shift quality with new fluid. others might disagree. so be it.
typically you can drain and fill 3times cycling your vehicle through all the gears each time, and that swaps out most of the fluid. doing so only once does not.
me, i'm a fan of having the dealer "flush" it out. i don't think it's a high-power flush, but instead, using a machine to push the fluid out with new fluid and the pump mechanism built into the transmission, but i could be mistaken. i don't think it increases the likelyhood of transmission problems, but then again, i don't let my transmissions go 90-100K before i get new fluid into them.
this "flush" runs a few hundred if I recall correctly.
google the fluid and capacity of the transmission, or read it in your owners manual (which you download). no doubt when you price it out, this is more expensive than the drain and fill several times (3) approach. however, to do this, you need to have tools and ramps at least, and I don't know if you have either, plus you have to find some documentation on how to drain and fill, and be willing and somewhat mechanically inclined.
you can find that information here if you search for it, but if you aren't changing your own oil, you're probably not likely to do the drain and fill required of the transmission.
what ever you do, i'd recommend making sure the job is done with only Honda recommended OEM fluid. don't use a substitute if you have the job done somewhere else.
regards.
Yes there is. You can start here: Maintenance Schedules, Recalls and Technical Service Bulletins.
Even I don;t know how to solve this issue..Seems an issue with Honda Accord
i think if the battery and alternator are good (and you can have both checked at an auto parts store chain), then it *might* be the Electrical Load Detector (ELD) which is part of the chargine circuit on Hondas. if it malfunctions, it's supposed to force the system to throw a diagnostic code, but I guess it could be flakey and not do that. or possibly, it's not seated well, or the connector to it is faulty / intermittent, or mechanically not good.
it's located within the fuse box in the engine compartment and held in with two screws and has another connector to the wiring harness.
it's purpose if i understand it correctly is to regulate charging during periods of low vs. high loads.
You can clear up the alternator theory by driving at say 25 mph in second gear and get a feel for how it is pulsing. Repeat at 25mph in THIRD gear - pulsing slower then it may be the alternator, pulsing the same - then something in the guage cluster is likely to blame. You could also pull the VSS connector and drive it - if the pulsing quits, then it has to be in the guage cluster
Is above all for Speedo Lights on and off ?
Please advise what could cause this. Could it have been something the mechanic might have done accidentally? Like loosen a wire or something, a quick fix? Or is it likely unrelated. The stereo was also asking for "code" when I picked the car up so it means the battery or alternator power supply had been disconnected while it was there. I don't have the code but can get it from my Honda dealer. That is less of a concern than the whole dash being out. We've replaced the battery as the car is a '99 and had the original battery but still no fix. This is the first time in more than 8 years I took the car to anywhere besides Honda and am wondering if I made a mistake. We only drove it a short distance since picking it up because you can't tell how fast you're going and it overheated. My husband thinks it needs a new radiator cap, but we'll see. This is the first repair (the power steering leak) the car has needed in 8 years and seems like a whole bunch of things have gone wrong at the same time.
The mechanic says he didn't cause it but has no idea what is wrong with it and I should bring it to Honda. I've called them and made an appointment. I asked on the phone what it might be and he said he'll have to see it but most likely the instrument cluster has gone. Is this an expensive repair? Sounds like it. Is it possible the mechanic loosened a wire or something because it's odd that it happened at the same time the car was in the shop. I've heard from others they may have forgotten to attach a ground wire or they may have crossed wire when they were working on the car accidentally and fried the instrument cluster. We were hoping it was a fuse, but the manual shows the instrument panel and back up lights share the same fuse and the back up lights are still working.
This is a 1999 Accord with under 60,000 kilometres. I don't drive it very much but have never had any problems with it and dread the thought of spending thousands on it. Any help is appreciated. Thank you.
Mrbill
Good luk
Update: My husband called the mechanic this morning to discuss this and he didn't call back so he went directly to the shop. The mechanic said it's as much a mystery to him as us. He thinks it was like that when we brought it in (which it wasn't).
We had it towed to Honda. They've just called. They have said the circuit board on the instrument panel has gone and needs to have the entire instrument panel/instrument gauges replaced. They don't know why it would happen in a car with under 60K but can't say the mechanic did something, they thing it's random. I think it's odd that it happened while it was at the mechanics, but there's nothing I can do about it.
Regarding the overheating, they asked if I took the radiator cap off. My husband did after the engine cooled down to check the fluid levels. They said we should never take it off as it is dangerous. Then we realized they thought were had been driving with it off so we confirmed that we did not drive with the cap off. They said they noticed fluids in the engine but they drove it for a while and it didn't overheat. The fluids likely got there when the car overheated. I told them the displays on the dash weren't working so my husband couldn't tell it was overheating until it was already hot. They wanted to know how he knew it was overheating without the displays on the dash working so my husband said that steam had started coming out of the hood. He stopped the car and after it had cooled down for some time, he took off the radiator cap to check the fluid level. They can't figure out why it was overheating as it didn't happen today but they'll have the car for another 3 days waiting for the instrument panel and will drive it more
The bill so far:
$95 to diagnose the instrument panel problem
$95 to diagnose the overheating problem (even though no solution found, we're still being charge)
$201 for the instrument panel
$144 for the labour
They said if they can find out anything about the overheating they'll call and advise how much that fix will cost.
http://techauto.awardspace.com/vss.html
I just should make one clarification, as I just found out. There was a slight misunderstanding I think. When they called they told me the circuit board on the instrument panel was gone and the whole thing needed to be replaced. I guess I interpreted that to mean they were replacing the whole instrument panel. I'd called yesterday and asked for return of the old part out of curiosity. The message they left me today was that it's fixed, there is no core charge on the circuit board so they've left it in the car. I guess that would mean only the circuit board and not the whole instrument panel was replaced.
They seemed to try to be fair although I hadn't taken it there for the original repair. They said they've deducted an hour of labour to help offset the overheating diagnosis charge as they didn't find anything. So the cost came to just under $500/total including taxes.
So as of tomorrow I should have a car again.
Thank you for your help. At least I got to learn a (little!) bit more about the mechanics of cars throughout this. Hopefully we won't have any more problems.
When I got the car back, the gear shift indicator on the dash (PRN etc.) has a green light around each gear but it does not change when I move from park to drive etc. as it did before the repair.
Does anyone know what might cause this and if it is likely related to the repair done on the circuit board. I wonder if I bring it back to the dealership if they can fix it or if the change of the circuit board means I won't have this feature anymore? Thanks.
sounds to me like a harness coming from the gear shift (basically a multi-position switch) has not been re-connected to the instrument panel ckt board.
they should take care of it right?
of all the things on the circuit board, the indication of P, R, N, D, 1, 2, 3 (or what have you) has got to be the lowest tech, or one of the lowest tech portions of the whole board.
you can of course determine your shift position by looking at the shifter, and more than likely in your AT vehicle, your mostly only shifting when at a stand-still so heads-down time isn't an issue.
still, getting it fixed i suspect they'll take care of you.
Replace both front calipers.
What happens after you have this situation, is that when new pads are put on...the pistons are forced back into the calipers (to make room for the extra pad thickness). When they do that, the piston is forced past the area that has the corrosion on it, and the piston now begins to bind.
When the brake pedal is put on with lots of pressure, the piston is forced outward to put the brakes on. However, the piston does not float back by itself when it is supposed to, as the brake pedal is released. As a result, you run with the front pads continually trying to stop the car, and they wear down very fast. You will usually also see a lot of brake dust on your wheels, as well as feel heat, and/or smell the brakes.
