The error code is pointing to a leak. It could be a rubber hose cracked, canister cracked, etc. You need to check over the whole system carefully to figure out where the leak might be.
I have an 01 honda accord lx, and it is making rear noise when i brake or slow down. I know it's not the brake because it is new and I just change it n stuff like that, and braking noise is more like a screeching noise. This noise sound more like a soft grinding noise but loud. It happen even if i don't step on the brake when it slowing down bout 15-20 mph. Some said it is the calibar, some said its the bearing and some said it the axle. Don't know who to listen too but I really do not want to bring it in to the shop because it will cause me an arm and a leg brfore they will tell what is wrong with it. PLEASE HELP....
Thanks all in advance
Susan
here's an intro, you can google for more information
http://usedcars.about.com/od/usedcartestdrives/ss/Road_Test_6.htm
i personally like the bounce test and if the vehicle doesn't quickly stabilize, there's an issue. problem is, it's not a very objective test so YMMV.
if i looked at the struts and they showed signs of fluid leakage, that would be a done deal for me.
there's another forum for you to post your question:
http://townhall-talk.edmunds.com/direct/view/.efd3d52
monroe has this site which may be helpful:
http://www.monroe.com/tech_support/tec_faq.asp
Honda OEM struts can be found here (including other great pictures on parts / sub-assemblies... struts don't seem cheap):
front:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - - cgry1=Accord&catcgry2=1998&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=FRONT+SHOCK+A- - - BSORBER
rear:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- - - cgry1=Accord&catcgry2=1998&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=REAR+SHOCK+AB- - - SORBER
if it were me, i'd probably bring it to an independant specializing in Honda unless a local dealer is running a special. :surprise:
is your guy an independant, dealer/service writer? i highly doubt (unless the vehicle was driven hard in very bad road conditions) you need struts all around. my cars have never ever failed struts: hondas, vws, mazdas...
just WAGing it, i would suspect a loose strut, or possibly a loose suspension component, missing rubber grommet or something like that, and i'd bring it for a third opinion to an independant.
I went to the dealer last week for my 60k service. I needed a new transmission as well (which I told them was under an extended warranty) and they replaced it free of charge. However, I also needed rear brakes and an EGR valve. Cost of the valve with labor was $275. After I got home I happened to look in my "Honda folder" in my file cabinet and came upon the extended warranty info Hondo sent out in 2001 re the EGR valve. I called them this morning and they agreed to refund my $275 for the EGR valve.
However, I sincerely believe many other Honda owners have had this valve replaced and I am sure their delaer never informed them of the warranty, and they spent the money as I did. I really think the dealer shoul be aware at all recalls as well as extended warranties issued by Honda. At this point even though they are returning the money I am very disapointed with this dealership.
Honda dealer suggests me do following services
1.Timing Belt $540
2.Master Cylinder $300
3. Braker Fluid Flush$90
4 Throttle Body service $100
Non dealer service @ MIDAS/ Pepboys quote me less.
Please suggest servicing at non dealer won't harm the engine?
Second of all, I certainly hope your master cylinder is failing/leaking if you are replacing it. If not, I can't help but wonder why that is listed? Does your brake pedal sink towards the floor (losing hydraulic pressure) when you are stopped with your foot on the brake?
It is four cylinder accord and It doesn't seem to have leaking master cylinder. It has 76K miles and I drive less than 3-4 miles per trip ( severe conditions)
I do routine maintenance and oil change. During last oil change dealer suggest for this expence to do list
If your "BRAKE" dashboard indicator light isn't on, and you can't tell anything different about your brake pedal operation, I wouldn't bother with the master cylinder being fixed.
Have a great day!
Thegrad
In 2002, I bought a 1999 Honda Accord with about 33K on it at San Francisco Honda. Now my car has 109K on it. Six months ago my car was jerking at times. I was told that I needed a new transmission by SF Honda and the Celica Auto Salon. I took my Honda to my mechanic at Auto Service Center and they changed/flushed the transmission fluid and said to see how it drove for the next few months.
I drove the car, although it revved at times, the jerking mostly stopped. Recently, the car has started to overheat in traffic in hot weather. 2 weeks ago it over heated on the way home and I towed it to the Auto Service Center in SF. They told me that I should sell the car as quickly as I can and get something else. The car was very low on cooling fluid but they could not tell where it was leaking.
I wonder if anyone has an opinion on what might be causing the overheating and does it really sound like this is the end of my Honda's useful life. Would it be advisable to fix the transmission and investigate/fix the overheating problem and be back in business?
I would appreciate advice on this and if anyone has a good place to recommend for getting transmission work done in San Francisco or a great mechanic who could give me a second opinion.
Thanks, Anne - middle age single mom, not ready to spend all my money on a new car yet.
http://techauto.awardspace.com/
manuals can also be purcased on eBay and other web locations.
The problem was a bad FUEL RELAY SWITCH. Make sure that they check this component.
Bad fuel relay switch caused my car to stall at high speeds, low speeds, and in all weather conditions.
Good luck...I know how maddening the situation is.
This is the same problem. There is a switch on the brake pedal, that when the brake pedal is depressed it turns on the switch. That switch turns on the back brake lights, and tells the transmission that it is okay to take out of Park.
If the switch is bad, your lights don't work and you don't get out of park.
You jamming on the brakes a couple times, is just trying to see if you can get the switch which might be intermittent...to work. If you have a bad or intermittent switch, get it replaced. You don't need someone running into the back of you causing an accident and you getting whiplash....nor do you want to be stuck somewhere not being able to go.
Their is a shift release button under the cover plate of the gear shift if it ever gets to the point you can not shift it out of park use this release button. You will need to stick a key into the small hole to release it.
My mechanic found that the break pedal switch had an open curciut and they need to replace the switch ASSY.
In the end I paid $300.00
The error codes will point to where the problem is.
What we don't know in your case, is whether the shop just gave you the complete list of things to replace....or whether they took the time to look at the individual items and conclude that it is indeed defective.
This becomes a convenience, cost, trust, and time tradeoff. You've gone to the inconvenience of getting the vehicle scheduled at the shop, you've paid (or will pay) the diagnostic fee, and now you try to decide how many of the pieces are actually needed. If they are not sure and only replace the first one, then you may still have the failing code, and have to take it back to the shop to get something else replaced on the list. More inconvenience and more diagnostic fees.
If you are replacing the pieces yourself, then you can do them one at a time as needed until the problem goes away.
How good is this shop technically, and can you trust their diagnostic approach? Have you asked them how sure they were which parts were defective?
And the only thing now I concern is the risk, how high will it be IF I let it on all the time? New week I will have a trip about 6 hrs driving, hope nothing happen during the travel, especially on the highway. Any suggestions?
