-June 2024 Special Lease Deals-
Any help would be greatly appreciated. Thanks.
Mrbill
But in the 1st paragraph, he said the sensor #1 is before
the cat.
I'm not going outside to my cold car to double check the manual, but I do not recall it saying to have the oil changed at 15% as you said. My memory from my reading of the manual is that it will count down from 15% by 5s and that you should have the service performed before or when it gets to 0%.
With parents in Oklahoma (me in Alabama) I like to keep my car ready for such a trip in the blink of an eye if I needed/wanted to...So for that, I get the car serviced between 20 and 15%. I understand wanting to keep yours stretched out as long as possible, but is pushing that little button absolutely ruining your day?
Then, 1) log in 2)click on"My vehicles" 3)then click on " Service/ Maintenance" 4)then click on "Maintenance Minder" 5)then you see a link: "Click here to learn more about Maintenance Minder", click on it. And watch the video.
Pushing that button was a minor annoyance at first. After several weeks of this, it has crossed the line. I don't want to go through it again. I'll sooner change my oil earlier than I otherwise would have.
Also, now that my car is showing 5%, I'll get my oil changed at my earliest convenience, probably on Saturday.
If, as I suspect, it is like the Chevy's, than my recommendation is to do an oil change at the appropriate mileage and just reset and ignore the indicator. I've always believed in the 3 mos. or 3000 miles rule (although today's oils are much more durable than those of my father's heyday). It's the best maintenance one can do for a car - particularly these new VTEC motors that have tiny little oil ports in system that opens and closes the variable cam mechanism.
However, I drive my '04 Accord 100 miles roundtrip to work each day and my wife drives similar mileage herself in her '078 Odyssey. So we've pushed that out to around every 3 mos. or 4-4500 miles with both cars.
At the very least, even if the car is leased and you're cutting corners (and I hope I never buy a car that was leased by such a person) do it at the maximum recommended service interval printed in the manual (which, if I recall correctly, is 7500 miles). The dealer cannot surcharge you if you are complying with the intervals required in the contract and/or the owner's manual.
-FS
I believe it goes off of the cumulative revolutions of the engine, rather than off the mileage. That way it will more accurately reflect driving style vice just mileage.
To coin a phrase;
"What he said."
I just do not like to do any maintenance until it is time. For instance, when we used to go by mileage intervals, I changed the oil at 3,750 mile intervals as per the Honda owner's manual. Now maintenance intervals have bocome more of a customized thing - the manitenance minder for oil change that came on for me at 6,000 miles for 15% oil life may come on for someone else at 4,000 miles or 8,000 miles dependinig how the car is used and what the sensors sense about your driving.
I feel that 15% is too soon for maintenance minder alert to takeover your odometer function every single time you start the car, unless of course you are on the verge of taking a road trip, in which case it would be useful to know.
From what I have heard and read, long gone (but not forgotten) are the days when it was necessary and/or desirable to change the oil more frequently, such as every 3,000 miles. Today's oils are more durable and today's engines run cleaner. It should be perfectly fine to follow your owner's manual or maintenance minder, as the case may be. I believe (but cannot now check to confirm) that in the case of Accords with maintenance minders, the owner's manual no longer states mileage intervals for maintenance items. Instead each owner is supposed to rely on the maintenance minder to know when to do something.
First according to Honda, it's just needed and it's absolutely enough to follow MM.(see post #2230). Dealer's schedule for service and maintenance is so long,complicated and expensive. Would you like to spend more money? Would you like to go to dealers so often? Would you like to do some unnecessary services for a reliable car like Honda?
Secondly, to keep your warranty or extended warranty valid you should have you car serviced. You can choose between MM, dealers' schedule or any thing else. But I believe MM is the simplest and the cheapest.
Thirdly, MM has three codes: 1) oil life in percentage 2) alphabetical codes (A-B) 3)numerical codes (1-2-3-4-5-6). Each of these shows a type of service which is due and should be done. (details can be found in Owner Manual). But the point is that you won't get alphabetical and numerical codes before oil life reaches to 15%. So if you change your oil sooner than 15% you won't get other code(s)and you can not follow MM to do other services on time.
I just will follow MM and won't waste my money and time.
This brings me to my question. What aftermarket suspension products could my father go with to soften up the ride of his 2006 Accord sedan? He seems to like everything about the car but the ride. Any of you guys know of a replacement strut, or other suspension modification, that may just do the trick for my father? By the way, my mother is really tired of hearing him gripe about how "rough" their '06 Accord rides. I'd like to try and help them both solve the problem with their latest ride. Any help would certainly be appreciated.
Ron M.
Good point. However, don't the MM codes correspond to the maintenance schedule seen in the owner's manual of older vehicles? I haven't read the MM section of my manual since I got the car, but it seems like I vaguely remember the MM codes relating very closely to the highway maintenance schedule of my last car. Then again, maybe not.
I just hit 5% at 5800 miles. I plan to drive to 0% because I am a lazy poor college student. Plus, if the MM wasn't all that useful, why would Honda, of all manufacturers, include it?
front and 30psi for the rear.
Try lower the front to 30 psi.
to be honest, its good to change your oil every 3K miles, and only costs you $10, so go for it. But the manual isn't propaganda, if it says the maintenance minder can manage it, then I believe it.
I asked the dealer once and they said it was normal. I'm going to take it in again in a few weeks for an oil change and tire rotation and I'll demand they look at it.
By the way, it is much more noticeable when the gas is near 1/2 tank or below...do you have the same problem?
This one is VERY personal so others get to make their own decisions.
Of course people can change their engine oil sooner or later. It's their personal choice and I respect it. But even they should be aware that they need some sort of services. They can follow other schedules for services or even a personal one. Good luck
I can't say what's typical, but my 15% came at around 6,000 miles on the original oil. Now I'm at 5% and 6,600 miles. Will have the oil change done tomorrow. Nearly double the traditional 3,750 miles intervals for Hondas.
I am not sure which model year Honda changed over to the MM system. My 2004 Odyssey did not have it. My 2006 Accord has it, as does my 2007 Pilot. BMW has a better way (in my opinon). You press a button if and when you want to check how many miles you have left to go for various types of maintenance. With Honda, once you get to 15%, you have to press a button every time you start the car to make the maintenance information go away (and until you get down to 15%, you cannot get any information at all about your progress, not even by pressing a button). Otherwise, you can't see your odometer. This has caused confusion for Mrs. D and daughter D. They start the car. Maintenance is not overdue, yet there's a wrench showing up on the dashboard and something is a amiss with the odometer making it appear that there may be some sort of oil crisis. "Something is wrong with the car," they told me. I then had to explain to them about this new MM system. They also find it to be annoying.
Thinking ahead to the equivalent of what used to be the first major maintenance interval (30,000 miles), I wonder what will happen with the MM system. If oil changes that used to be done every 3,750 miles are now being done every 6,600 miles, will the first major service be called for at say 50,000 miles instead of 30,000 miles (or is that unchanged).
Here's another thought, getting back to my orginal point which started this discussion. Suppose that MM would call for the first major service to be done at 30,000 miles. When the MM shows 15%, the car will only have 25,500 - - leaving 4,500 miles of driving to be annoyed by the MM every single time you start the car, unless and until you have the maintenance done.
Over the weekend I plan to read the pertinent part of my owner's manual again to better understand this new MM system. I also plan to watch the Honda video that someone recommended earlier this week.
I suppose that MM is considered to be an advancement over the traditional maintenance schedules with only two sizes to fit all (something like change your oil every 3,750 miles for severe condition and change your oil every 7,500 miles for normal conditions). I do not yet know what MM monitors, but I gather that MM is a customized system that comes up with somewhat different maintenance timing for each car by somehow taking into account how the car is used. The customization aspect is a neat feature. The MM taking over your dashboard at 15% is an annoying feature.
Some quotes from that video:
"The system keeps track of maintenance intervals automatically and let's you know when it's time to come in for service"
"The system performs this oil life calculation based on engine operating conditions. If the engine runs at higher temperature and RPM or at lower temperature during short trips the oil life will deplete faster than during more normal conditions."
"When the oil life reaches 15% service is due SOON ......... When the oil life reaches 5% service is due NOW and when it reaches 0% service is overdue"
Hope these can help.
When my Accord was new, it did ride quite hard, but the tires were over-inflated and either the suspension softened or I became accustomed to the ride because it doesn't seem to ride too hard at all now.
I keep the tires at about 33 pounds--just slightly above the recommended pressure.
So, I suggest setting the COLD pressure to 32 lbs front, and 30 lbs rear per the manual, and give the car a chance to break in.
So for me, when it's been a year, I would do an oil change, but then the MM might still not have hit 15%, which means none of the maintenance codes will show either. Do I then have to follow some other kind of schedule? If so, where is it available?
To be honest I don't have a complete or an accurate answer. But I can say:
1)Read the owner manual, maintenance chapter, It explains the codes, you will find some hints that can help you such as: change your brake fluid every 3 years regardless of mileage, change transmission oil first at... miles then....,
2) Try to find an older model owner manual. Usually you can find a type of schedule there.
3)Go to your dealer and ask them to give you a print of their schedule. They will give you one or two sheets that explain what services you should do at different mileages.
Now try to compare, mix and figure out a schedule for you yourself.
This is what I know. May be others can help.
In post #2248 you wrote:
"So I looked it up in the owner's manual. I have an 03 model, and there is no MM system. The scheduled maintenance is done the old fashioned way (miles or time, which ever comes first). The time/distance for oil and filter change is 3,750 miles (V6 engine)."
That's strange. The Owner's Manual for my 2004 Accord (identical car and engine - one year later) says to change my V6's oil and filter "every 7,500 miles or every 1 year, whichever is sooner".
Honda OwnersLink also says "The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.".
Based on the engine operating conditions and accumulated engine revolutions, the onboard computer calculates the remaining engine life and displays it as a percentage.
Contrary to what I said in my previous post, it is possible to see the current engine oil life at any time, by pushing and releasing the odometer reset knob until engine oil life is displayed.
When the display shows 15% oil life, actual calculated oil life is anywhere between 11% to 15%. Similarly, when it shows 10%, it's anywhere between 6% and 10%. And when it shows 5%, it's anywhere between 1% and 5%. Above 15%, oil life is displayed by increments of 10% (i.e., when it shows 50%, oil life is anywhere between 41% and 50%). One might ask why the display is not more precise. I do not have the answer.
When the remaining oil life is 15% to 6%, you will see the oil life indicator every time you start the car (and it stays there unless you press the odometer knob to change it back to the odometer). When remaining oil life is 5% to 1%, the message changes from "oil life" to "service oil life." When the remaining oil life is 0%, the oil life indicator will be blinking and you should have the indicated maintenance items performend ASAP. If you do not have the maintenance performed within 10 miles after 0% is first displayed, negative mileage will be displayed (in lieu of a percentage)and you should have the service done immediately. While the owner's manual does not quite spell it out in this way, my take is that service should be performed at your earliest convenience after oil life first shows 5%.
Here's something to be careful of. The MM must be reset after maintenance is done. If you have the required service done but do not reset the display (or you reset the display without doing the service), the MM system will not show the proper maintenance intervals thereafter. This can lead to serious mechanical problems because you will no longer have an accurate record of when maintenance is needed. This reset issue should be more of a concern if your car is serviced by yourself or an independent shop, rather than a Honda dealer (who should be well aware of it). The owner's manual tells you how to do it if you want to (or need to) do it for yourself.
Hope this helps.
Have you considered giving your father a soft cushion to place between himself and his vehicle's seat? The memory foam type may be your solution until he gets acclimated to the Accord's superior ride and handling.
Had it done by an independent service station and they reset the MM for me (they knew about it). They don't like the MM system either, but for a different reason than my reason for not liking it. They don't like it because people who do their maintenance in accordance with MM (as I believe most people would) are going much longer between oil changes, which is bad for business. They love the people who still do oil changes every 3,000 miles no matter what.
Still mightily surprised and impressed with this car. I was just looking for a good lease deal on a reliable 4-door sedan. Leftover 2006 Accord was the best deal going at my moment of need. I figured I was getting a ho-hum mainstream family car. But it turns out that this car (I have the V6) has more of a sports sedan feel. Power, handling and ride are all very good. I enjoy driving it, much more than I thought I would.
I did a quick Google search for "motor oil color" and thought you might be interested in the following from the top of the list:
Oil Change Intervals
Few subjects generate as much debate on Usenet as the proper oil change interval. Since few people bother with oil analysis the debate centers on time and mileage.
Follow the Money
Unfortunately, there are market forces that have a vested interest in convincing vehicle owners to change their oil more often than necessary. The legal prey of these market forces have become convinced that they are purchasing "cheap insurance" or "peace of mind" by changing their oil more often than necessary. Complicating things is the fact that doing oil changes is one of the few do-it-yourself maintenance tasks that is still within the ability of the backyard mechanic to perform.
Recreational Oil Changing
The term "recreational oil changer" was coined to define people that change their oil far more than necessary because they actually enjoy doing it. It's easy to understand the psychology behind the recreational oil changing. It's the visceral feel of the tools, the victory when that old oil filter breaks free, the hot dirty oil pouring out, the joy of oiling of the gasket on the new filter, that new copper or fiber gasket on the drain plug, the clean clear oil going in, and the sense of accomplishment when you start the car, the oil light comes on for a moment, then goes out. For $8-10 in oil and parts, it's pretty cheap entertainment, but if people would be content to do it only when it provides some benefit to the vehicle it would be better.
The 3000 Mile Myth
The 3000 mile oil change interval has been pounded into people's heads for decades. It had a scientific basis when engines used non-multi-weight, non-detergent oil. It no longer has any scientific basis, but it is still being promoted by certain entities, most notably the oil change industry in the United States. This myth is also sometimes known as the "Cheap Insurance Myth."
The 3000 Mile Fact
There are still vehicles that need 3K oil changes, but it's not because the oil goes bad after 3K miles. One example is the Saturn S series. These vehicles have a timing chain system that is very sensitive to clean oil because oil pressure is used as hydraulic fluid to ratchet up the timing chain tensioner. If varnish forms in the timing chain tensioner bore then this system can fail and the chain will become loose and eventually break. Dealers have gone as far as tearing out the normal service schedule (6000 miles) and leaving only the severe service schedule. If your engine is destroyed (under warranty) by a failed timing chain then the dealer will legitimately request evidence of oil changes. Unfortunately this problem usually won't manifest itself during the warranty period.
The Dark Oil Myth
Dark oil does not indicate the need for an oil change. The way modern detergent motor oil works is that minute particles of soot are suspended in the oil. These minute particles pose no danger to your engine, but they cause the oil to darken. A non-detergent oil would stay clearer than a detergent oil because all the soot would be left on the internal engine parts and would create sludge. If you never changed your oil, eventually the oil would no longer be able to suspend any more particles in the oil and sludge would form. Fortunately, by following the manufacturer's recommended oil change interval, you are changing your oil long before the oil has become saturated. Remember, a good oil should get dirty as it does it's work cleaning out the engine. The dispersant should stop all the gunk from depositing in the oil pan.
The only real way to determine whether oil is truly in need of changing is to have an oil analysis performed. Since most people don't want to bother with this, it's acceptable to err heavily on the safe side and simply follow the manufacturer's recommended change interval for severe service. There are still a few cars that specify 3K intervals for severe service, but not many. If you look at countries other than the U.S., the oil recommended change interval is much higher than even the normal interval specified by vehicle manufacturers in the U.S.
Severe Service versus Normal Service
Each manufacturer specifies what constitutes normal and severe service. Generally, severe service consists of operating the vehicle in a very muddy or dusty areas (because dust particles get through the air filter and contaminate the oil more quickly), operating the vehicle in a very hot areas (heat breaks down oil more quickly), using the vehicle only for short trips in cold weather (the moisture in the oil never gets vaporized), or using the vehicle for towing or when carrying a car-top carrier. You'll often see claims such as "everyone falls into the severe service category," but these claims are untrue (follow the money and see who's making these claims). If you primarily do freeway driving in moderate weather you do not fall into the severe service category. If you're in doubt, the best way to see if you fall into the severe service category is to have an oil analysis done at the mileage of the severe service interval. Many people just like to play it safe and follow the severe service schedule, which is fine, but there is no benefit in changing the oil sooner than the severe service schedule states.
It's a psychological thing. If you constantly saw your oil life dropping, 1% every 65 miles-- you'd get this impending doom' feeling and may feel more reluctant driving longer distances, because you can feel the remaining use of the engine/oil slipping away from you. so if it goes down in 10% increments, you prolly wont notice EXACTLY when it goes down, and you don't WORRY about it as often.
That said, I'm a mechanical/aerospace engineer, not a psychologist, so I have no clue. Plus, you see the mileage on the odometer always going up? I guess the countdown from 100% to 5% is a lot more stressful than seeing the odometer slooooowly make its way to 150,000 200,000 300,000 or whenever the damn engine will actually fail. they're pretty solid.
All of this information sounds very logical, and I am considering going up to 4,000 miles for my oil changes (slightly over the severe interval). It's hard to teach an old dog new tricks though, and dark brown oil bothers me :surprise: . I know if I paid someone else to change my oil, I would be more likely to change my ways
While I don't mind changing my own oil, I certainly don't get a thrill out of it (as your post suggests). It's just my obsession with clean oil, that makes me do it so often.
For those of you who may be confused at my including the beer company reference above, it is because one of the truly great pleasures of changing the oil yourself on a late Saturday afternoon is to sit down on a stool in your garage, stare at your car, sip a cold beer, and think, "I've just made the universe run a little better, a little cleaner..." Two cars, two beers. Admit it: if we factor in beer, most of us lose money on changing our own oil...
Well this problem is inherent with any used car. Did he change the timing belt? Did he change the transmission fluid? Fuel filter?
This is from Honda video (Post#2230):
"........ note the sub codes will only appear with main codes...."
Main code=A-B
Sub codes=1-2-3-4-5-6
Also please see post#2247
If it is the case that one should only reset the Maintenance Minder when the oil life reaches 15% or less, and that one will screw up the subcodes otherwise, then the MM is a kind of informational straitjacket. I suspect a lot of folks will end up ignoring it, especially conscientious guys like the readers of these notes who do change oil, fluid, coolant, plugs, filters, and so on, regularly. Result: false maintenance signals popping up as time goes on and the cars age. Now that is annoying. What strikes me is that dealer personnel seem as confused about these matters as everyone else.
I think the MM is a very good idea--it's just in a primitive stage right now. Watch and see how better it gets when it can store the vehicle's maintenance history and it can adapt to differing needs and schedules and to exceptions. There are many reasons for an out-of-schedule oil change, for example, besides being a maintenance freak. Suppose you are going to drive coast-to-coast, round trip, 6,000 miles? It's a good idea to start out wth a little preventive maintenance (oil, tires, hoses, etc.) How does MM account for that?
As I was reading the post here, I think I hit upon what might be the solution to the "what to do if I change the oil more frequently than MM says" quandary. Think of MM as serving two purposes - when to change the oil, and when to do other stuff (trans fluid, tire rotation, etc). Unfortunately, the "other stuff" only shows up when the MM gets down to 15%.
So what to do if you change oil at say 4K miles, but still want to use MM for everything else? I think you can get this to work if you DON'T reset the MM after each oil change, but instead wait until it does in fact get down to 15%, then you can see if the MM is showing only an oil change or an oil change plus something else (the AB/12345 indicator). If it's a oil change only (ie. A), then just reset the MM (after all, you've already changed the oil). If it's oil change plus something else (B or A/B with a number), then have that service performed and reset MM then.
I think this way you can still perform the oil per your preference (the 3K mile fan base), but still use MM for the rest of the service, since Honda seems to be a bit obtuse for those folks that might want to see a more concrete milage indicator for other services written on paper.
Using this method, it's obviously up to you to keep track of the mileage for your oil changes, but that's what you're choosing to do.
I really don't know what the MM does with the other, non-oil related maintenance items if you reset the MM before 15% (say every 3K miles). But then again, it's sort of a moot point, as you'll never see the other items because you never let it down to 15% (can someone say "Catch-22")?
Does this make sense?
It was posted here(or another thread) from Honda's Owners Link a few months ago.
