So, I don't have to replace the water pump with proper maintanence? Awesome!
I think it's because the chain would be very long, heavy, and noisier. Although the belt does have to be changed, it has a lot of benefits.
I didn't use the Honda coolant when I did use it. I used a brand called Prestone that I obtained from the Advance Autoparts store. Is this brand okay? It does say it's certified for many makes. Or using any other brand might damage the water pump?
Did it say Honda specifically? I doubt it. The maintenance interval for changing the coolant is 120k miles, but there is no way I was going to wait that long. I've changed my coolant at 50k miles. Since it's not a good idea to mix types of fluids (coolant, brake fluid, transmission fluid, etc.) and all the fluids do not drain out when doing a change, I would rather be safe than sorry.
You are right, it didn't specifically mention Honda. But it did mention it's ok for most makes and models, and since Honda is a major car company, I thought it's safe to assume that Honda was included. No?
So 50k is good for changing all the fluids... I'll make sure I'll change all the fluids by then. One more question, it should be okay to change something a lot earlier right? Because I already changed the auto trans fluid at around 15k(I did use the Honda factory AT fluid for this one, since I don't want to experience one of those transmission failures :P).
Thanks again.
Thanks for your input, it's all very helpful.
I mentioned to my granddad he ought to have his Civic's transmission serviced. He has never had it done in 115k miles. His 255k mile 1987 Civic Wagon had one transmission service in its life, he says, at 180k or so.
I thought about changing the AT fluid at 30k too. But my car was feeling a little rough at the time, and since I could not pinpoint exactly the problem to ask the dealer to fix it, I thought it could have something to do with the AT fluid, especially since I also read somthing about Honda trans failures. So, I decided to replace it the same time when I did the oil change.... My car was smoother afterwards but it turned out the AT fluid was pretty clean, so it probably had nothing to do with it.
I'll never try that with my car. That's pushing the car beyond its limits. The fact that his car lasted 255k miles is what I call 'automotive miracle'.
Gotcha! I'll be safe to change it on a longer interval. Not as long as the 180k thegrad mentioned though lol. Tha't's quite a story, but I think that probably has more to do with his grandpa's driving style, more than anything. So 30k it is!
tankbeans scared me for a second with that $715 quote for his 95 Accord EX I4's timing belt change, but luckily (thanks to the graduate's post), I don't have to worry about this since I have a timing chain in my car. To reiterate thegraduate's reiteration, 2.4L 4-cyl in the 2003-present Accords don't have a timing belt to be replaced.
And thanks to elroy5 for his advice on the water pump on the 4 cylinder. To reiterate that also, it wouldn't need changing, unless it fails (he hasn't heard of that happening yet). And using the right coolant (Honda), changed at the maintenance interval, would make the pump last the life of the car.
I just checked my 2004 Accord Sedan Auto 4-cyl EX's owner's manual, and here's what it said about the coolant:
SERVICE / MAINTENANCEMAINTENANCE SCHEDULE
120,000 mi/192,000 km/10 yrs Scheduled Maintenance
Recommended service for your 2004 Honda Accord:
Replace engine coolant, then replace every 60,000 mi/96,000 km/5 yrs.
Hope this helps summarize everything related to the timing chain, water pump, and coolant for at least my car.. but possibly all 2003-2007 4-cylinder Accords?
I bought new Honda accord 2007 Ex in July,2007. Currently my car is having 3000mile odometer reading with 50 percent oil life remaining. When should I go for oil change and servicing, Has it to do with timeline or how many miles it has run. Not sure, what to follow to keep my car under warranty and good condition
Wow... you don't drive very many miles! I would recommend following the Maintenance Minder system for your car. There is no need to change the oil too soon. In fact, you shouldn't make the initial change early because there is an additive in the oil to take care of the new engine.
Most of us try to change the oil when the MM gets down to 15% or so. Now if you don't get that far after one year, then change it anyway. That part is in your owner's manual too.
Thank for your reply, my office was so near my home(hardly 1 mile) that i did not drove much.Now I stay 8 mile from office,so I would add some milage to my car and maybe explore Florida where I stay and nearby state georgia. Other three side of Florida is water , cannot go far.
Victor
I'm used to my '04 Accord Sedan 4 cylinder EX where I have to do the oil change every 10k miles.
Any thoughts on using regular oil vs synthetic oil? That's what I've been using in my '04 Accord since pretty much the beginning - nothing but Mobil 1. I'm wondering what to do in my wife's '07 Accord.
What are the signs of a lose or broken mount?
Is there a way to figure out how many mounts were replaced on Hondas?
To me it seems that it is such a passive component, nothing should go wrong with it unless the mount is of low grade material, or the bolt holding it is of defective material/design.
Any thoughts on all the questions - one by one.
I've never used synthetic oil so I don't have any expertise on the subject. I do know that my 95 Accord (that my son now drives) has survived just fine without it. I think it has around 220k miles now.
Honda service center advised me (and I agreed) to change rear brake pads during my 20,000 Kms (12,500 Miles) routine service for my Honda Accord 2007 LX. I thought that was too early! I use the brakes firmly but not in an abusive manner. Also I wondered that rear pads were replaced before front pads.
Any expereience in that regard? Any recommendation?
Thanks in advance.
I'll change over to synthetic in my '06 Accord EX-L 4 cyl once it gets to 15,000 miles. Many mechanics suggest running conventional oil for 10-15,000 before switching.
We're low mileage drivers and rarely get off the two laner here on the Island. The 2001 Dakota has 41K and the '06 Accord has about 12,000 (22 mos. old).
I took my 2004 Accord Coup V6 in for regular maintenance on Friday and was told that my "compliance bushings were torn" and had to be replaced. My car only has 35,000 miles. Has anyone heard of this being a problem in this model? They asked if I drove on dirt roads alot, which I sometimes have to do for work. Not sure why this would matter, I'm not racing on them or anything. Also, it cost $500 (parts only $17) is this that labor intensive? Lastly, they also charged me $60 for front end alignment which is what I asked for in the beginning, but shouldn't it have been included in the $500?
Thanks in advance for any info you have!
I have a quick questions, I want to buy a set of alloy wheels (it is originally from a 05 Accord V6 EX coupe) and put them on my 05 Accord I4 LX sedan to replace the original plastic cover and steel wheels. Is it doable? I called two honda dealership and one of them was firm that it is doable but needs an alignment after the replacement; the other said it might need to check if the calibers needs to be replaced as well.
Does anyone has experience on replace rims for 05 Accord?
Jim
What is the average fuel consumption for Honda Accord 2007 (LX 2.4 engine) in miles per galon or liters per kilometers?
Thanks in advance.
Back to the point you should be able to get around 26-30mpg once spring hits, when the winter-blend gasoline is phased back out.
I'm one of the 40 MPG people, but I don't get that often. On a typical trip running 75- 80 MPH with little stop and go I'll average well over 35 MPG, usually balancing around 37 MPG on average. Occasionally I top 40 MPG, but that's usually when I stay closer to 70 MPH.
By the way, I have a 2006 EX 4-cyl Auto, same powertrain as the LX from 2007.
I have the same car here(but 1 yr older).
You can always check out the MPG forum for more info...
The official EPA number I believe is 24/34 (city/highway).
That varies so much for everyone. Driving styles, outside temps, city/highway combinations, etc. are all factors.
I have over 42K miles on my 06 EX-L I4 manual and I've only had 7 tanks of gas under 30 mpg and two of those were under 29 (28.0 has been the lowest). And all of those were in the winter with a lot of short trips.
I'm not sure why you are asking but everyone is different. Visit the MPG thread and you will see.
Anyway there isn't enough information about your driving style or where you live to make an informed guess. Good luck.
You could also try www.fueleconomy.gov and look up the mpg on the model you are researching. Newer cars tend to do better than older ones of the same model.
I have accord 2003 sedan. on the driving seat belt, some times when i release the belt it rolls back to its position but sometimes Supplemental Restraint System light comes up, when I turn off the car and later some time I start it is normal that Supplemental Restraint System comes when car starts then goes normally.
I observed that it is related to my driving seat belt not any other cause of air bag. What can be done to fix this problem? the belt is okay it rolls back to its position i am confused why it comes once in 5/6 days.
Wajeeh :confuse:
Did anybody have such a problem? Is there a way to detect signs of cracked/broken mounts while starting or driving?
Don't worry, you didn't ruin your transmission.
The other two posts are about a feature that your car would have if it has a V6 engine. If you have the smaller, 4 cylinder engine, you don't have it and you did the right thing to get yourself out of trouble.
1. Bring the transmission up to normal operating temperature (radiator fan comes on).
2.Park the vehicle on level ground, and turn the engine off.
3.Remove the drain plug, and drain the fluid. You will probably have to jack the car up, to get the plug out, then lower it so the fluid will all drain out.
The torque spec is 36 lbs-ft.
How many drain and fills would depend on how dirty the fluid looks, and how much crap is stuck to the drain plug magnet. If the fluid is not dark, doesn't smell burnt, and there is very little stuck to the magnet, one change should be enough. If a second change is needed, a short drive (going through all the gears including reverse a couple times) and repeat. The washer should last through a couple of changes (at least). Really it depends on how deep the grooves are in the washer. The hardest part for me was finding a funnel that would work for refilling (long and slender). Have fun
I think it's going to be a great year!
Has anyone else had the problem?
