Ford Bronco Problems
in Ford
I own a 1993 Ford Bronco Eddie Bauer with the 5.8 engine. I have a vibration in the front and the shop told me I had to replace the Torque Converter in the transmission. At a cost of $600.00. Does this seem to much for this job? Any suggestions on how I can cut this cost down???? Sure would like some advice on this. Thanks
Thanks......Joe
http://car-part.com/
Also, my interior lights came on and wouldn't go off(had to remove the bulbs) and my rear top reverse lights did the same. Think there is a wire short but not sure where to start to look for it. My windshield wipers will work if thumped on and not sure if this is wiring or the wiper motor. Any and all help is greatly appreciated. Shirley
I have a 95 Bronco that has a bad transmission. Does anyone have any ideas for the cheapest way to fix it? Rebuild? Used tranny? Also, if I go to a junk yard, are there other Ford vehicles that use the same transmission? Would an F150 tranny work too? Any help would be great. Also, any suggestions for how much a used tranny should cost for this truck?
Rob
http://www.thetoolwarehouse.net/shop/TTW364.html
You may want to soak the bolt in solvent if you can by squirting stuff in there and also hit it sharply with a hammer a few times.
You're only going to get once good chance to get this out, and if you break it off in the block it's going to have to be drilled out--which is a royal PITA.
So, the right tool, solvent, and if safe, even some heat.
Here are some ideas for you:
http://findarticles.com/p/articles/mi_qa3828/is_199906/ai_n8872738/pg_2
I've had the ignition module checked, O2 sensor checked, new coil, new computer. Nothing seems to be fixing the problem. Any suggestions?
Did you make any progress with your ABS Lite problem? I've got the same situation and it's driving me crazy! I changed the Front Wheel Sensors and the Module, but No Luck! I understand that the rear end has a ABS Sensor also. Have you got a clue where it's at? I would appreciate any help sent my way.
Rascalracers
