A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Has anyone else had these problems? I have the extended warranty so will bring it to the dealer but was wondering if anyone knew the root of the problem.
Can anyone help?
Thank You
Good Luck,
E.D. in Sunny Florida
I started getting squeaking and squealing sounds last week and thought it would be the idler pully bearings going bad. I pulled off the belt, and sure enough I still heard the squealing, it kind of comes and goes, stops and starts, or it may start and continue for a while. It sure did sound exactly like a dry rubber seal squealing, and the only seal it could be is the one on the front of the crankshaft, behind the harmonic balancer pully. It was very difficult to reach, but I squirted WD-40 behind the pully in the direction of the seal, from every angle that I could reach. It seemed to work, as the squeal has went away for now. The question now is if the squeal will stay gone or not. I replaced the bearings in both of the idler pullies while I was in there, as they were starting to get loose and did not spin smoothly. I'll post back if the squeak reocurres, and what the solution would be. I'd hate to have to drain the cooling system, pull the radiator, pull the fan and pull the Harmonic Balancer Pully just to reach a squeaky seal. If I did all that work, I'd be sure to put in a new seal and grease it good with some synthetic grease. Once the Harmonic Balance Pully is off, the Front Crankshaft Seal removes from the front, so the timing cover does not need to be removed. Just pull out the old seal, and press in the new seal, and put everything back together.
Good Luck,
You didn't answer my question about where the air is blowing. Does air blow out anywhere? Where? I assume it was blowing out the bottom at the heater discharge, that is what usually would happen if it does not blow out the dash vents or defroster vents. This would still point to a problem with the air doors, which are usually controlled by vacuum motors, some of the doors now are electric controlled, I know the blend door is an electric motor and the temperature knob turns a electric poteniometer that moves the blend motor position. Since you heard the hiss, which sounds like it could be a leak from a loose or broken vaccuum hose, that would be the most likely thing to look for first.
Nick
I have a few issues and any advice would be appreciated. I recently purchased the Explorer from my sister, who had taken good care of it until a year ago. It has just been sitting and driven only occasionally. I knew there were a few issues, but got it for a very cheap price. The transmission seems to be loosing fluid. If it sits for a month or so, fluid has to be added. When I drove it 400 miles or so, half a quart had to be added. Any suggestions? Also, when slightly heavy acceleration or going up an incline it sounds like the valves rattle. I filled up with Premium Gas and added octane buster, this seemed to help. But, I can still hear some rattle. What causes this and is there a simple solution? Any mechanical failure to be concerned about? Also, the battery gage & fuel gage do not work. I have heard that it may often be the fuel float causing the fuel gage problem. Is there anything I can personally check to find the cause? Thank you in advance for any suggestions.
There is no drop in performance of the engine, it is just annoying and I fear that if it goes unchecked I may do some serious damage to the engine (i only have 75,000 miles on it. Has anyone else experienced anything similiar? My father-in-law owns a Taurus with a V6 and he is experiencing the same sound.
Any tips would be greatly appreciated.
Jim in Houston
If fuel gauge reads empty all the time, replace fuel sending unit float.
For Transmission leak, look underneath to see where fluid is coming from, most likely the pan gasket needs replacing. It could also be a leak at the tail housing seal or the front pump seal.
any answers other than not driving through the mountains?
Thanks in advance!
Does anyone have any idea why this is happening? Please help.
H
Steve106
No more check engine light ...priceless !
Good Luck,
What's going on here? I know that Ford has transmission issues with Explorers, but why the relatively cheap bill? Is it likely that Ford (as opposed to the dealer)is picking up the bill?
:sick: :confuse:
Anyway, I've basically narrowed my search to Jeep or Explorer, and currently am looking at a 1994 JGC with recently rebuilt transmission, 166K, new tires, new front brake pads, engine work done to replace valve seals (?), one owner salesman, "test driven" all last winter by a friend who recommends it but needs to sell it (already owns 7 vehicles). Only "quirk" known is back driver side window doesn't work - not the motor. Asking $3,000 more or less....Is this a good deal???
In comparison, looking at a 1997 Ford Explorer Eddie Bauer, maintenance records available, 106K, $5,500 OBO. No other details known.
Either one seems to give the flexibility for cargo room and road safety (we hope to go on road trips - no real off road but camping, parks, etc), but the cost vs the mileage and age - -
Does anyone have any opinions from owning both of these vehicles? Any years to avoid? Any specific questions to ask?
Soon after, I noticed that if I turned from a stopped position, there was major grinding in the tires, like it was trying to get traction not a grinding on metal, which was especially noticeable if I was on gravel. It's not as noticeable when going through road curves at more than 30 mph. I've had the tires checked, the differential checked, and the universal joint looked at - all came back fine. Now they've changed out the power steering fluid and added an additive, but so far, it's still there. It's coming from both the front and back, but more noticeable in the front because of the turning tires. Please help - my mechanic is at a loss. :sick:
E.D. ISF
E.D. ISF
