Good Luck,
E.D. ISF
I will however make sure the rad is blown out when I get to work on Monday and have access to a compressor. As far as leaks are concerned, I haven't had to top up the coolant yet and I've been checking it daily since the truck died the first time.
Thanks for your response, here's hoping.
Loui C.
It depends on if you think $100 is expensive. I have seen them advertised online for less than $100. Do a search for "tools" and for "infrared thermometer" and you will find a lot of good stuff. The brand I have is a Raychem, with a laser beam pointer, I've had it for about 5 years, since they first came out cheap enough to afford. I bought it for the AC work, but found it is vastly useful in many ways, AC, Cooling Systems, even use it it to check the temp of your coffee or soup! Everybody should have one of these.
"I will however make sure the rad is blown out when I get to work on Monday and have access to a compressor."
Please don't "Blow Out" your radiator with an air compressor, unless you are planning to buy a new radiator. The radiator can't take any more pressure than 16 to 20 pounds, any more than that and it will "Blow Out" for sure. What I said was have it FLUSHED OUT by a professional Radiator Shop, they have the proper equipment to do it right and do it safely. They backflush it with a cleaning chemical that removes the scale from the entire cooling system. They pressure test for leaks at the same time.
The easiest and best thing to do first is to be sure you have plenty of air flow through the radiator, check the fan, belt, front of AC Condenser and front of radiator to be sure they are clean, and check the temperatures with a infrared thermometer if you can get one.
Good Luck
E.D. ISF
A number of tire shops will check your alignment for free, but I'd assume that it will need alignment.
I have recently purchased a 1998 Ford Explorer 4 litre 67,000 miles on the clock....
It has suddenly developed a problem with the internal heater in that you can turn the dial from cold to hot and only really really hot air comes through the vents not variation in temperature at all - just HOT. Air con works perfectly and there's no indication of the engine temperature getting above normal.
Any idea guys ? always willing to have a go at these jobs prior to paying big bucks to the Ford dealer so any help appreciated in advance !
Cheers guys, and brilliant info on this forum - really chuffed to find it :shades:
Jon
I have the V6 sohc engine with 106k miles. It look like it's leaking from the rubber gasket on this black box looking thing that has a big hose running from top of it, to what looks like the reserve tank. It also has a big hose running from below the black box thing to what appears to be the radiator. The black box thing is underneath the black plastic shield guard that says 4.0l. Is this the thermostat housing?
I put stop leak in the coolant when I first bought the car, in the radiator and then in the reserve tank like a fool. I shortly drained the radiator coolant, but left the reserve tank stop-leak-junk in there. The coolant is the reserve was brown in color for a year. It finally used this stuff up in the reserve, and I've been adding coolant and smelling coolant ever since. thanks
Note: One good thing about the Explorers that I have had, not one of them ever needed a water pump, the first two went over 165K miles, and now I'm on the second two Explorers. The Chevys that I owned before always needed a water pump, usually about every 60 to 70K miles.
Good luck with your repairs.
E.D. ISF
The first time I used it, was a year ago but I shortly drained the coolant afterwards and put in new -- but like I said just in the radiator not the reserve. Getting to the leak is going to be tough, you have to remove all kinds of stuff.
It's just up to you. I give you the best advice I can, but it's your car and your money.
Good Luck,
E.D. ISF
Good Luck,
E.D. ISF
Also, the door ajar light intermitently comes on (more times than not). I've isolated it to the front passenger door. It also interferes with the alarm as when I try to set it the horn honks twice letting me know a door is open. I saw a couple of posts about spraying WD40 in the latch. I'll give that a try but sounds like a temp fix.
Thanks for any help.
has our blend door replaced under warranty. i hear that is a common problem and from what i have read may be the cause of what you are experiencing
http://www.blenddoorfix.netfirms.com/
http://my.voyager.net/~sscully/F-15097HtrCoreRepairF150_Exp_002.doc
http://autorepair.about.com/library/images/bl332a-lib.htm
Good Luck
E.D. ISF
Tks. deadeye
Good Luck.
E.D. ISF
WHy your oil level increases in your engine oil pan is another matter. That needs more investigation to determine exactly what it is. The level could be raised by coolant leaking into the engine oil system. How has your coolant level been doing? Had to add any coolant lately?
E.D. ISF
Good Luck
E.D. ISF
Thanks for your help ...
Also the rear end is starting to make noise again. This vehicle has had two new ring and pinions the frist two trips to Ford, and finally a complete new rear end on the last trip. Is anyone having these problems with their vehicles?
This vehicle only has 21K miles.
I think we Ford owners have a recall situation. I think ford knows it to.
E.D. ISF
Chuck
Please Help!!!!!!
E.D. ISF
E.D. ISF
Good Luck.
E.D. ISF
When I shop for a vehicle, I look for one that is known to be reliable, stay away from vehicles with known problems, like bad timing chains, bad trannys, bad rear axles. You at least want a reliable drivetrain. The forums here and elsewhere can help guide you. I'm not meaning to pick on you or your vehicle, just trying to help. Too late to help much with this one, maybe the next one will be better.
Good Luck,
E.D. ISF
