Stories from the Sales Frontlines
Anyways, i saw that appraise my car show too - very interesting! (its on Discovery HD channel here in CT though) That guy with the firebird was a little suspect. he saw the lady drive it around...sure...i believe that! :P
and the guy with the alfa romeo was kinda funny. they've been 18k cars all day long, and he wants $25 for it! it could be the twin to the delorean used in back to the future, minus the stainless steel exterior!
anyways, good show!
The Corvette was first made in 1953 as a '54 model, not '63. They air "Appraise My Car" on Discovery HD also. Sometimes it's interesting, most times not. Good concept, though.
Exactly why I said what I did in post 7354.
Now don't get me wrong, I'm not blaming you since that post wasn't published when you did your cleaning.
Well on a modern car very little water actually gets in the engine compartment when you hit a puddle. Especially on the top of the motor where the electrical and fuel injection is.
As far as adding water to a radiator it has nothing to do with the exhaust manifold. When you overheat an engine you usually have very little water in the system. When you add water to a basically empty radiator some of it will go into the block. If the engine is off, so is the water pump. The cold water will go into a very hot block and just sit there often causing a crack in the block.
As mentioned previously, a modern engine running correctly doesn't get that dirty, so this is usually only after another issue got the engine dirty in the first place (driving on a dirt road, spilling oil all over the place, valve cover gasket failure, hose failure, etc).
Most underhood components in modern cars are spec'd to deal with a lot of heat/moisture, and they are typically pretty well shielded (to the point where I have to remove shields to clean sometimes).
I have found it beneficial to blow out the radiator using relatively high pressure water or air from the inside out to get rid of trapped bugs and debris that is clogging the fins. YMMV
On a few occasions I have gone to a lot well in advance of my purchase, usually just killing time on my lunch hour. I was upfront about it and was treated just fine. A few times got to take a test drive b/c the salesman wanted a "break". I had the built in excuse of having to go back to work so there was no way they were getting me inside to talk $$ even if I wanted to.
thene...yeah, the guy with the Alfa kind of got on his high horse when they appraised his sled. He acted like it was in such high demand. NOT!
Interesting, towards the end of the show, they had an early '70s MGB go on the auction block. They appraised it for $12K. It sold at auction north of $9K.
If I had known that, I would have kept my college ride, a '69 MGB-GT. Wonder what that puppy would bring today? I think I paid $2,500 for it in the early '80s, and then proceeded to restore it myself.
I love HD....just wish there was more programming.
HD Net has lots of "guy stuff" in HD. Car shows, motorcyle shows, sports.
And "Get Out" with Kelly Ripa and friends visiting exotic destinations.
Stolen? (It happens)
Engine blew up after the deal.
Employee bought it up just after it was traded in.
Employee accidently drove it into the river that runs right behind the dealerships property (This happened where I worked in high school).
Nope sorry, some dealers do have requirements for the used cars they put on their lots. Many luxury car dealers around her will not put a non luxury car on their lot. Some won't even put a luxury car thats not the same make as their new cars. There is a BMW dealer that only sells BMW's (new or used). Sure they will take anything in for a trade, but if its not a BMW it will be removed from the lot as fast as they can get it off.
-rebuilds/or salvage titles
-older Hyundais
-anything with over 200k kms
-Explorers
-older VWs (unless it's really special or mint)
-very high end cars (I took a SL55 AMG on a trade on a Odyssey, my used car mgr wanted to have a buyer secured BEFORE we committed to the Benz, as we wouldn't want to tie up $100k plus on a rare car that might sell in 6 months)
Other than that as long as it's in decent shape, and the inspection checks out ok, it stays on the lot.
Speaking of our compound, it's our lot where we store about 300 new cars.
Also on that lot are the trade ins rejected by society (read: people, brokers, wholesalers, even used car lots). Usually you can find Aerostars, Tauruses, early 80s Hondas, and GM cars of all sorts typically from the 90s sitting there for months until a movie production crew comes by, picks up a bunch and blows them up :sick:
When you're ready to unload it, 'graph' golfs with a guy that might be looking for one of these for his BHPH lot.
Treat him nice and he'll get you his card.
If that doesn't work 'boomchek' might be able to arrange to have it blown up for ya.
When I unload it its most likely going to go to Victory Auto wreckers as I plan to drive it into the ground.
None of them do wrecked cars though. If it has a mark on carfax then it goes to wholesale.
Our particular dealership does not do well with sedans so we normaly send them somewhere else or wholesale them. Unless they are very high line sedans, S-class/7 series/A8/XJ/LS, etc then we send it to wholesale. Oh and in the winter we don't typicaly stock anything that is 2wd.
There were a number of difficulties with this situation, as I recall: a group of five, a language barrier, a lengthy timeline, bad weather conditions, and a request that the salesman drive. There must be ways, graceful or otherwise, to move on to the next customer when something like this happens.
Regarding your prior comment, I see nothing wrong with a customer taking as much time as necessary to make a purchase decision, including test drives without an imminent purchase date. I also see nothing wrong with salespeople qualifying their prospects and giving priority to those ready to purchase soon. Both are, and should be, free to act in their own interests.
We are in that position right now. We have a 2003 Acura RSX that I love to drive. However, if it were stolen, I don't know what I would get to replace it since Acura has stopped making that model. Maybe a vintage TR6?
We will take in any trade if the customer wants us to do so. We've taken in Harley's, $100 junkers, mobile homes and all kinds of boats. If the values are acceptable to both parties then it's a trade.
Could I even trade in a T-shirt belonging to screen legend Anthony Quinn?
One of my sisters has a '65 Mustang V8, covertible, manual tranny. Car is in real nice shape, all original with Ford OEM parts that needed replacement....paint is good, no rust, no rips, no tears and just a few creaks here and there. She keeps it garaged most of the time, but does take it out during the summer for community parades.
I've driven it several times. I'm always amazed at how far handling/ride/NVH has come in the ensuing 40 years. The '66 Mustang feels very crude in comparison. In a straight line, it's pretty quick, but nothing compared to modern day Mustangs. Try to turn it, though....and you spin the steering wheel and wait....and wait for the car to respond.
I know she put new OEM shocks and springs in it, but I've driven lawn tractors with better handling/ride. Brakes (also replaced with Ford OEM parts)? You better have a strong leg and you better give yourself plenty distance if you want to stop. SAme with the clutch....better hope your left leg is in shape to engage it. The shifter feels like it's lubricated with rocks.
If I had my license back in '66, I had better be a burly, muscle bound person to drive it every day.
I know it's a collectable. But aside from using it as a trailer queen, I wouldn't want to own it.
I'm sure there are those who consider these types of cars "hi buck". I guess I'm just not one of them.
Don't you mean The Odyssey? As in Homer's "The Odyssey." The original manuscript. Because if someone traded an SL55 AMG for a HONDA Odyssey minivan, the SL must've been stolen and they needed to get rid of it fast. How much did you give him for the trade?
I have taken in trades that were worth more then the car I was selling but not that often and not to that extreme. How big was the check you cut the guy for the SL?
The radio ad has the typical screamer announcer saying:
"If you've made a deal, break it. If you've put down a deposit, get it back."
"We're selling at dead cost. Federal law says that if we say we'll sell for dead cost, we have to sell for dead cost."
"We're willing to lose money on select units because the more we sell in January, the more the factory will give us to sell in the coming months."
What do you guys think of this - especially the kill the deal part?
Did you at least get to take an extended test-drive before giving it to the buyer?
Well, I think the dealer may be very motivated to sell cars. If they had a car in stock that I wanted to buy, I would definitely go there and make an offer.
By the way, we were in Boston last Fall for the first time in our lives and I thought it was a wonderful town. While sitting in front of Fanuiel Hall, I even found a Liberal to discuss politics with. Imagine that - a Liberal in Boston. Who would have thunk it?
I'm not in the biz but it's could very well be true.
What they probably didn't say is, the Doc Fees are $699 and they still get the factory to dealer incentives which customers don't get unless they're aware of them and can negotiate to get some of this.
NOBODY MAKES NO MONEY ON A SALE.
I've learned it's more important to listen to what hasn't been said vs. what has. :surprise:
jomnroe
That's how folks back then stayed in shape and I'm sure you could have "handled it" too.
Not like the "girly-boys" we have today. :shades:
You must have seen me when I was driving for UPS while working my way through night school.
On the list...
Cars with branded titles or body damage.
Anything European unless very low miles
Land Rovers
PT Cruisers..most domestics in fact.
VW Beetles...they just don't sell!
Durangos, Explorers...
What if I wanted to trade my 06 Ram on a new Accord? Would I be told to go pound sand?
Seriously, not trying to flame, I just want to know.
I too am interested in how Isell will respond to this.
From my perspective (not in the biz), I would think they wouldn't be thrilled to get your Ram, just because I would think they don't have many people walk on to their lot (being a Honda lot) that would be interested in buying a full-size domestic pick-up. If they are going to pay to keep something in their inventory, it would most likely be something like a Camry that they could easily steer a shopper to (maybe a guy comes in wanting to buy a new Accord, but can only afford a 3 year old Camry).
We are happy to take anything that comes in!
In the case of your Dodge Ram we would pick up the phone and call the used car manager at the dodge dealer in town and ask him for a "buy bid".
He would give us a number (hopefully he would want it)and we would give you that amount for it. you would get a massive sales tax credit and we would bring the truck to him.
And, we would cringe when we saw your truck. We would assume (perhaps incorrectly)that you would owe a lot more than it's trade value. We would assume (correctly)that it has depreciated horribly in that first year. We would also assume that there would be a good chance the Dodge dealer would hit us 3000.00 "back of book" because he really didn't want it.
Assuming things has cost many a salesperson many sales but unfortunatly these assumptions are usually right.
Too bad.. We just bought a used PT cruiser from a respected dealer. It was an ex Thrifty rental. Only had 14k miles on it. Seems a lot of dealers I drive by have PT cruisers on their used car lots.
There is nothing wrong with PT Cruisers if that's what you like but, at least on our lot, they just don't seem to sell. The rental companies drive down the values of these when they dump them en masse.
They depreciate like a rock so your ex-rental was probably a great buy for you! That is the way to buy them!
I never really thought about it before but, generally speaking, rocks (minerals) are appreciating. We need something else to liken a vehicle's depreciation too. How about "they depreciate like a computer"?
I'd be surprised if the Dodge was only 3 grand back though
Oh, and one of your assumtions is correct, it has depreciated horrible in its first year. Still love it and it's big gas sucking self! :P
I'd love to hear some more stories of vehicles that you would refuse to take as a trade.
