General Motors discussions
1364365367369370558
    I checked and the B13 has goosenecks. They are widely spaced and tuck into an alcove in the trunk liner by the wheel wells, so the crush risk is pretty minimal.
    I really hate the fake wood. It should stay in the Buicks it came from IMO. Aside from that, the main thing that bothers me is the mismatched color palette. There are three tones of cream-tan-brown in there without any reason to their placement, and the center stack is an out-of-place GM Gloomy Gray. Also, there are no indicators for the shifter and the hazard flasher is nowhere to be seen?
    What's all that squinty stuff between the dials?
    This is how simple is done:
  • Kirstie_HKirstie_H Administrator Posts: 11,251
    That may not be a good photo color-wise... the interior really did match and looked good. The steering wheel hides some stuff in this shot. The shifter indicators aren't there, but you can easily see them on the digital display.
    I still have an issue with the climate control... just way too much going on... separate control for everything. I prefer digital, or at least more compact.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    Personally, I like the dash pretty well. At least for GM, it's fairly attractive. But I believe the news said GM lost to Toyota, who makes substantially uglier dashes, IMO.
  • andre1969andre1969 Member Posts: 26,154
    For some reason, GM seems to have had a fetish with that for years. I remember on the 80's Monte Carlo SuperSports with the floor shifter, there were no labels on the console. Made it look kinda odd, like it was missing something. It still had the PRNDL up with the gauges though.
    Does the Impala have a dual-zone climate control? Maybe that's one reason the one pictured above seemed a bit fussier than it needed to be.
    Actually, I think most climate controls these days are fussier than they need to be. I kinda like the old Chrysler system of the late 70's/80's, where you had a lever to select your fan speed, another to select your temperature, and then buttons to push for Max AC, AC, heater, defrost, etc. The only thing that wasn't intuitive was for fresh air vents...for that you pressed the AC or Bi-Level (Chrysler sometimes called it Hi-Lo) button, and then pulled the button back out. That would keep the fan running, but turn the a/c off.
    I kinda like about the new Impala's dash is the way there's a hump over the instrument display and another hump on the passenger side. Makes me think a bit of the '57 Chevy or, to a lesser degree, those old Corvettes with the gull-wing dash.
  • 210delray210delray Member Posts: 4,721
    Now that's what I like in climate controls -- 3 rotary dials -- simple to understand and operate. The first widespread use of this system in America was in the 1986 Taurus/Sable.
    My rental G6 for my recent Southwestern trip also had this -- bravo. Same for my former '97 Camry and current '04 Camry LE. My '05 Camry XLE has a fancy auto climate control, which isn't quite as intuitive.
    But I had the same problem as Kirstie with the trip computer/odometer -- too many buttons to fiddle with, as opposed to a stalk on the speedo itself. And I was using one trip meter for gas mileage and the other to keep track of accumulated miles.
    It's been mentioned in passing, but there really is a packaging advantage in FWD compared to RWD.
    Take "Grandma's" car, the Ford Five Hundred (soon to be Taurus): tons of interior room and trunk space. Honest seating for five. Compare with the Chrysler 300 -- sure it is was a head-turner, but that center transmission/driveshaft hump makes the rear center position nearly useless for an adult. And the trunk space is severely compromised because the spare tire can't be hidden in a deep well.
  • m1miatam1miata Member Posts: 4,551
    The 2005 PT Cruiser had a very simple to use dial system, much as displayed in your pic. They screwed that up in 2006 model year - oh well.
    Loren
    Loren, the TL stuck like glue pal. As of being not safe ? I was by myself and would never go that fast with my family in the car but my former house was on a Farm and Market road thus the traffic was very light. It's a 2 lane highway and flat as a pancake. The fastest I ever took the TL, was 137 mph. I've read it can do 152 mph in perfect conditions.
    The fastest I ever took the Seville STS around that same curve was in the high 90's and the Magneride held it pretty darn good for being such a big car. the stabilitrack kicked in as I had a lil tire slip from the gravel.
    I know it's probably not the safest place to test a car at it's limits but I have always been a little bit of a dare devil. ;) I did drive the TL, quite hard and it satisfied my cravings when I got a hair up my butt to go into the triple digits. The fastest I driven since is maybe 85-90 mph running late to work one day. :sick:
    Rocky
    I noticed those differences as well, between the 500 and 300. However, in addition to the space efficiency of the FWD, I think that a lot of the increased interior room is simply because of the way the 500 is styled. The 300 seems to have a lower roof, as well as a lower decklid. The 500's seating position is upright and kind of close to the firewall, more like a pickup truck than a passenger car. I found it to be a bit tight for my legs, and less comfy than the 300.
    Isn't the 500 offered as an AWD model? It would be interesting to compare the center spot in one of those to the 300. Also, since the 300 has an independent rear suspension, which means no driveshaft travel like with a live rear axle, they were able to move the gas tank under the back seat, just like in an FWD car. It just kind of wraps down under the driveshaft. Then, with the gas tank ahead of the axle, they were able to get the spare tire under the trunk floor, just like on most FWD cars.
  • imidazol97imidazol97 Member Posts: 27,805
    I have driven other cars with the three dial system. I see the lever at the bottom changes the air from intake to mostly reciruclated. The button turns off the compressor to allow venting in economy mode.
    I found it usually very easy to operate and get the right temps. But I have not driven a newer Impala with the system; I drove other GMs. I like my button-operated systems on my cars with computers operating the HVAC, but earlier cars were very stable.
    I own a 2004 Chevy Impala LS as you probably already know Kirstie. I also agree with your review on your rental. I think the 2008' Malibu, will make a better replacement as everything has been upgraded. :) Now it would be exciting for me to see what the 09' Impala, would look like in person as that is expected to be bigger. We will just have to see if Lutz, pushes the play button from the pause button the RWD Zeta's. I have my fingers crossed that these great Zeta's will see production. I think there is a big market for these cars which included my beloved Buick Velite Convertible and Sedan. :blush:
    I really do appreciate you honest review and there are a lot of likes with our Impala. I like the 3800 V6 as it is really fuel efficient and has plenty of power when I need it. Since I baught it used it is very economical also as a family sedan to carry around 2 little ones and have plenty of room. The Trunk is huge which is good for us as we carry strollers, diaper bags, etc, with us. ;)
    The great thing is Kirstie, is we are really getting a lot of choices and when I do buy my next new automobile whatever that might be I will have a very very hard decision to make. I think that is a good thing, I think ? :surprise:
    Have you driven a new Aura, yet ?
    Rocky
    My friend, you best slow down before becoming yet just another government fatality statistic and possibly adding some others along with you. Life has its limits. You may consider buying some track time. Not too cheap for real race tracks, but at least you are not on public roads.
    Have fun - be safe doing it.
    Loren
    that really bugs me these days on the Impala is the same thing that's bugged me on every W-body GM ever built...inadequate back seat legroom. Now it's not often that I'm a passenger in the back seat of my own car, but I do have people back there fairly often. And by the time I get the front seat to where it's comfortable for me, you're not getting any adult back there, except maybe for a double-amputee or a circus dwarf. And even worse, since the '06 restyle, somehow the car lost some headroom back there as well. My head hits the headliner, something that didn't happen with the '00-05.
    I do like the way they spruced up the interior on the '06 though, and while the exterior styling is less distinct, I think it's more attractive.
    I'm curious to see the '08 Malibu when it comes out. I've seen the concept car on the auto show circuit, and it looks promising.
    I have slowed down. I however don't think driving fast on the flat, mostly straight, farm and market roads in high-performance cars is really that un safe. since I don't own a high performance automobile like the Seville STS or Acura TL, anymore I have no reason to drive fast. I usually set my cruise at 72-73 mph in the Impala, and just munch miles. Kinda boring. :sick: I need a car to thrill me once again both my mind and soul. The TL, did both with it's performance and it's gadgetology. :blush:
    Rocky
    andre,
    really ? I have sat in the back of my Impala, once to play with my daughter and found the room more than adequate. I guess being married to a women who I consider a dwarf in height I had probably a few extra inches than normal. ;)
    Rocky
    Rocky, what's up with the new Buick names, such as Velite and Enclave. Are they preparing for some sort of war or something? An American Revolution, gather the Velites, meeting at the Enclave tonight. That's OK, as the Lucerne shall remain neutral, and the LaCrosse team is just out to play. But beware the Velites!
    Something is just wrong about those last two names. First, when asked what car you are driving at the hotel check-in, you have to sort spit the name Buick, then come up with Velite or worse than that Enclave. I like Lucerne (Safeway liked the name too), as you could nickname the car the Lucy. I love Lucy! LeSabre was better than the LaCrosse. And more fitting with the Velite. Meet ya at the Starbucks Enclave tonight. :shades:
    Loren
    Logic like that usually ends as a national statistic. Another 11-44 as code in CA. :sick:
    Loren
    When I checked the Aura in the showroom I found lots of rear legroom. I always sit in the front seats and adjust them for my body size and then hop in back to see what's there on the both sides of the car. I don't recall from the new Impala I checked a summer ago when I came out. And I believe you are much taller than my 5 ft. 7 in.
    I have to agree that "Enclave" is a dumb name. It's a near-synonym for "Compound," as in Kennedy Compound, Bush Compound, or heaven forbid, Branch Davidian Compound (of Waco, TX infamy).
    Maybe all the good "Western" names like Durango, Santa Fe, and Silverado were already taken and "Winslow" or "Tucumcari" wouldn't cut it?
    Then again, they could have resurrected "Electra" if the name had to start with an "E."
    Electra would have done it for me. Good Buick historical name. But I believe it is the historical connotations they were told they need to stay away from. I'm surpised it's not called the BTS SEi or something like that.
    LOL....Well I don't live in a heavy traffic state like CA. Some of our F&M roads are lucky to see a dozen vehicles a day. ;)
    Rocky
    How bout the Buick Amarillo ? :P
    Rocky
  • What is silly is ignoring the price point of the Phaeton. The Phaeton was tens of thousands more expensive than the next cheapest VW car. That was a big mistake. I fail to see how the G8 is in the same boat when the Grand Prix cost up to $33k right now.
    You don't get my point. You said
    Your logic is flawed. People will buy good vehicles regardless of what the brand USED to stand for if they like the vehicles enough.
    I used the Phaeton to illustrate that brand image matters. If the Phaeton had a Mercedes or Lexus badge on it it would have sold much better. Give me a break, it's obvious the market cares about reputation and image of a brand. Part of first year MBA school.
    Barstow has yet to be used. :blush:
    Loren
    As Wilbur, would say "GREAT NAME" ;)
    Rocky
    Buick Barstow?????
    Enclave is better. ;-)
    Hey Rock, did you buy your Impala new or used? Just curious if you have the new one or the one with the four big round taillights.
    Nippon, actually the wife did it all as she asked me if she could as she said just once in her life she wanted to buy a car all by herself without anyone's influence. She got a good deal but not great like I would of. :P
    the Impala LS btw is a 2004 model. Plum with grey leather, sunroof, spoiler, alloys. It's a pretty nice car as it is what the boss wanted. It will be her car after our strike is over and I go buy something else. I'm going to buy a work car and then go buy a brand new car hopefully by the 2009 MY ;)
    Rocky
  • torque_rtorque_r Member Posts: 500
    Pontiac. Publisher's Note: When getting serious about GM's "too many models, too many divisions, too many dealers" conundrum, Pontiac all of a sudden stands out as a glaring example of what continues to ail GM. In the last seven years, Cadillac, Saturn, Chevrolet, Hummer and to lesser extent, Buick, have all gotten help in terms of product and marketing muscle within GM. Even Saab has gotten a little marketing boost. But in that same period, Pontiac buried the Aztek, thankfully got out of the minivan business, abandoned the Bonneville nameplate, launched the G6 and the Solstice, rebadged the Chevy Equinox calling it the Torrent, launched and killed the GTO, and carried the Vibe and Grand Prix. In this same period, Pontiac marketers have gone big for "hip" advertising-marketing opportunities of-the-moment, chasing anything that came along - whether it was worth a [non-permissible content removed] or not - in a desperate attempt to gain traction for the brand. And it hasn't worked. Pontiac sales in 2006 were down from 2005, and it's weak performance is starting to be a deep concern at GM. Will the new, rear-wheel-drive G8 be enough to get Pontiac back on track? I'm not so sure about that. Pontiac has been in the hands of the marketers for so long that the once fiercely proud brand has lost its way. The brand's original rebel persona within the GM family is virtually nonexistent, and without it, Pontiac is just another division. Yes, the G8 holds promise, but there's just no "buzz" around the brand on the street. And the street was where Pontiac thrived back in its heyday. Unless GM comes up with a leader for the Pontiac brand, someone who actually gets what the brand should be about, and throws enough money at it to move the needle and then some, I fear for its future. When all the talk swirled around which GM division would be "on the block" next after Bob Lutz' famous "damaged brands" comment from a couple of years ago at the NY auto show, I always thought it might be Buick, but now, Buick has a reason for being because of its hugely successful presence in China. As someone who worked on some of Pontiac's more memorable ad campaigns, to see the brand on the ropes now is just painful. Memo to GM: Do the Right Thing for Pontiac - or else just put it out of its misery. -PMD
    Pontiac. Another reason the division is on shaky ground? GM is investing a total of $3.2 billion in GM Daewoo Auto & Technology Co. in 2008-2009. Within GM's new "No. 2" empire, it's easy to see that funding priorities are skewed to the red-hot Pan-Asian markets. But where does this leave Pontiac in the scheme of things? The short answer? Flat broke and busted at the side of the road. Not good.
    You'd think that with all of the sturm und drang going on in the global automotive world and GM's freshly-minted "We're No. 2 - We Try Harder!" standing sending a message screaming throughout the organization that this in fact is not business as usual that it might dawn on certain employees that GM is in full crisis mode. Well, some engineers are clueless, apparently. A sure ticket out of GM Engineering these days is to utter the phrase, "I won't work more than 40 hours" when asked to do so. The fact that anyone has to be asked to begin with is the real stunner
    Toyota. All of that head down, focused consistency has made you the No. 1 car brand in the world. Now what? Your company is struggling to maintain the pace and keep up the growth, you've had heretofore unheard of quality lapses, and you're finding out that not everything you touch turns into gold. Plus now, you have to get used to running up front with competitors breathing down your neck. On the race track, some drivers are better at pursuing than leading, because once they finally do get in the lead - they don't know how to keep it. Congratulations, but now the hard part really begins.
    As shares rise so does speculation that better offers than Icahn's bid for takeover could emerge.
    http://www.detroitnews.com/apps/pbcs.dll/article?AID=/20070426/AUTO01/704260344/- 1148
    Rocky
    Fight hard for every sale? Does this mean GM will go back to incentives and increase fleet sales to maintain its #1 position? Shouldn't GM move on and concentrate on becoming a more efficient company with greater profit margin for every vehicle it sells?
    But then, what do you expect from someone who said only last year "We have been #1 for 70 years, and we will be #1 for another 70 years to come". I sure hope this guy does not jeopardize GM's future to prove the statement he made was right.
    Cerberus hasn't pulled its bid for Delphi
    DETROIT -- A key investor in Delphi Corp .'s plan to exit bankruptcy protection says it has not pulled out of the deal as expected by the troubled auto parts supplier. Delphi officials said April 19 that the company had been told that Cerberus Capital Management LP would leave a consortium of investors who would pump up to $3.4 billion into the company in exchange for new shares of Delphi stock. Nearly a week later, Cerberus spokeswoman J.J. Rissi in New York said that has not happened. "There has not been any decision made," she said Wednesday.
    Rocky
    Wagoner urged the company to remain focused on its upgraded sales and marketing strategy, which has attempted to move away from its past reliance upon incentives and discounts. Wagoner cited 70,000 fewer daily rental sales in the U.S. and Canada this year - "nearly the entire amount of our global sales gap versus Toyota. But it was the right thing to do."
    -Did you not read it throughly as he clearly says it was the right thing to do to give up fleet sales. :confuse:
    Rocky
    That's true, which makes me wonder what all the buzz about retaining to #1 is about. How is he going to do it? We have to admit that Wagoner is very concerned about it that he thought of buying Chrysler, which would have been a stupid thing to do. That's your strategy of remaining #1. Adding more brands would ensure keeping the position, even if you cut back fleet sales. Never mind if it is disastrous on the long term.
    torque_r ,
    I don't think Wagoners main concern was to remain #1 but I'm sure it was a important issue with him. He was a Duke basketball player and is obviously very competitive. I think he saw potential in Chrysler. If I was in his position I would of took a close look. The problem is their is no prestige in Chysler. The trucks have loyal buyer and so do some models of Jeeps, but overall it would take billions to reshape the brands.
    Wagoner, has enough problems with his own brands like Pontiac, that need special attention. If they would get Pontiac, to be a RWD performance brand it might deserve to live. Pontiac, should be a competitor in gadgetology contenet to the entry-level luxury cars Acura TL/RL, Infiniti G35/M45 and of course Lincoln. The brand doesn't need wood trims interiors but could use some aluminum and maybe some fauz carbon fiber to add a sport flair. The perfect interior I can think of for Pontiac, is the current Acura TL. The G8, reminds me of what a modern day sport's car interior should look like.
    I like where Buick, is headed as long as they get to the finish line. I like the concepts I've seen and the Enclave, is a great start for the future. Buick, needs some RWD cars as well and I still think a RWD Lucerne and a mid-size Buick Velite Sedan/Convertible can complete the line-up It would be 4 models in the Buick stable. I do think Pontiac, needs to use the Holden Statesman as a Bonneville replacment and keep the price under $40K for a fully loaded version. I'd put in the 3.6 V6 300 hp engine in the Bonneville and make a GXP version with the Ultra V8. I think it's possible to make this work. The RWD Ultra V8 Lucerne, could move up market and start at $45K. The Velite could start out at $35K and top out in the mid $40's. The Convertible could top out in the mid-high $40K range. The LaCrosse could be axed. What I'd still like to see is a Cadillac BLS size Buick, make production. Something ultra luxurious and very fuel efficient with perhaps a turbo 4 out of the soltice/sky making around 260 hp. and of course a hybrid. ;)
    Saturn, is doing great. No need to change focus besides maybe open a few more dealerships in area's that closed.
    Chevy looks to be doing better. It will be great once it get's the 08' Malibu and 09' RWD Impala, to the market.
    Saab, on paper looks to have plans but until I see them I will just wonder. :surprise: :confuse: I myself could make Saab, into a strong seller. They just need to focus better. I for one would make the brand have RWD and a new state of the art AWD system that incorporates 4WS. The brand needs to be unique or die IMHO. ;) That would make it better than Volvo, and I'd assume make it sell quite well.
    Hummer, has the H3 SUT coming. They need to power all hummers with diesel engines IMHO to keep fuel economy up. Well I suppose the H3 could get away with a hybrid motor.
    GMC, needs some unique models. It could be a upscale chevy division and offer brand unique features. The Denali trim works but their is lots of room for improvement. Like on the Yukons, I'd have features like height adjustable suspension's, HD Radio, Maybe Satelitte TV, etc to get middle-upper middle class family's in the show room. ;)
    That is my $0.02
    Rocky
    Of course you didn't point that out to her having been educated in marriage maintenance skills in the early years. :blush::) :shades:
    I found there were some colors that were great on that car. Red is good, burgundy is good, plum is good, black is good... It's just a pleasant pallete. I also like the body color covers over the rear lights surrounds that leave only the round openings.
    That car is a great example of a car that serves most buyers well. A few have comments about width in rear and leg room rear probably due to the W-body shape which is that way for who knows why. I still feel if it said HonYotaDai on the car it would get fewer comments on its deficiencies (which are real in those cases).
  • jerrywimerjerrywimer Member Posts: 588
    Just a quick note- still reading, so I'm only addressing one point here:
    The SE includes 16" alloy wheels, according to the Honda USA web site. I don't see a distinction between painted or whatnot. Most alloys are at least clearcoated nowadays though, so I fail to see a distinction between 17" alloys and 16" 'painted' alloy wheels. I'd be highly surprised if whatever size Honda alloys you might be able to get with any Accord trim aren't 'painted', at the very least with clearcoat. In fact, I recall early 90's SE accords in parking lots with chipped finishes on those alloys being fairly common.
    Anyway, between this, and the fact that the SE *does not* have 17's, I guess Honda doesn't win this one.
    Next point. I'd guess that your leather wrapped wheel might be nicer than the one in the Lacrosse. Then again, wasn't it Audi that GM mostly used as their target sample when redesigning their new interiors? (as in my 07 Avalanche)
    So GM has acknowledged Audi as a leader. What's this got to do with the steering wheel in the Accord versus the one in the Lacrosse though?
    Last point for this post (I can more or less agree with anything I haven't bothered replying about in your post):
    Trunk hinges- used rarely? You smoking the good stuff? Most people that buy a "family sedan" use the trunk. Often for the regular shopping trip and grocery runs. Speaking directly from LOTS of experience gained before I became a minivan / truck only household, it's fairly often that hinges have to be accounted for when loading the trunk. Smashed bread and eggs don't go down well around my house. Nor to broken items or torn giftwrapping during the holiday visit to relatives!
    I'm 6'3", and a little extra long in the legs, more average in the torso, so usually I have to watch for legroom more than headroom. The Impala's probably fine for most people, and I did think the front seat was comfy. But by the time I had the seat back all the way, it turned the seating position right behind me into an inhospitable torture chamber.
    I remember in the previous generation, the Impala felt roomier in the back than the Aurora/Century/Regal, which in turn felt roomier than the Grand Prix. Nowadays though, the Impala, LaCrosse, and Grand Prix all felt about the same in the back, although the rear doors seem to be tighter on the LaCrosse and Grand Prix, making it harder to get in and out.
    Still, I guess if I found a good enough deal on a used W-body and needed a car, it wouldn't be a total deal breaker. If nothing else, I guess having a car with a cramped back seat would get me out of being volunteered to drive during big family get togethers and such!
    Back in late 2003, my Dad wanted to get a car, after relying on public transportation for eons. We found a used '03 Regal that had been a rental, and had about 19,500 miles on it. It was $10,995. Heck, I told him that if he didn't buy it, I would!
    It's been a good car so far. I think he only has about 40,000 miles on it now, so most likely the kinds of problems it develops will be more age related than mileage. Lately though he's been second-guessing himself on the car, and thinks that maybe there was something wrong with it, and that's why it was so cheap! But it's been over 3 1/2 years now. I think if it was hiding any problems, they would've surfaced by now!
    Re: The auto dimming rear view mirrors. They're only dimmed when there's light shining too brightly on them. So they normally don't affect your ability to see the cars behind you clearly unless there's already an issue, as with your example of SUV and truck headlights shining at eye level through the rear window.
  • 14871487 Member Posts: 2,407
    Toyota doesnt make stability standard on any of their cars. The G6, Aura, GP, 2008 Malibu and 2008 Impala have stability standard on some models. I suspect the Lacrosse will have it standard on most trims for 2008 as well.
    "I'm curious to see the '08 Malibu when it comes out. I've seen the concept car on the auto show circuit, and it looks promising."
    the Malibu you saw is the production car, it's not a concept.
    Being short helps with the ability to appreciate sunroofs and moonroofs I guess, because the headroom thing usually doesn't apply. The first vehicle I had with any sort of opening roof was a 94 Tracker soft top. The first with a real moonroof was the 2003 Trailblazer. Once I'd experienced that, I missed it any time in a vehicle that lacks it, especially on *any* hot day after the vehicle has been left sitting in the lot in bright sun and the temperature inside reached 100+ F. Tilt the roof to the vent position and crack the shade open a few inches (keeping most sun off the head while providing a vent for the hot air to exit through), and things are quickly back to normal. This happens a LOT, btw.
