Ford F-Series Computer Problems
I am interested to ask other professionals that know these ford vehicles very well.
Is there one or more of you Techs that can tell me if it is possible to:
Accessing the Codes in Ford vehicles by shorting the connectors?
I know in the GM's you can short a and b and pull the codes which is the most common that I have in my shop other than the foreign vehicles.
If I may be of assistance to you please let me know and I will respond as soon as possible.
Thanks Again
Thanks Again
Thanks Friends
I'd get under the dash with a strong lamp and start looking for evidence of water intrusion. Hopefully you can find it without too much trouble. Unfortunately leaks are sometimes a real SOB to find. (Pull back the carpet too, you'll probably find it's all wet behind it.) Hopefully your electromics will recover once you find the water source, and you don't need to repair a bunch of different things.
I just bought a F-250 crew cab and need to modify 2 things:
1- Is there a way I could replace the headlights to
give it a different look ?
2- Can I purchase the computer used to modify the
truck's parameters as I need to reprogram the tire
size from 20 inches to 17 for the winter season.
Does the truck have a Pyromter? That's a gauge that measures the temperature of the exhaust gasses as they come outta the turbocharger. As you climb a hill, watch the pyrometer, if your exhaust gas temp starts to climb quickly and goes over ~1200-1300, you need to back off on the go pedal and allow the thing to cool. You may have to go up the hill slower, but it'll save you expensive repairs.
You may have problems in the offing; that growling sound seems kinda ominous to me.
Russ
Mark.
usually its up against right side, its basically a rubber button/plunger you push down to reset.
<ark
Mark.
Can anyone tell me if the computer for a 89 F250 and a 90 F250 are different in any way?
Please help. I'm loosing my mind!
Thanks in advance!
John
I have the same problem with a 99 F350 Diesel and have yet to find the fix. Did you have any luck?
Ed Boyle
I have a 2000 f-250 6.8L V10 4x4,Automatic... One day last summer right after refueling I was sitting at a red light and my engine just died, I went to crank it over in neutral, and it started right up. When I put it back into drive the whole truck jumped forward about a foot and then killed the motor again. repeated the process a few times and finally after reving engine to about 3000 rpm's and slamming it into gear it took off but was real sluggish and non-responsive... Shortly after that the check engine light came on.. :mad:
I took it to a transmission shop they thought it was a pump inside the transmission that was warped, but quickly figured out that it was not. So they unplugged the transmission from the computer to test on their diagnostics machine, it shifted through all gears just fine. And apparently with the computer unplugged it will drive like an old school tranny.. just hi and low gears (2 and 3) no 1st or overdrive but you have to manually shift.. so they told me it was most likely a computer issue and to take it to the dealer. So I took it to ford and after the $543.40 diagnosis fee and a week of headaches they supposedly found nothing wrong with any part of the computer or electrical system besides a misfire on cylinder 9.( Which I fixed) And then they told me they thought it was the transmission!!..If anyone knows what might be wrong please help!!! Having to manually shift with no overdrive I'm getting roughly 5 miles to the gallon on the highway and I'm working out of state!!!!
Ryan
The instrument cluster on my 2001 F350 (88,000 miles) suddenly went dead today. In addition to the instrument cluster, the windows do not roll down the horn doesn not honk when locking the doors remotly and the dome light flashes like I have the hazard lights on.
I have checkd all the fuses and cannot find any that have blown. The truck runs fine and the rest of the electrical system seems to work without any problems.
I live in the high desert and we have not had any rain for quite some time so I doubt I have an condensation issue.
Any feedback would be greatly appriciated.
The truck starts and idles fine
When I am exelerating (changinging gears) The trucks vilantly shakes just once
The check engine light comes on briefly (less than a second) when this happens
Once the light goes out the truck is fine until the next time
Its almost as if you turn the ignition switch off then right back on
Checked all fuses and relays All connections in harness
Have had on the computer/scanner No codes No help
I am lost Please help
Thanks John
