Not necessarily. The Taurus X has a different engine, 3.5 vice the 3.0 in the Freestyle. So the parts are probably different.
thanks!
I am interested in getting local news, and a recall. I have contacted the attorney generals office and now the Office of Defects Investigation....they can make Ford recall the part. Has anyone got an attorney yet? Really, this is crazy...
problem did not occur again until middle of october, again in highway traffic. i pulled over to shoulder, turned ignition off then re-started car which seemed to re-set the computer. problem occurred 3 times within 15 minutes/wrench and engine lights both went on. i drove another 50 miles home worried about car dying in traffic.
took car to dealer the next day and was told problem was a bad "megatronix" unit. $1,500.00 dollars and 1 week later, i picked car up from dealer. it ran great for 4 days then problem occurred again.
took vehicle back to dealer and am now told that Ford is recommending a new transmission at the cost of over $4,500.00
i feel at wits end and that they are just jerking me around. it appears that there are well documented, dangerous problems with the freestyle and ford should be held accountable for them.
any suggestions on how to proceed as a group toward justice and restitution for this extremely dangerous problem?
THE CAUSE WAS GREEN ENGEN COOLANT THAT I PUT IN AFTER 50K MILES.
THE FIX IS A $5 DOLLAR TEMP/SAFTY SENSOR.
THIS SENSOR HAD 4 WIRES COMING FROM IT. 2 OF THE WIRE WENT TO DASH GAGE AND THE OTHER 2 WENT TO THE FUEL PUMP.
WHEN THE SENSOR READS A HIGH TEMP IT TURNS OFF THE FUEL PUMP.
SO WHEN YOU ARE DRIVING 65MPH OR HIGHER THE PUMP TURNS OFF AND THE CAR JUST SUCK AIR WITH NO WARNING LIGHT ON IN DASH UNTILL THE CAR COMES TO A COMPLETE STOP.
IM THANKFUL JUST TO HAVE MY CAR BACK.......
SUVs and Smart Shopper
acquired a used 2005 Freestyle with 98k miles on it, and the family loves it.
June 2009: the engine began shutting off while driving... no warning, no "check engine" light, nothing. Took it to Ford, "no fault found", and no advice to do anything except keep driving.
It began to happen more frequently over the next month, finally (of course, on a long trip, away from home) took it to Ford #2, who reprogrammed the Engine Control Module... did not solve the problem. On the way home, the shutoff problem continued, so took it to Ford #3, who saw the "check Engine" light and diagnosed the defective throttle body. Of course, no spare available, so the only option was to limp it home.
Limped the car most of the way home, required a tow the final 30 miles.
January 2010: We have waited 6 months for the new throttle body to make it into distribution. It's installed, but the dealer now claims that the "limp" mode damaged the catalytic converter and needs replacement.
I'm highly aggravated that Ford could not diagnose this problem when first reported. That is a failure of their diagnostic design that unexpected shutdowns are apparently NOT stored in the on-board computer.
The unexpected shutdown is a safety hazard. So is, from what I read on this forum and other places, a lot of the other unexpected behaviors related to the TBA.
I encourage folks to contact not only Ford but NHTSA and complain about your documented throttle body problems. The web link is www dot NHTSA dot gov, click on the complaints button.
Talk to the service manager, ask to see your complete extended warranty contract if you cannot get your hands on it.
Good luck -
Correct in general, but I think most people are speaking of the Ford extended warranties, NOT aftermarket. I believe all those warranties cover the engine and transmission at the minimum. The more expensive ones will cover more items, but those two are in all of them. After that it is a matter of what deductible the owner pays.
I had an experience with one of the sensors going bad in the transmission. It wasn't covered by my ESP, but ended up being one of the components covered by the 80,000 mile standard emissions warranty.
It's all way too complicated.
I had an experience with one of the sensors going bad in the transmission. It wasn't covered by my ESP, but ended up being one of the components covered by the 80,000 mile standard emissions warranty. "
I did some checking and you are correct, the more expensive plans DO cover more. The URL below lists ESP coverages. I'm using PremiumCare for my 2008 FEH, so it doesn't really matter to me, but people should check the coverages they want before purchase. Thanks for the heads up.
ESP Transmission Coverage
To make matter worse I am being told that the item is in National back order. Now, in order to order the part I had to pay for it up front but they don't have it!!! and they had to know they did not have but now they have my money.
I bought this car in part because one of my best friends who has young children like me bought a 2006 Freestyle and I drove it and liked it. My friend relocated I called him today and guess what? he had the same acceleration issue that required a throttle body replacement. He had to wait four months to get the part!!!!!
because the item was in National back order in 2009 s well!!!
PLEASE HELP how did you get them to cover the throttle body and how do I make them pay for a rental or give me a loaner I am afraid to drive the car the acceleration is getting worse
I wonder with the amount of complaints with this part, this vehicle, and with the scams with the ESP if any legal agency or attorney would be interested in collecting the data and file lawsuit on behalf of all of us!!!!!! for deceitful practices :mad:
To make matter worse I am being told that the item is in National back order. Now, in order to order the part I had to pay for it up front but they don't have it!!! and they had to know they did not have but now they have my money."
ESP Elite Plus? When I bought the ESP warranty for my FEH last year, they only had 4 types
* PremiumCARE
* ExtraCARE
* BaseCARE
* PowertrainCARE
But maybe they are different for the Freestyle or have changed since 2007. I don't see "Throttle Body" in the current PremiumCare list, but maybe it is exclusive to the CVT.
We were told part was on back order but KC MO suburban dealer found part and after four hour wait drove off same day we took it in for problem.
9926A E29 42 throttle body air intake replace 9E926
12650D Quick test diagnosis
12650DX1 Quick test diagnosis
6F9Z 9E926 A Kit throttle control
TEST AND REPLACE THROTTLE BODY
Now my dealer has offered me to trade my 2004 Freestar for a 2007 Freestyle, since I need a versatile vehicle for my kids and my business.
After reading some of the posts here I am becoming scared, but this IS the problem section, so what to expect....
Can anyone give me a list of questions I should ask my dealer about the Freestyle, deatails that I need to check? They are offering me $8000 as a trade-in value for my Freestar and the Freestyle has about 63000 km. With a price tag of 17,988.00 plus tax and fees. We are talking Canadian Dollars here, but that is beside the point.
I like the car, but am not sure what to do. My car is at the dealership, I am unwilling to drive it at the moment. I need a reliable car asap. Anyone who has some suggestions? :confuse:
Thanks, Mim
See if they can get you a 2008 Taurus X. It is the same body style, but has the 6 speed transmission.
The only way we can make sure the dealer fixes this problem is to call the Department of Transportation, National Highway Traffic Safety Administration at 1-888-327-4236 and file a complaint. After they review the complaint they have the authority to request that the Dealer issues a recall and fix the issues. I just did this myself and it took me about 20 minutes, however, a case number was sent to me immediately. If we all take 20 minutes of our time, we can have Ford fix these problems and who knows? maybe even save somebody's life...
I had a problem with a Transmission Control Module that wasn't covered by my ESP but was covered under the emissions warranty, so it was fixed without any cost to me.
I got screwed buying the only extended warranty they offered to me, but they also told me that they had someone come in complaining about the same issue with another Ford two weeks before I did.
It is time something be done before someone is killed in an accident caused by the throttle sticking.
Thanks so much for the number and you can be sure I am going to call!
link">
Everybody in this site should complain to DOT and we can definately make a difference and stop them from continuing to rip-us off over and over again.
I had a 2001 Ford Explorer Sport Trac and never had any problems! That is why I chose another Ford.
You missed a step. "After they review the complaint and determine it is a valid design problem that affects many vehicles ..."
On this forum we tend to see the problems, but they sold a lot of Freestyles and most have not had the issues. The Toyota problems were also on vehicles that were pretty new. The FS hasn't been produced since 2007.
