Visitor Agreement.
:confuse: :confuse:
It also had the airbag light on prior awhile-my bad not to fix, and engine light for evap sys. Not sure if that means anything to this issue. Runs fine though.
-Adam
kcram - Pickups/Wagons Host
dodge wire are famous for just breaking ,, i had four wire break
I have a 98 Ram 1500 4x4 5.2L. I was parked on an incline, and after returning to my my Ram, it wouldnt start, only cranked and sputtered. I noticed when turning on the key, I did not hear the fuel pump pressurizing. I swapped around some fuses and relays in the Power Distribution Center, still no joy. After pushing the vehicle off to the side that was on abit of an incline, I turned the key and heard the fuel pump pressurize, so I cranked the starter and she started up. Any ideas on the cause of this issue? Any switches or connections I need to check? I would hate to get stuck somewhere again.
Ken
Ken
My right tail light socket housing keeps melting. I have replaced it three times and I now have LED bulbs in it to keep it from over heating. All of the bulbs work, but I have no rear turn signal on the right side. I have verified that the bulb that is in does in fact work.
Can anyone help?!!?
I was out yesterday and someone pulled up next to me and told me that all three of my brake lights were not functioning.
I replaced my brake light switch (easy fix) and checked all of my fuses with a fuse tester and still the lights don't work.
Can anyone help?
The interior/dome lights work fine when I open either of the passenger side doors, but do not come on at all when opening the driver's side doors.
Any ideas?
