They fit quite well. They are warmer than the cloth seats, but not too much so. Now I do not need to worry so much about getting the seats wet and dirty. The head rest covers are not all that perfect with the velcro on the bottom, but are quite OK. Will probably tack stitch the bottom edge together after they stretch out. A side good thing is that I can stick a small piece of foam under my right leg to raise it up (so it feels better) without it looking tacky. They were not cheap, but were not that expensive (their distributors are much cheaper than ordering direct, but they just do a drop shipment from the maker).
I have no relationship with this maker, but just thought the information would be useful to those thinking about seat covers which would not block the airbags.
Did you ever switch the turn signal and backup light plugs? If so, was it difficult? Thanks....
Bubba
I am quite sure that if you really want to change them it wouldn't be too much work. The only thing was that I tried this 3 days after I got it, and I didn't want to damage anything in my brand new car when I didn't really know what I was doing....
I will take a look again and see what can be done...keep you posted.
Thanks for the answer. I'll wait for your reply.
Koszonom szives faradozasat,
Bubba
~marc
I ended up getting seat covers made with fabric fronts & vinyl backs, for the back seat the vinyl covers the whole back of the seat and with the cargo mat the entire back area is protected.
I have the keys in my pocket, and when I bend over sometimes, the panic button the key fob gets pressed, and the horn starts going off. It stops when I press the lock or unlock button.
I know this is not caused by someone trying to break in or by the wind, because it often happens in my garage!
Mike
Does the alarm system have a diff set of beeps from when it is set off one way vs another? (my old car did)
http://tinyurl.com/ylvmxd
The description notes that though it is the same color as the visors in the USDM Fit, it has a different texture. This one is made in Thailand. Is this the same as the JDM visor? Has anyone installed one of these? Was the texture different? How bad or good a match for the driver's sun visor is it?
Yes, it makes sense. I was reading that with the remote keyless entry, some hacker with a properly equipped laptop can activate the unlock feature. It would be equivalent to someone with garage door opener outside your house trying many combos till they get it but with a pc its that much faster a process.
That said, a proper theif would steal a high end car with remote entry that also had auto startup. Why would they steal a car valued at 16K and still have to jimmy the ignition when they could get a new lexus or other high end auto, that even starts for them with the right laptop combo?
Thats my philosophy on why I wont personally worry too much.
Not to say someone won't want to steal a fit, just saying it seems less likely with 35K autos out there parked right next to mine.
If I were you, I would go see the dealer's general manager, ask for an exact explanation and description of what was added. If it was what I described above, I would demand that they remove it, or at the very least, not charge you for it.
I tried to remove the black plastic to see if I could just use the metal part, but I still can't find a Phillips head screwdriver that's tiny enough. I don't want to destroy a perfectly good key in the process.
~marc
I'd like to but want to know others experiences and costs.
Suzecruise
(By the way, they have a really nice armrest - but I can't afford it. They didn't reply to an emailed question but they did send the order promptly )
Since I'm from Canada, this was quite a savings. I installed the Keyless Entry first to make sure it was working and then I immediately installed the Security System - just so I could remember where everything was - my memory is short. They both come with detailed instructions and drawings. Needless to say there is not much space under the dash and I spent a couple hours with my head by the brake pedal because I don't know much about cars. Some of the original connecters were quite tight to pry apart and it's a tight fit to put in some of the new ones.
Hint: When installing the Security System (step 7) you have to locate a 16-pin connector with a green tape on it. I had a hard time finding it until I looked up under the dash with my head near the gas pedal instead of the brake pedal!
Both items are working well, except the security system started arming automatically. I'll have to read the instructions to change it back to manual.
The Keyless Entry might prevent some key scratches from around the keyhole, but it doesn't open the door for me and I still have to walk to the car!!! In other words, I think it's kind of useless. But I bought them because I like gadgets. Most of my driving is at night, so I want to install some driving lights - as soon as I figure out where to put them. The car has 40,000 miles and seems as good as new. The oil indicator light has me changing oil about every 9,000 miles and I use Mobil 1 synthetic. (I got 440,000 miles out of a Honda Odyssey using Mobil 1 oil.)
Since you just purchased your car - make sure you can remove your spare tire. Mine was impossible to unscrew by hand.
And congratulations on your new purchase - the Fit is one of the best handling cars out there - regardless of price.
And you're right, the Arm rest looks like something worth saving for!
What are "driving lights" If you drive at night, what about the regular headlights and highbeams?
Art
No, it won't work...that's what I had mentioned earlier. In the last post, I had just compared the merits of the Fit's key vs. a simple metal key. The Fit's key has a microchip inside the black plastic, and it sends a signal to the immobilizer that allows the car to start when you turn the ignition. Despite the drawbacks of the key (replacement cost, being careful it doesn't get wet, etc) I prefer the security of it.
I've been unsuccessful in reaching either Honda UK or Honda Access regarding the mat.
Does anybody know how much it would be to buy these and have them shipped to Canada?
And last but not least, are there any orange trim kits out there for the Blazing Orange Metallic Sport? I've seen them on a concept car, but unable to find them anywhere to buy.
Any help would be appreciated,
Mrs_Fit
BTW, Honda Canada was completely useless in helping me on these issues.
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&catref=C6&from=R10- &satitle=honda+fit+arm+rest&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=20- 0&fpos=ZIP%2FPostal&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1&fsoo=1
I think one website was daxmaxx.com but dont quote me on that. Just google it under "jazz accessories".
I think most* of the accesories you mentioned above are listed for the Jazz and may be the exact sameones. I am sure you can compare specs with the fit.
hope that helps
thanks!
www.japanparts.com
I've found that even with shipping, it's cheaper to buy from them than from the UK (that's if I could actually find a place to order from there!!).
Their Fit stuff is very reasonably priced. Eg: Luggage mat (Magic mat) including shipping is about $200 CAD. When I found it in the UK, the price was 100 UK pounds, which is about $195 CAD not including shipping!!
I'll be ordering my stuff shortly .
Mrs_Fit.
Mary
www.japanparts.com
Called the Luggage Mat. Runs about $200 CAD including shipping.
Here's a note from Jose Leng at Maxdax about the delivery and cost of painted side moldings:
Hi Bubba,
Thank you for your inquiry.
- Side molding: S$220 / USD144 per set painted (4pcs)
Shipping to the USA by postal air parcel:
- Standard (15 to 20 days): USD43
- Express (3 to 7 days): USD69
Please allow 4 working days for painted items to be ready before shipping.
Feel free to email if you have further questions. Thank you.
Warmest Regards,
Leng
Maxdax LLP (Reg. No. LL0500339C)
Maxdax.com
Looks like about $187 delivered in USA
Bubba
PS I asked about Milano Red moldings.........
passenger side
driver side
No idea why it's in same place on both doors, perhaps some sort of tape that strapped across the top during transportation to dealer?
Is there some quick way to "patch" the plastic or should I take this in for a warrantee repair?
Make: Honda
Model: Fit sport model
Year: 2007
This solutions can be viewed on our website under this address:
http://www.thuleracks.com/fit.asp?id=8176
I haven't bought one, but this appears to be a standard Thule solution.
Enjoy
The first one and the second one look identical to me, though I can tell the third one is darker. If anyone here has one, please let me know which you picked and how well it matches. Thanks!
BTW, my FIRST accessory was a JDM right side visor with mirror, a request from my wife before we even got the car!
You can do the same thing by utilizing "tall mode". :-)
