it it still shakes, then move downstream and suspect wheel bearings, brake rotors or bent wheel.
good luck,
ace
-johnskev
Otherwise It's a wonderful vehicle! I really like the navigation system.
thanks much
I sent you an email with a contact and more info. Everybody has been using this dealer that I know of, but I don't want to post it all over the place and make it look like "advertising". You will need to do a purchase - they can't lease to US residents. But with the savings of a few thousand dollars, this might be the best anyway.
-Jon
BTW- This forum has been great, spent the past few weeks reading the posts. Will be purchasing a QX4 by the end of the month. Thanks everyone!
I have two questions for you:
1: What should be the position of Head light switch during normal operation? There are 4 of them: Off, Auto, "semi-on" and On. Is it okay just to leave it at Auto all the time?
2: Break in period: How long and what kind of speed it should be? Should I try to cruise it at 65 MPH?
As far as headlights, you can leave them on Auto, however the manual says frequent on/off will shorten the life of the Xenon headlights. So, depending on how often the lights would cycle ona typical day, you may not want to do that. For break-in, look in the manual; it gives the guidelines. Basically for the 1st 1000 miles, vary your speed (ie no cruising at 65) and no high revs; doesn't define that but I think on other vehicles I've had, no more than 2500 - 3000 rpm. Congrats and enjoy - I love mine!
George -- do you have the book from the dealer? There are color samples in the back that are fairly true. Millenium Jade is greener than the book shows and Silver Sage must be seen in person.
Vikingfan2 -- Our negotiations started a few weeks ago when we did the test drive. We weren't ready to buy and the sales person gave us some numbers, which led us to request quotes from other dealers, which kept getting better the more calls we made. Much to my amazement, the original salesperson refused to offer a deal less than 36 even when I told him he wasn't even close to what had been offered. He wanted to know who we were dealing with and kept saying "I don't know how they can go any lower and stay in business -- they must have a lower cost factor. I can get you a better price but then you can't have all the options." This was not the Infiniti "experience" I expected!
I learned from another dealer that they all have the same cost factor -- Infiniti treats them all the same. The advertising fee is $450, one dealer mentioned specifically that it is not included in the invoice price, but no one else did.
<< Could someone please help me decide whether to buy a 2x4 or a 4x4 QX4. I live in the suburb, do not own anything that could be towed. I don't normally go off road. This QX4 that I am going to buy will used for commuting... (and occasional camping trips) Please let me know if gas mileage is different even if the 4X4 switch is turned off... I live in southern california, so it rains a little bit. Is it worth it to get a 4X4 just for that?>>
Drew
I have an offer for 39 months, $450 a month including tax, with $1196.00 initial payment, this includes $1,000 coupon to previous owners.
4x4, with luxury package. Anyone find anything better.
George, I feel for you. I'm sure they are around, though; this weekend our dealer advertised they have like 20 or 25 in stock. Based on what I saw when we bought, they're all 4x4/sport/premium, only difference is whether they get Navi. They did have a couple/few in black a month ago, so you should find something. Good luck!
Will pick it up tomorrow after work. It's going to be a long day.
I like to hear my engine though, and the other features of this superb vehicle make it one hell of an SUV compared to the others I have owned and driven.
Also has anyone noticed that their ride gets a bit choppy over bumps ..is that because of the rear axle and not rear independent suspension?
Love my silver sage w/ prem/sport/sunroof/rear deflector/woodkit/pinstripe ...it looks sharp! Dealer tells me that finding a '01 with Navigation now is nest to impossible!
Thanks everyone.
Mark, I seem to recall there is a shuffle feature; don't have my manual in front of me, but think I remember reading it in the manual and thinking I probably wouldn't use it because of the disc change time! As far as bumps, try checking your tire pressure. I had thought it was awfully rough over bumps, too, and after one particularly bad evening, checked the pressure. It was 36psi rather than the recommended 26psi! I personally think 26 is a bit low, so dropped it down to 30-32 and it rides much smoother now. Just make sure you check it cold (ie, after sitting overnight or for a few hours).
You activate by pressing the middle button
between the track forward/track reverse buttons
on the left bottom side of the CD player
(or its the middle button between the in-song
forward reverse buttons on the right side).
I agree with jeepluv - the disc change time is
long enough that you probably won't be using
the shuffle feature much, although I do
occasionally use the single-disc shuffle.
Q last night! Does anyone else think the radio is hard to read or is it just me? There doesn't seem to be any contrast between the numbers and the background.
Markinct -- was your woodkit installed by the dealer or did you get one aftermarket? Cost?
George, regarding the headlight setting ... my dealer and the manual told me to put it on Zero. You only change the setting when the terrain causes the lights to shine in the mirror of the ca in front of you ... e.g. going up or down hills.
Mark
Mark, thanks for your info on the wood dash. The 20 piece set (w/o door panels) is 278. The only piece I care about is the console piece -- it looks really empty. I will make some calls about installation. Silver sage is a great color too -- impossible to describe to someone who hasn't seen it.
This was our first weekend with the Q and fortunately, we had places to go that were far away! I think we put almost 200 miles on. It is great -- either to drive or just be a passenger. The visibility is fantastic -- the big side mirrors and the proportion of the vehicle -- I never feel like I have a blind spot.
Hope everyone is enjoying their Q as much as we are.
This car was made for me as I had to order it because I wanted the navigation system, so it is a late model 2001.
Thanks...
Steve
Drew
